Some Q3 owners have enabled the lap counter display under 17-Instruments 10 Adaptions, so I thought that I'd try it but this channel is not available on my 2012 model year Audi Q3 2.0 TDi.
I don't know whether it will be of any help to you folks at Ross-Tech but I decided to create a channel map for each of the control modules - if it's no use to you please delete this post. I'm not particularly looking for a resolution to the lap counter problem.
01-Engine
02-Auto Trans
03-ABS Brakes
04-Steering Angle
08-Auto HVAC
09-Cent. Elect.
10-Park/Steer Assist
15-Airbags
16-Steering wheel
17-Instruments
19-CAN Gateway
22-AWD
25-Immobilizer
42-Door Elect, Driver
44-Steering Assist
46-Central Conv.
52-Door Elect, Pass.
53-Parking Brake
55-Headlight Range
56-Radio
5F-Information Electr.
62-Door, Rear Left
69-Trailer
72-Door, Rear Right
01-Engine
;SW:03L-906-018-PH HW:03L-906-018-ES --- Engine,,,,
;Component:R4 2,0L EDC H26 1793, Coding:00250012043701080000,,
;EV_ECM20TDI01103L906018PH,3002,EV_ECM20TDI01103L906018EQ.rod,,
;Saturday,7,March,2015,11:51:49:04481
;VCDS Version: Release 14.10.1 (x64) Data version: 20150130,,,,
;VCID: 7F0D36E6E6ECFDD917A-802A,,,,
Activation of start-stop function,active ,,,
Idle RPM correction,0.0 /min,,,
Individually adjustable maximum speed limit,300.0 km/h,,,
Injector 1 correction value,8SRR2S4 ,,,
Injector 2 correction value,AZ8O7I5 ,,,
Injector 3 correction value,7HPOZ13 ,,,
Injector 4 correction value,A18T8I6 ,,,
Learned values for solenoid valve closing time correction,FF 82 00 0F FF 82 FF 82 24 07 FF 82 D7 0C 31 1E 53 0A 0A 0F 9F 0C D1 04 25 FE 80 0C C2 1A F0 04 97 0A CC 07 3B 04 78 05 35 05 16 07 09 09 1A FB E1 0E 16 27 B3 11 12 14 69 11 AB 13 04 06 76 0E B8 FC A7 ED 89 F4 5C EE FE F1 65 F7 60 F0 1A F4 93 04 63 F1 78 0B 11 05 97 07 74 09 FF FF F4 08 42 0B A7 01 A7 11 21 0E 43 0C E0 13 10 0E C5 0D 24 04 11 00 5B 0C 12 0D DD 11 EA 09 2E 0A F9 00 B7 00 00 00 00 00 400DF3B4 01 01 00 400DEC14 01 01 00 00 00 403A8D00 01 4007FEB9 01 FFFFFF9C 00 25A84F 00 40000024 00 00 00 2AB4750 00 40066945 01 403CAF20 01 44A08AD 00 00 00 00 00 00 00 01 00 00 00 40049014 01 00 00 20 32393100 7540B76F 29 7169332A 58E0 403CAF20 01 100 00 01 00 32000000 33393932 00 00 7169335A 58E0 403CAF20 01 100 00 01 00 00 00 01 00 4004E061 01 01 00 4011616A 01 403A96A7 01 7FFFFFF7 00 403CAF20 01 100 00 01 00 00 00 00 00 40080093 01 01 00 01 00 ,,,
Particle filter initialization,0 Tkm,,,
Service regeneration of particulate filter while driving,0,,,
;SW:0BH-300-011-K HW:0BH-927-711-C --- Auto Trans,,,,
;Component:DSG DQ500-7A H05 1725, Coding:0014,,,
;EV_TCMDQ500021,1001,EV_TCMDQ500021_AU21.rod,,
;Saturday,7,March,2015,11:52:25:04481
;VCID: 2A5B37B24DEEA871104-807F,,,,
;SW:5N0-614-109-AM HW:5N0-614-109-AM --- ABS Brakes,,,,,
;Component:J104 C6 450M V413 0005, Coding:0052365,,,,
;Saturday,7,March,2015,11:52:41:04481,
;VCDS Version: Release 14.10.1 (x64) Data version: 20150130,,,,,
;VCID: 76E3D3C201D6BC9144C-8023,,,,,
Channel,,Field 1,Field 2,Field 3,Field 4
1,,ERROR:,Channel 01,Not,Available
2,,ERROR:,Channel 02,Not,Available
3,,ERROR:,Channel 03,Not,Available
4,,ERROR:,Channel 04,Not,Available
5,,ERROR:,Channel 05,Not,Available
6,,ERROR:,Channel 06,Not,Available
7,,ERROR:,Channel 07,Not,Available
8,,ERROR:,Channel 08,Not,Available
9,,ERROR:,Channel 09,Not,Available
10,,ERROR:,Channel 10,Not,Available
11,,ERROR:,Channel 11,Not,Available
12,,ERROR:,Channel 12,Not,Available
13,,ERROR:,Channel 13,Not,Available
14,,ERROR:,Channel 14,Not,Available
15,,ERROR:,Channel 15,Not,Available
16,,ERROR:,Channel 16,Not,Available
17,,ERROR:,Channel 17,Not,Available
18,,ERROR:,Channel 18,Not,Available
19,,ERROR:,Channel 19,Not,Available
20,,ERROR:,Channel 20,Not,Available
21,,ERROR:,Security,access,required
22,,ERROR:,Channel 22,Not,Available
23,,ERROR:,Channel 23,Not,Available
24,,ERROR:,Channel 24,Not,Available
25,,ERROR:,Channel 25,Not,Available
26,,ERROR:,Channel 26,Not,Available
27,,ERROR:,Channel 27,Not,Available
28,,ERROR:,Channel 28,Not,Available
29,,ERROR:,Channel 29,Not,Available
30,,ERROR:,Channel 30,Not,Available
31,0,Enabled,N/A,N/A,N/A
32,,ERROR:,Channel 32,Not,Available
33,,ERROR:,Security,access,required
34,,ERROR:,Channel 34,Not,Available
35,,ERROR:,Channel 35,Not,Available
36,,ERROR:,Channel 36,Not,Available
37,,ERROR:,Channel 37,Not,Available
38,,ERROR:,Channel 38,Not,Available
39,,ERROR:,Channel 39,Not,Available
40,,ERROR:,Security,access,required
41,,ERROR:,Security,access,required
42,,ERROR:,Security,access,required
43,,ERROR:,Channel 43,Not,Available
44,1,Enabled,N/A,N/A,N/A
45,,ERROR:,Channel 45,Not,Available
46,,ERROR:,Channel 46,Not,Available
47,,ERROR:,Channel 47,Not,Available
48,,ERROR:,Channel 48,Not,Available
49,,ERROR:,Channel 49,Not,Available
50,,ERROR:,Channel 50,Not,Available
