Results 1 to 1 of 1
Thread: Automatic Transmission Procedures in Pictures
    Administrator Andy's Avatar
    Sector 7G
    This is an example of transmission kickdown on a 2001 Eurovan VR6:
    http://www.ross-tech.com/vag-com/cars/autotrans.html
    Basic Settings:
    Basic Settings should be performed on an Automatic Transmission after:
    Engine replacement .
    ECU replacement
    Throttle Valve adjustment
    TPS replacement
    TPS adustment
    TCM Replacement
    First, make sure there are no fault codes in the Auto Trans. Then, with the key in the on position, and engine OFF. Do not touch the accelerator pedal.
    [Select]
    [02 - Auto Trans]
    [Measuring Blocks - 08]
    In the top left Group field enter "000" and Click [Go!]
    Click on [Switch to Basic Settings]
    Press and hold the accelerator all the way to the floor for at least 3 seconds (doesn't hurt to go longer):
    Click on [Switch to Meas. Blocks]
    Take your foot off the accelerator pedal:
    Click on [Done, Go Back]
  2. Likes Sebastian, Mari, DrPeter liked this post
