Someone had asked me to look at their 2013 Passat. The issue with it is that the car doesn't start whenever the car is parked out in the sun or recently running. The dashboard displays "immobilizer active". If the car is left in the shade for a few hours or hasn't been running for a few hours (and not eposed to sunlight, then the car may start and run without issue. The car will stay running once started if left in the sun and will drive to the destination without an issue. The issue will resurface once attempting to restart the hot vehicle. This issue happens with both genuine keys that the car came with.
I've placed an AutoScan below for your perusal.
Sunday,09,August,2020,20:48:03:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.2.0 (x64)
Dealer/Shop Name: Matthew Taylor
VIN: WVWZZZ3CZDP008334 License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 25 2E 42 44 46 4C 4F 52 53
56 61 62 72 77
VIN: WVWZZZ3CZDP008334 Mileage: 72710km-45179miles
Address 01: Engine (CCZ) Labels:. 06J-907-115-CCZ.clb
Part No SW: 06J 906 027 M HW: 06J 907 309 B
Component: MED17.5.2 03 8324
Revision: PAH04--- Serial number: VWZCZ000000000
Coding: 040400101C070160
Shop #: WSC 00028 028 00001
VCID: 354FD8585CDD5E2EF0-8060
000604 - Fuel Pump Control Module
P025C - 000 - Short to Ground - Intermittent
Temperature: -40.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.192 V
005488 - Engine Start Blocked by Immobilizer
P1570 - 000 - - Intermittent
Fault Frequency: 33
Mileage: 69953 km
Date: 2014.10.27
Time: 00:19:31
RPM: 1307 /min
Load: 11.0 %
Temperature: 96.0°C
Temperature: 45.0°C
Voltage: 12.192 V
Readiness: 0000 0001
Part No SW: 02E 300 058 N HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3501
Revision: 05551213 Serial number: 00001205241579
VCID: 256F0818EC7D2EAE40-8070
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 BK HW: 3AA 614 109 BK
Component: J104 C2 450M VDF6 0024
Revision: --H07--- Serial number: 00000005896729
Coding: 0001929
VCID: 77D3125006516C3E22-8022
Part No SW: 3AA 907 044 AG HW: 3AA 907 044 AG
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0014004802
Shop #: WSC 00028 028 00020
VCID: 75CF1858D45D1E2E30-8020
13701936 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 251
Mileage: 71894 km
Date: 2020.07.24
Time: 20:34:43
Address 09: Cent. Elect. Labels: None
VCID: 558F78D8BC9D7E2E10-8000
Address 10: Park/Steer Assist (J446) Labels:| 3AE-919-475.clb
Part No SW: 3AE 919 475 B HW: 7N0 919 475
Component: PARKHILFE 8K H06 0016
Revision: -------- Serial number: 28261216701352
Coding: 108101
ASAM Dataset: EV_EPHVA18VW47X0000 001005
ROD: EV_EPHVA18VW47X0000.rod
VCID: 3E5DC774A1EB9D7621-806A
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Revision: 00000000 Serial number: 11061200550002
Coding: 010180
VCID: 2773021056713CBE72-8072
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__108 VW10 HI 2118
Revision: 24017000 Serial number: 003L7PCHFSUT
Coding: 0012344
VCID: 7CD90D7C3F774F664F-8028
Subsystem 1 - Serial number: 6332MTS664221482
Subsystem 2 - Serial number: 6342MTS665481492
Subsystem 3 - Serial number: 6351HTS67DSS4BKR
Subsystem 4 - Serial number: 6361HTS60UOS3BKR
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
008 - Implausible Signal - Intermittent - MIL ON
Fault Status: 10101000
Mileage: 70226 km
Date: 2014.11.04
Time: 06:45:26
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C5 953 501 BG HW: 5K0 953 569 T
Revision: FF010041 Serial number: 20120618301859
Coding: 098A250000
VCID: 6BFB3E208219D8DED6-803E
Component: E221__MFL-TK6 H07 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1