51,,ERROR:,Security,access,required
52,,ERROR:,Channel 52,Not,Available
53,1,Rear Axle,Full,Delay,Enabled
54,,ERROR:,Channel 54,Not,Available
55,2,Brake discs,drying,Enabled,Stage 2
56,1,Trailer,Function,Enabled,N/A
57,,ERROR:,Security,access,required
58,0,normal,Enabled,N/A,N/A
59,0,Engine,ON,Engine,OFF
60,,ERROR:,Channel 60,Not,Available
61,0,Brake Booster,Deactivated,N/A,N/A
62,,ERROR:,Channel 62,Not,Available
63,1,Test,Enabled,N/A,N/A
64,,ERROR:,Channel 64,Not,Available
65,2,normal,Enabled,N/A,N/A
66,,ERROR:,Channel 66,Not,Available
67,1,Enabled,N/A,N/A,N/A
68,,ERROR:,Channel 68,Not,Available
69,,ERROR:,Channel 69,Not,Available
70,,ERROR:,Channel 70,Not,Available
71,,ERROR:,Channel 71,Not,Available
72,,ERROR:,Channel 72,Not,Available
73,1,Enabled,N/A,N/A,N/A
74,,ERROR:,Channel 74,Not,Available
75,1,Enabled,N/A,N/A,N/A
76,,ERROR:,Channel 76,Not,Available
77,1,Adaptation,Performed,N/A,N/A
78,,ERROR:,Channel 78,Not,Available
79,,ERROR:,Channel 79,Not,Available
80,,ERROR:,Channel 80,Not,Available
81,0,Deactivated,N/A,N/A,N/A
82,,ERROR:,Channel 82,Not,Available
83,,ERROR:,Channel 83,Not,Available
84,,ERROR:,Channel 84,Not,Available
85,,ERROR:,Channel 85,Not,Available
86,,ERROR:,Channel 86,Not,Available
87,,ERROR:,Channel 87,Not,Available
88,,ERROR:,Channel 88,Not,Available
89,,ERROR:,Channel 89,Not,Available
90,,ERROR:,Channel 90,Not,Available
91,,ERROR:,Channel 91,Not,Available
92,,ERROR:,Channel 92,Not,Available
93,,ERROR:,Channel 93,Not,Available
94,,ERROR:,Security,access,required
95,,ERROR:,Channel 95,Not,Available
96,,ERROR:,Channel 96,Not,Available
97,,ERROR:,Channel 97,Not,Available
98,,ERROR:,Channel 98,Not,Available
99,,ERROR:,Channel 99,Not,Available
100,,ERROR:,Channel 100,Not,Available
101,,ERROR:,Channel 101,Not,Available
102,,ERROR:,Channel 102,Not,Available
103,,ERROR:,Channel 103,Not,Available
104,,ERROR:,Channel 104,Not,Available
105,,ERROR:,Channel 105,Not,Available
106,,ERROR:,Channel 106,Not,Available
107,,ERROR:,Channel 107,Not,Available
108,,ERROR:,Channel 108,Not,Available
109,,ERROR:,Channel 109,Not,Available
110,,ERROR:,Channel 110,Not,Available
111,,ERROR:,Channel 111,Not,Available
112,,ERROR:,Channel 112,Not,Available
113,,ERROR:,Channel 113,Not,Available
114,,ERROR:,Channel 114,Not,Available
115,,ERROR:,Channel 115,Not,Available
116,,ERROR:,Channel 116,Not,Available
117,,ERROR:,Channel 117,Not,Available
118,,ERROR:,Channel 118,Not,Available
119,,ERROR:,Channel 119,Not,Available
120,,ERROR:,Channel 120,Not,Available
121,,ERROR:,Channel 121,Not,Available
122,,ERROR:,Channel 122,Not,Available
123,,ERROR:,Channel 123,Not,Available
124,,ERROR:,Channel 124,Not,Available
125,,ERROR:,Channel 125,Not,Available
126,,ERROR:,Channel 126,Not,Available
127,,ERROR:,Channel 127,Not,Available
128,,ERROR:,Channel 128,Not,Available
129,,ERROR:,Channel 129,Not,Available
130,,ERROR:,Channel 130,Not,Available
131,,ERROR:,Channel 131,Not,Available
132,,ERROR:,Channel 132,Not,Available
133,,ERROR:,Channel 133,Not,Available
134,,ERROR:,Channel 134,Not,Available
135,,ERROR:,Channel 135,Not,Available
136,,ERROR:,Channel 136,Not,Available
137,,ERROR:,Channel 137,Not,Available
138,,ERROR:,Channel 138,Not,Available
139,,ERROR:,Channel 139,Not,Available
140,,ERROR:,Channel 140,Not,Available
141,,ERROR:,Channel 141,Not,Available
142,,ERROR:,Channel 142,Not,Available
143,,ERROR:,Channel 143,Not,Available
144,,ERROR:,Channel 144,Not,Available
145,,ERROR:,Channel 145,Not,Available
146,,ERROR:,Channel 146,Not,Available
147,,ERROR:,Channel 147,Not,Available
148,,ERROR:,Channel 148,Not,Available
149,,ERROR:,Channel 149,Not,Available
150,,ERROR:,Channel 150,Not,Available
151,,ERROR:,Channel 151,Not,Available
152,,ERROR:,Channel 152,Not,Available
153,,ERROR:,Channel 153,Not,Available
154,,ERROR:,Channel 154,Not,Available
155,,ERROR:,Channel 155,Not,Available
156,,ERROR:,Channel 156,Not,Available
157,,ERROR:,Channel 157,Not,Available
158,,ERROR:,Channel 158,Not,Available
159,,ERROR:,Channel 159,Not,Available
160,,ERROR:,Channel 160,Not,Available
161,,ERROR:,Channel 161,Not,Available
162,,ERROR:,Channel 162,Not,Available
163,,ERROR:,Channel 163,Not,Available
164,,ERROR:,Channel 164,Not,Available
165,,ERROR:,Channel 165,Not,Available
166,,ERROR:,Channel 166,Not,Available
167,,ERROR:,Channel 167,Not,Available
168,,ERROR:,Channel 168,Not,Available
169,,ERROR:,Channel 169,Not,Available
170,,ERROR:,Channel 170,Not,Available
171,,ERROR:,Channel 171,Not,Available
172,,ERROR:,Channel 172,Not,Available
173,,ERROR:,Channel 173,Not,Available
174,,ERROR:,Channel 174,Not,Available
175,,ERROR:,Channel 175,Not,Available
176,,ERROR:,Channel 176,Not,Available
177,,ERROR:,Channel 177,Not,Available
178,,ERROR:,Channel 178,Not,Available
179,,ERROR:,Channel 179,Not,Available
180,,ERROR:,Channel 180,Not,Available
