Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: PLEASE HELP with 2013 facelift A4 coding fix, post Bi-Xenon conversion.
    Verified VCDS User socalfun64's Avatar
    Feb 2015
    Hi
    I really need help with this as I have tried everything I know and have been to 2 local Audi shops that have not been able to help. I have a 2013 Audi 'facelift' A4 premium that came with Halogen headlights. I have nearly successfully completed my Bi-Xenon conversion after following various threads and Kufatec instructions. I am hopeful that only a final coding fix for the DRL's remains, which is why I need your help.
    I'll give the current status relative to switch position as I think that will make it clear:
    Switch at 0 or 'off': No lights at all (should be Daytime Running Lights on full).
    Switch at pos 2 or 'auto': HID on when dark, and DRL's on but dim, orange parking lights on.
    Switch at pos 3 or 'parking lights': Orange parking lights on and DRL's on dim.
    Switch at pos 4 or 'on': HID on and DRL's on dim, orange parking lights on.
    HIGH BEAMS: work with push and pull of selector stalk.
    I have tried all kinds of combinations of coding found on various threads from Audizine, Audiworld, etc and the above is pretty much the best I can get. I have been able to get the DRL's to flash fully bright twice and then go off when the switch is moved to 'auto' or 'on' position using other coding options on BYTE 3, so I know the DRL will work at full brightness. I also have tried changing the 'adaptation channel 3 to many different values from 24-100 with no change at all in brightness when in the corresponding switch positions. I have never had anything come on when the switch is in the 'off' position.
    Here is my current scan:
    <Monday,23,February,2015,16:20:33:63444
    VCDS Version: 14.10.1.1 (x64)
    Data version: 20150130
    VIN: WAUBFAFL2DN050306   License Plate:
    Mileage: 40050km-24885mi   Repair Order:
    Chassis Type: FL (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 44 46 47 52 53 56 62 72
              77
    VIN: WAUBFAFL2DN050306   Mileage: 40050km-24885miles
    Address 01: Engine (DET-CPMA)       Labels: 06H-907-115-CDN.clb
       Part No SW: 8K5 907 115 F    HW: 8K2 907 115 L
       Component: 2.0l R4/4V TF H09 0007
       Revision: ECH09---
       Coding: 4A2A0013242600062000
       Shop #: WSC 49954 000 1048576
       ASAM Dataset: EV_ECM20TFS0118K5907115F 001008
       ROD: EV_ECM20TFS0118K5907115F.rod
       VCID: 35611EF394B6A2898D6-8060
    Readiness: 1010 0101
    Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
       Part No SW: 8K0 927 158 T    HW: 0BK 927 156 AL
       Component: 0BK 20TFSIUSA H16 1003
       Revision: --H16---
       Coding: 000002
       ASAM Dataset: EV_TCMAL551211 002020
       ROD: EV_TCMAL551211_AU48.rod
       VCID: 479D643BFE5A2019EFA-8012
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
       Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
       Coding: 2D1D10
       VCID: 0407B33787ECCB014A8-8051
       Part No SW: 8K0 907 064 GL    HW: 8K0 907 064 FL
       Component: BCM2 2.0      H12 0633
       Coding: 09814000000000000000
       VCID: 000FBF2793F4D7216E0-8055
       Subsystem 1 - Part No SW: 8K0 959 754 F    HW: 8K0 959 754 F
       Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
       Part No SW: 8K1 820 043 R    HW: 8K1 820 043 R
       Component: KLIMA 1 ZONE  H02 0121
       Revision: A1000000    Serial number: 01220420131441
       Coding: 6480208000
       VCID: 377D14FB86BA50999FA-8062
       Part No SW: 8K0 907 063 DL    HW: 8K0 907 063 DL
       Revision: 10016001    Serial number: 00000906718901
       Coding: 26001031863CA7C00000090300001D0D0F1C520822080221000004004000030000000000000000
       Shop #: WSC 03784 444 132089
       VCID: 7CF7CBD7FF1CB3C1328-8029
       Component: WWS 300413  H07 0080
       Coding: 00F511
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Component: USHL4.2  H30 0030
       Subsystem 5 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
