Results 11 to 20 of 28
Thread: PLEASE HELP with 2013 facelift A4 coding fix, post Bi-Xenon conversion.
    Verified VCDS User socalfun64's Avatar
    Feb 2015
    This is the OEM equipment that I'm using.
    All equipment is AUDI OEM. I’m using 2013 ecodes that are from a 2013 B8.5 “facelift” S4, bought from Eurocode. All part #’s are the same across A4/5 S4/5 for 2013+ models per Audi parts database.*
    My headlight housings #’s
    8KO 941 043E(R) AL
    8KO 941 044E(L) AL
    My HID XENON Ballast #’s
    8KO 941 597 E MITSUBISHI (comes on 2013 A4/S4/A5/S5).
    LED Control Unit #’s. (come on 2013 A4/S4/A5/S5 and many more).
    4G0 907 697 D
    4G0 907 697 D
    J519 CECM (#9 electronics module):
    8K0 907 063 P (original)
    8K0 907 063 DL (replacement model per Nick @ OEM+)
    Kufatec Conversion Cable:
    40845 / 36229 (model # changed but same cable for 2009+ A4 8K).
  2. Likes Uwe liked this post
  3. #12
    VCDS Distributor AIB Wolfgang's Avatar
    Sep 2014
    at my knowledge, the Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS Component: E1 - LDS H03 0031 is connected by LIN-Bus
    and different marked by PR-Codes for halogen headlights and Bi-Xenon.
    I hope, this will solve your coding problem.
    -Wolfgang
    Drive more talk less
  4. #13
    Feb 2015
    Quote Originally Posted by AIB Wolfgang View Post
    Wolfgang,
    Thank You very much!! Being just an amature though, can one of the other guys interpret what he means for me? What changes I would actually need to make?
    Thanks so much!!
  5. #14
    Sep 2014
    Hi
    I never did such retrofitting, but I would change the light switch to this component with PR-Code for Bi-Xenon.
    Maybe there are some other wire connections you need, but I'm just out of office and no access to WD for further help.
    -Wolfgang
  6. Likes Uwe liked this post
  7. #15
    Mar 2017
    Poland
    Hello
    anyone know how resolve problem with xenon range control defective - error on dash?
    I sucessfull add bcm module 8k0907063DH (org 8k0907063DD) and remove CP in audi dealer. Now I have 1 error in bcm and error on dash 01312 - powertrain data bus - no signal communication.
    I can adjustment xenon range control in bcm and all is ok 0.0
    If someone resolve this problem I want pay - no problem,
    In attachment autoscan
    http://www.image-share.com/ijpg-3491-90.html
    Thursday,23,March,2017,10:15:09:32995
    VCDS Version: 17.1.3.0
    Data version: 20170203 DS267.2
    VIN: WAUZZZ8K7FA187549   License Plate: A4 B8.5 ERROR
    Mileage: 55020km-34187mi   Repair Order:
    Chassis Type: 8K (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 6D 72
              AC
    VIN: WAUZZZ8K7FA187549   Mileage: 55020km-34187miles
    Address 01: Engine (J623-CSUA)       Labels: 04L-907-309-V1.clb
       Part No SW: 04L 906 021 CA    HW: 04L 907 309
       Component: R4 2,0L EDC   H23 8466
       Revision: 85H23---
       Coding: 12034012232401080000
       Shop #: WSC 06208 123 12345
       ASAM Dataset: EV_ECM20TDI01104L906021CA 002007
       ROD: EV_ECM20TDI01104L906021BG_002.rod
       VCID: 66C99E9999E72E7173-8032
    Address 02: Auto Trans (J217)       Labels: 0AW-927-156.clb
       Part No SW: 8K5 927 155 B    HW: 0AW 927 156 K
       Component: 0AW 20TDI RdW H08 0002
       Revision: --H08---    Serial number: 0000000385
       Coding: 000002
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMVL381 A02433
       ROD: EV_TCMVL381_AU57.rod
       VCID: 377703DD8ECD67F918-8062
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V2.clb
       Part No SW: 8K0 907 379 CN    HW: 8K0 907 379 CN
       Component: ESP8 front    H09 0020
       Coding: 3D1DCC00
       Shop #: WSC 06325 123 12345
       VCID: 0717B31DB6ADD779A8-8052