181,,ERROR:,Channel 181,Not,Available
182,,ERROR:,Channel 182,Not,Available
183,,ERROR:,Channel 183,Not,Available
184,,ERROR:,Channel 184,Not,Available
185,,ERROR:,Channel 185,Not,Available
186,,ERROR:,Channel 186,Not,Available
187,,ERROR:,Channel 187,Not,Available
188,,ERROR:,Channel 188,Not,Available
189,,ERROR:,Channel 189,Not,Available
190,,ERROR:,Channel 190,Not,Available
191,,ERROR:,Channel 191,Not,Available
192,,ERROR:,Channel 192,Not,Available
193,,ERROR:,Channel 193,Not,Available
194,,ERROR:,Channel 194,Not,Available
195,,ERROR:,Channel 195,Not,Available
196,,ERROR:,Channel 196,Not,Available
197,,ERROR:,Channel 197,Not,Available
198,,ERROR:,Channel 198,Not,Available
199,,ERROR:,Channel 199,Not,Available
200,,ERROR:,Channel 200,Not,Available
201,,ERROR:,Channel 201,Not,Available
202,,ERROR:,Channel 202,Not,Available
203,,ERROR:,Channel 203,Not,Available
204,,ERROR:,Channel 204,Not,Available
205,,ERROR:,Channel 205,Not,Available
206,,ERROR:,Channel 206,Not,Available
207,,ERROR:,Channel 207,Not,Available
208,,ERROR:,Channel 208,Not,Available
209,,ERROR:,Channel 209,Not,Available
210,,ERROR:,Channel 210,Not,Available
211,,ERROR:,Channel 211,Not,Available
212,,ERROR:,Channel 212,Not,Available
213,,ERROR:,Channel 213,Not,Available
214,,ERROR:,Channel 214,Not,Available
215,,ERROR:,Channel 215,Not,Available
216,,ERROR:,Channel 216,Not,Available
217,,ERROR:,Channel 217,Not,Available
218,,ERROR:,Channel 218,Not,Available
219,,ERROR:,Channel 219,Not,Available
220,,ERROR:,Channel 220,Not,Available
221,,ERROR:,Channel 221,Not,Available
222,,ERROR:,Channel 222,Not,Available
223,,ERROR:,Channel 223,Not,Available
224,,ERROR:,Channel 224,Not,Available
225,,ERROR:,Channel 225,Not,Available
226,,ERROR:,Channel 226,Not,Available
227,,ERROR:,Channel 227,Not,Available
228,,ERROR:,Channel 228,Not,Available
229,,ERROR:,Channel 229,Not,Available
230,,ERROR:,Channel 230,Not,Available
231,,ERROR:,Channel 231,Not,Available
232,,ERROR:,Channel 232,Not,Available
233,,ERROR:,Channel 233,Not,Available
234,,ERROR:,Channel 234,Not,Available
235,,ERROR:,Channel 235,Not,Available
236,,ERROR:,Channel 236,Not,Available
237,,ERROR:,Channel 237,Not,Available
238,,ERROR:,Channel 238,Not,Available
239,,ERROR:,Channel 239,Not,Available
240,,ERROR:,Channel 240,Not,Available
241,,ERROR:,Channel 241,Not,Available
242,,ERROR:,Channel 242,Not,Available
243,,ERROR:,Channel 243,Not,Available
244,,ERROR:,Channel 244,Not,Available
245,,ERROR:,Channel 245,Not,Available
246,,ERROR:,Channel 246,Not,Available
247,,ERROR:,Channel 247,Not,Available
248,,ERROR:,Channel 248,Not,Available
249,,ERROR:,Channel 249,Not,Available
250,,ERROR:,Channel 250,Not,Available
251,,ERROR:,Channel 251,Not,Available
252,,ERROR:,Channel 252,Not,Available
253,,ERROR:,Channel 253,Not,Available
254,,ERROR:,Channel 254,Not,Available
255,,ERROR:,Channel 255,Not,Available
n/a
;SW:8U0-820-043-C HW:8U0-820-043-C --- Auto HVAC
;Component:E87 Klimavoll 0050, Coding:
;Saturday,07,March,2015,11:59:33:04481
;VCID: 316920DEA838DBA9D1E-8064
Channel,,Field 1,Field 2,Field 3,Field 4,
01,4,2.0*C,N/A,N/A,N/A,
02,0,0.0*C,N/A,N/A,N/A,
03,1,ON,N/A,N/A,N/A,
04,0,0.0,N/A,N/A,N/A,
05,,ERROR:,Channel 05,Not,Available,
06,0,OFF,N/A,N/A,N/A,
07,0,OFF,N/A,N/A,N/A,
08,0,OFF,N/A,N/A,N/A,
09,118,11.80 V,N/A,N/A,N/A,
10,0,0.0,N/A,N/A,N/A,
11,1,1.0,N/A,N/A,N/A,
12,0,0.0,N/A,N/A,N/A,
13,0,0.0,N/A,N/A,N/A,
14,0,0.0,N/A,N/A,N/A,
15,,ERROR:,Channel 15,Not,Available,
16,0,0.0,N/A,N/A,N/A,
17,0,0.0,N/A,N/A,N/A,
18,0,0.0,N/A,N/A,N/A,
19,1,1.0,N/A,N/A,N/A,
20,0,0.0,N/A,N/A,N/A,
21,5,5.0,N/A,N/A,N/A,
22,5,5.0,N/A,N/A,N/A,
23,0,0.0,N/A,N/A,N/A,
24,23,23.0*C,N/A,N/A,N/A,
25,43,43.0*C,N/A,N/A,N/A,
26,65,65.0*C,N/A,N/A,N/A,
27,0,0.0*C,N/A,N/A,N/A,
28,10,10.0,N/A,N/A,N/A,
29,0,0.0,N/A,N/A,N/A,
30,0,0.0,N/A,N/A,N/A,
31,,ERROR:,Channel 31,Not,Available,
32,,ERROR:,Channel 32,Not,Available,
33,,ERROR:,Channel 33,Not,Available,
34,,ERROR:,Channel 34,Not,Available,
35,,ERROR:,Channel 35,Not,Available,
36,,ERROR:,Channel 36,Not,Available,
37,,ERROR:,Channel 37,Not,Available,
38,,ERROR:,Channel 38,Not,Available,
39,,ERROR:,Channel 39,Not,Available,
40,,ERROR:,Channel 40,Not,Available,
41,,ERROR:,Channel 41,Not,Available,
42,,ERROR:,Channel 42,Not,Available,
43,,ERROR:,Channel 43,Not,Available,
44,,ERROR:,Channel 44,Not,Available,
45,,ERROR:,Channel 45,Not,Available,
46,,ERROR:,Channel 46,Not,Available,
47,,ERROR:,Channel 47,Not,Available,
48,,ERROR:,Channel 48,Not,Available,
49,,ERROR:,Channel 49,Not,Available,
50,0,0.0,N/A,N/A,N/A,
51,0,0.0,N/A,N/A,N/A,
52,,ERROR:,Channel 52,Not,Available,
53,,ERROR:,Channel 53,Not,Available,
54,,ERROR:,Channel 54,Not,Available,
55,,ERROR:,Channel 55,Not,Available,
56,,ERROR:,Channel 56,Not,Available,
57,,ERROR:,Channel 57,Not,Available,
58,,ERROR:,Channel 58,Not,Available,
