hello dear wizards
i have a audi a4 2012 the problem is that the car shows temperature 90deg even after disconnecting the coolant sensor. as a result the fan stays on all the time. i cant get 5v ref on the coolant sensor or the ecu on relavant points. please help me diagnose this one
Monday,10,August,2020,14:43:10:02918
VCDS Version: 20.4.2.0 (x64) HEX-NET CB: 0.4513.4
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 52 53 56 5F 62 6C
72
VIN: WAUZFC8K7DY700468 Mileage: 65200km-40513miles
Address 01: Engine (J623-CMFA) Labels: None
Part No SW: 03L 906 018 LP HW: 03L 906 018 JL
Component: R4 2.0l TDI H24 9979
Revision: 45H24---
Coding: 0A034012242400080000
Shop #: WSC 57310 002 1048576
ASAM Dataset: EV_ECM20TDI01103L906018LP 003006
ROD: EV_ECM20TDI01103L906018LP.rod
VCID: 834618DC0A1EFE9E8E-80D6
U1113 00 [039] - -
Mileage: 65207 km
Date: 2020.08.10
Time: 13:04:38
Coolant temperature: 150 °C
Intake air temperature: 130 °C
Ambient air pressure: 930 mbar
Voltage terminal 30: 11.740 V
Cruise Control System (CCS): switch position-Bits 0-7: 129
Cruise Control System (CCS): status-Bits 0-7: 47
Cruise control switch-off: irreversible-Bits 0-7: 255
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
4821 - Engine Coolant Temp. Sensor (G62)
P0117 00 [039] - Signal too Low
Mileage: 65207 km
Date: 2020.08.10
Time: 13:04:38
Coolant temperature at radiator outlet: actual value: 150.0 °C
Heat delivery temperature in cooling system: -273.1 °C
Outside air temperature: 30.0 °C
Fuel consumption: 0.00 l/h
Fuel temperature: 136.7 °C
Engine oil temperature: 54.9 °C
5268 - Sensor 1 for Exhaust Temp Bank 1 (G235)
P0545 00 [036] - Short to Ground
Mileage: 65207 km
Date: 2020.08.10
Time: 13:01:46
Voltage terminal 30: 12.700 V
Exh.gas temp.sen 1: 950.5 °C
Exh.gas temp.sen 2: -0.0 °C
Exh.gas temp.sen 3: 637.2 °C
Exh.gas temp.sen 4: 630.1 °C
Shut-off timer: last engine shut-off time: 3 s
Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
Part No SW: 8K2 927 155 G HW: 0AW 927 156 K
Component: 0AW 20TDI RdW H04 0003
Revision: --H04--- Serial number: 0000000997
Coding: 000001
Shop #: WSC 90001 000 00000
ASAM Dataset: EV_TCMVL381 A02431
ROD: EV_TCMVL381.rod
VCID: B93ABA343852744E94-80EC
2223 - Load Signal
P1857 00 [047] - Error Message from ECU
Mileage: 65207 km
Date: 2020.08.10
Time: 13:04:38
Engine speed: 100.00 /min
Transmission input speed: 1 /min
Transmission output speed: 1 /min
Engine torque: -40 Nm
Transmission fluid temperature: 45 °C
Accelerator position: 0.0 %
Clutch status: 1
Occurrence_counter_over_length_of_life: 29
Part No SW: 8K0 907 379 CH HW: 8K0 907 379 CH
Component: ESP8 front H09 0100
Coding: 171D58
Shop #: WSC 90001 123 12345
VCID: 814A12D41802EC8E9C-80D4
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 233
Mileage: 65207 km
Date: 2020.08.10
Time: 13:04:37
Hex Value: 0x00C0
Hex Value: 0x0782
Hex Value: 0x000B
Hex Value: 0x4691
Hex Value: 0x0000
Part No SW: 8K0 907 064 FR HW: 8K0 907 064 FR
Component: BCM2 2.0 H10 0602
Coding: 01910000000000000000
VCID: 854206C40C2AC0AEA0-80D0
Subsystem 1 - Part No SW: 8T0 959 754 HW: 8T0 959 754
Component: FBSAUDIB8 IDG H60 0072
Serial number: 0812000043977014
Part No SW: 8K2 820 043 AC HW: 8K2 820 043 AC
Revision: D0000000 Serial number: 01030420120217
Coding: 340462E000
VCID: EA98557805740FD62D-80BE
Reset counter: 233
Mileage: 65207 km
Date: 2020.08.10
Time: 13:04:38
Part No SW: 8K0 907 063 DG HW: 8K0 907 063 AG
Component: BCM1 1.0 H14 0103
Revision: 07014001 Serial number: 00000397580002
Coding: 260000108034AFC00081400000001D0D0F1D430823090201000008000401020100000034000000
Shop #: WSC 61394 002 1048576
VCID: F7BE7C0C46C6A23EA2-80A2
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 280312 H06 0070
Serial number: SWF12030280312
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 20190018