       Part No SW: 8K0 907 064 KG    HW: 8K0 907 064 KG
       Component: BCM2 2.0      H15 0711
       Coding: 01A24000000000000000
       VCID: 7F072BFDEE7D9FB990-802A
       Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
       Serial number: 0815000120019011
       Part No SW: 8K1 820 043 AT    HW: 8K1 820 043 AT
       Component: KLIMA 1 ZONE  H02 0122
       Revision: A1000000    Serial number: 01151020150824
       Coding: 342000A000
       VCID: 7AF1DAE9F55FBA91A7-802E
       Revision: 08016001    Serial number: 00001019414602
       Coding: 26000010803400C00081400300001D0D001C070826090401000004000400020100000020000000
       VCID: 78F5C0E1CB53A881D1-802C
       Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
       Component: MITSUBA240915  H19 0461
       Serial number: 1509210307645
       Coding: 00F511
       Subsystem 2 - Part No SW: 8K0 941 531 AS    HW: 8K0 941 531 AS
       Serial number: 00000000000910157184
       Subsystem 3 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
       Serial number: 0D5802D7000000000001
    01312 - Powertrain Data Bus
                        Reset counter: 41
                        Mileage: 55027 km
                        Date: 2017.01.10
                        Time: 14:43:14
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Component: AirbagVW-AU10 H49 0610
       Serial number: 003KFDD21ZCS
       Coding: 30514435363030303030554A304C384B3053
       VCID: 48957021F333180161-801C
       Serial number: 6334MSME551A12658
       Serial number: 6344MSME551E13058
       Serial number: 6352QSME644E1B56S
       Serial number: 6362QSME2D564D62T
       Serial number: 63732SME21153F4A/
       Serial number: 63832SME6B144C544
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862OJJ000TT
       Coding: 000017
       VCID: 48957021FB33180161-801C
       Component: E221 - MFL  H03 0003
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 932 D    HW: 8K0 920 932 D
       Component: KOMBIINSTR.   H36 0567
       Revision: 00100000    Serial number: 61-53RGAG
       Coding: 13A7100003010008000000
       VCID: 306538C163A3B0C159-8064
       Part No SW: 8R0 907 468 T    HW: 8R0 907 468 C
       Component: GW-BEM 4CAN-M H11 0070
       Revision: 1Y090032    Serial number: 3241Y15A060606
       Coding: 80CF07FF00
       VCID: 50A558410363D0C139-8004
       Serial number: 2734608103
       Serial number: 15287000538011200181
       Part No SW: 8K0 959 793 S    HW: 8K0 959 793 Q
       Component: TSG FA        H02 0511
       Revision:             Serial number: 0000169849230
       Coding: 011003204000410001
    Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
       Part No SW: 8K0 909 144 P    HW: 8K0 909 144 B
       Component: RCEPS         H43 0510
       Revision: 00001000    Serial number: 0013316559
       Coding: 100000000001
       Shop #: WSC 06324 123 12345
       ASAM Dataset: EV_RCEPSAU48X 008018
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3E7916F9A1F756B1DB-806A
       Revision: 00002001    Serial number: 0382145866
       Coding: 0100063820B930008120023680000047
       Part No SW: 8K0 959 792 S    HW: 8K0 959 792 Q
       Component: TSG BF        H02 0511
       Revision:             Serial number: 0000169858685
       VCID: 4FA75B3D1E5DCF3920-801A
       Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
       Component: EPB-4         H02 0005
       Revision: --------    Serial number: 10000000606402
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 3A711AE9BDDF7A91E7-806E
       Part No SW: 4G0 035 056 J    HW: 4G0 035 056
       Component: Radio U STD   H60 0133
       Revision: AB001007    Serial number: 230JT0F3403382
       Coding: 010003020100000001
       VCID: 2855D0A15B73F80181-807C
       Part No SW: 8R1 035 670 K    HW: 8R1 035 670 J
