- Joined
- Feb 6, 2020
- Messages
- 77
- Reaction score
- 42
- Location
- New Zealand
- VCDS Serial number
- C?ID=380572
Hi All
Seeking some suggestions on where to go from here;
Have a well maintained (by us) Audi S6 V10 that has intermittent multiple cylinder/random cylinder misfires. Seems to have no pattern as to when - can be hot, cold, at idle, driving, cruising etc. Has over time affected all cylinders, and none seem to be more common than others.
Can happen several times in a day, or not at all for 3 months - car is driven several times a week.
We have done the following in the last 10,000kms (some of this for this fault, some of it for maintenance or at owners request) and nothing has made any difference whatsoever.
Replaced all spark plugs (Genuine)
Replaced all ignition coils (Genuine)
Replaced RH HP fuel pump (was leaking)
Removed and cleaned throttle body, intake manifold and back of valves.
Had ECUs reflashed for more power. (Customer request)
Autoscan from today when he popped back in and said it had happened a couple of times.
Any suggestions as to where to next would be appreciated.
Regards
Dan
Thursday,13,August,2020,15:50:41:56060
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
Dealer/Shop Name: Topp Motors
VIN: WAUZZZ4F77N165022 License Plate: FAF246
Mileage: 117370km-72930mi Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 11 31 15 16 17 19 1E 36 42 46 47 4F
52 53 55 56 57 61 62 6C 72 76 77
VIN: WAUZZZ4F77N165022 Mileage: 117370km-72930miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
Address 01: Engine Labels: None
Part No SW: 4F7 910 552 HW: 4F1 907 552
Component: 5.2L V10/4V FSI ª0010
Revision: 59H14--- Serial number:
Coding: 01050003190F0160
Shop #: WSC 08646 001 1048576
VCID: 678BBB4243607BF3F39-8032
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Mileage: 117377 km
Temperature: 92.0°C
Temperature: 20.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.192 V
Part No SW: 4F2 910 156 M HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI RdW 0030
Revision: --H01--- Serial number: 0105976
Shop #: WSC 02325 758 00200
VCID: 2F3B1362AB10E3B3FB9-807A
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 P HW: 4F0 614 517 P
Component: ESP 8.0 quattro H05 0070
Coding: 0020920
VCID: 313F151ABD24F543EDD-8064
Part No SW: 4F0 910 852 A HW: 4F0 905 852 C
Component: FBSAUDIC6 ELVSG H01 0030
Revision: 31050601 Serial number: 10601200744963
Coding: 0000019
Shop #: WSC 02323 758 00200
VCID: 2411EC4EF2D650EB16B-8070
Subsystem 1 - Part No: 4F0 910 131 A
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 731 S HW: 4E0 035 729 A
Component: Interfacebox H43 3450
Revision: 00000000 Serial number: 351DN077545550
Coding: 0010002
Shop #: WSC 02335 758 00200
VCID: 323D1A16B822CE5B947-8066
Subsystem 2 - Serial number: 00000000789107
Subsystem 3 - Serial number: 0121.06.070000000100010451ÿ
Subsystem 4 - Serial number: 010451ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F2 820 043 Q
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000030238253
Coding: 0525386
VCID: 1C61D4AECAA6682BAEB-8048
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Coding: 0115101
VCID: 3039101EB62EFC4BE23-8064
Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H04 0190
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 (R192) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 HW: 4E0 035 785
Component: SG ext.Player H09 0170
Revision: 00000000
VCID: 6597B14AB56C69E3C15-8030
Address 11: Engine II Labels: None
P0300 - 008 - - Intermittent - MIL ON
Fault Status: 10101000
Mileage: 117306 km
Date: 2020.08.10
Time: 11:25:05
RPM: 1140 /min
Load: 28.2 %
Temperature: 31.0°C
Temperature: 21.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.970 V
000771 - Cylinder 3
P0303 - 008 - Misfire Detected - Intermittent - MIL ON
Mileage: 117306 km
Date: 2020.08.10
Time: 11:25:05
RPM: 1140 /min
Load: 28.2 %
Temperature: 31.0°C
Temperature: 21.0°C
Voltage: 13.970 V
000772 - Cylinder 4