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000002103123665
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: 6208CF16000000000001
Reset counter: 233
Mileage: 65207 km
Date: 2020.08.10
Time: 13:01:44
00003 - Control Module
Fault Status: 00111110
Mileage: 31691 km
Date: 2018.04.19
Time: 21:34:38
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Serial number: 003KFD926DB6
Coding: 30544435363030303030554A3052384B3053
Shop #: WSC 02787 002 1048576
VCID: C8DCCFF073B81DC61B-809C
Serial number: 6334MSME6D404433A
Serial number: 6344MSME6D4610206
Serial number: 6352QSME131019664
Serial number: 6362QSME7D105264G
Serial number: 63732SME7E0F175CH
Serial number: 63832SME3B0F0A747
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20120411000914
Coding: 000016
VCID: CFEEE4EC9ED6CAFE5A-809A
Component: E221 - MFL H03 0003
Part No SW: 8K0 920 931 C HW: 8K0 920 931 C
Component: KOMBIINSTR. H35 0540
Revision: 00000000 Serial number: NTD70524D
Coding: 3326080003010008010000
VCID: AE109968F91CA3F631-80FA
Part No SW: 8R0 907 468 C HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H10 0025
Revision: 1Y030014 Serial number: 1441Y1222902D4
Coding: 00C303FF00
VCID: BFCED42C2E765A7EAA-80EA
Serial number: 1496267101
Reset counter: 18
Mileage: 65207 km
Date: 2020.08.10
Time: 13:37:50
Bin. Bits: 00000
Voltage: 12.20 V
Count: 7
Bin. Bits: 10000
Time: 0.40 s
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0076
Revision: AA000000 Serial number: 00000025630124
Coding: 00781300000000000000
VCID: BB36A03C3A6E465E86-80EE
Part No SW: 8T0 959 793 G HW: 8T0 959 793 G
Component: TSG FA H09 0302
Coding: 011C02205E01410001
VCID: CDD2FEE494DAF8EE28-8098
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H39 0507
Revision: 00001000 Serial number: 0003115627
Coding: 100000010001
Shop #: WSC 00070 000 00000
ROD: EV_RCEPSAU48X_008.rod
VCID: B4248B001F30892647-80E0
Revision: 00002001 Serial number: 0173858679
Coding: 011A062000B901848020013280000000
Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J245 PS050 H08 0043
Part No SW: 8T0 959 792 G HW: 8T0 959 792 G
Component: TSG BF H09 0302
VCID: CCD4F3E06FC0F1E63F-8098
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 J HW: 8K0 907 801 J
Component: EPB-4 H01 0001
Revision: -------- Serial number: 30000000008957
ROD: EV_ParkiBrake_AU48.rod
VCID: B620B108094C9B3679-80E2
464384 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
Reset counter: 233
Mileage: 65207 km
Date: 2020.08.10
Time: 13:04:37
Voltage terminal 30: 11.7 V
Internal Fault ID: 188
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Auto Adjust: not active
Part No SW: 4G0 035 056 E HW: 4G0 035 056
Component: Radio U STD H60 0093
Revision: AB001007 Serial number: 230CL0C2505328
Coding: 070003020100000001
VCID: A306785CA2DE1E9EAE-80F6
Part No SW: 8R2 035 754 A HW: 8R2 035 754
Component: H-BN-RW H43 0467
Revision: -------- Serial number: 070DS0C7506065
Coding: 0F0001000006A1EF41808B4E00000403FC0000020000000000
VCID: B522B6041C4A902E70-80E0
Subsystem 1 - Part No: 8R0 060 884 AJ
Component: ROW 2012 0403
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130D30CS141475
Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
Component: E0380 Bedient H02 0030
Serial number: 00000001388864
Component: CD-Database 3638
Part No SW: 8T0 959 795 H HW: 8T0 959 795 H
Component: TSG HL H07 0302
Coding: 010C02204001210001
VCID: D0ECE79083E8D50643-8084
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 D HW: 8T0 907 441 D
Component: J772__Rearview 0140
Revision: --H06--- Serial number: 525PA8-J2193UT
Coding: 1020006
VCID: B93ABA34F052744E94-80EC
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H07 0302
End----(Elapsed Time: 01:52, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
