Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 113
Thread: How to emergency Regen while sitting
    Feb 2015
    Hello all, I have a 2012 tdi jetta and i am using the hex net system. I have tried to put my car in a regeneration cycle while sitting using the 27971 code. Once i put that in it wants me to do some sort of peddle combination to initiate the process and i can not figure out the combination for the life of me. Any help would be great. Thanks
    Please post a complete auto-scan..........
    Did you try Brake and Gas full throttle while in basic settings for supported take over of RPM?
    Feb 2015
    VCDS Version: Release 14.10.1 (x64)
    Data version: 20150130
    Saturday,28,February,2015,20:01:02:13775
    Chassis Type: AJ (6N0)
    Scan: 01 03 08 09 15 17 19 25 2E 44 47 56 77
    VIN: 3VW3L7AJ2CM457587   Mileage: 104870km-65163miles
    Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 906 019 EH    HW: 03L 907 309 AA
       Component: R4 2,0L EDC G000SG  3523
       Revision: 12H14---    Serial number:
       Coding: 0050072
       Shop #: WSC 00066 000 00000
       VCID: F5A2ABE49CF47989CD6-80A0
    009315 - Diesel Particle Filter
                   P2463 - 000 - Excessive Soot Accumulation - MIL ON
                        Fault Status: 11100000
                        Mileage: 104860 km
                        Date: 2015.02.28
                        Time: 19:35:46
                        RPM: 2346 /min
                        Speed: 92.0 km/h
                        Pressure: 79 mbar
                        Hex Value: 0xFF01
                        Temperature: 192.0*C
                        (no units): 260.1
                        Mileage: 2550 km
    Readiness: 1 1 0 0 1
       Revision: 00H31001
       Coding: B14B400C492700018D1002EC92200042A71000
       VCID: FDB2B3C464C421C9856-80A8
                        Reset counter: 21
                        Mileage: 104211 km
                        Date: 2015.02.24
                        Time: 00:00:53
                        Count: 2
                        Count: 12800
                        Count: 16390
                        Count: 52224
                        Count: 253
    Address 08: Auto HVAC        Labels: 5C0-820-047.clb
       Part No SW: 5C0 820 047 AQ    HW: 5C0 820 047 AQ
       Component: J301  Klimaanlage   0203
       Revision: 2001010S    Serial number: 00000000917255
       VCID: EFAE998CFEA8435907A-80BA
    Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
       Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
       Component: BCM25 JLB H3  H66 0256
       Revision: B2066001    Serial number: 04371110121185
       Coding: 7B994B9A08AB0B0008382000240884C50082502E60000000300000000000
       VCID: AF2E598CFE28035947A-80FA
       Subsystem 1 - Part No SW: 6R0 959 801 AF    HW: 6R0 959 801 AF  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  004 3464
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 AF    HW: 6R0 959 802 AF  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  004 3464
       Coding: 820000
       Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
       Component: J245 PS41.022  H09 0007
       Coding: 180000
       Subsystem 4 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
       Component: E221__MFL-TAS  H09 0013
       Coding: 020000
       Subsystem 5 - Part No SW: 6R0 959 811 H    HW: 6R0 959 811 H
       Component: J388__TSG_HL  004 3464
       Coding: 800000
       Subsystem 6 - Part No SW: 6R0 959 812 H    HW: 6R0 959 812 H
       Component: J389__TSG_HR  004 3464
       Coding: 800000
                        Reset counter: 19
       Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
       Component: AirbagVW10G   014 0808
       Serial number: 003GTM05H2HP
       Coding: 00003936
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
       ROD: EV_AirbaVW10SMEVW360_SK35.rod
       VCID: B42456E01F0E20813A8-80E1
       Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
       Component: BF-Gewichtss.  H10 0045
       Serial number: 6940000Y120000DEJ30J
       Coding: 303036
       Serial number: 3572MSME5A24606AZZZ-
       Serial number: 3582MSME5B41356CZZZ+
       Serial number: 3516KSME705D2118ZZZQ
       Serial number: 3526KSME1B1C4B18ZZZ$
       Serial number: 3556LSME14266717ZZZS
       Serial number: 3566LSME1C195D17ZZZ1
       Part No SW: 5C6 920 951 A    HW: 5C6 920 951 A
       Component: KOMBI         H04 0604
       Coding: 270A01
       Shop #: WSC 00066 000 00118
       VCID: A91AB794C8CC6D6999E-80FC
    Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
       Part No SW: 6N0 909 901     HW: 5C0 937 087 A