Part No SW: 3AA 920 870 H HW: 3AA 920 870 H
Component: KOMBI H05 0705
Coding: 160F01
ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
VCID: 3753D2508ED1AC3EE2-8062
Part No SW: 7N0 907 530 T HW: 7N0 907 530 K
Component: J533 Gateway H40 1632
Revision: H40 Serial number: 160612F2002526
Coding: 461007
VCID: 41A7BC88D815E28E5C-8014
Reset counter: 26
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 043 0400
Revision: 00043000 Serial number: VWZCZ000000000
VCID: 76CD1F54015B153639-8022
Component: ELV 029 0380
3C0905861J ELV 029 0380
01176 - Key
Fault Frequency: 82
Reset counter: 245
Mileage: 69970 km
Date: 2014.10.27
Time: 23:01:51
02811 - Control Module for Electronic Steering Column Lock (J764)
014 - Defective
Fault Status: 01101110
Fault Frequency: 78
Reset counter: 245
Mileage: 70012 km
Date: 2014.10.30
Time: 00:11:18
02815 - Steering Column Lock; Supply Voltage for Locking Motor
Fault Status: 00100110
Fault Frequency: 13
Reset counter: 29
Mileage: 70012 km
Date: 2014.10.30
Time: 00:19:09
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662863366
Coding: 010100
VCID: 2A75FB24456301D66D-807E
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0534
Revision: 12110009 Serial number: 0005157179
Coding: 0002FF
VCID: 354FD85894DD5E2EF0-8060
Slave Driver:
Subsystem 1 - Part No SW: 3AA 959 704 B HW: 3C8 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0502
Serial number: 00000002974954
Coding: 0102D8
66304 - Switch for Drivers Side Window Regulator
B11F0 29 [008] - Signal Implausible
Reset counter: 26
Mileage: 72552 km
Date: 2020.08.06
Time: 03:12:56
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 205 3305
Revision: 00H22000
VCID: 3753D25046D1AC3EE2-8062
00750 - Warning Lamp
Fault Status: 00101101
Reset counter: 40
Mileage: 71023 km
Date: 2014.11.25
Time: 00:00:25
Voltage: 9.38 V
PD
Temperature: 34.0°C
Component: KSG PQ47 ELV 043 0634
Coding: 01910A0002860E763404941570085FCE105801
Component: Neigungssensor 004 0611
Reset counter: 251
Mileage: 71894 km
Date: 2014.12.15
Time: 20:34:36
Part No SW: 7N0 907 532 HW: 7N0 907 530 K
Component: EZE_2 H40 1632
Coding: 00000008
VCID: 6FC32A30BE0124FEFA-803A
Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0004
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0534
Revision: 14110009 Serial number: 0005172214
Coding: 0002FE
Shop #: WSC 46069 002 1048576
VCID: 364DDF5489DB5536F9-8062
Slave Passenger:
Subsystem 1 - Part No SW: 3AA 959 703 B HW: 3C8 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0502
Serial number: 00000002970488
Coding: 0102D8
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000000264097
Coding: 0022157
VCID: 364DDF5441DB5536F9-8062
03200 - Switch for Electric Parking Brake (E538)
Fault Frequency: 112
Reset counter: 27
Mileage: 65594 km
Date: 2014.06.25
Time: 11:17:37
Voltage: 12.80 V
Count: 10
Speed: 16.0 km/h
Hex Value: 0x1260
Hex Value: 0x0014
Hex Value: 0x0101
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 B HW: 5K0 035 190 B
Component: Radio RCD510 005 0234
Revision: 00000001 Serial number: VWZ1Z3M7246423
Coding: 01000410040010
VCID: 2469151C2747D7A657-8070
Part No SW: 7N0 907 534 HW: 7N0 907 530 K
Component: Batt.regelung H40 1632
Coding: 03260859
VCID: 71C72C48A835320EEC-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900566795
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007662846461
Coding: 0A00000000010100
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A55CB64BDC3B1561D-806E
End-------------------------(Elapsed Time: 05:59)--------------------------
