Results 1 to 7 of 7
Thread: Bixenon Retrofit Golf VII
    Feb 2015
    Italy
    Dear All ,
    first of all , sorry for my english,
    i retrofit on my golf VII bixenon headlight of Golf R , then i change BCM , Can Gateway , and installed the Headlight Range.
    THe problem that i have now are from when i replace the Can gateway i have all this error :
    Monday,02,March,2015,13:57:58:49087
    > VCDS -- Windows Based VAG/VAS Emulator
    > VCDS Version: 15.2.0.0 (x64)
    > Data version: 20150130
    > VIN: WVWZZZAUZDW064011   License Plate:
    > Mileage: 41130km-25556mi   Repair Order:
    > Chassis Type: AU (5Q0)
    > Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F
    > VIN: WVWZZZAUZDW064011   Mileage: 41130km-25556miles
    > 01-Engine -- Status: Malfunction 0010
    > 03-ABS Brakes -- Status: OK 0000
    > 08-Auto HVAC -- Status: OK 0000
    > 09-Cent. Elect. -- Status: Malfunction 0010
    > 15-Airbags -- Status: OK 0000
    > 16-Steering wheel -- Status: OK 0000
    > 17-Instruments -- Status: Malfunction 0010
    > 19-CAN Gateway -- Status: Malfunction 0010
    > 42-Door Elect, Driver -- Status: OK 0000
    > 44-Steering Assist -- Status: OK 0000
    > 52-Door Elect, Pass. -- Status: OK 0000
    > 55-Headlight Range -- Status: Malfunction 0010
    > 5F-Information Electr. -- Status: Malfunction 0010
    > Address 01: Engine (J623-CRBC)       Labels: 04L-907-309-V1.clb
    >     Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
    >     Component: R4 2,0L EDC   H22 4941
    >     Revision: 83H22---
    >     Coding: 01190012032405082000
    >     Shop #: WSC 01364 002 1048576
    >     ASAM Dataset: EV_ECM20TDI01104L906021DS 002008
    >     ROD: EV_ECM20TDI01104L906021DS_AU37.rod
    >     VCID: 79F9E308F866EDF024-802C
    > 1 Fault Found:
    > 17149 - Check Coding of ECUs on Powertrain Data Bus
    >            P1647 00 [038] - -
    >            Intermittent - Not Confirmed - Tested Since Memory Clear
    >               Freeze Frame:
    >                      Fault Status: 00000001
    >                      Fault Priority: 2
    >                      Fault Frequency: 5
    >                      Mileage: 41130 km
    >                      Date: 2015.02.28
    >                      Time: 13:17:06
    > Readiness: 0 0 0 0 1
    > Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
    >     Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
    >     Component: ESC           H75 0437
    >     Revision: 00000000    Serial number:
    >     Coding: 01FA62A120260A700377060101C42980460450C0608094F300680024C0
    >     Shop #: WSC 01357 011 00200
    >     ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
    >     ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
    >     VCID: 7DF1F718EC4ED1D008-8028
    > No fault code found.
