- Joined
- Feb 1, 2017
- Messages
- 134
- Reaction score
- 47
- Location
- Oulu, Finland
- VCDS Serial number
- C?ID=229426
Hey!
Is it possible for the Audi A6 C7 to have the warning buzzer switched off when the door is opened with the engine running?
Saturday,25,July,2020,14:34:11:00464
Dealer/Shop Name: J.P - V3lmu
VIN: WAUZZZ4G1GN090083 License Plate: AUDI A6 C7
Mileage: 99570km-61869mi Repair Order:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 08 09 15 16 17 19 34 3B 42 44 46 52 53 5F 62 72
8F 90 AC
VIN: WAUZZZ4G1GN090083 Mileage: 99570km-61869miles
Address 01: Engine (J623-CRTE) Labels: Redir Fail!
Part No SW: 4G2 907 311 C HW: 4G2 907 401
Component: 3.0TDI EDC17 X34 0007
Revision: 92X34---
Coding: 0A254012052601030000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM30TDI0114G2907311C 001007
ROD: EV_ECM30TDI011_AU57.rod
VCID: 2517F18315611B2300D-8070
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G0 927 166 A HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H03 0008
Revision: --H03---
Coding: 100001
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021.rod
VCID: 2B0307BB73852D53D69-807E
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 17A6DE41E8657B829B00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41DF4513E109D7031C5-8014
Part No SW: 4H0 907 064 GN HW: 4H0 907 064 GN
Component: BCM2 2.0 H37 0572
Coding: 01A8700E000000000000
VCID: 7BA3F7FBC3E57DD3069-802E
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 CB HW: 4G0 820 043 CB
Component: KLIMA 2 ZONEN H14 0112
Serial number: 24091500111245
Coding: 36011108210000
ASAM Dataset: EV_AirCondiBasisUDS 003009
ROD: EV_AirCondiBasisUDS_003.rod
VCID: 619FA59341C9B7033C5-8034
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00001176423902
Coding: 2600C01400349FE08901408300001D0CCF9CC20826090201000004206101170200400024030000
Shop #: WSC 12345 123 61029
VCID: 71BFD5D391A90783AC5-8024
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 150808 H38 0080
Serial number: 150903042155
Coding: 0045F7
Component: G397_RLFS H06 0004
Serial number: 20705292
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 30 09 2015 00000551
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: EEC84EC7000000000001
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P1006NAP7
Coding: 30333130313730323735554A304C34473053
VCID: 3B2337FB83E5BDD3469-806E
Serial number: 3575HRB40653KGHSE1L
Serial number: 3585HRB40593KGHS690L
Serial number: 3515JRB404V3J2AS4OQB
Serial number: 3525JRB40673FSTU3PKR
Serial number: 3554VRB40533K8QIH8G%
Serial number: 3564VRB404V3KDM68GPO
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862OIO001VK
Coding: 000014
VCID: 3B2337FB8365BDD3469-806E
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Serial number: 24 07 2015 G0080881
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 934 D HW: 4G8 920 934 D
Component: TDieRdw H11 0104
Revision: 07001088 Serial number: 658011015596020
Coding: 03AF0A001B410008010200
ASAM Dataset: EV_RBD4K 004055
ROD: EV_RBD4K_AU57.rod
VCID: 323D1ADF54AF7C9B95F-8066
Part No SW: 4G5 907 468 F HW: 4G0 907 468 AC
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000001996509
Coding: C0CD078118
ASAM Dataset: EV_GatewPkoUDS 001028
VCID: 382928F7B2D396CBABB-806C
Serial number: 0917338003
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663 D
Component: J532_DCDCStab H23 0022
Serial number: 1507250000000000013F
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H19 0783
Coding: 008000
ASAM Dataset: EV_AirSuspe 003025
ROD: EV_AirSuspe_VW51.rod
VCID: 2F3B13AB479D5173FA1-807A
C10C8 00 [008] - -
Reset counter: 103
Mileage: 99376 km
Date: 2020.07.23
Time: 13:04:20
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA820A8DB3
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 363526CFB8C760BBB97-8062
Component: TSG FA H03 0511
Coding: 011F17014000628002080002
VCID: 47CB5B0BCFADE933D21-8012
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H53 0202
Revision: 00000003 Serial number: 0000251345
Coding: 101000010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A2D32FF8CDF84DB5DF-806E
Revision: 00002001 Serial number: 0381549437
Coding: 0100063800B90000C320080408010E470000000000000000000000000000
Component: TSG BF H03 0511
Coding: 011F17014C00628002080002
VCID: 46D5560FC8A7F03B297-8012
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001604696
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D0709A34D912363C8D-8078
Part No SW: 4G1 035 182 A HW: 4G1 035 182 A
Component: RMC Cnct Plus H61 0139
Coding: 0100000001E15B47482B060301010000000000
VCID: 2019E0970AC3FE0B73B-8074
Subsystem 1 - Part No SW: 4G0 919 603 B HW: 4G0 919 603 B
Component: DU6 Basic H43 0084
Serial number: 9464I10F2728264
Subsystem 2 - Part No SW: 4G1 919 610 E HW: 4G1 919 610 E
Serial number: 90349OII000E7
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Component: TSG HL H03 0511
Coding: 010F15004000628002080002
VCID: 49CF5D33D9B91F43C45-801C
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0511
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H14 0080
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
VCID: 313F15D351A94783EC5-8064
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H14 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R_VW51.rod
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 152531261
ROD: EV_RDCMA00100.rod
End----------(Elapsed Time: 01:33, VBatt start/end: 14.6V/14.6V)-----------
