Tuesday,14,July,2020,19:52:59:09568
VCDS Version: 20.4.1.0 (x64)
VIN: WAUZZZ4H0FN012370 License Plate: VK6
Mileage: 61528km-38231mi Repair Order:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 20 28 30 34 36 3B 42 44 46
47 52 53 55 56 57 5F 62 6C 6D 6F 72 81 88 89 8F 90 AC
VIN: WAUZZZ4H0FN012370 Mileage: 61528km-38231miles
Address 01: Engine (J623-CTBA) Labels:. 059-907-401-V2.clb
Part No SW: 4H0 997 401 E HW: 4G0 907 401 E
Component: 3.0TDI EDC17 H14 0002
Revision: 58H14---
Coding: 0A2A4032052601030800
Shop #: WSC 56987 001 1048576
ASAM Dataset: EV_ECM30TDI0114H0997401E 001002
ROD: EV_ECM30TDI0114H0997401E.rod
VCID: 2F6AC2D076382CFEA2-807A
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4H1 927 158 CL HW: 0BK 927 156 AD
Component: 0BK 30TDIRdW H18 1011
Revision: --H18---
Coding: 000001
ASAM Dataset: EV_TCMALX51011 002022
ROD: EV_TCMALX51011_002_AU64.rod
VCID: 7CF0259CF7CE076657-8028
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 T HW: 4H0 907 379 T
Component: ESP PREMIUM H10 0665
Coding: 60E5AB8006A7D501E300
ASAM Dataset: EV_ESPPremi 005024
ROD: EV_ESPPremi_005_AU64.rod
VCID: 43829E60CAB0B89E56-8016
Part No SW: 4H0 907 064 FB HW: 4H0 907 064 EB
Component: BCM2 2.0 H36 0551
Coding: 05B76F4E000000000000
VCID: 6ED41FD4B9B265F6E9-803A
Serial number: 0214000096215008
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-BFS H08 0156
Revision: AA000000 Serial number: 00000107698895
Coding: 0038320000047201000001010101112131313333283333
VCID: 3460CDBC971E0F26DF-8060
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 N HW: 4H0 820 043 N
Component: Klima 4 Zonen H20 0210
Coding: 362100BE300000
ASAM Dataset: EV_AirCondiFront 003001
ROD: EV_AirCondiFront_002.rod
VCID: 2B52D6C0422050DE8E-807E
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 AB HW: 4H0 907 063 AB
Component: BCM1 2.0 H20 0242
Revision: 19020001 Serial number: 00000846087801
Coding: 0105001440349FE0C9014087A0001800009DC30A2F080201800008946100170000400034030000
VCID: 68D869CC9B56BBC6A3-803C
Subsystem 1 - Part No SW: 4H2 955 119 C HW: 4H2 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 140322 H36 0090
Serial number: 140617221752
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 22835169
Coding: 02004E
Subsystem 3 - Part No SW: 4H0 941 531 B HW: 4H0 941 531 B
Component: E1 - LDS H07 0044
Serial number: 03 07 2014 00000706
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA108371000007682258
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 38584537000000000001
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P1001JZFD
Coding: 30333045313430303038554A305234483053
VCID: 3B72E680B240C05E1E-806E
Serial number: 3575HRB40552LPPK4OFA
Serial number: 3585HRB40672MSOA586Q
Serial number: 3515JRB405F2SIIAB0BL
Serial number: 3525JRB405D2SIIAO0J+
Serial number: 3554VRB400E52L7E7HLQ
Serial number: 3564VRB400E52L7EJ1PR
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 01335NG40016P
Coding: 000034
VCID: 377AFAB08668E43EFA-8062
Subsystem 1 - Part No SW: 4H0 951 528 A HW: 4H0 951 528 A
Serial number: 16 05 2014 E0404115
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4H0 920 910 P HW: 4H0 920 910 P
Component: TDieGB------- H53 0707
Revision: 37081202 Serial number: 658030714592022
Coding: 33A608001B412600010000
ASAM Dataset: EV_RBD4K 004050
ROD: EV_RBD4K_AU64.rod
VCID: 316EC4A8600C3A0EB4-8064
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 Q HW: 4H0 919 204 Q
Component: Analoguhr D4 H05 0225
Serial number: 2140613000158
Part No SW: 4H0 907 468 AF HW: 4H0 907 468 AC
Component: J533--Gateway H13 0075
Revision: -------- Serial number: 00000001458644
Coding: C0CD078108
ASAM Dataset: EV_GatewPkoUDS 001024
VCID: 75E630B8D4E4562E28-8020
Subsystem 1 - Part No SW: 4H0 915 181 F HW: 4H0 915 181 F
Component: J367-BDM H08 0181
Serial number: 51167757381911393258
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 C HW: 8K0 959 663 C
Component: J532_DCDCStab H05 0006
Serial number: 14182003481021200410
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: FLA H04 0020
Revision: AA001002
Coding: 04028B6B74745D545420363E00
VCID: 67DA6AF09648B4BEAA-8032
Address 28: HVAC, Rear (E265) Labels:| 4H0-919-158.clb
Part No SW: 4H0 919 158 K HW: 4H0 919 158 K
Component: Klima Fond H16 0200
Coding: 2800000000
ASAM Dataset: EV_AirCondiHeck 002001
ROD: EV_AirCondiHeck.rod
VCID: 3878F98C8376EB46F3-806C
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0030
Revision: S0H06000 Serial number: 00000000061133
Coding: 01010101000000000001000202
VCID: 64C07DFC677EDFA68F-8030
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H19 0783
Coding: 008000
ASAM Dataset: EV_AirSuspe 003025
