I'm at a complete loss on diagnosing this thing any further. This car will start and idle just fine, and leave the driveway and cruise just fine. All of a sudden i will lose all power as if the key was cut off for a TENTH of a second. The car will of course buck and the EPC and CEL light will kick on. Also if im running VCDS, i will lose comms with the module im logging (in this case engine). Its clear the ECM is losing power because if i had a check engine light pre-existing, it would be gone. It is very hard to reproduce this error but it is prone to doing it when shifting BUT NOT ALWAYS sometimes its just under slow accel. All this is kinda telling me a connection is lose but i've SCOURED and found every connection and come up empty. The only connection i can not find is ground connection 121. All it says is it's "Ground Connection 2 (in right front wiring harness)". I've replaced the Fuel and ECM relays.
Below are my codes, luckily the ABS module caught something
Also this happens with the MAF unplugged as well. Granted its not as bad, it still does it between shifts and at throttle tip-in.
VCDS Version: Release 14.10.1 (x64)
Data version: 20150130
USRT
Tuesday,17,February,2015,20:18:44:00899
67 69 75 76 77
VIN: WAUGL58E35A520761 Mileage: 146530km-91049miles
Address 01: Engine Labels: 079-910-560-BBK.lbl
Part No SW: 8E0 910 560 K HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number:
Coding: 0007711
Shop #: WSC 06335 000 00000
VCID: 2D51D6BAB412BD49F56-8078
Readiness: 0000 0101
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 C HW: 8E0 614 517 BB
Component: ESP8 quattro H04 0180
Coding: 0004901
VCID: 275D249296EE97190FA-8072
01312 - Powertrain Data Bus
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Part No: 8E0 820 043 AM
Component: A4 Klimaautomat 2731
Coding: 00000
VCID: 6CD71BBE1C887441A28-5124
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 J
Component: int. Lastmodul USA 0503
Coding: 01023
Shop #: WSC 65536
VCID: 3979F2EA235A11E969E-4B00
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036N000CWJ9
Coding: 0032707
VCID: 3C77EBFE7F6824C1728-8069
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 02 0070
Serial number: 6332DRB401818618G
Coding: 00032707
Subsystem 2 - Serial number: 6342DRB401829425F
Subsystem 3 - Serial number: 6352ARB4003B259CO
Subsystem 4 - Serial number: 6362ARB4003B62308
Subsystem 5 - Serial number: 63729RB4005238089
Subsystem 6 - Serial number: 63829RB400523AC9P
9 Faults Found:
01794 - Control Module - Incorrect Chassis (VIN) Number
00532 - Supply Voltage B+
01639 - Crash-Sensor for Side Airbag; Rear Passenger Side (G257)
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 02041
Shop #: WSC 06335
VCID: 41899A0A4B8A492921E-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 981 Q HW: 8E0 920 981 Q
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0023201
Shop #: WSC 02301 444 10073
VCID: 3B75E8E2796623F97B2-5124
6 Faults Found:
01771 - Control Module for Headlight Range (J431)
01304 - Radio
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023201
VCID: 3B75E8E2796623F97B2-5142
6 Faults Found:
01304 - Radio
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
VCID: 71E90ACA3BAA99A991E-4AE8
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 E HW: 8E0 035 192 E
Component: RNS-E HIGH EU H54 0650
Revision: 03S Serial number: AUZBZ7E1501313
Coding: 0309137
VCID: 2643299692E48E1134C-515E
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BT
Component: Komfortgerát T7B 3232
Coding: 16232
Shop #: WSC 06335
VCID: 0407531E14189C014A8-4AE8
Subsystem 1 - Part No: 8E1959801F
Component: Tõrsteuer.FS BRM 1315
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
17 Faults Found:
37-10 - Faulty - Intermittent
35-00 - -
35-00 - -
35-00 - -
01574 - Alarm triggered by Door Contact Switch; Rear Right
35-00 - -
00955 - Key 1
35-10 - - - Intermittent
00956 - Key 2
35-00 - -
01403 - Glass-Break Sensors; Rear
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Coding: 0000019
Shop #: WSC 01041 444 52566
VCID: 285F27AE9BF09861060-807D
Subsystem 1 - Part No: 8E0 941 329 A
Component: AFS-Modul links H05 0030
Subsystem 2 - Part No: 8E0 941 329 A
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0309137
End-------------------------(Elapsed Time: 07:11)----------------------