    > Address 08: Auto HVAC (J255)       Labels: 5G0-907-044.clb
    >     Part No SW: 5G0 907 044 Q    HW: 5G0 907 044 Q
    >     Component: Climatronic   H02 0503
    >     Revision: 00001K06
    >     Coding: 00020104202100011005000000101000
    >     ASAM Dataset: EV_ACClimaBHBVW37X 002017
    >     ROD: EV_ACClimaBHBVW37X_VW37.rod
    >     VCID: 35612F3894FEC99080-8060
    > Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-HV1.clb
    >     Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
    >     Component: BCM MQBAB H   H16 0124
    >     Serial number: 00011424100117
    >     Coding: 00000A42C24322FB4FE4400000040368100A000000000000000000000000
    >     Shop #: WSC 12345 123 12345
    >     ASAM Dataset: EV_BCMCONTI 012001
    >     ROD: EV_BCMBOSCH_VW37.rod
    >     VCID: 7BF5F900F25ADFE036-802E
    >     Slave 1:
    >     Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A
    >     Component: WWS    121111  042 0551
    >     Serial number:         121204015002
    >     Coding: 0E4DD5
    >     Slave 2:
    >     Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547   Labels:
    > 5Q0-955-547.CLB
    >     Component: RLFS  024 0042
    >     Serial number: Y13M01D03H21M30S36S1
    >     Coding: 00A8DD
    > 1 Fault Found:
    > 540693 - Databus
    >            U1121 00 [008] - Missing Message
    >            Intermittent - Confirmed - Tested Since Memory Clear
    >               Freeze Frame:
    >                      Fault Priority: 6
    >                      Fault Frequency: 1
    >                      Reset counter: 46
    >                      Mileage: 41130 km
    >                      Date: 2015.02.28
    >                      Time: 13:15:53
    > Address 15: Airbags (J234)       Labels: 5Q0-959-655.clb
    >     Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
    >     Component: AirbagVW20    011 0361
    >     Serial number: 003F5R01Y5JN
    >     Coding: 98CCC000000000005C0000CF004800000065
    >     ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
    >     ROD: EV_AirbaVW20SMEVW37X_VW37.rod
    >     VCID: 408F4EECDB3C7C3823-8015
    >     Crash sensor for side airbag; driver side:
    >     Subsystem 1 - Part No SW: -----------    HW: 480 000 201 13
    >     Component: SideSensor_Df  001 0887
    >     Serial number: 35767000000828EC7C05
    >     Coding: 2D2D2D
    >     Crash sensor for side airbag; front passenger side:
    >     Subsystem 2 - Part No SW: -----------    HW: 480 000 201 13
    >     Component: SideSensor_Pf  001 0887
    >     Serial number: 358670000000B02C7C0U
    >     Coding: 2D2D2D
    >     Crash sensor for side airbag; rear; driver side:
    >     Subsystem 3 - Part No SW: -----------    HW: 480 400 301 13
    >     Component: SideSensor_Dr  001 6149
    >     Serial number: 3516502C50D5D60311C7
    >     Coding: 2D2D2D
    >     Crash sensor for side airbag; rear; passenger side:
    >     Subsystem 4 - Part No SW: -----------    HW: 480 400 801 13
    >     Component: SideSensor_Pr  001 6149
    >     Serial number: 3526502BD0D5D60042AE
    >     Coding: 2D2D2D
    >     Crash sensor for front airbag; driver side:
    >     Subsystem 5 - Part No SW: -----------    HW: 480 401 112 12
    >     Component: FrontSensor_D  001 6149
    >     Serial number: 3556502B50CD5EC3532P
    >     Coding: 2D2D2D
    > Address 16: Steering wheel (J527)       Labels: 5Q0-953-549.clb
    >     Part No SW: 5Q0 953 507 AA    HW: 5Q0 953 549
    >     Component: Lenks. Modul  007 0070
    >     Revision: --------    Serial number: 19121208490414
    >     Coding: 8400
    >     ASAM Dataset: EV_SMLSKLOMQB 009001
    >     ROD: EV_SMLSKLOMQB_SE37.rod
    >     VCID: 75E1EF38D47E899040-8020
    > Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb
    >     Part No SW: 5G0 920 860 A    HW: 5G0 920 860 A
    >     Component: KOMBI         236 0555
    >     Coding: 07A401002380000800082A00040000
    >     Shop #: WSC 02205 264 00000
    >     ASAM Dataset: EV_DashBoardVDDMQBAB 008026
    >     ROD: EV_DashBoardVDDMQBAB_VW37.rod
    >     VCID: 2643F8745958B20839-8073
    > 1 Fault Found:
    > 13636608 - Control Module Incorrectly Coded
    >            U1014 00 [009] - -
    >               Freeze Frame:
    >                      Fault Priority: 2
    >                      Fault Frequency: 9
    >                      Reset counter: 6
    >                      Mileage: 41125 km
    >                      Date: 2015.02.28
    >                      Time: 11:12:38
    > Address 19: CAN Gateway (J533)       Labels: Redir Fail!