ROD: EV_AirSuspe_VW51.rod
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000107699072
Coding: 00383B0000057201000001010101112131313333203333
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 K HW: 4H0 907 637 F
Component: SARA 6D H03 0056
Revision: -------- Serial number: EJ1BPA7701XB3D
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 377AFAB08E68E43EFA-8062
Part No SW: 4H0 959 793 S HW: 4H0 959 793 H
Component: TSG FA H07 0280
Revision: -------- Serial number: 0000099537368
Coding: 011F12015E01628202083002
VCID: 499E8C48E09C62CE9C-801C
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0027721498
Coding: 101000010001
ASAM Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_009.rod
VCID: 3362CEA09A10081EC6-8066
Revision: 00002001 Serial number: 0338055991
Coding: 011B0E2280B93881B320C784080316470000000000000000000000000000
Subsystem 1 - Part No: 4H0 951 177
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4H0 947 135 A HW: 4H0 947 135 A
Component: Dachelektroni H13 0080
Serial number: A2014000000000802314
Subsystem 4 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: GEB.F.Heckoef H16 0811
Serial number: 93260572
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000116369
Coding: 030000
VCID: 1D3608180494AE6E00-8048
Part No SW: 4H0 959 792 H HW: 4H0 959 792 H
Component: TSG BF H06 0280
Revision: -------- Serial number: 0000105535178
VCID: 3D76E898A454CE6E20-8068
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001127612
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D56D8D87C345EEE90-8078
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Part No SW: 4H4 907 357 B HW: 7P6 907 357 B
Component: MxB-ECU 001 0049
Coding: 02F6021022630200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 004002
ROD: EV_HeadlRegulAUDIMXBAU64X_004_AU64.rod
Subsystem 1 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7530
Coding: E00200
Subsystem 2 - Part No SW: 7PP 941 472 G HW: 7PP 941 472 G Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7540
Coding: E00200
Part No SW: 4G0 035 061 N HW: 4G0 035 061
Component: Radio U DAB H60 0139
Revision: AB001007 Serial number: 109G10E7944850
Coding: 010103010000000001
VCID: 285829CC5BD67BC663-807C
Address 57: TV Tuner (R78) Labels: None
Part No SW: 4G0 919 129 C HW: 4G0 919 129
Component: NGTV-DVB H04 0690
Revision: R0043000 Serial number: 06801301405001
Coding: 03000000
VCID: 2D56D8D874345EEE90-8078
Part No SW: 4H0 035 666 R HW: 4H0 035 666 N
Component: H-BN-EU H47 0814
Revision: -------- Serial number: 178GZ0EB001334
Coding: 02010100000BF1EF45908B1E00000003E00001020000000000
VCID: 3878F98C8B76EB46F3-806C
Subsystem 1 - Part No: 8R0 060 884 BT
Component: EUR 2014 1903
Subsystem 2 - Part No SW: 4H0 919 604 G HW: 4H0 919 604 G
Component: DU8 D4 SV NB H48 0021
Serial number: AUZ8ZDEC901LKWP
Subsystem 3 - Part No SW: 4H2 919 600 H HW: 4H2 919 600
Component: E380 BDT D4 H09 0065
Serial number: 00000000163688
Component: CD-Database 5950
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 E HW: 4H0 959 795 E
Component: TSG HL H06 0280
Revision: -------- Serial number: 0000105537294
Coding: 010F12014000628202083002
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
Part No SW: 4S0 907 441 B HW: 5Q0 907 441 A
Component: D4-PA RVC Mid H07 0050
Coding: 024601010201000300
ASAM Dataset: EV_CamSysRearPANAAU914 002002
ROD: EV_CamSysRearPANAAU914.rod
VCID: 326CCBA4650A0116CD-8066
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 AC HW: 4H0 959 107 AC
Component: HDSG-Modul H12 0049
Revision: 10012001 Serial number: 173401591
Coding: 021004C020
ASAM Dataset: EV_DeckLidContrUnit 001032
ROD: EV_DeckLidContrUnit.rod
VCID: 6FEA02D0B6B86CFEE2-803A
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000156007
Coding: 220000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 63C27EE06A70D89E76-8036
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H06 0280
Revision: -------- Serial number: 0000105536924
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H2 927 731 A HW: 4H2 927 731 A
Component: GSM-RL H09 0083
Revision: 0R0D5015 Serial number: SN140531 0086
ROD: EV_GSM2x3Mono_AU64.rod
VCID: 2C50D5DC472E57E687-8078
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00016971192901
Coding: 672FF2
ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00016971189201
Coding: 272FF2
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Coding: 00060000031F030000030800424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R_VW51.rod
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 141630386
ROD: EV_RDCMA00100.rod
End-------------------------(Elapsed Time: 06:58)--------------------------
