- Apr 21, 2019
- 29
- 32
- Worcester, UK
- C?ID=339141
Can I assume that these are transient errors caused by disconnecting and reconnecting the caravan with the engine running and can be ignored/cleared?
My wife checked the caravan lights were all working each time we set off.
Thanks...
Thanks...
Thursday,06,August,2020,07:48:08:52412
VCDS Version: 20.4.1.0 (x64) HEX-NET CB: 0.4523.4
VIN: WVGZZZCRZLD003566 License Plate:
Mileage: 13957km-8672mi Repair Order:
Chassis Type: CR-VW53 (4N2)
Scan: 01 02 03 06 09 13 15 16 17 19 2B 36 42 44 46 52 5F 69 6C 6D
74 81 A5 AC BB BC CB D6 D7 DE
VIN: WVGZZZCRZLD003566 Mileage: 13957km-8672miles
CB-Rear Axle Steering -- Status: OK 0000
Address 01: Engine (J623-DENA) Labels: None
Part No SW: 760 907 401 G HW: 059 907 309 L
Component: 3.0l V6 TDI H26 0002
Revision: CAH26---
Coding: 292A4032057E050335180000000400000000000000000000
Shop #: WSC 31414 039 00001
ASAM Dataset: EV_ECM30TDI011760907401G 001002
ROD: EV_ECM30TDI011760907401G.rod
VCID: 197A3B6B18550E4EEC-804C
17159 - Databus
Mileage: 12914 km
Date: 2020.07.24
Time: 09:45:27
Engine speed: 731.50 /min
Normed load value: 40.8 %
Coolant temperature: 28 °C
Intake air temperature: 20 °C
Voltage terminal 30: 14.820 V
Unlearning counter according OBD: 19
Drivetrain coordinator: brake function status-Bits 0-7: 32
Acceleration: 0.000 m/s²
Engine status: COENG_RUNNING
Address 02: Auto Trans (J217) Labels:* Redir Fail!
Part No SW: 760 927 158 B HW: 0D5 927 156 N
Component: 0D5 30TDIRdW H05 1003
Revision: --H05---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002014
ROD: EV_TCMALX52011_VW53.rod
VCID: 1F0E15730671607E12-804A
Part No SW: 4M6 907 379 AC HW: 4M6 907 379
Component: ESP9 Premium H06 0856
Coding: 1DA732B730A20B99DEA34897188356EAE93AE1B84C0CD07B12186A57975C87
ROD: EV_ESP9BOSCHCMP_VW53.rod
VCID: 7EB008F7E13BC97679-802A
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 4M6 959 760 B HW: 4M6 959 760 B
Component: MEM-BFS 009 0044
Serial number: 00000384427733
Coding: 0138B8000000A88188000101210100008900000707008F8F00000000015000
Shop #: WSC 31414 043 00001
ROD: EV_SCMPasseSideCONTIAU736_VW38.rod
VCID: 3D32CFFBACBD126E20-8068
Valve Block 1 In Passenger Side Front Seat:
Subsystem 1 - Part No SW: 4N0 907 182 HW: 4N0 907 182
Component: N477 VB1 BFSv H04 0011
Serial number: SJ8001250619402580D7
Coding: BF2F00
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 4N0 907 063 KG HW: 4N0 907 063 AG
Component: BCM1 MLBevo H10 0691
Coding: 07501143E1790009070D97085BBE8C40000B30100000009301100800FB2476011BC500BB12B6C6170000010000D128181800000044010104000000000000000000
ASAM Dataset: EV_BCM1BOSCHAU651 016011
ROD: EV_BCM1BOSCHAU651_016.rod
VCID: 7DB20FFBEC3DD26E60-8028
Subsystem 1 - Part No SW: 762 955 113 HW: 762 955 113
Component: WIPER 250719 011 0420
Serial number: VZ1SKA 1000917250719
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 23357623X81A955555A0
Coding: 02006D
Subsystem 3 - Part No SW: 762 941 633 HW: 762 941 633
Component: E1 - LTM H06 0054
Serial number: 13S27.06.1900140204
Subsystem 4 - Part No SW: 3G0 857 511 AL HW: 3G0 857 511 AL
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE130041920810040
Coding: 030000
Interior Light Module:
Subsystem 5 - Part No SW: 760 947 105 N HW: 760 947 105 N