59,,ERROR:,Channel 59,Not,Available,
60,,ERROR:,Channel 60,Not,Available,
61,,ERROR:,Channel 61,Not,Available,
62,,ERROR:,Channel 62,Not,Available,
63,,ERROR:,Channel 63,Not,Available,
64,,ERROR:,Channel 64,Not,Available,
65,,ERROR:,Channel 65,Not,Available,
66,,ERROR:,Channel 66,Not,Available,
67,,ERROR:,Channel 67,Not,Available,
68,,ERROR:,Channel 68,Not,Available,
69,,ERROR:,Channel 69,Not,Available,
70,,ERROR:,Channel 70,Not,Available,
71,,ERROR:,Channel 71,Not,Available,
72,,ERROR:,Channel 72,Not,Available,
73,,ERROR:,Channel 73,Not,Available,
74,,ERROR:,Channel 74,Not,Available,
75,,ERROR:,Channel 75,Not,Available,
76,,ERROR:,Channel 76,Not,Available,
77,,ERROR:,Channel 77,Not,Available,
78,,ERROR:,Channel 78,Not,Available,
79,,ERROR:,Channel 79,Not,Available,
80,,ERROR:,Channel 80,Not,Available,
81,,ERROR:,Channel 81,Not,Available,
82,,ERROR:,Channel 82,Not,Available,
83,,ERROR:,Channel 83,Not,Available,
84,,ERROR:,Channel 84,Not,Available,
85,,ERROR:,Channel 85,Not,Available,
86,,ERROR:,Channel 86,Not,Available,
87,,ERROR:,Channel 87,Not,Available,
88,,ERROR:,Channel 88,Not,Available,
89,,ERROR:,Channel 89,Not,Available,
90,,ERROR:,Channel 90,Not,Available,
91,,ERROR:,Channel 91,Not,Available,
92,,ERROR:,Channel 92,Not,Available,
93,,ERROR:,Channel 93,Not,Available,
94,,ERROR:,Channel 94,Not,Available,
95,,ERROR:,Channel 95,Not,Available,
96,,ERROR:,Channel 96,Not,Available,
97,,ERROR:,Channel 97,Not,Available,
98,,ERROR:,Channel 98,Not,Available,
99,,ERROR:,Channel 99,Not,Available,
100,,ERROR:,Channel 100,Not,Available,
101,,ERROR:,Channel 101,Not,Available,
102,,ERROR:,Channel 102,Not,Available,
103,,ERROR:,Channel 103,Not,Available,
104,,ERROR:,Channel 104,Not,Available,
105,,ERROR:,Channel 105,Not,Available,
106,,ERROR:,Channel 106,Not,Available,
107,,ERROR:,Channel 107,Not,Available,
108,,ERROR:,Channel 108,Not,Available,
109,,ERROR:,Channel 109,Not,Available,
110,,ERROR:,Channel 110,Not,Available,
111,,ERROR:,Channel 111,Not,Available,
112,,ERROR:,Channel 112,Not,Available,
113,,ERROR:,Channel 113,Not,Available,
114,,ERROR:,Channel 114,Not,Available,
115,,ERROR:,Channel 115,Not,Available,
116,,ERROR:,Channel 116,Not,Available,
117,,ERROR:,Channel 117,Not,Available,
118,,ERROR:,Channel 118,Not,Available,
119,,ERROR:,Channel 119,Not,Available,
120,,ERROR:,Channel 120,Not,Available,
121,,ERROR:,Channel 121,Not,Available,
122,,ERROR:,Channel 122,Not,Available,
123,,ERROR:,Channel 123,Not,Available,
124,,ERROR:,Channel 124,Not,Available,
125,,ERROR:,Channel 125,Not,Available,
126,,ERROR:,Channel 126,Not,Available,
127,,ERROR:,Channel 127,Not,Available,
128,,ERROR:,Channel 128,Not,Available,
129,,ERROR:,Channel 129,Not,Available,
130,,ERROR:,Channel 130,Not,Available,
131,,ERROR:,Channel 131,Not,Available,
132,,ERROR:,Channel 132,Not,Available,
133,,ERROR:,Channel 133,Not,Available,
134,,ERROR:,Channel 134,Not,Available,
135,,ERROR:,Channel 135,Not,Available,
136,,ERROR:,Channel 136,Not,Available,
137,,ERROR:,Channel 137,Not,Available,
138,,ERROR:,Channel 138,Not,Available,
139,,ERROR:,Channel 139,Not,Available,
140,,ERROR:,Channel 140,Not,Available,
141,,ERROR:,Channel 141,Not,Available,
142,,ERROR:,Channel 142,Not,Available,
143,,ERROR:,Channel 143,Not,Available,
144,,ERROR:,Channel 144,Not,Available,
145,,ERROR:,Channel 145,Not,Available,
146,,ERROR:,Channel 146,Not,Available,
147,,ERROR:,Channel 147,Not,Available,
148,,ERROR:,Channel 148,Not,Available,
149,,ERROR:,Channel 149,Not,Available,
150,,ERROR:,Channel 150,Not,Available,
151,,ERROR:,Channel 151,Not,Available,
152,,ERROR:,Channel 152,Not,Available,
153,,ERROR:,Channel 153,Not,Available,
154,,ERROR:,Channel 154,Not,Available,
155,,ERROR:,Channel 155,Not,Available,
156,,ERROR:,Channel 156,Not,Available,
157,,ERROR:,Channel 157,Not,Available,
158,,ERROR:,Channel 158,Not,Available,
159,,ERROR:,Channel 159,Not,Available,
160,,ERROR:,Channel 160,Not,Available,
161,,ERROR:,Channel 161,Not,Available,
162,,ERROR:,Channel 162,Not,Available,
163,,ERROR:,Channel 163,Not,Available,
164,,ERROR:,Channel 164,Not,Available,
165,,ERROR:,Channel 165,Not,Available,
166,,ERROR:,Channel 166,Not,Available,
167,,ERROR:,Channel 167,Not,Available,
168,,ERROR:,Channel 168,Not,Available,
169,,ERROR:,Channel 169,Not,Available,
170,,ERROR:,Channel 170,Not,Available,
171,,ERROR:,Channel 171,Not,Available,
172,,ERROR:,Channel 172,Not,Available,
173,,ERROR:,Channel 173,Not,Available,
174,,ERROR:,Channel 174,Not,Available,
175,,ERROR:,Channel 175,Not,Available,
176,,ERROR:,Channel 176,Not,Available,
177,,ERROR:,Channel 177,Not,Available,
178,,ERROR:,Channel 178,Not,Available,
179,,ERROR:,Channel 179,Not,Available,
180,,ERROR:,Channel 180,Not,Available,
181,,ERROR:,Channel 181,Not,Available,
182,,ERROR:,Channel 182,Not,Available,
