Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: PLEASE HELP with 2013 facelift A4 coding fix, post Bi-Xenon conversion.
  1. #21
    Jan 2017
    Interesting project. I completed something similar. My methodology was to first get the schematics of the stock with upgrade HID system, then integrating my hardware and the cabling I purchased to make sure it matches. Then I took the scans and coding of the modules from stock upgrade HID system and compared my coding and made changes to those channels that were different. Then I worked each problem as it came up. This is the DIY of my project. http://www.golfmk7.com/forums/showthread.php?t=29237
  2. Likes Uwe liked this post
  3. #22
    Mar 2017
    Poland
    any chance to someone resolve my problem ??
    this fault automaticaly exist if I change coding in byte 31 from 00 to 01 (xenon)
  4. #23
    Jan 2015
    Bosnia and Herzegovina
    try byte 31 hex 02
    also for drl check byte 02
  5. #24
    Mar 2017
    Poland
    I trying byte31
    01 xenon
    02 afs
    my drl working 100%
  6. Likes Uwe liked this post
  7. #25
    Nov 2014
    Bucharest Romania
    Autoleveling
    Quote Originally Posted by milkatrek View Post
    I trying byte31
    01 xenon
    02 afs
    my drl working 100%
    Did you find a solution?
    I have same situation'
    Thank you
    Vipers
  8. #26
    Nov 2018
    Romania
    Hi. I have the same problem as milkatrek after retrofitting a 2013 A4 B8.5 from halogen to bixenon headlamps.
    The error reported by the VCDS on 09-Cent. Elect. is ,,01312 - Powertrain Data Bus 004 - No Signal/Communication", and the ,,Range control defective" message on DIS. The headlights are performing the auto-leveling test after deleting de 09-Cent. Elect. error, but after turning on the engine, the auto-leveling test isn't performed.
    Chassis Type: 8K-AU48 (8R0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 42 44 46 47 52 53 56 5F 62
              6C 72
    VIN: WAUZZZ8K2EA005884   Mileage: 198440km-123304miles
    Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 JJ    HW: 03L 906 018 JL
       Component: R4 2.0l TDI   H25 9978
       Revision: 45H25---
       Coding: 12034012232401080000
       Shop #: WSC 42803 002 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018JJ 003010
       ROD: EV_ECM20TDI01103L906018JJ.rod
       VCID: 7BB60FD9F2BC7797F2-802E
    Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
       Part No SW: 8K5 927 155 L    HW: 0AW 927 156 K
       Component: 0AW 20TDI RdW H05 0001
       Revision: --H05---    Serial number: 0000001112
       Coding: 000002
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMVL381 A02433
       ROD: EV_TCMVL381.rod
       VCID: 41CABD31D0D0DD47E8-8014
    Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
       Part No SW: 8K0 907 379 CE    HW: 8K0 907 379 CE
       Component: ESP8 front    H09 0050
       Coding: 175DC401
       Shop #: WSC 43270 003 104857
       VCID: 7EB006CDE9AE62BFD5-802A
       Part No SW: 8K0 907 064 GC    HW: 8K0 907 064 FC
       Component: BCM2 2.0      H12 0633
       Coding: 01A24000000000000000
       VCID: 77BE13E9C69453F796-8022
       Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
       Serial number: 0813000071481013
       Part No SW: 8K1 820 043 AG    HW: 8K1 820 043 AG
       Component: KLIMA 1 ZONE  H02 0123
       Revision: A1000000    Serial number: 01240520131385
       Coding: 342002E000
       VCID: 6D923181B4C8E9277C-8038
       Part No SW: 8K0 907 063 DD    HW: 8K0 907 063 DD
       Revision: 04016001    Serial number: 00000047305501
       Coding: 290000318134AFE00381000300001F1F439C470826080201000004004001020000000000000000
       VCID: 74A424E5D7E238EFB3-8020
       Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
       Component: MITSUBA160513  H18 0461
       Serial number: 13051307025350
       Coding: 004577
       Serial number: 21336368
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001605130337
       Serial number: DE884DA6000000000001
       Part No SW: 8K0 919 475 AA    HW: 8P0 919 475 N
       Component: PARKHILFE 8K  H01 0081
       Revision: 11001001    Serial number: 12531119208920
       Coding: 300103
       VCID: 78BC10D5CB8A5C8F9F-802C
       Serial number: 003KFD9ACBV
       Coding: 30514435363030303030554A304C384B3053
       Shop #: WSC 21397 001 1048576
       VCID: 48DCA015F3EAEC0F2F-801C
       Serial number: 6334MSME7A010F7FS
       Serial number: 6344MSME79450F51K
       Serial number: 6352QSME663125549
       Serial number: 6362QSME563108427
       Serial number: 63732SME6731054AZ
       Serial number: 63832SME6531484A+
       Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
       Component: Lenks.Modul   H02 0171
       Revision: 00000000    Serial number: 20130527000080
       Coding: 000017
       VCID: 4FEE8B091E843B376E-801A
       Part No SW: 8K0 920 932     HW: 8K0 920 932
       Component: KOMBIINSTR.   H35 0563
