Main Menu - missing entry Convenience
tlchzj79
C?ID=77738
In which control module can I change settings to make the "Conveniece" entry visible in the Main Menu ?
 Tuesday,14,May,2019,16:07:27:21620
VCDS Version: 17.8.0.1
VIN: WVGBV95N79W004569   License Plate: BB
Mileage: 55070km-34218mi   Repair Order:
Chassis Type: 5N (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 22 25 36 42 44 46 47 4F 52
          53 55 56 62 65 72
VIN: WVGBV95N79W004569   Mileage: 55070km-34218miles
65-Tire Pressure -- Status: Not registered 0011
   Part No SW: 06J 906 026 H    HW: 06J 906 026 AF
   Component: MED17.5 TFSI 2,0    3322
   Revision: AAH03---    Serial number: VWX7Z0H23NS02Y
   Coding: 0423010A190F0160
   Shop #: WSC 07807 444 69274
   VCID: 2F4241C2BE49383E23-807A
   Part No SW: 09G 927 750 GG    HW: 09G 927 750 GG
   Component: AQ 250 6F           1174
   Revision: 00H76000    Serial number:
   Coding: 0000840
   Shop #: WSC 01324 785 00200
   VCID: 7CD8A68E3FBF13A6D6-8028
Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
   Part No SW: 5N0 614 517 L    HW: 5N0 614 517 L
   Component: J104    C2 450 V2   0006
   Revision: --H11---    Serial number: 00000001034628
   Coding: 0002332
   VCID: 375279A24619F0FE7B-8062
   Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: 6DFE9BCA74C58A2E51-8038
00716 - Air recirculation Flap Positioning Motor (V113)
            000 -  -
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Revision: 00H54000    Serial number: 01000008282884
   Coding: E78C8FA340041C004719000014000000007AF7475C400125390000000000
   Shop #: WSC 00001 001 00001
   VCID: 71C687BA68FD6ECE75-8024
   Subsystem 1 - Part No: 5N1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 030408  012 0203
   Coding: 00038805
   Shop #: WSC 00001
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     110408 046  0204
   Coding: 00208933
   Shop #: WSC 00001
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0284634
   Coding: 0000100
   VCID: 334A4DB252611CDE47-8066
   Part No SW: 5N0 959 655 B    HW: 5N0 959 655 B
   Component: J234__202 VW10 HI   1815
   Revision: 19013000    Serial number: 0039EP4G54D7
   Coding: 0012338
   VCID: 3C58668E7F3FD3A696-8068
   Subsystem 1 - Part No: 5N0 959 339 A
   Component: BF-Gewichtsens. 001 0004
   Subsystem 2 - Serial number: 000000000007X3
   Subsystem 3 - Serial number: 0017.02.080000100000850061ˇÜ63
   Subsystem 4 - Serial number: 850061ˇÜ6333FTS669500808 ˇÜ63
   Subsystem 5 - Serial number: 00808 ˇÜ6343FTS614690818 ˇÜ63
   Subsystem 6 - Serial number: 90818 ˇÜ6353ETS6H66TSVNH ˇÜ63
   Subsystem 7 - Serial number: TSVNH ˇÜ6363ETS65QCTSVNP ˇÜ63
   Subsystem 8 - Serial number: TSVNP ˇÜ6373JTS64LFQSVNP ˇÜ63
   Subsystem 9 - Serial number: QSVNP ˇÜ6383JTS6TEMQSVNP ˇ
   Subsystem 10 - Serial number: QSVNP ˇ
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Component: J0527           752 0101
   Coding: 0012022
   VCID: 78D0BA9E0B873F86B2-802C
00576 - Terminal 15
            015 - Cannot Be Tested at this Time - MIL ON
00885 - Ignition Switch (D) Terminal 50
   Part No SW: 5N0 920 970 E    HW: 5N0 920 970 E
   Component: KOMBIINSTRUMENT VDD 2222
   Revision: V0004000    Serial number: VWX7Z0H23NS02Y
   Coding: 0007204
   Part No SW: 1K0 907 530 N    HW: 1K0 907 951
   Component: J533  Gateway   H06 0052
   Revision:   H06 01    Serial number: 310308F2024377
   Coding: FD83FF061013036002
