Hi
Vw caddy van with the radiator fan on all the time once the ignition is on 3 seconds later the fan runs.
I tried another fan unit, i tried another relay for the j329. but no joy, the Engine Ecu has just been replaced with the instrument cluster, but we had the same problem with the old Ecu,, so ecu ok.
disconnected the Rad outlet temp sensor G83 which i believe triggers the fan, The fan still run's. Changed the G83, Still no difference,
This van has one large Radiator only, although my disc shows two fans,, NO Aircon Fitted,, Van is 2008 march build date, pdf i have also shows on engine side of image, coolant temp sender G62 which i think is for the ecu and dash temp and maybe with the other sensor they compare temp for rad speed etc.
The only way to stop the fan is by taking out the fuse SB24 or removing the j329 relay, which does not fix the fault, i thought maybe it was in limp home mode, but looking at the autoscan did not see anything to cause this only Dtc for fan to ground.
Does anyone know if the 2008 has a radiator fan control unit J293 or was this on earlier models only, if it does have one ,,where is it located on the van, i have seen some by the radiator fan itself but there are several variations, Need to eliminate the fan controller if it has one, other than that maybe wiring to ground as something is grounding it all the time it seems.
MVB shows the temp sensor readings correct when cold 9 deg c and duty cycle of fan when on approx 87%.
Tuesday,03,March,2015,16:43:51:46146
VCDS Version: 14.10.1.1 (x64)
Data version: 20150130
VIN: WV1ZZZ2KZ8X118552 License Plate: BF08 TVD
Mileage: 78470km-48758mi Repair Order: Dave scan 2
Chassis Type: 2K (1K0)
Scan: 01 03 09 15 16 17 19 25 42 46 52 56
VIN: WV1ZZZ2KZ8X118552 Mileage: 78470km-48758miles
16-Steering wheel -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 1010
Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 021 PD HW: 03G 906 021 CG
Component: R4 1,9L EDC 000SG 2387
Revision: --H07--- Serial number: VWX7Z0H13NB033
Coding: 0000071
Shop #: WSC 66565 257 00032
VCID: 70EFFCFA631751A19E0-8025
005685 - Powertrain Data Bus
P1635 - 000 - Missing Message from A/C Controller
Mileage: 78471 km
Time: 00:30:53
Voltage: 12.08 V
Bin. Bits: 00000100
Bin. Bits: 00000000
(no units): 16.0
005716 - Please check DTC Memory of Instrument Cluster
P1654 - 000 -
Mileage: 78471 km
Time: 00:30:57
Voltage: 12.08 V
Temperature: 12.6*C
Temperature: 20.7*C
Temperature: 14.4*C
001681 - Fan 1 Control Circuit
P0691 - 000 - Short to GND
Mileage: 78471 km
Time: 00:30:59
Voltage: 12.08 V
Bin. Bits: 00000100
Temperature: 20.7*C
Duty Cycle: 9.7 %
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 000 - Open Circuit
Fault Status: 01110000
Mileage: 78471 km
Time: 00:33:48
RPM: 945 /min
Voltage: 12.31 V
Bin. Bits: 00000100
Temperature: 20.7*C
Bin. Bits: 10110000
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 000 - Open Circuit
Mileage: 78471 km
Time: 00:33:48
RPM: 945 /min
Voltage: 12.31 V
Bin. Bits: 00000100
Temperature: 20.7*C
Bin. Bits: 10110000
Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AF HW: 1K0 907 379 AF
Component: MABS MK70M 0104
Revision: 00H32001
Coding: 0020801
Shop #: WSC 35110 377 00155
VCID: 76E3CAE201737F9144C-8023
003 - Mechanical Failure
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Revision: 00H54000 Serial number: 01000008045806
Coding: 00884F030004100047000000000000000008FB075C000100000000000000
Shop #: WSC 35110 377 08192
VCID: 6FEDFF867E294E5987A-803A
Subsystem 1 - Part No: 2K2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 121207 021 0501
Coding: 00038805
Shop #: WSC 35110
02399 - Control Circuit for Terminal 30 for Interior Illumination
009 - Open or Short to Ground
Fault Status: 01111001
Reset counter: 82
Mileage: 78471 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.55 V
01800 - Light Switch (E1)
Reset counter: 121
Mileage: 78471 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 11.35 V
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Fault Status: 00101001
Reset counter: 121
Mileage: 78471 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 11.25 V
Reset counter: 122
Mileage: 78471 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.15 V
00059 - Terminal 30 for Interior Lighting
Reset counter: 82
Mileage: 78471 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 11.25 V
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 09 AIRBAG VW52 023 2400
Revision: 04023000 Serial number: 0037TD0H1Z1K
Coding: 0012345
Shop #: WSC 35110 377 00156
VCID: 7DF1D5CE24452CC9056-8028
6 Faults Found:
00595 - Crash Data Stored
000 - - - MIL ON
01214 - Crash Data for Belt Tensioner Stored
000 - - - MIL ON
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
001 - Upper Limit Exceeded - Intermittent - MIL ON
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
Part No SW: 1K0 953 549 AE HW: 1K0 953 549 AE
Component: Lenksäulenmodul 034 0070
VCID: 75E1CDEE1C7574894D6-8020
Part No SW: 2K0 920 944 C HW: 2K0 920 944 C
Component: KOMBIINSTRUMENT VDD 1212
Revision: V0002000 Serial number: VWX7Z0H13NB033
Coding: 0016401
Shop #: WSC 00464 210 83173
VCID: 2C57288A8FBF7541E28-8079
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 79
Reset counter: 82
Mileage: 78471 km
Time: 00:00:05
Fault Status: 00101010
Reset counter: 122
Mileage: 78471 km
Time: 00:04:18
00771 - Fuel Level Sensor (G)
Reset counter: 82
Mileage: 78471 km
Time: 00:00:09
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 040108F2001379
Coding: 89801F020002027401
VCID: 306F3CFAA39711A1DE0-8065
9 Faults Found:
Fault Status: 00110100
Reset counter: 121
Mileage: 223269 km
Time: 00:16:56
Reset counter: 121
Mileage: 117243 km
Time: 03:18:50
Reset counter: 121
Mileage: 223269 km
Time: 19:20:55
Reset counter: 121
Mileage: 421279 km
Time: 00:55:08
Reset counter: 121
Mileage: 223269 km
Time: 04:26:27
Reset counter: 121
Mileage: 290145 km
Time: 02:33:14
Reset counter: 122
Mileage: 98377 km
Time: 00:00:01
Reset counter: 121
Mileage: 98377 km
Time: 00:00:02
Mileage: 421279 km
Time: 00:36:34
Component: IMMO VDD 1212
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1206
Coding: 0000560
VCID: 387F04DA4BE7C9E1960-806D
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 998A0C087F2D8405485A030010C0
Shop #: WSC 00581 210 71811
VCID: 000FAC3A53B741216E0-8055
7 Faults Found:
02483 - Module for Locking of Rear Lid (F327)
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000560
VCID: 397901DE70EDD0E969E-806C
6 Faults Found:
Part No: 1K0 035 186 P
Component: Radio BVX 016 0023
Coding: 0040400
Shop #: WSC 05311 000 00000
VCID: 336533F652812AB9A32-8066
End-------------------------(Elapsed Time: 01:15)--------------------------
