I change module because operation fault.Ori was 1K0907397BC 18 digit code (have it),new module is 1K0907397BK 19 digit,depend of your calc what data you need? I try with avdi but not succes.
Tuesday,11,August,2020,08:00:57:04922
VCDS Version: 20.4.2.0 HEX-NET CB: 0.4513.4
VIN: WVWZZZ1KZ9W415396 License Plate: IM449BE
Mileage: 143280km-89030mi Repair Order:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ9W415396 Mileage: 143280km-89030miles
Address 01: Engine (CBD) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 MC HW: 03L 906 022 G
Component: R4 2.0l TDI 0000SG 9979
Revision: 13H01--- Serial number:
Coding: 0000071
Shop #: WSC 21959 133 65834
VCID: F2A88419EDBC9B1695-80A6
7 Faults Found:
009298 - Diesel Particle Filter; Differential Pressure Sensor
P2452 - 000 - Elect. Malfunction
Mileage: 143285 km
Date: 2015.01.02
Time: 21:09:16
Voltage: 11.93 V
Pressure: 0 mbar
Pressure: 0 mbar
(no units): 0.0
Temperature: 29.7°C
009258 - Exhaust Gas Temperature Sensor; B1 S3
P242A - 000 - Malfunction
Mileage: 143285 km
Date: 2015.01.02
Time: 21:09:16
Voltage: 11.86 V
Temperature: 28.8°C
Temperature: 18.0°C
Temperature: 930.0°C
009326 - Exhaust Gas Temperature Sensor 4 Bank 1
P246E - 000 - Electrical Malfunction
Mileage: 143285 km
Date: 2015.01.02
Time: 21:09:16
Voltage: 11.86 V
Temperature: 28.8°C
Temperature: 18.0°C
P242A - 000 - Malfunction - MIL ON
Fault Status: 11100000
Mileage: 143285 km
Date: 2015.01.02
Time: 21:09:21
Voltage: 11.86 V
Temperature: 28.8°C
Temperature: 18.0°C
P246E - 000 - Electrical Malfunction - MIL ON
Mileage: 143285 km
Date: 2015.01.02
Time: 21:09:21
Voltage: 11.86 V
Temperature: 28.8°C
Temperature: 18.0°C
004374 - Oxygen (Lambda) Sensor Heating; B1 S1
P1116 - 000 - Open Circuit
Mileage: 143285 km
Date: 2015.01.02
Time: 21:09:22
Load: 0.0 %
Voltage: 11.86 V
Voltage: 11.86 V
Voltage: 11.86 V
Voltage: 11.86 V
049441 - No Communication with ABS Brake Control Module
U0121 - 000 - - Intermittent
Temperature: 29.7°C
Voltage: 12.01 V
Bin. Bits: 00000000
Torque: 108.0 Nm
Temperature: 31.5°C
Part No SW: 1K0 907 379 BK HW: 1K0 907 379 BK
Revision: 00H31001
Shop #: WSC 35110 377 08192
VCID: FCB4AA217FF8DD66CF-80A8
Reset counter: 119
Date: 2015.01.02
Time: 23:49:21
Count: 3
Count: 20992
Count: 195
Count: 41984
Fault Status: 01100101
Reset counter: 119
Mileage: 143285 km
Date: 2015.01.02
Time: 23:48:02
Count: 3
Count: 20480
Count: 279
Count: 41984
Count: 9728
Reset counter: 119
Mileage: 143285 km
Date: 2015.01.02
Time: 23:48:02
Count: 3
Count: 20480
Count: 295
Count: 41984
Count: 9728
Reset counter: 119
Mileage: 143285 km
Date: 2015.01.02
Time: 23:48:02
Count: 3
Count: 20480
Count: 270
Count: 41984
Count: 9728
Part No SW: 5K0 907 044 AK HW: 5K0 907 044 AK
Component: Climatronic 130 0303
Coding: 0000000000
ASAM Dataset: EV_Climatronic A01001
VCID: F4A482015FA8952687-80A0
13701392 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Bremsensteuergerät - kein Signal/Kommunikation]
Reset counter: 159
Mileage: 143285 km
Date: 2020.08.11
Time: 21:12:09
13701936 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Steuergerät für Bordnetz - bitte Fehlerspeicher auslesen]
Reset counter: 159
Mileage: 143285 km
Date: 2020.08.11
Time: 00:01:16
13701456 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
Reset counter: 159
Time: 00:00:00
9481988 - Air Quality Sensor
B10AF 04 [008] - Internal System Fault
Reset counter: 159
Mileage: 119851 km
Date: 2019.03.27
Time: 09:47:09
Part No SW: 1K0 937 086 HW: 1K0 937 086
