New to working on 03 Jetta VR6
vwtech
Verified Coal Cracker
Wilkes-Barre, PA
C?ID=7573
Intake Air Temp. Sensor (G42) is in the mass I believe. But not positive on the BDF 24 valve though?
If you cleared codes and this returned I believe only way is new mass.
8.6 % Adaptation (Partial) Bank 1 Sensor 1
Under load (driving) it's lean a little 5% is perfect.
10% is okay by some info. But I am with Jeff in my car 8.6% just won't do... But we are tech's and picky. Real picky with are own cars!!!!
Good Luck
   #22
Chuck L.
C?ID=210737
Thank you,
about 15 miles after posting the last codes the CEL shut off. Have about 20 miles with it off now. I'll keep going and see if they return. I may read them tonight to see what they are now with it off.
   #23
I would really check the spring tension of the MAF connectors and apply stablient 22A or a good contact enhancer.
Maybe tweak with dental pick.
   #24
Chuck L.
C?ID=210737
Ok, Sorry I haven't posted...CEL is still off...Scan today shows the following along with Block 032 info. I have not done anything in the 3 weeks other than run some injector cleaner
Monday,21,April,2014,18:00:38:45566
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: 3VWTH69M53M159772   License Plate:
Mileage: 290270km-180365mi   Repair Order:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
          75 76
VIN: 3VWTH69M53M159772   Mileage: 290270km/180365miles
Address 01: Engine        Labels: 022-906-032-BDF.lbl
   Part No: 022 906 032 CR
   Component: MOTRONIC ME7.1.1G01 0005
   Coding: 00033
   Shop #: WSC 01023
   VCID: 5DB19613D78070F6D01-5140
   3VWTH69M53M159772     VWZ7Z0C6701103
No Faults Found
Address 02: Auto Trans        Labels: 09A-927-750.lbl
   Part No: 09A 927 750 AH
   Component: AG5 Getriebe 09A   0218
   VCID: 71E9DAA33B18E496649-5140
00300 - Transmission Fluid Temp. Sensor (G93)
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 M
   Coding: 0019970
   Shop #: WSC 00028 000 00000
   VCID: 346713B7548A91BE4FF-5140
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 01000
   Shop #: WSC 00028
   VCID: 2149EAE3AB781416B49-5198
   Part No: 1C0 909 605 F
   Component: 04 AIRBAG VW61 0202 0001
   Coding: 12340
   Shop #: WSC 00066
   VCID: 275DF4FBC55CEA26FAD-5122
            32-10 - Resistance Too High - Intermittent
Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
   Part No: 1J0 907 487 A
   Component: Lenkradelektronik   0005
   Coding: 00118
   Shop #: WSC 00028
   VCID: 2F6D1CDBEDACB26632D-5140
   Part No: 1J0 920 926 F
   Component: KOMBI+WEGFAHRSP VDO V65
   Coding: 07234
   VCID: 2D5106D3E7A0C076001-5122
01304 - Radio
            49-00 - No Communications
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00028
   VCID: F0EF5FA7B0126D9EEB7-5122
01304 - Radio
Address 36: Seat Mem. Drvr        Labels: 3B1-959-760.lbl
   Part No: 3B1 959 760 E
   Component: Sitzverstellung     0301
   VCID: 2F6D1CDBBDACB26632D-5106
   Part No: 1C0 959 799 C
   Component: 1H Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 00028
   VCID: 377D24BB15FC7AA66AD-4B00
   Component: 1H Tõrsteuer.FS KLO 0009
   Component: 1H Tõrsteuer.BF KLO 0009
   Component: 1H Tõrsteuer.HL KLO 0009
   Component: 1H Tõrsteuer.HR KLO 0009
 Address 01: Engine  (022 906 032 CR)
18:02:51 Group 032: Lambda Control (Mixture Adaptation)
  -0.8 %  Adaptation (Idle) Bank 1 Sensor 1
  10.2 %  Adaptation (Partial) Bank 1 Sensor 1
            Bin. Bits
            Bin. Bits
vwtech
Wilkes-Barre, PA
C?ID=7573
Still lean a little check for small Vac. leak or bad mass.
while driving or under load 10.2% is a little high but with no light is okay.
I think software should be updated to 0006 at least.
Do you have a warm restart stall? Or a low idle after a warm restart? If so update should fix it.
Ask Jack about that he knows more on this.
Good luck
   #26
Yup post 4.......... said that.
Very common for combi line to leak at line on VR kraut box......do to dry rot and heated area.
   #27
Chuck L.
C?ID=210737
I will still hunt for a vacuum leak, especially on the Combi line...when I can get the time to pull the front.
I do occasionally have an issue where the idle is low or it stalls out during a warm restart. How do I go about upgrading the software? Jack is just a little out of my way :) Replacing the ECU sounds a bit expensive
Chuck
   #28
vwtech
Wilkes-Barre, PA
C?ID=7573
You don't need a new ECU just the software inside it needs to be updated to current level.
You can try and looking in your area but not many people can do it right. Dealer can but is like pulling teeth!
It hurts and they are a pain to deal with! At least my local dealer is!
You can pull the ECU and ship it to Jack the turn around is a few days.
I have sent him a few because the dealer here sucks! He does them the same way official V.W. updates.
The time and tools he has to buy are not cheap. Jack is Jack. You love him or hate him... But he's good and does it right!
Jack spends a lot of time helping others for free with advice. So I try to give back, if I need an update he deserves the work and he's earned it!
Good Luck
   #30
Chuck L.
C?ID=210737
HI,
I've been busy and the weather hasn't really cooperated for taking the car apart, So I still haven't looked for any leaks. The CEL is still out and the car passed inspection.
I will have to look around here for a dealer that may upgrade the software. Sending the ECU to Jack would be a little tough as this is my daily driver and it would take some planning in order to send it to him.
Chuck
   #32
Chuck L.
C?ID=210737
Been really busy..no time to do much..
vwtech..I had read that post of yours and it made me worried about having dealers do it
   #33
vwtech
Wilkes-Barre, PA
C?ID=7573
I really can't say all the dealer are this way. All I know is my local dealer doesn't know what they are doing or they just lie to get you out the door.
If you do go to your local dealer please post the results it my post. Thanks.
I will be sending it out to Jack as soon as the customer can come off the car for a few days. The UPS turn around is a few days.
Good Luck