183,,ERROR:,Channel 183,Not,Available,
184,,ERROR:,Channel 184,Not,Available,
185,,ERROR:,Channel 185,Not,Available,
186,,ERROR:,Channel 186,Not,Available,
187,,ERROR:,Channel 187,Not,Available,
188,,ERROR:,Channel 188,Not,Available,
189,,ERROR:,Channel 189,Not,Available,
190,,ERROR:,Channel 190,Not,Available,
191,,ERROR:,Channel 191,Not,Available,
192,,ERROR:,Channel 192,Not,Available,
193,,ERROR:,Channel 193,Not,Available,
194,,ERROR:,Channel 194,Not,Available,
195,,ERROR:,Channel 195,Not,Available,
196,,ERROR:,Channel 196,Not,Available,
197,,ERROR:,Channel 197,Not,Available,
198,,ERROR:,Channel 198,Not,Available,
199,,ERROR:,Channel 199,Not,Available,
200,,ERROR:,Channel 200,Not,Available,
201,,ERROR:,Channel 201,Not,Available,
202,,ERROR:,Channel 202,Not,Available,
203,,ERROR:,Channel 203,Not,Available,
204,,ERROR:,Channel 204,Not,Available,
205,,ERROR:,Channel 205,Not,Available,
206,,ERROR:,Channel 206,Not,Available,
207,,ERROR:,Channel 207,Not,Available,
208,,ERROR:,Channel 208,Not,Available,
209,,ERROR:,Channel 209,Not,Available,
210,,ERROR:,Channel 210,Not,Available,
211,,ERROR:,Channel 211,Not,Available,
212,,ERROR:,Channel 212,Not,Available,
213,,ERROR:,Channel 213,Not,Available,
214,,ERROR:,Channel 214,Not,Available,
215,,ERROR:,Channel 215,Not,Available,
216,,ERROR:,Channel 216,Not,Available,
217,,ERROR:,Channel 217,Not,Available,
218,,ERROR:,Channel 218,Not,Available,
219,,ERROR:,Channel 219,Not,Available,
220,,ERROR:,Channel 220,Not,Available,
221,,ERROR:,Channel 221,Not,Available,
222,,ERROR:,Channel 222,Not,Available,
223,,ERROR:,Channel 223,Not,Available,
224,,ERROR:,Channel 224,Not,Available,
225,,ERROR:,Channel 225,Not,Available,
226,,ERROR:,Channel 226,Not,Available,
227,,ERROR:,Channel 227,Not,Available,
228,,ERROR:,Channel 228,Not,Available,
229,,ERROR:,Channel 229,Not,Available,
230,,ERROR:,Channel 230,Not,Available,
231,,ERROR:,Channel 231,Not,Available,
232,,ERROR:,Channel 232,Not,Available,
233,,ERROR:,Channel 233,Not,Available,
234,,ERROR:,Channel 234,Not,Available,
235,,ERROR:,Channel 235,Not,Available,
236,,ERROR:,Channel 236,Not,Available,
237,,ERROR:,Channel 237,Not,Available,
238,,ERROR:,Channel 238,Not,Available,
239,,ERROR:,Channel 239,Not,Available,
240,,ERROR:,Channel 240,Not,Available,
241,,ERROR:,Channel 241,Not,Available,
242,,ERROR:,Channel 242,Not,Available,
243,,ERROR:,Channel 243,Not,Available,
244,,ERROR:,Channel 244,Not,Available,
245,,ERROR:,Channel 245,Not,Available,
246,,ERROR:,Channel 246,Not,Available,
247,,ERROR:,Channel 247,Not,Available,
248,,ERROR:,Channel 248,Not,Available,
249,,ERROR:,Channel 249,Not,Available,
250,,ERROR:,Channel 250,Not,Available,
251,,ERROR:,Channel 251,Not,Available,
252,,ERROR:,Channel 252,Not,Available,
253,,ERROR:,Channel 253,Not,Available,
254,,ERROR:,Channel 254,Not,Available,
255,,ERROR:,Channel 255,Not,Available,
;SW:8X0-907-063-K HW:8X0-907-063-K --- Cent. Elect.
;Component:BCM PQ35 M 110 0667, Coding:0E000A2CA805F1C0201841C02100094C53FF84AA216F912AE40887A400C5
;Saturday,07,March,2015,12:03:47:04481
;VCID: 4487790AC78A5E010A8-8011
01,,ERROR:,Channel 01,Not,Available,
02,,ERROR:,Channel 02,Not,Available,
03,1,OPEN,Single Door,1, - ,
04,1,Auto Lock /, ,ON, - ,
05,1,Auto Unlock, ,ON, - ,
06,1,Comfort,Remote Ctrl.,ON, - ,
07,0,Comfort,Conv. Top 0,OFF, - ,
08,,ERROR:,Channel 08,Not,Available,
09,,ERROR:,Channel 09,Not,Available,
10,,ERROR:,Channel 10,Not,Available,
11,,ERROR:,Channel 11,Not,Available,
12,1,safe,Blink,Delay, - ,
13,1,Adjustment,Alarm horn,1, - ,
14,200,Tilt Sensor,Adaptation,100.0 %, - ,
15,200,Interior,Monitor,100.0 %, - ,
16,,ERROR:,Channel 16,Not,Available,
17,0,Comfort,CLOSE,OFF, - ,
18,1,Alarm delay,Door Open,Door Open, - ,
19,0,Locked,Inactive,OFF, - ,
20,,ERROR:,Channel 20,Not,Available,
21,,ERROR:,Channel 21,Not,Available,
22,0,Adapt Value,Erase, , - ,
23,15,Coming Home, ,15.00 s, - ,
24,60,Leaving Home, ,60.00 s, - ,
25,15,Timer Rear,Window Htr.,600, - ,
26,8, , ,8, - ,
27,200,Dimmer,Footwell light.,100.00 %, - ,
28,,ERROR:,Channel 28,Not,Available,
29,0, ,Status,Erase, - ,
30,6,AFL,Delay,0.06 s, - ,
31,3,Comfort,Blink,3, - ,
35,0,Dimmer,Footwell light.,0.00 %, - ,
36,0,Automatic,Stopped,normal, - ,
40,35,HCS time,ON,35, - ,
41,50,HCS time,OFF,50, - ,
42,65,HCS time,ON,65, - ,
50,,ERROR:,Channel 50,Not,Available,
51,,ERROR:,Channel 51,Not,Available,
;SW:8X0-919-475-K HW:4H0-919-475-C --- Park/Steer Assist
;Component:PARKHILFE 8K H07 0040, Coding:090305
;EV_EPHVA18AU21X0000,002005,EV_EPHVA18AU21X0000.rod
;Saturday,07,March,2015,12:07:41:04481
;VCID: 4E935B2211C6A451ACC-801B
Audio reduction request,On
Deactivation of start-stop function,Start-stop function in control module active
Park assist activation tone,On
Speaker frequency for front park assist,Stage 3