       Revision: 00400000    Serial number: WWD617F5E
       Coding: 138F100003010008000000
       VCID: 6C943C858FD2E02F6B-8038
       Component: GW-BEM 4CAN-M H11 0056
       Revision: 1Y070028    Serial number: 2841Y135150298
       Coding: 80CF07FF00
       Shop #: WSC 06325 123 12345
       VCID: 4AD89A1DE5E61E1F39-801E
       Serial number: 5422970503
       Serial number: 13143000800021200181
       Part No SW: 8K0 959 793 S    HW: 8K0 959 793 Q
       Component: TSG FA        H02 0506
       Revision:             Serial number: 0000061664162
       Coding: 011E02204800410001
       VCID: 50EC887503BA24CF77-8004
       Revision: 00001000    Serial number: 0013492476
       Coding: 100000000001
       Shop #: WSC 06324 000 00000
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3424E4E59F6278EF73-8060
       Revision: 00002001    Serial number: 0305712450
       Coding: 011E062820B900008120023680000047
    03389 - Data Set Implausible
                        Reset counter: 139
                        Mileage: 198442 km
                        Date: 2020.02.14
                        Time: 15:11:25
       Revision: 00005001    Serial number: 94813031596305
       VCID: 2D12F181744829273C-8078
       Part No SW: 8K0 959 792 S    HW: 8K0 959 792 Q
       Component: TSG BF        H02 0506
       Revision:             Serial number: 0000061668416
       Coding: 011E02204C00410001
       Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
       Component: EPB-4         H01 0004
       Revision: --------    Serial number: 10000000216048
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 393AD5D1B8008587A0-806C
       Part No SW: 4G0 035 056 J    HW: 4G0 035 056
       Component: Radio U STD   H60 0133
       Revision: AB001007    Serial number: 229ET0D7700602
       Coding: 010003010000000001
       VCID: 281C00955BAA0C0FCF-807C
       Part No SW: 8R2 035 666 L    HW: 8R2 035 666 C
       Component: H-BN-EU       H46 1036
       Revision: --------    Serial number: 206IZ0D7536611
       Coding: 0F0100010006E1EF05808B5E00000403040000000000000000
       Shop #: WSC 06335 123 12345
       VCID: 42C8B23DDDD6C65FF1-8016
       Subsystem 1 - Part No: 8R0 060 884 GA
       Component: EUR 2019  2802
       Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
       Component: DU7 High  H43 0098
       Serial number: 9466KX0A0256431
       Serial number: 00000002160950
       Component: CD-Database  5298
                        Reset counter: 139
                        Mileage: 198442 km
                        Date: 2020.02.14
                        Time: 15:11:30
                        Text: DU9466,Front,M,0,0,6
                        Reset counter: 139
                        Mileage: 198442 km
                        Date: 2020.02.14
                        Time: 15:11:28
                        Voltage: 12.10 V
                        Bin. Bits:      010
    03623 - Invalid Security/Release Code
                        Reset counter: 139
                        Mileage: 198442 km
                        Date: 2020.02.14
                        Time: 15:11:29
                        Hex Value: 0x0004
                        Hex Value: 0x000B
                        Count: 6
       Revision:             Serial number: 0000062125334
       Coding: 010C02204000210001
       VCID: 46C0AE2DF1FEFA7FDD-8012
       Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
       Component: J772__Rearview      0070
       Revision: --H12---    Serial number: 525PA8-J8791UC
       Coding: 1020007
       Shop #: WSC 20599 142 86696
       VCID: 373ED3E9461493F756-8062
    03006 - Back-up Camera System not calibrated
                        Reset counter: 139
       Revision:             Serial number: 0000062125371
    End----------(Elapsed Time: 01:50, VBatt start/end: 12.3V/12.3V)-----------
    And this is the log after retrofitting the headlights to bixenon and the 09-Central Electrics module from DD to DH
    Scan: 01 02 03 05 08 09 10 15 16 17 19 3C 42 44 46 47 52 53 56 5F
              62 6C 6D 72
    VIN: WAUZZZ8K2EA005884   Mileage: 199470km-123944miles
       Revision: 45H25---
       Coding: 000002
       Coding: 175D8C01
       Part No SW: 8K0 907 064 KJ    HW: 8K0 907 064 KJ
       Component: BCM2 2.0      H15 0711
       Coding: 05220000000000000000
       VCID: 0248723D9D56065FB1-8056
       Coding: 342002E000
       Revision: 08016001    Serial number: 00000980423901
       Coding: 260000118134AFE00381400300001D0D439C070826090201000004004000020100000010000000
       Coding: 004577
       Coding: 02005D
                        Reset counter: 55
                        Mileage: 199475 km
                        Date: 2020.03.16
                        Time: 18:38:51
       Coding: 300103
       Coding: 000017
       Component: GW-BEM 5CAN-M H11 0060
       Revision: 1Z120030    Serial number: 3041Z1413003F1
       Coding: 80CF07FF00
       VCID: 4CD49C05EF92002F0B-8018