       Component: GW-K-CAN TP20 H66 0256
       Revision: B2066001
       Coding: 102200
       VCID: F0AC9AF023965CA11E0-80A5
       Component: IMMO          H04 0604
       VCID: EA9888980D4AA671504-80BF
    Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
       Revision: A1001003    Serial number: 7661922437
       VCID: A91AB794C0CC6D6999E-80FC
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 70     3305
       Revision: 00H22000
       Shop #: WSC 02069 000 90108
       VCID: B73E61ECC678CB991FA-80E2
       Part No SW: 5C6 035 456     HW: 5C6 035 456
       Component: KonzernAmp10K H07 0468
       Revision: --------    Serial number: EAA083A0015924
       VCID: E582FBA4E45489097D6-80B0
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
       Component: Radio Prem-8  H02 0016
       Revision: -----16S    Serial number: VWZ4Z7M3285691
       Coding: 01020000010006
       VCID: E386E5BCE260F739932-80B6
                000 -  -
                        Reset counter: 70
                        Mileage: 13236 km
                        Date: 2013.02.03
                        Time: 08:01:53
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
       Component: TELEFON       H09 2902
       Revision: 1B001001    Serial number: 00007662015916
       Coding: 0A10040000010110
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_UHVNA A01719
       ROD: EV_UHVNA.rod
       VCID: A71EB1ACDED85B198FA-80F2
    End-------------------------(Elapsed Time: 01:49)--------------------------
    This is my auto scan. I have tried to use the brake and gas but it does not tell me how long to hold each one or just to press each one. I have tried both and it doesnt start anything. I think my calculated soot level may be to high to allow the regen. Calculated soot is at 50.1 and Measured soot level is at 22.8. Thanks
    If soot level is too high it will not allow a regen to prevent a fire.
    Drive the car in a lower gear and raise the RPM for the next couple of days.
    This way it will burn the ash and the air flowing by will cool the cat by convection.
    Add Lubromoly diesel hi-test and purge to the tank.
    Sometimes I run a cup of gasoline per tank in winter.
    Consider changing oil more often with SAE oil and changing air filter more frequently to prevent blow by that causes soot pile up.
    Run the oil level on low side of stick.
    Feb 2015
    Does my soot level seem to high?
  6. #6
    I'm on the road this weekend and don't have numbers handy, but my fuzzy brain thinks it remembers the threshold of "too high" being in the 40s. If that's correct, your calculated value is too high, but measured is not. I also have the notion that people have had better luck with the driving regen than the standing one.
  7. Likes AIB Wolfgang liked this post
    Feb 2015
    Is there any way to trick the ecu that will allow me to for a regen? O thought I seen somewhere you can enter in a value somewhere or a drop down box that tells it you installed a new dpf filter
  9. #8
    May 2014
    Alexandria/fairfax county VA
    45g is the limit for soot, and I am pretty sure the computer treats the problem as greater of [calculated, measured]
    so the computer will not let you start a DPF regeneration cycle, nor will it start one.
    your choices are to remove the DPF, and have it cleaned, (http://www.dpfregeneration.com/ for example), or replace with new.
    You also could lie to the computer so it thinks you have replaced the DPF, and are starting over.
    this would reset the calculated soot, and the measured soot would call for a regen (or you could initiate one if you don't want to wait)
    the danger, of course, with this, is you would be second guessing the VW engineers who think the risk of fire or of destroying the DPF is too great to run a regeneration on the car with over 45g f soot in the DPF.
    you can google up "vw tdi dpf regeneration with too much soot" or such to gather a few hints.
    If it was me, I would replace or have it cleaned.
    how did it get so much soot in the first place? what was the problem?
  10. #9
    May 2014
    VW is pretty clear on not putting anygasoline in a common rail diesel.
  11. #10
    Feb 2015
    Quote Originally Posted by mikeme View Post
    Im on the fence about tricking the ecu. I wanted to save the effort of pulling the filter but i think thats going to be the best way, i have already picked up the dpf gaskets from the dealer, just need to start turning wrenches. Has anyone had any luck cleaning the filter on their own? How long does it take to pull one with proper tools and a lift?