Speaker frequency for rear park assist,Stage 5
Speaker volume for front park assist,Stage 2
Speaker volume for rear park assist,Stage 5
Switch-off speed for parking assist,10 km/h
Visual display for park assist,OPS display
;SW:8U0-959-655 HW:8U0-959-655 --- Airbags
;Component:AirbagVW-AU10 H05 0410, Coding:30393132313030303030554A305238553053
;EV_AirbaAU10SMEAU316,001005,EV_AirbaAU10SMEAU316.rod
;Saturday,07,March,2015,12:08:06:04481
;VCID: 0407B90A8F0A9E014A8-8051
(1)-Airbag adaptations-Seat occupied recognition,activated
(2)-Airbag adaptations-Igniter for battery interrupt,not defined
(3)-Airbag adaptations-Key switch,Airbag deactivation key switch installed
(4)-Airbag adaptations-Passenger side rear safety belt tension igniter,not defined
(5)-Airbag adaptations-Driver side rear safety belt tension igniter,not defined
(6)-Airbag adaptations-Front passenger side seat belt tension igniter,activated
(7)-Airbag adaptations-Driver side seat belt tension igniter,activated
(8)-Airbag adaptations-Front passenger knee airbag igniter,not defined
(9)-Airbag adaptations-Driver knee airbag igniter,not defined
(10)-Airbag adaptations-Isolator for backrest adjustment motor; frt. pass. seat,not defined
(11)-Airbag adaptations-Isolator for backrest adjustment motor; driver seat,not defined
(12)-Airbag adaptations-Front passenger head curtain airbag igniter,activated
(13)-Airbag adaptations-Driver head curtain airbag igniter,activated
(14)-Airbag adaptations-Passenger airbag igniter,activated
(15)-Airbag adaptations-Driver airbag igniter,activated
(16)-Airbag adaptations-Front passenger side airbag igniter,activated
(17)-Airbag adaptations-Driver thorax airbag igniter,activated
;SW:8X0-953-521-D HW:5K0-953-569-B --- Steering wheel
;Component:LENKS.MODUL 014 0140, Coding:1894204000
;EV_SMLSNGVOLWSXS,A01004,EV_SMLSNGVOLWS.rod
;Saturday,07,March,2015,12:08:31:04481
;VCID: 3D710CEEAC602FC9456-8068
p_a_entprellung_bremse_getriebe_can,5
p_a_grenze_botschaftszaehler,8
p_a_protokollfehler_max,8
p_t_blinker_err_el_kurzschluss,200 ms
p_t_blinker_err_el_unterbrechung,1000 ms
p_t_blinker_err_gra_haengt_aus,5000 ms
p_t_blinker_err_gra_haengt_ein,300 s
p_t_blinker_err_lichthupe_haengt_aus,5000 ms
p_t_blinker_err_lichthupe_haengt_ein,300 s
p_t_blinker_err_unplausibel,200 ms
p_t_blinker_sperrzeit,100 ms
p_t_elv_fehler,400 ms
p_t_entprellzeit_ueberspannung,60000 ms
p_t_entprellzeit_unterspannung,60000 ms
p_t_err_plaus,250 ms
p_t_ezs_entprellen,200 ms
p_t_gra_tip,500 ms
p_t_grahebel_err_el_kurzschluss,200 ms
p_t_grahebel_err_el_unterbrechung,1000 ms
p_t_grahebel_err_gra_haengt_aus,5000 ms
p_t_grahebel_err_gra_haengt_ein,300 s
p_t_grahebel_err_unplausibel,800 ms
p_t_hupe_err_hinweis,2000 ms
p_t_hupe_err_hupe_haengt_aus,5000 ms
p_t_hupe_err_hupe_haengt_ein,60 s
p_t_hupe_indien_entprellen,500 ms
p_t_lin_err_kurzschluss,800 ms
p_t_lin_sleepframe_kl15_aus,1000 ms
p_t_p_verriegelt_err_el_kurzschluss,10 ms
p_t_p_verriegelt_err_unplausibel_aus,200 ms
p_t_p_verriegelt_err_unplausibel_ein,2000 ms
p_t_p_verriegelt_err_unplausibel_in_parkposition_aus,1000 ms
p_t_p_verriegelt_err_unplausibel_in_parkposition_ein,30 s
p_t_plaus_start,50 ms
p_t_s_kontakt_nachlauf,5000 ms
p_t_spannung_obere_schwelle,15.5 V
p_t_spannung_untere_schwelle,8.5 V
p_t_startverzoegerung_lin_kom,200 ms
p_t_waschen_front_bew,500 ms
p_t_wischer_err_el_kurzschluss,200 ms
p_t_wischer_err_el_unterbrechung,1000 ms
p_t_wischer_err_mfa_haengt_aus,5000 ms
p_t_wischer_err_mfa_haengt_ein,300 s
p_t_wischer_err_unplausibel,200 ms
p_t_wischer_err_waschen_haengt_aus,5000 ms
p_t_wischer_err_waschen_haengt_ein,300 s
p_t_wischer_err_wischen_haengt_aus,5000 ms
p_t_wischer_err_wischen_haengt_ein,300 s
p_t_wischer_winterstellung,60 s
p_t_zss_err_kurzschluss_aus,4 ms
p_t_zss_err_kurzschluss_ein,500 ms
p_t_zss_err_unterbrechung,500 ms
p_w_blinker_nur_bei_kl15,1
p_w_dimmung_offset,0
p_w_erkannter_mfl_typ,0
p_w_fas_nur_bei_kl15,1
p_w_fernlicht_nur_bei_kl15,1
p_w_fzggeschw_elv_lock_enable,0.80 km/h
p_w_grenze_erkannter_mfl_typ,5
p_w_helligkeitsfaktor,255
p_w_mfa_nur_bei_kl15,1
p_w_mfg_nur_bei_kl15,1
p_w_mfl_nur_bei_kl15,1
p_w_waschen_nur_bei_kl15,1
p_w_wischer_intervall_nur_bei_kl15,1
p_w_wischer_nur_bei_kl15,1
p_w_zss_direktansteuerung,0
;SW:8U0-920-990-A HW:8U0-920-990-A --- Instruments,,,,
;Component:KOMBI_COLOUR H14 0030, Coding:42CF00,,,
;EV_Kombi_UDS_VDD_AU10,A04391,EV_Kombi_UDS_VDD_AU10.rod,,
;Saturday,7,March,2015,11:41:35:04481
;VCID: 3B7502F6B27421F97B2-806E,,,,
Activating and deactivating all development messages,not active ,,,
Automatic door locking,Display ,,,
Day,7,,,
Day counter,1171 d,,,
Deactivate seat belt warning,No ,,,
Display correction of consumptions and operating range,100%,,,
Display correction of fuel gauge,0.0 °,,,
Display format,not active ,,,
Distance,28370 km,,,