    03354 - Bulb for DRL and Marker Light; Right
                        Reset counter: 45
                        Mileage: 40051 km
                        Date: 2015.02.23
                        Time: 13:07:12
    03351 - Bulb for DRL and Marker Light; Left
                        Reset counter: 45
                        Mileage: 40051 km
                        Date: 2015.02.23
                        Time: 13:07:13
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
       Serial number: 003KJD91R1BI
       Coding: 303842354730303030304A55304C384B3053
       ROD: EV_AirbaECUVWAUDI010_AU48.rod
       VCID: 4A9B5D0FED48DD71F04-801F
       Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
       Serial number: 5810000R130000BH8U
       Serial number: 6334MSME7B15466BO
       Serial number: 6344MSME7B157156H
       Serial number: 6352QSME14383958I
       Serial number: 6362QSME0C383F6E$
       Serial number: 63732SME26340660Q
       Serial number: 63832SME5B330862
       Part No SW: 8K0 953 568 L    HW: 8K0 953 568 L
       Revision: --------    Serial number: 90372MDT000GZ
       Coding: 000016
       VCID: 4385702BC2620C39332-8016
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 950 R    HW: 8K0 920 950 R
       Component: KOMBIINSTR.   H09 0556
       Revision: 00500000    Serial number: UVE790P4E
       Coding: 831F09000301D705020000
       VCID: 3E7301DFA98061D15CC-806B
       Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
       Component: GW-BEM 5CAN   H11 0056
       Revision: 1V080027    Serial number: 2741V13419800E
       Coding: 80C303FF00
       VCID: 489F6707FB442F61E60-801D
    Address 2E: Media Player 3 (R199)       Labels: 8T0-035-785.clb
       Part No SW: 8T0 035 785 A    HW: 8T0 035 785
       Component: SG ext.Player H08 0290
       Revision: 00000000
       Coding: 020302
       VCID: 397912C3B0AE46E969E-806C
       Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
       Component: TSG FA        H09 0304
       Coding: 011C03204000410001
       VCID: 56A3B97F21F0899164C-8003
    Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
       Revision: 00001000    Serial number: 0028439164
       Coding: 100000000001
       ROD: EV_RCEPSAU48X.rod
       VCID: 346723F79FCCBB81BA8-8061
       Revision: 00002001    Serial number: 0306350795
       Coding: 0106023A00FA400480B0013200000000
       Component: GTO BF  H01 0080
       Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
       Component: J245 PS050  H08 0043
       Part No SW: 8R1 035 223 A    HW: 8R1 035 223
       Component: DSP STD       H08 0230
       Revision: 26S00000
       Coding: 0203010102
       VCID: 2B55388B4AF2E479EB2-807E
       Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
       Component: TSG BF        H09 0304
       VCID: 55A1BE733CF682896D6-8000
       Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
       Component: EPB-4         H01 0003
       Revision: --------    Serial number: 10000000208100
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 387F17C783A45FE1960-806D
    Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
       Part No SW: 8R1 035 186 Q    HW: 8R1 035 186 Q
       Component: Con3 Sirius   H09 0471
       Revision: 00000002    Serial number: AUZ5Z6M1890263
       Coding: 04020002010185004159070800
       Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
       Component: Display
       Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
       Component: TSG HL        H07 0304
       Coding: 010C03204000210001
       VCID: 59B9B24350EEA6E949E-800C
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
       Component: TSG HR        H07 0304
       Part No SW: 8T0 862 336 F    HW: 8T0 862 336 E
       Component: FSE_256x BT     H45 0660
       Revision: 00000000    Serial number: 00000005309241
       Coding: 0010370
       VCID: 3E7301DF698061D15CC-806B
    End-------------------------(Elapsed Time: 03:49)--------------------------
    THANK YOU SO MUCH FOR ANY HELP YOU CAN OFFER! I AM AT MY WITS END.
