Your PR sticker would help as the type of fan might be indicated there. I'd do it BEFORE tracing the wiring.
BR, Andy
Hi
The label is not on the van, I did find a document with PR CODE of PR 1C if that tells you anything.
I tried to slow the fan in output test but as the fan was already running i did not want to press activate just incase it damaged anything,, here is a small log of info from of fan and log of A/C. The wiring check would be easier if i new 100% what fan control was on here, I have eliminated the one out of 3, and the other two,, One has one & two speed using radiator fan thermal switch 3 pin and a two pin switch depending on what speed, with j329 relay, & fuse sb24 , no fan controller shown just a N235 protection resistor, then to . and shows one fan, ours has one fan,
Do you know if the thermo type fan switch, F18 is located in the same place as the G83 outlet temp sensor, if it is in the same location this could be our fan control type thermo to no controller which i cant find?
The othe system list Variable radiator fan control from 2007, which i think ours maybe except i cant find any controller j293. this diagram has the same relay same fuse sb24 as the previous system but is linked to the controller then to using G83 outlet temp sensor.The G83 shows no wire colours only linked to two pins. The fan just has a large black connector which the other vans here also have they, have no air con, but some use different fan control as some have G83 some not. and some twin fans but no other connector as the diagram disc i have shows to types of controllers one like a small module with to separate plugs for pins, the other looks like a small connector linked to the fan and that one shows it by the fan-fans. I'm begining to think it is not a wiring fault, maybe a controller if it has one,, problem regarding A/C 005685 p1635 missing message from A/C controller which the van does not have any A/C. problem is how do you code it , also i noticed yesterday the oil level/temp sensor has a intermittent , whether this may cause the fan to run. will have a look at that, I did trace the 4 main wires at the fan connector heavy Red + Bttery etc, Heavy brown earth 642 to location, thin yl/vi to , and Bl/rd to sb24 fuse via relay,
Saturday,14,March,2015,22:15:25:46146
-- Windows Based VAG/VAS Emulator
Version: 14.10.1.1 (x64)
Data version: 20150130
VIN: License Plate: BF08TVD
Mileage: Repair Order: Dave
Address 01: Engine (03G 906 021 )
22:15:11 Group 064: Engine Cooling
8.1*C Coolant Temperature (G62)
9.0*C Coolant Temp. Cooler Outlet
87.3 % Coolant Fan 1 Duty Cycle
Saturday,14,March,2015,22:13:17:46146
22:12:37 Group 063: Engine Cooling (Air Conditioner)
20.18 bar Refrigerant Pressure
0.0 Nm Compressor Load Torque
Cooling Requirement
16.0 Air Conditioner Shut-Off Status