Component: Dachelektroni H32 0057
Serial number: 00000774360000000000
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 760 907 561 C HW: 760 907 561
Component: LRR4R H04 0333
Coding: 32657FCB78000400000020A000000010051246484401009E00
ASAM Dataset: EV_ACCBOSCHAU65X 002023
ROD: EV_ACCBOSCHAU65X_VW53.rod
VCID: 1C74227F17677B66F7-8048
0935 - Databus
[FAULT_TRAILOR_LIGHT_DEFECTIVE]
Reset counter: 9
Mileage: 12914 km
Date: 2020.07.24
Time: 09:45:27
Voltage terminal 15: 14.8 V
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s²
Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
Steering_angle-Data: -386.600 °
Yaw_rate-Data: -0.002 rad/s
adjustment_calculation: On
Misalignment angle: horiz: -0.114 °
Misalignment angle: horiz: fast algorithm: -0.170 °
Congestion pilot: status: OFF
Outside air temperature: 17.50 °C
Sensor blindness: radar: no blindness detected
Address 15: Airbags (J234) Labels:* None
Part No SW: 4M0 959 655 J HW: 4M0 959 655 J
Component: AirbagVW31 H07 2720
Serial number: 003YQM020RRC
Coding: 88CCC0C00C800000585400EF308D41A80065
Shop #: WSC 31414 030 00001
ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
ROD: EV_AirbaVW31SMEAU65x_VW53.rod
VCID: 42C8BC07D5436D965D-8016
Subsystem 1 - Part No SW: ----------- HW: 480 002 207 19
Serial number: 357000000004BC819E3Y
Subsystem 2 - Part No SW: ----------- HW: 480 002 207 19
Serial number: 35800000000D0B152E3M
Subsystem 3 - Part No SW: ----------- HW: 480 032 507 19
Component: SideSensor_Dr 002 0149
Serial number: 351001C24B8AC8C07B0L
Subsystem 4 - Part No SW: ----------- HW: 480 032 507 19
Component: SideSensor_Pr 002 0149
Serial number: 352001C1CC740CA03B1A
Subsystem 5 - Part No SW: ----------- HW: 480 030 606 19
Component: FrontSensor_D 002 0189
Serial number: 355001C20FF2EDF0CB95
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 480 030 606 19
Component: FrontSensor_P 002 0189
Serial number: 356001C20FF326A07ABM
Pedestrian Protection Driver:
Subsystem 7 - Part No SW: ----------- HW: 480 032 606 19
Component: PedP_Sensor_D 002 014A
Serial number: 228001C208FD7590192A
Subsystem 8 - Part No SW: ----------- HW: 480 031 807 19
Component: PedP_Sensor_P 002 014A
Serial number: 229001C2462C0020BC90
Pedestrian Protection Center:
Subsystem 9 - Part No SW: ----------- HW: 480 032 506 19
Component: PedP_Sensor_C 002 014A
Serial number: 230001C208F57E711D6B
Subsystem 10 - Part No SW: ----------- HW: 480 001 406 19
Component: PedPSensor_D2 001 0887
Serial number: I0M00000000B1438CCBG
Subsystem 11 - Part No SW: ----------- HW: 480 001 406 19
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000E1438CCBK
Address 16: Steering wheel (J527) Labels: None
Part No SW: 760 953 507 B HW: 760 953 507 B
Component: Lenks.Modul H03 0006
ROD: EV_SMLSKLOAU736_VW53.rod
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 762 920 790 A HW: 762 920 790 A
Component: FBenRDW H12 0208
Coding: A5A631E27F94260001A86322B0E06808E40000A0
ROD: EV_DashBoardAU65X_VW53.rod
VCID: 1B76216312697C5EFE-804E
Operating Unit Drive Mode Selection:
Subsystem 1 - Part No SW: 760 927 531 G HW: 760 927 531 G
Component: E881 BedieFPA 001 0460
Serial number: 000000091171SG3000M1
Level control system control head:
Subsystem 2 - Part No SW: 760 927 135 B HW: 760 927 135 B