Component: BCM PQ35 M 020 0358
Revision: 00020000
Coding: 40180A3A98251AC040080080540081E445510088736D8D60648000000000
VCID: ED929765348244EE48-80B8
Component: Wischer 09100 21 0501
Coding: 009795
Component: RLS 231008 05 54 0402
Coding: 0330AD
01800 - Light Switch (E1)
Reset counter: 159
Mileage: 143285 km
Term 15 Off
Voltage: 12.35 V
Term 50 Off
Reset counter: 159
Mileage: 143285 km
Date: 2015.01.02
Time: 00:01:10
Term 15 On
Voltage: 12.00 V
Term 50 Off
Fault Frequency: 13
Reset counter: 119
Mileage: 143285 km
Date: 2015.01.02
Time: 00:02:06
Term 15 On
Voltage: 11.95 V
Term 50 Off
01316 - ABS Control Module
Reset counter: 159
Mileage: 143285 km
Date: 2015.01.02
Time: 21:12:08
Term 15 On
Voltage: 12.00 V
Term 50 Off
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 5K0 919 475 HW: 5K0 919 475
Component: PARKHILFE 8K H07 0002
Revision: -------- Serial number: 60640825303325
Coding: 100001
VCID: F3A6811D52A6921E9E-80A6
Reset counter: 159
Mileage: 143285 km
Date: 2015.01.02
Time: 21:12:08
Temperature: 30.0°C
Part No SW: 5K0 959 655 HW: 5K0 959 655
Component: AirbagVW10 020 0507
Serial number: 003C2D040KR
Coding: 00003135
ASAM Dataset: EV_AirbaVW10SMEVW360 A01003
ROD: EV_AirbaVW10SMEVW360.rod
VCID: F7BEB50D4EDEFE3EA2-80A2
Component: S.Sens.Fahr.V U01 ----
Serial number: 11543442ZZZZZZZZZZZZ
Component: S.Sens.Beif.V U01 ----
Serial number: 0E2A3442ZZZZZZZZZZZZ
Serial number: 0E110D60ZZZZZZZZZZZZ
Serial number: 28140F0EZZZZZZZZZZZZ
12656896 - No Communication with ABS Brake Control Module
U0121 00 [008] - -
[Lost Communication With Vehicle Dynamics Control Module]
Reset counter: 159
Mileage: 143285 km
Date: 2020.08.11
Time: 21:12:07
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 853 0111
Coding: 0000004
VCID: 8346D1DDC206A29E8E-80D6
Part No SW: 5K0 920 870 C HW: 5K0 920 870 C
Component: KOMBI H21 0028
Coding: 170F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
VCID: AD125765FC0284EE08-80F8
12656896 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Bremse: keine Kommunikation]
Reset counter: 159
Time: 00:00:00
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K089030836
Coding: E9A07F06000202000002
VCID: B73E750DC65E3E3E62-80E2
Reset counter: 159
Reset counter: 159
Mileage: 143285 km
Date: 2015.01.02
Time: 21:12:06
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H21 0028
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
Part No SW: 1K0 959 701 AN HW: 1K0 959 701 AN
Component: Tuer-SG 008 2015
Coding: 0004278
VCID: FAB8AC39B5CCE356DD-80AE
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 69 2301
Revision: 00H15000
Shop #: WSC 01324 785 00200
VCID: AA185C7905EC93D6ED-80FE
Reset counter: 169
Mileage: 143285 km
Date: 2015.01.02
Time: 21:12:08
Voltage: 11.88 V
DU
Temperature: 30.0°C
Speed: 50.0 km/h
Speed: 50.0 km/h
Part No SW: 1K0 959 702 AN HW: 1K0 959 702 AN
Coding: 0004534
VCID: FBB6A93DBAF6DA5EC6-80AE
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: Radio RCD510 036 0130
Revision: 00000001 Serial number: VWZ1Z3H3348221
Coding: 0500040004
Shop #: WSC 00028 028 00001
VCID: E582EF45EC727CAE00-80B0
00625 - Vehicle Speed Signal
Reset counter: 159
Mileage: 143285 km
Date: 2015.01.02
Time: 21:12:12
Part No SW: 1K0 959 703 AL HW: 1K0 959 703 AL
Component: Tuer-SG 007 2009
Coding: 0000144
Shop #: WSC 01357 011 1012552
Part No SW: 1K0 959 704 AL HW: 1K0 959 704 AL
Coding: 0000144
End----(Elapsed Time: 01:12, VBatt start/end: 11.8V/11.7V. VIgn 11.8V)-----
