Abs long coding for 2010 vw gti
Pnuts13
New Member
Can anyone help me get the code for the abs module. Thanks in advance
Sunday,05,July,2020,19:33:37:52994
VCDS Version: 20.4.1.0 (x64)
VIN: WVWED7AJ1BW255668   License Plate:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 47 52 56 65 77
VIN: WVWED7AJ1BW255668   Mileage: 129730km-80610miles
1C-Position Sensing -- Status: Malfunction 0010
2E-Media Player 3 -- Status: Malfunction 0010
   Part No SW: 1K0 907 115 AQ    HW: 1K0 907 115 AK
   Revision: E3H25---    Serial number:
   Coding: 0403010818070160
   VCID: 75EA1AEA1C0E342E28-8020
001431 - Thermostat for Mapped Engine Cooling (F265)
               P0597 - 000 - Open Circuit
                    Mileage: 129737 km
                    Date: 2014.11.26
                    Time: 00:04:48
                    Load: 0.0 %
                    Temperature: 45.0°C
                    Temperature: 43.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.573 V
Readiness: 1110 1101
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Revision: 00H30001
   VCID: 78F413DECB1C494633-802C
                    Reset counter: 76
                    Mileage: 185885 km
                    Date: 2017.07.05
                    Time: 00:10:24
                    Count: 7
                    Count: 15
                    Count: 28672
                    Count: 128
                    Count: 26624
                    Count: 256
                    Reset counter: 76
                    Mileage: 129737 km
                    Date: 2014.11.23
                    Time: 00:00:24
                    Count: 7
                    Count: 3
                    Count: 28672
                    Count: 195
                    Count: 24576
                    Count: 512
                    Fault Status: 01100101
                    Reset counter: 76
                    Mileage: 129737 km
                    Date: 2014.11.23
                    Time: 00:00:11
                    Count: 2
                    Count: 2
                    Count: 28672
                    Count: 279
                    Count: 36608
                    Count: 256
                    Reset counter: 76
                    Mileage: 129737 km
                    Date: 2014.11.23
                    Time: 00:00:11
                    Count: 2
                    Count: 2
                    Count: 28672
                    Count: 295
                    Count: 36608
                    Count: 256
                    Reset counter: 76
                    Mileage: 129737 km
                    Date: 2014.11.23
                    Time: 00:00:11
                    Count: 2
                    Count: 2
                    Count: 28672
                    Count: 270
                    Count: 36608
                    Count: 256
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000001002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 75EA1AEAD40E342E28-8020
13635840 - Supply voltage
                    Reset counter: 116
                    Mileage: 185885 km
                    Date: 2023.02.12
                    Time: 00:03:40
   Part No SW: 1K0 937 087 G    HW: 1K0 937 087 G
   Component: BCM PQ35  H+  103 0576
   Revision: 00103 AF
   Coding: 6D180A1E90272A0480080081700005C441010086434D8D60648020200000
   Shop #: WSC 08213 444 12159
   VCID: 356ADAEA9C8E742EE8-8060
   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 02120  21  0512
   Coding: 009795
8 Faults Found:
                    Fault Frequency: 12
                    Reset counter: 116
                    Mileage: 185885 km
                    Date: 2017.07.05
                    Time: 00:11:29
                        Term 15 On
                    Voltage: 7.30 V
                        Term 50 On
00532 - Supply Voltage B+
                    Reset counter: 116
                    Mileage: 185885 km
                    Date: 2017.07.05
                    Time: 00:11:29
                        Term 15 On
                    Voltage: 7.30 V
                        Term 50 On
02391 - Terminal 30 Reference
                    Fault Status: 01101011
                    Reset counter: 76
                    Mileage: 185885 km
                    Date: 2017.07.05
                    Time: 00:00:02
                        Term 15 On
                    Voltage: 11.10 V
                        Term 50 On
00061 - Footwell Lights
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 24
                    Reset counter: 76
                    Mileage: 185885 km
                    Date: 2017.07.05
                    Time: 00:00:12
                        Term 15 Off
                    Voltage: 10.75 V
                        Term 50 Off
                    Fault Frequency: 13
                    Reset counter: 76
                    Mileage: 129737 km
                    Date: 2014.11.23
                    Time: 00:00:14
                        Term 15 On
                    Voltage: 9.85 V
                        Term 50 On
                    Fault Frequency: 13
                    Reset counter: 76
                    Mileage: 129737 km
                    Date: 2014.11.23
                    Time: 00:00:14
                        Term 15 On
                    Voltage: 9.85 V
                        Term 50 On
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 116
                    Mileage: 129737 km
                    Date: 2014.11.24
                    Time: 02:06:32
                        Term 15 On
                    Voltage: 8.30 V
                        Term 50 On
01179 - Incorrect Key Programming
                    Reset counter: 76
                    Mileage: 129737 km
                    Date: 2014.11.24
                    Time: 00:06:41
                        Term 15 Off
                    Voltage: 8.65 V
                        Term 50 Off
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   021 0706
   Serial number: 003C4D0A54Y%
   Coding: 00003031
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3972D6DAB896904E0C-806C
   Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
   Component: BF-Gewichtss.  007 0002