Driving profiled for range remaining,6.4,,,
(1)-ESI: Coding of Service Interval Extension (SIE)-Oil level,Oil level evaluation ,,,
(2)-ESI: Coding of Service Interval Extension (SIE)-Oil pressure,dynamic oil pressure ,,,
(3)-ESI: Coding of Service Interval Extension (SIE)-Oil quality,good oil quality ,,,
(4)-ESI: Coding of Service Interval Extension (SIE)-TOG,Oil level thermal sensor connected to instrument cluster ,,,
ESI: distance driven from inspection,13400 km,,,
ESI: maximum value km-driving distance/inspection,30000 km,,,
ESI: maximum value of time between inspections,730 d,,,
ESI: minimum value km-driving distance/inspection,15000 km,,,
ESI: minimum value of time between inspections,730 d,,,
ESI: oil quality,good oil quality ,,,
ESI: Resetting ESI,no warning ,,,
ESI: soot entry,15200 km,,,
ESI: thermal load,8000 km,,,
ESI: time from inspection,297 d,,,
Expanded display of traffic sign detection,On ,,,
FIX: Distance covered since last mileage-dependent inspection,13400 km,,,
Fix: Max. distance until next mileage-related inspection,30500 km,,,
FIX: Maximum time until next time-dependent inspection,730 d,,,
FIX: Time since last time-dependent inspection,12 d,,,
Hour,11 H,,,
Indicator light for start-stop operation,On ,,,
Language version,English ,,,
Language version in instrument panel insert control module,English ,,,
Minute,41 min,,,
Month,3,,,
Seat belt warning,Version 4 ,,,
(1)-Service-key settings-p_write_delay_time,40 s,,,
(2)-Service-key settings-p_write_delay_speed,20 km/h,,,
(3)-Service-key settings-p_write_distance,20 km,,,
(4)-Service-key settings-p_forcewrite_qual_time,10 s,,,
(5)-Service-key settings-p_main_switch_keyless,On ,,,
(6)-Service-key settings-p_main_switch_basis,On ,,,
SIA: maximum value of distance to service,14500 km,,,
SIA: maximum value of time to service,365 d,,,
Source for synchronization of time,GPS ,,,
Speed threshold of dynamic oil pressure warning,kein Offset ,,,
(1)-Speed warning-,active ,,,
(2)-Speed warning-Unit,Miles per hour ,,,
(3)-Speed warning-Speed,80,,,
Staging,not active ,,,
Synchronization duration radio clock,0 min,,,
(1)-Units adjusted-Temperature,°C ,,,
(2)-Units adjusted-Distance,miles ,,,
(3)-Units adjusted-Speed,Miles per hour ,,,
(4)-Units adjusted-Pressure,bar ,,,
(5)-Units adjusted-Volume,gallons (UK) ,,,
(6)-Units adjusted-Time,24h ,,,
(7)-Units adjusted-Date,dd_mm_yy ,,,
(8)-Units adjusted-Consumption,Miles per gallon (UK) ,,,
Upshift display in center panel,not active ,,,
Year,2015,,,
Service_Key_Clear_All_Counters,Yes ,,,
;SW:8U0-907-468-A HW:8U0-907-468-A --- CAN Gateway
;Component:GAT 4CAN 1L M H10 0044, Coding:FBCF0A5A000100610353
;Saturday,07,March,2015,12:09:22:04481
;VCID: 408F751AD39242212E0-8015
01,0,N/A,N/A,N/A,N/A,
02,- -,N/A,N/A,N/A,N/A,
03,0,Init,Test Complete,N/A,N/A,
04,068 VAO 211118I04J,N/A,N/A,N/A,N/A,
05,0,N/A,N/A,N/A,N/A,
06,0,N/A,N/A,N/A,N/A,
07,070000,N/A,N/A,N/A,N/A,
08,0C0C0C0C0C0C0C0C0C0C6400640064006400640064006400640064006400,N/A,N/A,N/A,N/A,
09,0A000A000A000A000A000A002800280028002800280028000A000A000A000A000A000A000A00,N/A,N/A,N/A,N/A,
10,000000000000000008075A000B0003006D070D0003003C003C003C003C003C003C0008077017,N/A,N/A,N/A,N/A,
12,,ERROR:,Channel 12,Not,Available,
13,,ERROR:,Channel 13,Not,Available,
14,,ERROR:,Channel 14,Not,Available,
16,--,N/A,N/A,N/A,N/A,
17,0,N/A,N/A,N/A,N/A,
18,,ERROR:,Channel 18,Not,Available,
19,,ERROR:,Channel 19,Not,Available,
22,,ERROR:,Channel 22,Not,Available,
23,,ERROR:,Channel 23,Not,Available,
24,,ERROR:,Channel 24,Not,Available,
25,,ERROR:,Channel 25,Not,Available,
26,,ERROR:,Channel 26,Not,Available,
27,,ERROR:,Channel 27,Not,Available,
29,,ERROR:,Channel 29,Not,Available,
30,,ERROR:,Channel 30,Not,Available,
37,- - - -,N/A,N/A,N/A,N/A,
49,1,1.0,N/A,N/A,N/A,
;SW:0BS-907-554-D HW:0BS-907-554-D --- AWD,,,,,
;Component:Haldex 4Motion 4017, Coding:0000005,,,,
;Saturday,7,March,2015,12:13:51:04481,
;VCID: 479D6E0636BC7519EFA-8012,,,,,
;SW:8U0-920-990-A HW:8U0-920-990-A --- Immobilizer
;Component:IMMO H14 0030, Coding:000002
;EV_Immo_UDS_VDD_AU10,A04108,EV_Immo_UDS_VDD_AU10.rod
;Saturday,07,March,2015,12:14:07:04481
Component protection,active
Vehicle Positioning System Interface Control Module,not installed
;SW:8X0-959-793-E HW:8X0-959-793-E --- Door Elect, Driver
;Component:TSG FA H09 0410, Coding:011E06201C01000000
;Saturday,07,March,2015,12:14:27:04481
;VCID: 4FAD46261ECCAD59A7A-801A
;SW:5N0-909-144-N HW: --- Steering Assist
;Component:EPS_ZFLS Kl. 293 3301, Coding:
;Saturday,07,March,2015,12:14:40:04481
;VCID: 3C7701EA7F7A26C1728-8069
02,0,K-Lamp 2-col.,N/A,N/A,N/A,
03,2, ,N/A,N/A,N/A,
04,2, ,N/A,N/A,N/A,
05,0, ,N/A,N/A,N/A,
09,0, ,N/A,N/A,N/A,
17,,ERROR:,Channel 17,Not,Available,
n/a
;SW:8X0-959-792-E HW:8X0-959-792-E --- Door Elect, Pass.
