Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Errors with '07 Beetle
    Mar 2015
    Washington, USA
    No I had not seen that video. Thanks!
    I gave up on the Jetta fob. But I had followed the instructions from the video pretty much identical, except I believe I hit the unlock (not lock) button. I'll try it again just to be sure. However, I do get the honk acknowledgement from the car when I pushed the button on the fob. It just won't unlock the car. To your other question, yes the interior lock button will lock and unlock, as will using the key in the mechanical lock outside.
    2013 GTI, 2018 Subaru Outback 3.6R Touring, 2010 Routan SEL. Passat and Jetta TDIs sold back to VW.
  2. #12
    Verified VCDS User roth's Avatar
    Feb 2015
    Quote Originally Posted by atc98092 View Post
    I'm feeling that there is nothing wrong with the remote. Probably its the drivers door latch or lock.
    Can you log n post ALL MVBs in 46 Comfort system? Do it under 3 conditions: 1. all doors closed and locked, 2. all door closed but unlocked, 3. all doors open.
    Thanks, Andy.
  3. Likes Uwe liked this post
  4. #13
    Mar 2015
    Washington, USA
    I would love to, if you tell me what an MVB is
  5. #14
    See how MVB is green and bold? Hover your cursor over it.
  6. Likes Jack@European_Parts liked this post
  7. #15
    Mar 2015
    Washington, USA
    Yeah, I saw that after I posted my response. Sneaky little forum you have here.
    I found a new battery in the cupboard this morning for the fob, so I'm going to replace it and give it another go. Since the interior lock switch works, and both doors will unlock using the key in the door, the electronics in the car seem to be communicating correctly. Just have to see why it won't accept the fob signal.
    If it makes any difference, it stopped working when my granddaughter was playing with the fob outside the car range. She was likely pounding all the buttons one after another. I've heard that will cause issues, but was hoping I could reset it. We have two keys for the car, but only one is a fob. The other is the valet key I would imagine.
  8. #16
    Mar 2015
    Washington, USA
    MVBs
    OK, replaced the fob battery. Used Channel Zero to reset, then set channel one to one (any other number, test and save was grayed out). Saved, then hit a button on the fob. Car beeps, but fob still doesn't work.
    Attached are the MVBs requested by Andy. Whoops, I see I can't post attachments. So, I'll copy the results here.
    Closed and locked:
    Sunday,15,March,2015,16:28:13:55621
    VCDS Version: 14.10.1.1 (x64)
    Data version: 20150130
    VIN: 3VWEW31C77M508372   License Plate:
    Mileage: 128840km-80057mi   Repair Order:
                    Address 46: Central Conv.  (1C0 959 799 G)
    16:28:07 Group 001: Driver's door
      Not Oper.  Electric window hall signal
      No  Electric window thermal protection
      Not Installed  Child safety switch
      N/A
    16:28:07 Group 002: Driver's door (driver's switch for electric windows)
      Not Oper.  Passenger side electric window
      Not Installed  Rear left electric window
      Not Installed  Rear right electric window
      N/A
    16:28:07 Group 003: Driver's door
      Not Oper.  Mirror adjustment switch driver
      Not Oper.  Mirror selection switch driver
      Not Installed  Mirror folding switch
      OFF  Mirror heating
    16:28:36 Group 004: Passenger's door (electric window)
      Not Oper.  Switch passenger (E107)
      No  Thermal protection passenger
      Not Installed  Working speed control switch
      N/A
    16:28:36 Group 005: Rear door's (electric windows)
      Not Installed  Switch rear left (E52)
      Not Installed  Thermal protection rear left
      Not Installed  Switch rear right (E54)
      Not Installed  Thermal protection rear right
    16:28:36 Group 006
      12.21 V  Supply Voltage (terminal 30)
      Term 15 On  Ignition
      Activated  S-Terminal
      0.0 km/h  Speed signal
    16:28:57 Group 007
      Not Oper.  Central locking key switch driver
      Not Oper.  Central locking key switch pass.