       Component: H-BNT-EU      H50 0941
       Revision: --------    Serial number: 516J70F7556644
       Coding: 0F0100010006A1ED01808B5E00000403E40000020000000000
       VCID: 3B7F1FEDBAE54399FC-806E
       Subsystem 1 - Part No: 8R0 060 884 CR
       Component: EUR 2015  2102
       Component: DU7 High  H42 0104
       Serial number: A130J.0F3486218
       Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
       Serial number: 00000002406035
       Component: CD-Database  6208
       Component: TSG HL        H01 0510
       Revision:             Serial number: 0000171203928
       Coding: 010003204000210001
       VCID: 46897E19F1270E7193-8012
       Part No SW: 8K9 827 851 C    HW: 8K9 827 851 C
       Component: J605  Master  H56 0330
       Revision: --------    Serial number: 8K9827851C
       VCID: 3E7916F9A9F756B1DB-806A
       Subsystem 1 - Part No SW: 8K9 827 852 C    HW: 8K9 827 852 C
       Component: J756  Slave  H56 0330
       Serial number: 8K9827852C
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
       Component: TSG HR        H01 0510
       Revision:             Serial number: 0000171203936
       Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0013
       Revision: 00000000    Serial number: 152651592
       ROD: EV_RDCMA00100_008.rod
       VCID: 2F673BBD769DAF3940-807A
    End-------------------------(Elapsed Time: 03:39)--------------------------
  8. #16
    United States
    milkatrek,
    Can you post the scan with the original BCM (8K0 907 063 DD) or a scan clip from it so we can check the before and after coding values?
    P.S. The VCDS Polish scan from the old module would be fine so don't go out of your way to try and obtain English. Plugging in the old BCM may cause CP problems.
  9. Likes milkatrek liked this post
  10. #17
    Mar 2017
    Poland
    thx Dana for you reply you are my last hope
    this is coding
    290010308034A7C00081000300001F1F001C47082608020100 0004004001020000000020000000 this from 8k0907063DD
  11. #18
    United States
    Thanks. For some reason PL24 shows a 8K0907063DL module which does not appear to supersede to a newer part number. That makes me wonder if that module wasn't already swapped at some point prior to this.
    Does pasting what we believe was the factory coding string
    290010308034A7C00081000300001F1F001C470826080201000004004001020000000020000000
    directly into the new module resolve the 01312 - Powertrain Data Bus - No Signal/Communication fault code?
  12. Likes Uwe, milkatrek liked this post
  13. #19
    United States
    P.S. Although it was from a UK/RoW 2013 A4 Avant Quattro 3.0L TDI, this is the closet scan info I located with factory Xenons in a facelift A4 with the BCM part number PL24 believes was original:
    >     Part No SW: 8K0 907 063 DL    HW: 8K0 907 063 DL
    >     Coding: 260080108034AFC00081400000001D0D001D470827090201000008004400030100000024000000
    PR Data
    Sales type 8K50JY
    Front fog light/additional headlight 8WB Front fog lights
    Headlight 8BP Bi-functional headlight with gas discharge lamp
    Headlight activation 8K4 Separate daytime running lights NAR
    Headlight washer system 8X1 Headlight washer system
    Headlight-range adjustment 8Q3 Automatic headlight-range adjustment dynamic (self-adjusting while driving)
    B0N Component parts set, complying with vehicle type for Great Britain, various parts
    You might be able to use bits of that coding when comparing results but I wouldn't paste the entire UK string into this car.
  14. Likes milkatrek liked this post
  15. #20
    Mar 2017
    Poland
    Hi
    new module DH not accepted old coding - 29 and 26 byte 00
    I try coding from uk/row - that same problem
    This fault is present only if I change coding byte 31 from 00 to 01 (xenon)