P0304 - 008 - Misfire Detected - Intermittent
Mileage: 117306 km
Date: 2020.08.10
Time: 11:25:05
RPM: 1140 /min
Load: 28.2 %
Temperature: 31.0°C
Temperature: 21.0°C
Voltage: 13.970 V
000777 - Cylinder 9
P0309 - 008 - Misfire Detected - Intermittent - MIL ON
Mileage: 117306 km
Date: 2020.08.10
Time: 11:25:05
RPM: 1140 /min
Load: 28.2 %
Temperature: 31.0°C
Temperature: 21.0°C
Voltage: 13.970 V
000775 - Cylinder 7
P0307 - 008 - Misfire Detected - Intermittent
Mileage: 117345 km
Date: 2020.08.12
Time: 06:34:58
RPM: 1154 /min
Load: 28.6 %
Temperature: 31.0°C
Temperature: 20.0°C
Voltage: 14.097 V
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4F AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0RKLL4
Coding: 0013382
VCID: 290FFD7A95F48D8325D-807C
Subsystem 1 - Serial number: 6332CSME19690D166
Subsystem 2 - Serial number: 6342CSME17680513-
Subsystem 3 - Serial number: 6352QSME292C3A6DY
Subsystem 4 - Serial number: 6362QSME2C4D1E43V
Subsystem 5 - Serial number: 63734SME294D1C4BE
Subsystem 6 - Serial number: 63834SME23741A3B0
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Revision: 00H08000 Serial number: 90055071160314
Coding: 0112141
VCID: 6695B646446A62FBC8F-8032
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 931 G
Component: KOMBIINSTR. M73 H20 0170
Revision: 00400000 Serial number: 5H156LH47
Coding: 2113848
Shop #: WSC 00000 000 402950
VCID: 2313EF52F7D857D36F1-8076
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B0741080C8
Coding: F5D1DEF7701606
Shop #: WSC 02334 758 00200
VCID: 6C81C46E5A8658AB9EB-8038
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H44 0350
Revision: 00044000 Serial number: AUZ5ZBG3225267
VCID: 1869C8BE3E9E040B8A3-804C
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0091138
VCID: 619FA55AAD4405C33DD-8034
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0210
Revision: 00000000 Serial number: †“i
Coding: 0002810
Shop #: WSC 02327 758 00200
VCID: 2C01046E9A0698ABDEB-8078
01705 - Selection Switch for Mirror-Adjust (E48)
Reset counter: 221
Mileage: 116421 km
Date: 2020.05.25
Time: 09:03:12
02123 - Door Warning Light / Entry Light
Fault Status: 00101100
Fault Frequency: 14
Reset counter: 221
Mileage: 116421 km
Date: 2020.05.25
Time: 09:11:49
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01042619050000
Coding: 0139761
VCID: 2E050E66AC1AEABBF0F-807A
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000026785
Coding: 0000017
VCID: 2517F14AF9ECA9E3015-8070
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000334962
Coding: 0011104
VCID: 5EE59EA69C3A3A3B00F-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0210
Revision: 00000000 Serial number: 9bp
Coding: 0002810
Reset counter: 221
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0008021
VCID: 2019E05EE6CE4CCB723-8074
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000016
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Revision: 00000000 Serial number: 394DX077764109
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 F HW: 4E0 919 146 C
Component: TV analog TUNER H15 0290
Revision: 00000089 Serial number: 00000000010098
Coding: 0000010
Address 61: Battery Regul.
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0002090
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J732002
Coding: 1020204
VCID: 5DE799AA913C2123195-8008
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0002090
Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
Component: Parkhilfe 8-Kan H12 0060
Revision: 00H12000 Serial number: 06330712404877
Coding: 0221106
VCID: 2809F87E8EFEB48B3A3-807C
02069 - Front Parking Aid Sensors
Fault Status: 00101011
Reset counter: 221
Mileage: 116421 km
Date: 2020.05.25
Time: 10:50:37
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 A HW: 4F1 862 335
Component: BTA H09 0710
Revision: 00H09000 Serial number: 00000007534127
Coding: 1040091
VCID: 221DEA56E8C25EDB647-8076
End----------(Elapsed Time: 02:17, VBatt start/end: 12.4V/14.4V)-----------
Regards
Dan