    Feb 2015
    I didn't mention that I did swap out the J519 module from the stock '8K0 907 063 P' unit to a brand new '8K0 907 063 DL' unit. I was told to use that unit by Nick from OEM+ while the Car was at Eurocode being looked at. Prior to the swap I couldn't get the BYTE 0 coding to accept a '26' and the High Beams weren't working. After the swap both of those issues were resolved and the DRL's started working but only in the manner described above and not in the way they are supposed to work. I'm hoping someone here can even just point me to what might be the issue, if not give me coding advice.
    Feb 2015
    Do you guys think this could be a wiring issue with the Kufatec cable possibly (due to possible changes in the facelifted A4's)?
    Feb 2015
    Can one of the Techs take a minute to at least tell me why they are not responding to my post.
    I expect nobody has responded because nobody is familiar with that particular conversion.
    --> It's certainly not factory as evidenced by the lack of any control module for the Xenons. <-- Seems I'm wrong about that -- sorry.
    Verified VCDS User roth's Avatar
    Feb 2015
    Quote Originally Posted by socalfun64 View Post
    Only other modules tat go in this car, besides 8K0 907 063 P, are:
    8K0 907 063 D
    8K0 907 063 BE
    Are you sure 063 DL is supposed to be there?
    Did they mentioned the other modules ??
    BR, Andy
  7. Likes Uwe, Dana liked this post
    United States
    This is one of those super duper looong coded B8 facelift BCM1 units so the lack-of 55 (depending on the factory installed PR codes/lights) is normal. The level sensors are wired to/from 09, the LED DRLs may be subsystems beneath it, etc ...but I don't think any of those are AFS.
    I do not have any personal experience with this retrofit but are you using the factory level wiring diagrams? If so, don't post them here, but let us know which current flow diagram numbers you are working from.
  9. Likes Uwe liked this post
  10. #8
    Feb 2015
    Quote Originally Posted by roth View Post
    8K0 907 063 D
    8K0 907 063 BE
    BR, Andy
    Thank you for responding! I replaced the original 8K0 907 063 P J519 module with the 8K0 907 063 DL module per Nick @ OEM+ who is the distributor for the Kufatec conversion cable. He told me that was the module I needed. That change did allow the High Beams to work and the DRL's to work in the manner they are now. I know others with pre-facelift A4/S4's have switched to the 'D' module but that is an old module and I didn't want to put that into a newer car.
    To the best of my understanding from all the reading I've done, people only changed the J519 module if the High Beams wouldn't work. I tried it because I was at a dead end. Keep in mind the DRL's are working now, just not properly which is the really frustrating part. I can't get them to come on at full brightness in Off or Auto like they are supposed to. Does that sound like just a coding issue to you?
  11. #9
    Feb 2015
    The only work with electrical I've done so far, other that swapping the J519, is using the Kufatec Conversion cable and following their instructions for plugging it's 2 wires into it (J519) for the High Beams.
    This has been successfully done by 2 people I've read about on Audizine and 1 guy I asked from ebay (as far as the 2013 facelift conversion). Thing is, they had private Audi shops do the work for them so they can't help with what was done exactly. 2 of them did mention that they think a couple wires were changed in the adapter. I have had it to 2 shops so far, Eurocode in Torrance, Ca. where the lights were bought from by the guy who sold them to me and Ingolstadt West in Canoga Park, Ca. Ian @ Ingolstadt West got them to the point they are now and is still trying to help me but nothing yet.
    I love the improved beam pattern of the ecodes and the improved light output overall of the Xenons, but I really am trying to get that trademark Audi look with the DRL's. So many people have done this successfully back to 2009 at least, that I never thought it would be this much trouble. I've invested close to 2k now, $400 of which was the ROSS-TECH cable because I thought I should be able to do it myself as so many others had! I know is crazy, but I kept thinking, this next thing will be it!
    I hate to think I've spent so much and just can't get that final step done.
  12. #10
    Feb 2015
    If you guys could at least say whether you think it needs wiring or coding to get the DRL's to work right, it would get me at least a step closer. These are factory options on the Premium plus and Prestige packages, which I wish to God I had got!! I sadly assumed since they are such an Audi trademark that they were standard. The dealer of course didn't mention it. I couldn't have afforded it at the time anyway, but with what I've put in now, it would be close to the same!