   Serial number: ---0000R--0004X9DT00
   Serial number: 3582MSME6242534EZZZY
   Serial number: 3512QSME2025413EZZZM
   Serial number: 3522QSME06494378ZZZX
   Serial number: 35527SME1407421FZZZA
   Serial number: 35627SME7A08421FZZZO
9443093 - Driver's Side Airbag Crash Sensor
          B1017 15 [137] - Open or Short to Plus
                    Mileage: 185885 km
                    Date: 2023.02.12
                    Time: 01:28:39
                    Reset counter: 116
                    Mileage: 185885 km
                    Date: 2023.02.12
                    Time: 01:29:37
9483264 - Seat Occupied Recognition
          B10B4 00 [008] - Function Restriction due to Undervoltage
                    Reset counter: 116
                    Mileage: 185885 km
                    Date: 2023.02.12
                    Time: 01:28:53
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Coding: 0000532
   VCID: 78F413DE0B1C494633-802C
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
   Part No SW: 5K6 920 971 C    HW: 5K6 920 971 C
   Coding: 270F01
   VCID: 356ADAEA948E742EE8-8060
9453330 - Outside temperature sensor
          B103F 1B [008] - Resistance Too High
                    Reset counter: 116
                    Mileage: 129737 km
                    Date: 2020.07.02
                    Time: 00:11:36
13638912 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 116
                    Mileage: 129737 km
                    Date: 2020.07.02
                    Time: 00:11:36
                    Reset counter: 116
                    Mileage: 129737 km
                    Date: 2020.07.02
                    Time: 00:01:31
13673472 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 168
                    Mileage: 129737 km
                    Date: 2020.07.02
                    Time: 00:11:36
13634048 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Frequency: 19
                    Reset counter: 76
                    Mileage: 129737 km
                    Date: 2020.07.02
                    Time: 00:11:36
   Component: J533  Gateway   H07 0111
   Revision:   H07 01    Serial number: 031209F1000860
   Coding: E9801F07101612000000
   VCID: 69D2469A40B6E0CEBC-803C
                    Reset counter: 116
                    Mileage: 185885 km
                    Date: 2017.07.05
                    Time: 00:01:01
   Revision: 00001000    Serial number: 1225223T746S04
   VCID: 7EF805C62938777679-802A
                    Reset counter: 0
                    Mileage: 129737 km
                    Date: 2014.11.24
                    Time: 00:01:10
   Coding: 000007
   VCID: 6AD039968DB0EBD6B5-803E
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667712863
   VCID: 26480DA651280FB651-8072
                    Reset counter: 116
                    Mileage: 185885 km
                    Date: 2017.07.05
                    Time: 01:28:37
                    Reset counter: 116
   Component: Tuer-SG         009 2111
   Coding: 0001076
   VCID: 3162EEFAA8E6580EB4-8064
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 74     3001
   Revision: 00H17000
                    Fault Status: 11100101
                    Mileage: 185885 km
                    Date: 2017.07.05
                    Time: 00:10:11
                    Battery Volts: 11.4 V
                        DD
                    Temperature: 34.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
   Part No SW: 5K0 035 456     HW: 5K0 035 456
   Component: KonzernAmp 8K H06 0340
   Revision: --------    Serial number: BP218198829176
   VCID: 67D640A29EA2D6BEAA-8032
12608512 - Infotainment CAN Bus (SAE Bus E)
          U0064 00 [008] - Malfunction
                    Reset counter: 116
          U1400 00 [008] - -
                    Reset counter: 116
                    Mileage: 185885 km
                    Date: 2023.02.12
                    Time: 01:28:43
   Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
   Component: Tuer-SG         009 2137
   Coding: 0001076
   VCID: 346CE7EE57F46D26DF-8060
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
   Part No SW: 5K0 035 190 B    HW: 5K0 035 190 B
   Component: Radio RCD510  005 0236
   Revision: 00000001    Serial number: VWZ1Z3M7367279
   Coding: 0100041004000B
   Shop #: WSC 09003 957 00200
   VCID: 244C17AE2714FDA64F-8070
                    Reset counter: 116
                    Mileage: 185885 km
                    Date: 2017.07.05
                    Time: 01:17:51
                    Reset counter: 116
                    Mileage: 185885 km
                    Date: 2017.07.05
                    Time: 01:19:09
                    Reset counter: 76
                    Mileage: 185885 km
                    Date: 2017.07.05
                    Time: 00:00:02
                    Reset counter: 76
                    Mileage: 185885 km
                    Date: 2017.07.05
                    Time: 00:00:02
                    Reset counter: 76
                    Mileage: 185885 km
                    Date: 2017.07.05
                    Time: 00:00:02
                    Reset counter: 76
                    Mileage: 185885 km
                    Date: 2017.07.05
                    Time: 00:00:02
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Component: RDK           103 0521
   Coding: 018704
02214 - Tire Pressure Warning
                    Mileage: 185885 km
                    Text: 3365508807
                    Pressure: 0.00 bar
                    Pressure: 2.40 bar
                    Temperature: 52.4°C
                    Text: 00
                    Mileage: 185885 km
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
   Component: Telefon       H08 6900
   Revision: 00008000    Serial number: 00000327606236
   Coding: 412100
   VCID: 2A50F99645302BD675-807E
                    Reset counter: 116
                    Mileage: 129737 km
                    Date: 2014.11.26
                    Time: 06:38:60
End-------------------------(Elapsed Time: 02:31)--------------------------
How did the ABS lose its coding?
What parts have been changed?
Do the VINs in 01, 17, and 25 match?