       Part No SW: 8K0 907 566 H    HW: 4L0 907 566 B
       Component: J0769_SWA_MasterH01 0010
       Revision: 00H01000    Serial number: 6PZ 009 014-82
       Coding: 0000102
       VCID: 3C34CCC57F32B0AFBB-8068
       Subsystem 1 - Part No: 8K0 907 568 H
       Component: J0770_SWA_Slave_H01 0010
       Subsystem 2 - Serial number: 6PZ 009 014-92
       Subsystem 3 - Serial number: 5F07.08.0900H010003C320316˙
       Subsystem 4 - Serial number: 320316˙
       Component: TSG FA        H02 0511
       Revision:             Serial number: 0000156597510
       Coding: 011D12205C00410001
       Coding: 100000010001
       Shop #: WSC 06324 123 12345
       Revision: 00002001    Serial number: 0516224809
       Coding: 011E0E2020BD30818120023680000000
       Revision:             Serial number: 0000144379375
       Coding: 011D12205400410001
       VCID: 4ED0960D198E323F65-801A
       Part No SW: 8R1 035 666 L    HW: 8R1 035 666 H
       Component: H-BN-EU       H48 1036
       Revision: --------    Serial number: 514J.0E7500735
       Coding: 0F0100010006E1EF15808B5E00000403040000000000000000
       VCID: 41CABD31D8D0DD47E8-8014
                        Reset counter: 55
                        Mileage: 199475 km
                        Date: 2020.03.16
                        Time: 18:38:55
    02612 - Audio Wire Adapter Set
                        Reset counter: 55
                        Mileage: 199475 km
                        Date: 2020.03.16
                        Time: 18:39:03
                        Voltage: 14.60 V
                        Reset counter: 55
                        Mileage: 199475 km
                        Date: 2020.03.16
                        Time: 18:38:54
                        Hex Value: 0x0004
                        Hex Value: 0x000B
                        Count: 6
       Coding: 010C12204000210001
       Coding: 1020007
                        Reset counter: 55
       Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
       Revision: --------    Serial number: 8K9827851A
       VCID: 3C34CCC5BF32B0AFBB-8068
       Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
       Serial number: 8K9827852A
    End----------(Elapsed Time: 01:52, VBatt start/end: 14.7V/14.8V)-----------
    Any help ?
  9. #27
    Nov 2014
    Bucharest Romania
    Retrofit bixenon
    Quote Originally Posted by paulkf View Post
              6C 72
       Revision: 45H25---
       Coding: 000002
       Coding: 175DC401
       Coding: 342002E000
       Coding: 004577
       Coding: 02005D
       Coding: 300103
       Coding: 000017
       Coding: 80CF07FF00
                        Reset counter: 139
                        Mileage: 198442 km
                        Date: 2020.02.14
                        Time: 15:11:25
                        Reset counter: 139
                        Mileage: 198442 km
                        Date: 2020.02.14
                        Time: 15:11:30
                        Reset counter: 139
                        Mileage: 198442 km
                        Date: 2020.02.14
                        Time: 15:11:28
                        Voltage: 12.10 V
                        Bin. Bits:      010
                        Reset counter: 139
                        Mileage: 198442 km
                        Date: 2020.02.14
                        Time: 15:11:29
                        Hex Value: 0x0004
                        Hex Value: 0x000B
                        Count: 6
       Coding: 1020007
                        Reset counter: 139
              62 6C 6D 72
       Revision: 45H25---
       Coding: 000002
       Coding: 175D8C01
       Coding: 342002E000
       Coding: 004577
       Coding: 02005D
                        Reset counter: 55
                        Mileage: 199475 km
                        Date: 2020.03.16
                        Time: 18:38:51
       Coding: 300103
       Coding: 000017
       Coding: 80CF07FF00
       Coding: 0000102
                        Reset counter: 55
                        Mileage: 199475 km
                        Date: 2020.03.16
                        Time: 18:38:55
                        Reset counter: 55
                        Mileage: 199475 km
                        Date: 2020.03.16
                        Time: 18:39:03
                        Voltage: 14.60 V
                        Reset counter: 55
                        Mileage: 199475 km
                        Date: 2020.03.16
                        Time: 18:38:54
                        Hex Value: 0x0004
                        Hex Value: 0x000B
                        Count: 6
       Coding: 1020007
                        Reset counter: 55
    Any help ?
    Salut treci pe la noi la viper si rezolvam. Spor
    Vipers
  10. #28
    May 2016
    You have to check the adaptions. If you get power train databus most likely car was equipped with AFS. Then its looking for slave units.
    For topic starter. Drl can make work by change adaptions