;Component:TSG BF H09 0410, Coding:011E06201E01000000
;Saturday,07,March,2015,12:19:11:04481
;VCID: 4E935B2219C6A451ACC-801B
;SW:3AA-907-801-G HW:3AA-907-801-G --- Parking Brake
;Component:J540 EPB4 VW-64783 0009, Coding:0025166
;Saturday,07,March,2015,12:19:24:04481
;VCID: 356114CE5C50F7898D6-8060
01,1,Enabled,N/A,N/A,N/A,
02,,ERROR:,Security,access,required,
03,,ERROR:,Channel 03,Not,Available,
04,,ERROR:,Security,access,required,
05,,ERROR:,Security,access,required,
06,,ERROR:,Channel 06,Not,Available,
07,,ERROR:,Security,access,required,
08,,ERROR:,Security,access,required,
12,2,Enabled,N/A,N/A,N/A,
21,255,N/A,N/A,N/A,N/A,
22,0,Deactivated,N/A,N/A,N/A,
40,255,N/A,N/A,N/A,N/A,
41,255,N/A,N/A,N/A,N/A,
42,255,N/A,N/A,N/A,N/A,
63,,ERROR:,Security,access,required,
80,,ERROR:,Security,access,required,
;SW:8X0-907-357-B HW:8X0-907-357-A --- Headlight Range
;Component:****LWR12**** H02 0021, Coding:1157A61010002300
;EV_HeadlRegulBasic,005001,EV_HeadlRegulBasic.rod
;Saturday,07,March,2015,12:23:08:04481
;VCID: 4189701ED0984B2921E-8014
Highway light,not active
LWR_Control_Strategy_Selection_Development,AUTO
LWR_Function_Activation_Development,active
LWR_Vehicle_Niveau_Sensor_External_Power_Supply_Explicit_Activation_Development,not active
Reference_Run_Start_Condition_Selection_Development,Reference run is carried out from an engine speed of 500 rpm
;SW:4G0-035-061-E HW:4G0-035-061 --- Radio
;Component:Radio U DAB H52 0099, Coding:010105020100000002
;Saturday,07,March,2015,12:23:26:04481
;VCID: 1F4DD6660EAC5DD977A-804A
04,,ERROR:,Channel 04,Not,Available,
07,,ERROR:,Channel 07,Not,Available,
17,65535,105.20,39.0,37.0,38.0,
19,65535,65535,37.0,Done,N/A,
20,65535,65535,37.0,Done,N/A,
22,0,105.20,37.0,39.0,Done,
24,0,65535,38.0,Done,N/A,
25,0,65535,37.0,Done,N/A,
80,65535,225,49698,7.0,0.00 %,
81,65535,225,49698,7.0,0.00 %,
82,65535,2679,57.00 %,100.00 %, 0,
83,20,0.0,N/A,N/A,N/A,
84,0,225,49698,7.0,0.00 %,
85,6,0.0,N/A,N/A,N/A,
96,0,N/A,N/A,N/A,N/A,
99,2,N/A,N/A,N/A,N/A,
100,0,N/A,N/A,N/A,N/A,
112,20, 000000,N/A,N/A,N/A,
113,0,TT,N/A,N/A,N/A,
114,1000, 000000,N/A,N/A,N/A,
115,2000,N/A,N/A,N/A,N/A,
116,12,N/A,N/A,N/A,N/A,
117,500,N/A,N/A,N/A,N/A,
118,0,N/A,N/A,N/A,N/A,
119,2,0.0,0 /min,N/A,N/A,
120,0, 000000,N/A,N/A,N/A,
128,0,N/A,N/A,N/A,N/A,
;SW:8U0-035-666-A HW:8U0-035-666 --- Information Electr.
;Component:H-BN-EU H42 0468, Coding:0E010106000AC1E90100233600000001E00000020000000000
;Saturday,07,March,2015,12:27:48:04481
;VCID: 387F1DFA8B420AE1960-806D
01,100,N/A,N/A,N/A,N/A,
02,15,N/A,N/A,N/A,N/A,
03,10,N/A,N/A,N/A,N/A,
07,0,N/A,N/A,N/A,N/A,
09,0,N/A,N/A,N/A,N/A,
15,0,14422,N/A,N/A,N/A,
17,3,N/A,N/A,N/A,N/A,
19,1,N/A,N/A,N/A,N/A,
31,0,0,0 /min,N/A,N/A,
32,0,N/A,N/A,N/A,N/A,
33,0,0x0000,0.00 %,0,N/A,
34,0,N/A,N/A,N/A,N/A,
36,0,N/A,N/A,N/A,N/A,
47,0,N/A,N/A,N/A,N/A,
48,,ERROR:,Security,access,required,
49,0,0.0 %,73.7 %,N/A,N/A,
50,188,0.0 %,73.7 %,N/A,N/A,
51,0,N/A,N/A,N/A,N/A,
52,0,75.0 %,not available,not available,N/A,
53,0,N/A,N/A,N/A,N/A,
54,0,N/A,N/A,N/A,N/A,
66,0,N/A,N/A,N/A,N/A,
67,0,N/A,N/A,N/A,N/A,
69,15,N/A,N/A,N/A,N/A,
81,0,N/A,N/A,N/A,N/A,
112,0,N/A,N/A,N/A,N/A,
117,0,N/A,N/A,N/A,N/A,
122,0,N/A,N/A,N/A,N/A,
123,255,N/A,N/A,N/A,N/A,
129,0,N/A,N/A,N/A,N/A,
130,0,N/A,N/A,N/A,N/A,
144,0,N/A,N/A,N/A,N/A,
;SW:8X0-959-795-A HW:8X0-959-795-A --- Door, Rear Left
;Component:TSG HL H06 0409, Coding:010E06200001000000
;Saturday,07,March,2015,12:33:55:04481
;VCID: 4D915C2E14C09F49D56-8018
;SW:7N0-907-383 HW:7N0-907-383 --- Trailer
;Component:Towbar module H09 0120, Coding:0109080000000000
;Saturday,07,March,2015,12:34:11:04481
;VCID: 73E5EAD6D2A4A9B9632-8026
;SW:8X0-959-795-A HW:8X0-959-795-A --- Door, Rear Right
;Component:TSG HR H06 0409, Coding:010E06200001000000
;Saturday,07,March,2015,12:40:56:04481