   Shop #: WSC 00002 002 00002
   VCID: 324448B6AD7B15D64C-8066
            000 -  -
                    Mileage: 53177 km
                    Time: 18:54:05
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0003
   Revision: 00001000    Serial number: 1225223T32LD03
   VCID: 7DDEAB8A24A51AAEE1-8028
   Part No SW: 0AY 907 554 B    HW: 0AY 907 554 B
   Component: Haldex 4Motion      0039
   Coding: 0000005
   VCID: 4AB4305625EB7D1614-801E
   Component: IMMO            VDD 2222
   Shop #: WSC 37401 136 81825
   Part No SW: 5N0 959 760 A    HW: 5N0 959 760 A
   Component: MEM-FS        H04 0032
   Revision: AA000000    Serial number: 00001001076906
   Coding: 20581300000044440011
   VCID: 38507A9E8B07FF8672-806C
   Part No SW: 5N0 959 701 A    HW: 5N0 959 701 A
   Component: Tuer-SG         006 1205
   Coding: 0001471
   Part No SW: 5N1 909 144 F    HW: 5N1 909 148 D
   Component: J500__APA-BS KL.051 0401
   Revision: 1AH03249    Serial number: 00080090004201
   Coding: 0000258
   VCID: 354E73AA5C1502EE69-8060
   Component:    KSG PQ35 RDK 052 0222
   Coding: 1280078852830C1B1B040587B0888F0C88DCA0
   VCID: 0428DE6E474F6B66AE-8050
00332 - Control Circuit for Tank Flap
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 68
                    Mileage: 51630 km
                    Time: 10:38:16
Address 47: Sound System        Labels: None
   Part No SW: 5N0 035 466 A    HW: 5N0 035 466 A
   Component: DSP 10 Kanal        0040
   Revision: 00H05001    Serial number: 75820000290302
   VCID: 2C7856CE8F5F432606-8078
Address 4F: Centr. Electr. II (J533)       Labels:. 1K0-907-532.clb
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Coding: 050B0500
   VCID: 66ECE4E69133B97610-8032
   Subsystem 1 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB09  H01 0170
   Subsystem 2 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J394EE16SKB09  H01 0170
   Part No SW: 5N0 959 702 A    HW: 5N0 959 702 A
   Coding: 0001470
   VCID: 34484EAE576F1BE65E-8060
   Part No SW: 5N0 907 801 B    HW: 5N0 907 801 B
   Component: J540 EPB3  VW-09384 0005
   Revision:   H08       Serial number: 00000000053118
   Coding: 0000057
   VCID: 2E7C5CC6B943313628-807A
   Part No SW: 5M0 907 357 B    HW: 5M0 907 357 B
   Component: AFS-Steuergeraet    X024
   Revision: 00H01000    Serial number:
   Coding: 1357062
   Component: AFS-Lst.-Modul l    S002
   Coding: 00000020
   Component: AFS-Lst.-Modul r    S002
   Coding: 00000020
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio PM6       019 0036
   Revision: 00019000    Serial number: VWZ5Z7H2222949
   Coding: 0010011
   VCID: 2976AFDA80AD560EFD-807C
   Part No SW: 5N0 959 703 A    HW: 5N0 959 703 A
   Component: Tuer-SG         006 1301
   Coding: 0001168
   Shop #: WSC 01324 785 1012552
   Component:    RDK              0450
   Coding: 0100100
                    Reset counter: 89
                    Mileage: 54626 km
                    Time: 09:32:50
   Part No SW: 5N0 959 704 A    HW: 5N0 959 704 A
   Coding: 0001168
   VCID: 364C74A6411309F660-8062
End-------------------------(Elapsed Time: 02:07)--------------------------
https://drive.google.com/file/d/12hMn7ByjYItemrRNtunCkWn2rB3vbuxS/view?usp=sharing
tlchzj79
C?ID=77738
Thanks PetrolDave
It is a Tiguan 5N Model 2009 USA / Year 2008 / imported to Germany
The problem with the missing entry "Convenience" is from the beginnig when I got the car.