    >     Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
    >     Component: GW MQB High   125 1109
    >     Revision: --------    Serial number: 0000355308
    >     Coding: 030100040B087300EF000248080F00010001000000000000000000000000
    >     Shop #: WSC 04940 001 00001
    >     ASAM Dataset: EV_GatewLear 006010
    >     ROD: EV_GatewLear_VW37.rod
    >     VCID: 3467123C9F84D098B7-8061
    >     Alternator:
    >     Multifunction unit control module:
    >     Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J
    >     Component: E221__MFL-DC1  H13 0035
    >     Serial number: 02120004913840040291
    >     Coding: 280000
    >     Battery Monitoring Control Module:
    >     Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
    >     Component: J367-BDMHella  H03 8042
    >     Serial number: 3216298701
    > 1 Fault Found:
    > 66054 - Extended CAN Bus (SAE Bus C)
    >            U0047 00 [008] - Performance
    >               Freeze Frame:
    >                      Fault Priority: 2
    >                      Fault Frequency: 1
    >                      Reset counter: 46
    >                      Mileage: 41130 km
    >                      Date: 2015.02.28
    >                      Time: 13:15:53
    > Address 42: Door Elect, Driver (J386)       Labels: 5QX-959-X93-42.clb
    >     Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
    >     Component: TSG FS        012 0006
    >     Serial number: 12121200091431
    >     Coding: 003B0320D000040000001000
    >     ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
    >     ROD: EV_DCUDriveSideEWMAXCONT.rod
    >     VCID: 3F8D4D10A6C203C05A-806A
    >     Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
    >     Component: Fond FHSG DRV  007 0002
    >     Serial number: 00000000000000494846
    >     Coding: 010000
    > Address 44: Steering Assist (J500)       Labels: 5Q0-909-144.clb
    >     Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
    >     Component: EPS_MQB_ZFLS  119 1021
    >     Coding: 81
    >     ASAM Dataset: EV_SteerAssisMQB 008022
    >     ROD: EV_SteerAssisMQB.rod
    >     VCID: 3D713718ACCE11D048-8068
    > Address 52: Door Elect, Pass. (J387)       Labels: 5QX-959-X92-52.clb
    >     Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
    >     Component: TSG BFS       012 0006
    >     Serial number: 13121200011143
    >     Coding: 003B0120DE00040000801000
    >     ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
    >     ROD: EV_DCUPasseSideEWMAXCONT.rod
    >     VCID: 3E733014A1C80AC851-806B
    >     Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
    >     Component: Fond FHSG PSG  007 0002
    >     Serial number: 00000000000000497419
    >     Coding: 090000
    > Address 55: Headlight Range (J745)       Labels: 7P6-907-357.clb
    >     Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
    >     Component: AFS-ECU       H07 0080
    >     Revision: --------    Serial number: --------------
    >     Coding: 028A000006000000
    >     ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
    >     ROD: EV_HeadlRegulVWAFS_VW37.rod
    >     Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329
    >     Component: LeiMo links  H05 0012
    >     Coding: 2E0000
    >     Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329
    >     Component: LeiMo rechts  H05 0012
    >     Coding: 2E0000
    > 2 Faults Found:
    > 5275220 - Headlight
    >            C107E 54 [137] - Missing Calibration / Basic Setting
    >            MIL ON - Confirmed - Tested Since Memory Clear
    >               Freeze Frame:
    >                      Fault Priority: 1
    >                      Fault Frequency: 1
    >                      Reset counter: 6
    >                      Mileage: 41130 km
    >                      Date: 2015.02.28
    >                      Time: 13:37:47
    > 5256721 - Rear Left Ride-Height Sensor
    >            C1036 11 [137] - Short to Ground
    >               Freeze Frame:
    >                      Fault Priority: 2
    >                      Fault Frequency: 3
    >                      Reset counter: 6
    >                      Mileage: 41130 km
    >                      Date: 2015.02.28
    >                      Time: 13:37:46
    > Address 5F: Information Electr. (J794)       Labels: None
    >     Part No SW: 5G0 035 819     HW: 5G0 035 819
    >     Component: MU-S--ER      039 0142
    >     Serial number: V1C00501131110
    >     Coding: 02730000FF00000011110001000800001F0100840100010001
    >     ASAM Dataset: EV_MUStd4CPASE 002036
    >     ROD: EV_MUStd4CPASE_VW37.rod
    >     VCID: 66C3B87499D87208F9-8033
    >     Media Player Position 1:
    >     Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
    >     Component: ABT_Std_Radio  H44 0020
    >     Serial number: VWZ8Z9M240145E
    > 1 Fault Found:
    > 7191 - Function Restricted due to Missing Message(s)
    >            U1111 00 [009] - -
    >               Freeze Frame:
    >                      Fault Priority: 6
    >                      Fault Frequency: 1
    >                      Reset counter: 6
    >                      Mileage: 41125 km
    >                      Date: 2015.02.28
    >                      Time: 11:12:19
    May someone help me to solve this problem.