Component: E281 BedieNiv 001 0110
Serial number: 000000091171SG3001CH
Part No SW: 4N2 907 468 BB HW: 4N2 907 468 AB
Component: Gateway H16 0052
Revision: BD000001 Serial number: 018BD855619725
Coding: 0301000300008E407F07000000DB0532589E00070C000000037D078E10000100
ASAM Dataset: EV_CGateCONTIAU491 004190
ROD: EV_CGateCONTIAU491_004_VW53.rod
VCID: 7AB804E7FD13E55645-802E
Subsystem 1 - Part No SW: 5G0 959 442 AB HW: 5G0 959 442 AB Labels: 3C8-959-537.CLB
Component: E221__MFL-MD9 H18 0052
Serial number: 39190001239260049243
Coding: 2FFFFF
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 7379992105
Part No SW: 3Q0 905 861 C HW: 3Q0 905 861 C
Component: ELV-MLBevo H05 0020
Serial number: 19000192483014
Coding: 8800000000000000
ROD: EV_ELVMarqMQBA0_VW41.rod
VCID: 3424EADF9FF7D326DF-8060
Address 36: Seat Mem. Drvr (J136) Labels:* None
Component: MEM-FS 009 0044
Serial number: 00000384338324
Coding: 01389A400000A48188000101210100008900000707008F8F00000000015000
ROD: EV_SCMDriveSideCONTIAU736_VW53.rod
Valve Block 1 In Driver Side Front Seat:
Component: N475 VB1 FSv H04 0011
Serial number: SJ8001250619402580CF
Coding: BF2F00
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M1 959 593 J HW: 4M1 959 593 D
Component: TSG FS002 0421
Serial number: YE007SFF28625
Coding: 003F9A00DE01040000013082
ROD: EV_DCU2DriveSideMAXHKLO.rod
VCID: 44C4BA1FCF5763A66F-8010
Part No SW: 4N0 909 144 E HW: 4N0 909 144 C
Component: EPS_MLBEVO2BS H22 0505
Coding: B2150101000100
ASAM Dataset: EV_EPSVWBSAU426 010017
ROD: EV_EPSVWBSAU426_010.rod
VCID: 3228ECC765E3DD16CD-8066
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 4N0 907 064 DP HW: 4N0 907 064 P
Component: BCM2 MLBevo H15 0202
Coding: 01350000AFB000487329A0041C00480203000000004704502F0400000508803F001F31C4010001
ASAM Dataset: EV_BCM2CONTIAU651 010009
ROD: EV_BCM2CONTIAU651_010_VW53.rod
VCID: 004C760F9BCFBF860B-8054
Ignition key:
Subsystem 2 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY1916516JJ
Subsystem 3 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000487902
Rear Spoiler Adjustment:
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 4M1 959 592 J HW: 4M1 959 592 D
Component: TSG BFS002 0421
Serial number: YE007SFF3060B
Coding: 003F9A00DE01040000013080
ROD: EV_DCU2PasseSideMAXHKLO.rod
VCID: 43C6B903CA59649E56-8016
Part No SW: 760 035 063 A HW: 760 035 063 A
Component: MU-H-LND-EU 049 2648
Coding: 02350601FF00000043110101C08808301F0206E601A004009F
Shop #: WSC 31414 152 00001
ROD: EV_MUHigGen2pALPI_VW53.rod
VCID: 0F6E4533D691D0FE82-805A
Subsystem 1 - Part No SW: 762 919 618 HW: 762 919 618
Component: ABT_Prem_R H40 5211
Serial number: VWZ6ZGW1710136
Subsystem 2 - Part No: V03 959 805 HK
Component: MIB2P_EU_Q419 0411
Component: Gracenote2 1010
Volume Control 1:
Subsystem 4 - Part No SW: 762 927 341 HW: 762 927 341
Component: VW536LLB H06 0109
Serial number: 2019050600000182
Media socket:
Subsystem 5 - Part No SW: 5G0 035 953 D HW: 0
H08 0014
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 4M0 907 383 G HW: 4M0 907 383 B
Component: Anhaenger H33 0273
Revision: 9A001003 Serial number: 0522821047
Coding: 0110000202000000
ROD: EV_TrailFunctGener2Hella_VW27.rod
VCID: 3620D0D7898BC136E1-8062
655882 - Bulb for Brake Light on Trailer