Here the latest autoscan
Tuesday,11,August,2020,11:39:19:21620
VCDS Version: 20.4.2.0 (x64)
Dealer/Shop Name: Axel's Garage
Workshop Code: 000 00001 000001
VIN: WVGBV95N79W004569   License Plate: BB HA 4642
Mileage: 60380km-37518mi   Repair Order: 1
          53 55 56 62 65 72
VIN: WVGBV95N79W004569   Mileage: 60380km-37518miles
65-Tire Pressure -- Status: Not registered 0001
   VCID: 2F4241C2BE4938FEBA-807A
   Coding: 0000840
   VCID: 7CD8A68E3FBF13664F-8028
   Coding: 0002332
   VCID: 375279A24619F03EE2-8062
   VCID: 6DFE9BCA74C58AEEC8-8038
   VCID: 71C687BA68FD6E0EEC-8024
   Coding: 00038805
   Shop #: WSC 00001
   Coding: 00208933
   Shop #: WSC 00001
   Coding: 0000100
   VCID: 334A4DB252611C1EDE-8066
   Coding: 0012338
   VCID: 3C58668E7F3FD3660F-8068
   Coding: 0012022
   VCID: 78D0BA9E0B873F462B-802C
00576 - Terminal 15
   Coding: 0007204
   VCID: 324448B6AD7B1516D5-8066
                    Mileage: 59945 km
                    Time: 14:14:26
   VCID: 7DDEAB8A24A51A6E78-8028
   Coding: 0000005
   VCID: 4AB4305625EB7DD68D-801E
   VCID: 38507A9E8B07FF46EB-806C
   Coding: 0001471
   Coding: 0000258
   VCID: 354E73AA5C15022EF0-8060
   VCID: 0428DE6E474F6BA637-8050
   VCID: 2C7856CE8F5F43E69F-8078
   Coding: 050B0500
   VCID: 66ECE4E69133B9B689-8032
   Coding: 0001470
   VCID: 34484EAE576F1B26C7-8060
   Coding: 0000057
   VCID: 2E7C5CC6B94331F6B1-807A
   Coding: 1357062
   Coding: 00000020
   Coding: 00000020
   Coding: 0010011
   VCID: 2976AFDA80AD56CE64-807C
   Coding: 0001168
   Component:    RDK              0450
   Coding: 0100100
   Coding: 0001168
   VCID: 364C74A641130936F9-8062
End-------------------------(Elapsed Time: 02:08)--------------------------
The problem with the missing entry "Convenience" is from the beginning when I got the car.
view
Is it even supposed to appear in the menu on the DIS/FIS?
tlchzj79
C?ID=77738
NEtech
C?ID=56995
Test if you should have Adaptation channel 82 in [17-Instrument].
If so, change new value, to 2 or 1, if possible.
tlchzj79
C?ID=77738
@NEtech - no I don't have Adaptation Channel 82 in [17-Instrument]
the booklet which originally came with the car explicit shows the "Convenience" entry in the Main Menu.
But it isn't there.
Obviously a mismatch of Owners Manual (Booklets) and installed resp actiated features. See picture below.
https://drive.google.com/file/d/1ogQVvhrwBsvXbDl0IX-o7yYJY6Vzym_1/view?usp=sharing
Manuals cover all possible options and are not specific to the individual car, so it's normal for things to appear in the manual that don't appear on the car.
tlchzj79
C?ID=77738
Meanwhile I found the coding for a function I was hoping to see it in the Main Menu.
Control Modul "Central Convenience" support dozens of functions to activate or deactivate.
The function I activated: open and close windows withe the Remote
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
There is a Low line and High line CCM, and in low line you will not have access to Convince via Instrument cluster . So most likely you have Low Line CCM.
tlchzj79
C?ID=77738
Main Menu - Entry "Convenience" missing
@ Jetta,97 - thank you that's the point
Axel
volkar
Estonia
C?ID=277260
By scan it show lebel of max CCM
and there is byte 18 bit 5 "Instrument Cluster > Comfort Menu inactive"
try to change it
siLc
Tallinn, Estonia
C?ID=330192
This here's a highline module. See autoscan...
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
MIN for lowline.
tlchzj79
C?ID=77738
volkar
Estonia
C?ID=277260
This is what I have:
Controler 17 Instrument
Software Coding (0 - 8388607) Value 0007204 (see picture)
https://drive.google.com/file/d/1SLze0Y8v19KOwkESccnhTJUz3IbPm40s/view?usp=sharing
There is no Byte 18 !
The scan I supplied is from Tiguan 5N (US Model 2.0 T 147 kW / 200 PS)
nono, You need check CCM
tlchzj79
C?ID=77738
@ Volkar - thank You !!
that did the trick
Coding: 1280078852830C1B1B040587B0888F0C88DC80
Now I can see and set entries in the convenience menu