    Thanks in advance.
    Giacomo
    Feb 2015
    Italy
    nobody can help me??
    Tartu, Estonia
    You have many fault codes...which one?
    But nr1 in my opinion would be that you have some error with level sensor, fix that, after that to headlight alignment and then erase all fault and see what returns.
    The world is my oyster...
    Feb 2015
    Hi Giacomo,
    Can you please clarify;
    - Are all of these errors present after you clear all DTCs (fault codes)?
    - or, did you not clear DTCs before, and this is a list of all the fault codes?
    If the last, then please perform AutoScan -> Clear DTCs -> (New) Autoscan and post that instead. Many DTCs can occur during work on the car, and it's quite clear that you have been doing something to the power train CANbus, which is also to be expected as you retrofitted address 55 - Headlight Range Control. But to determine what is actually wrong with the car, it's pretty important that all errors are still relevant, and that there aren't any errors listed which basically are no longer present in the car.
    The reason I ask, is that alot of the fault codes refer to issues with the power train CAN bus, but ABS controller for instance has no faults, but it is connected also to the drive train CANbus, so if a problem persisted with e.g. the connection in the gateway, more errors should be seen.
    Also; if you already know the cause of some of the errors (like instrument cluster not coded correctly - maybe you changed it?) then please say so as well.
    Thanks,
    Nicolai
    Feb 2015
    Italy
    Dear golfi_vend/ Nicoleise,
    i solve the problem of xenon range addr 55 , the ather two thinks that i have on the car are that drive profile , is not working and the auto speed too, but this happend from when i change the can gateway in order to install the xenon range, i post the last scan may you help me?
    Thanks in advance
    Giacomo
    VCDS Version: Beta 15.2.0 (x64)
    Monday,16,March,2015,17:05:35:49087
    VIN: WVWZZZAUZDW064011   Mileage: 41721km-25924miles
       Revision: 83H22---
              P1647 00 [038] - -
                        Mileage: 41721 km
                        Date: 2015.03.14
                        Time: 16:20:21
       Revision: 00001K06
       Slave 1:
       Coding: 0E4DD5
       Slave 2:
       Coding: 00A8DD
       Coding: 8400
       Coding: 07A401002B80000801082A00040000
       Shop #: WSC 02205 264 12345
    H13 0035
       Coding: 280000
       Coding: 81
       Coding: 090000
       Coding: 2E0000
       Coding: 2E0000
              U1111 00 [009] - -
                        Reset counter: 17
                        Mileage: 41721 km
                        Date: 2015.03.14
                        Time: 16:20:22
  6. #6
    Feb 2015
    Italy
    no news??
    Please
    Thanks in advance
  7. #7
    Feb 2015
    Italy
    Dear All,
    how i can code the can gateway in order to enable drive profile selection , that actually is not working??
    Thanks in advance
    Giacomo