      Not Oper.  Interior locking driver switch
      Not Oper.  Interior locking passenger switch
    16:28:57 Group 008
      Closed  Hood contact switch (F120)
      Not Oper.  Rear lid/tailgate key switch
      Closed  Rear lid/tailgate contact switch
      No  Central locking thermal protection
    16:28:57 Group 009: Central locking feedback
      Locked  Driver's side
      Locked  Passenger's side
    16:29:15 Group 010: Rotary latch switches
      Door Closed  Driver's side
      Door Closed  Passenger's side
    16:29:15 Group 011
      No  Immobilizer key recognition
      Not Oper.  Automatic lock/unlock switch
      Yes  Sliding/tilting sunroof released
      2-Wire  Status CAN-Databus
    16:29:15 Group 012: CAN-Databus communication
      Dr. Door 1  Door contr. module Driver side
      Pas. Door 1  Door contr. module Passenger side
         Door contr. module rear left
         Door contr. module rear right
    16:29:32 Group 013
      Not Oper.  Rear lid button rear lid handle
      Closed  Rear first detent
      0.0 %  Instrument illumination
      N/A
    16:29:32 Group 014
      no Value  Permanent code known
      no Value  Code within effective range
      no Value  Algorithm
      0  Key number
    16:29:32 Group 015
       0 0 0 0  Remote control button
      Not Installed  Interior monitor sensor (G273)
      Not Installed  Interior monitoring switch-off (E267)
      N/A
    16:29:45 Group 016: Alarm Sources
      2  1st Alarm Source
      16  2nd Alarm Source
      16  3rd Alarm Source
      16  4th Alarm Source
    Closed and unlocked:
    Sunday,15,March,2015,16:30:26:55621
    Mileage: 128840km-80057mi   Repair Order: 2
    16:30:13 Group 001: Driver's door
      N/A
    16:30:13 Group 002: Driver's door (driver's switch for electric windows)
      N/A
    16:30:13 Group 003: Driver's door
      OFF  Mirror heating
    16:30:36 Group 004: Passenger's door (electric window)
      N/A
    16:30:36 Group 005: Rear door's (electric windows)
    16:30:36 Group 006
      Term 15 On  Ignition
    16:30:48 Group 007
    16:30:48 Group 008
    16:30:48 Group 009: Central locking feedback
      Unlocked  Driver's side
      Unlocked  Passenger's side
    16:30:58 Group 010: Rotary latch switches
    16:30:58 Group 011
    16:30:58 Group 012: CAN-Databus communication
    16:31:11 Group 013
      N/A
    16:31:11 Group 014
      no Value  Algorithm
      0  Key number
    16:31:11 Group 015
      N/A
    16:31:22 Group 016: Alarm Sources
      2  1st Alarm Source
      16  2nd Alarm Source
      16  3rd Alarm Source
      16  4th Alarm Source
    Doors open and unlocked:
    Sunday,15,March,2015,16:32:02:55621
    Mileage: 128840km-80057mi   Repair Order: 3
    16:31:57 Group 001: Driver's door
      N/A
    16:31:57 Group 002: Driver's door (driver's switch for electric windows)
      N/A
    16:31:57 Group 003: Driver's door
      OFF  Mirror heating
    16:32:10 Group 004: Passenger's door (electric window)
      N/A
    16:32:10 Group 005: Rear door's (electric windows)
    16:32:10 Group 006
      12.10 V  Supply Voltage (terminal 30)
      Term 15 On  Ignition
    16:32:18 Group 007
    16:32:18 Group 008
    16:32:18 Group 009: Central locking feedback
    16:32:25 Group 010: Rotary latch switches
      Door Open  Driver's side
      Door Open  Passenger's side
    16:32:25 Group 011
    16:32:25 Group 012: CAN-Databus communication
    16:32:33 Group 013
      N/A
    16:32:33 Group 014
      no Value  Algorithm
      0  Key number
    16:32:33 Group 015
      N/A
    16:32:43 Group 016: Alarm Sources
      2  1st Alarm Source
      16  2nd Alarm Source
      16  3rd Alarm Source
      16  4th Alarm Source
  9. Likes Uwe liked this post