C10F3 15 [008] - Open or Short to Plus
Reset counter: 9
Mileage: 12914 km
Date: 2020.07.24
Time: 09:45:27
656394 - Bulb for Left Tail Light on Trailer
C10F5 15 [008] - Open or Short to Plus
Reset counter: 9
Mileage: 12914 km
Date: 2020.07.24
Time: 09:45:27
Address 6C: Back-up Cam. (J772) Labels:* None
Part No SW: 760 980 568 HW: 760 980 568
Component: RVC Compact+ H09 0250
Coding: 0135060123002015000048
ASAM Dataset: EV_CamSysRVRVCARPANAMLBEv 001001
ROD: EV_CamSysRVRVCARPANAMLBEv.rod
VCID: 618A538B7085168E64-8034
Part No SW: 4M0 959 107 D HW: 4M0 959 107 A
Component: HDSG-Modul H13 0171
Revision: -------- Serial number: A2-C737-6252-4
Coding: 17D8
ROD: EV_DeckLidCONTIAU736_VW27.rod
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 4M0 907 777 S HW: 4M0 907 777 B
Component: Fahrwerk-SG H37 1253
Serial number: 0807190824
Coding: B0504940F8
ASAM Dataset: EV_ChassContrContiAU426 001004
ROD: EV_ChassContrContiAU426.rod
VCID: 49DAAB2BE875BECE9C-801C
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 HW: 4M0 907 778
Component: V66LFKompOLV H06 0013
Serial number: 00000000004130657889
Coding: 303030
Address 81: Gear Shift (J587) Labels: None
Part No SW: 762 713 041 B HW: 4M2 713 041 G
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 19061753171127
ASAM Dataset: EV_GSMWaehlZFAU736 001017
ROD: EV_GSMWaehlZFAU736.rod
VCID: 116A434BC0A5C60E94-8044
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* None
Part No SW: 4KE 907 107 AL HW: 4N0 907 107 G
Component: zFAS Var B H09 0293
Coding: 04C2840000000000000806000090C63C18075300000000000000000000000000000000000000000000000000000000000000000000000000000040000000000000001004000000700000004000000000008040000020
ASAM Dataset: EV_ZFASAU516 001003
ROD: EV_ZFASAU516_001.rod
VCID: 095A6B2BA8F5FECE5C-805C
4107 - Databus
[reversibler_Fehler_im_ACC_System]
Reset counter: 9
Mileage: 12914 km
Date: 2020.07.24
Time: 09:45:28
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 D HW: 4M0 907 355 B
Component: SCR-Stg-G3H05 0006
ASAM Dataset: EV_RDCMINERGAU736 005012
ROD: EV_RDCMINERGAU736_VW53.rod
Part No SW: 4M1 959 595 J HW: 4M1 959 595 D
Component: TSG HFS004 0421
Serial number: YE007SFK23657
Coding: 003E92000000040000013080
ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
VCID: 46C0A017F96B51B671-8012
Component: TSG HBFS004 0421
Serial number: YE007SFK23656
ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
Address CB: Rear Axle Steering (J1019) Labels:* None
Part No SW: 4M0 909 145 AA HW: 4M0 909 145 E
Component: HAL_MLBevoH08 0698
Revision: -------- Serial number: CCC_098_B_1122_
Coding: 42250E00
ASAM Dataset: EV_RearAxleSteerZFAU736 010018
ROD: EV_RearAxleSteerZFAU736_010.rod
VCID: 6FAE25B3B651B0FEE2-803A
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 BH HW: 7P5 941 591 B
Component: LED1L H07 0009
ROD: EV_LED_PLUS_L_KEBODAVW416_VW27.rod
VCID: 034679038AD9A49E16-8056
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H07 0009
Address DE: Charger 1 for mobile dev (J1146) Labels:* 4N0-035-502.clb
Part No SW: 4N0 035 502 B HW: 4N0 035 502 B
Component: WLC Front H14 0061
Coding: 400000
ROD: EV_Charg1MobilDevicAU651.rod
VCID: 230619832A19449E36-8076
End----------(Elapsed Time: 02:14, VBatt start/end: 12.1V/12.1V)-----------
