- Joined
- Aug 9, 2020
- Messages
- 2
- Reaction score
- 0
- Location
- Austin, TX, USA
- VCDS Serial number
- C?ID=413584
This is my first post after scanning the forums to no avail. Perhaps you can help!
THE VEHICLE
2012 VW GTI 2.0T 2DR Stage 2 APR
ISSUES PRIOR
It currently throws a 'Check your gas cap" light but it's the purge valve which I have - but not replaced yet
WHAT HAPPENED
Honestly? ugh - ok, I have been running around in this little rocketship forever and finally got a chance to open it up. On the Extraterrestial Highway in Nevada I had 5 miles of flat pavement and no traffic. The car hit 157mph @ 6200 rpm - good stuff, so before I blew it up, or hit a pebble and went flying off the road, I slowed down to stop.
As soon as I stopped, BING BING BING... the following dash lights illuminated;
Steering wheel (malfunction in power steering or electronic steering column lock)
Air Bag
ABS
ESC
TPMS
I checked the OBD and it reported no codes (so there is that anyway)
I tried clearing the TPMS from the glovebox but nothing
I tried disabling traction control but nothing
Now the strange part - sometimes some or all of those lamps will go out as if the car is fine, but generally they all come on within seconds of each other after 5mph.
Does anyone have ANY idea whats up? all of them all at once?? I'm maggoo'd on this end - it runs, stops, and starts fine, but those lights remain. I'm frankly stumped
Mike
THE VEHICLE
ISSUES PRIOR
WHAT HAPPENED
Air Bag
ABS
ESC
TPMS
Mike
Friday,07,August,2020,15:13:06:14911
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
VIN: WVWED7AJ3CW349147 License Plate: QUICKSCAN
Mileage: 101200km-62882mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 77
VIN: WVWED7AJ3CW349147 Mileage: 101200km-62882miles
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AT HW: 1K0 907 115 AK
Component: 2.0l R4/4V TFSI 0010
Revision: E3H26--- Serial number:
Coding: 0403010818070160
VCID: 78A9ECD15ED0E83B6A3-802C
U1017 - 007 -
Fault Status: 01100111
Fault Frequency: 38
Mileage: 98856 km
Date: 2014.12.24
Time: 12:55:02
RPM: 3255 /min
Load: 20.8 %
Speed: 133.0 km/h
Temperature: 96.0°C
Temperature: 48.0°C
Absolute Pres.: 840.0 mbar
Voltage: 13.208 V
001109 - EVAP System
P0455 - 000 - Large Leak Detected - MIL ON
Fault Status: 11100000
Mileage: 100975 km
Date: 2014.12.28
Time: 09:34:44
RPM: 2343 /min
Load: 7.1 %
Speed: 63.0 km/h
Temperature: 93.0°C
Temperature: 56.0°C
Absolute Pres.: 920.0 mbar
Voltage: 13.208 V
Readiness: 0010 0001
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 114B600C49260003880C06E892200041B70800
VCID: 7BA3F3DD63E6C323071-802E
02214 - Tire Pressure Warning
Reset counter: 180
Mileage: 94577 km
Date: 2014.10.19
Time: 17:49:19
Count: 24
Count: 32768
Count: 12800
Count: 16401
Count: 49664
Count: 507
03543 - Mechanical Malfunction in Suspension
Reset counter: 210
Mileage: 100902 km
Date: 2014.12.27
Time: 14:35:43
Count: 4608
Count: 16389
Count: 47617
Count: 255
Fault Status: 00100011
Fault Frequency: 37
Reset counter: 174
Mileage: 98815 km
Date: 2014.12.24
Time: 12:31:04
Count: 17472
Count: 32768
Count: 12800
Count: 85
Count: 47362
Count: 255
Count: 231
Count: 7680
Reset counter: 170
Mileage: 98815 km
Date: 2014.12.24
Time: 12:31:36
Count: 3
Count: 12800
Count: 16390
Count: 47360
Count: 1533
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0404
Revision: 00001018
Coding: 0000001002
VCID: 005984310A80A0FB523-8054
Address 09: Cent. Elect.
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA27VWU
Coding: 00003131
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3FDB47CD37FE1F036B9-806A
Subsystem 1 - Part No SW: 5K0 959 339 B HW: 5K0 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--00003TL300
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME1227656EZZZ-
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME1001626EZZZO
Serial number: 3512QSME6C1C1179ZZZ/
Serial number: 3522QSME7C0A1315ZZZV
Component: F.Sens.Fahr --- ----
Serial number: 35527SME3C48402CZZZL
Component: F.Sens.Beif --- ----
Serial number: 35627SME68040F2CZZZO
9483008 - Seat Occupied Recognition
B10B3 00 [008] - Function Restriction due to Implausible Message(s)
Fault Frequency: 44
Reset counter: 215
Mileage: 98815 km
Date: 2020.08.02
Time: 12:31:46
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440LE30001F
Coding: 108A140000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 72BDDEF9342C826B547-8026
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0033
Serial number: 0060925
Coding: 820000
448275 - Multi-Function Switches in Steering Wheel; Right
B114C 96 [008] - Component internal failure
Reset counter: 212
Mileage: 100971 km
Date: 2020.08.06
Time: 08:59:24
Part No SW: 5K6 920 972 C HW: 5K6 920 972 C
Component: KOMBI H03 0607
Coding: 270F01
VCID: 363522E918C4DE4BB8F-8062
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 290412F1001730
Coding: 350000
VCID: 3A2D36D92C5C3A2B5C7-806E
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 002 0002
Revision: 00002000 Serial number: 1225223RJ1TN07
VCID: 7EA5FAC97CF4D60B20F-802A
Component: IMMO H03 0607
VCID: 6A8DC6991CFC4AABEC7-803E
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7662495158
VCID: 290FF995D9FA81B325D-807C
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2117
Coding: 0001076
VCID: 313F11F5FD2AF973EDD-8064
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 74 3305
Revision: 00H22000
VCID: 372B2FED134E2743A39-8062
Fault Status: 00101101
Fault Frequency: 42
Reset counter: 215
Mileage: 101172 km
Date: 2014.12.29
Time: 13:40:20
Voltage: 13.63 V
DU
Temperature: 48.0°C
RPM: 3149 /min
Speed: 45.0 km/h
Speed: 45.0 km/h
Address 46: Central Conv.
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001076
VCID: 323D1EF9F82CC26B947-8066
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7M1117330
Coding: 01000400040005
VCID: 6393ABBDFB561BE32F1-8036
Reset counter: 242
Mileage: 87939 km
Date: 2014.02.20
Time: 13:26:43
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007662448063
Coding: 0A10040000010100
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 270BFFADCF6EB7C3339-8072
End----------(Elapsed Time: 00:53, VBatt start/end: 13.1V/13.1V)-----------
