Can anyone help me get the code for the abs module. Thanks in advance
Sunday,05,July,2020,19:33:37:52994
VCDS Version: 20.4.1.0 (x64)
VIN: WVWED7AJ1BW255668 License Plate:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 47 52 56 65 77
VIN: WVWED7AJ1BW255668 Mileage: 129730km-80610miles
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AQ HW: 1K0 907 115 AK
Component: 2.0l R4/4V TFSI 0030
Revision: E3H25--- Serial number:
Coding: 0403010818070160
VCID: 75EA1AEA1C0E342E28-8020
001431 - Thermostat for Mapped Engine Cooling (F265)
P0597 - 000 - Open Circuit
Mileage: 129737 km
Date: 2014.11.26
Time: 00:04:48
Temperature: 45.0°C
Temperature: 43.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.573 V
Readiness: 1110 1101
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
VCID: 78F413DECB1C494633-802C
Reset counter: 76
Mileage: 185885 km
Date: 2017.07.05
Time: 00:10:24
Count: 7
Count: 15
Count: 28672
Count: 128
Count: 26624
Count: 256
Reset counter: 76
Mileage: 129737 km
Date: 2014.11.23
Time: 00:00:24
Count: 7
Count: 3
Count: 28672
Count: 195
Count: 24576
Count: 512
Fault Status: 01100101
Reset counter: 76
Mileage: 129737 km
Date: 2014.11.23
Time: 00:00:11
Count: 2
Count: 2
Count: 28672
Count: 279
Count: 36608
Count: 256
Reset counter: 76
Mileage: 129737 km
Date: 2014.11.23
Time: 00:00:11
Count: 2
Count: 2
Count: 28672
Count: 295
Count: 36608
Count: 256
Reset counter: 76
Mileage: 129737 km
Date: 2014.11.23
Time: 00:00:11
Count: 2
Count: 2
Count: 28672
Count: 270
Count: 36608
Count: 256
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
ROD: EV_ClimaBasis_VW36.rod
VCID: 75EA1AEAD40E342E28-8020
13635840 - Supply voltage
Reset counter: 116
Mileage: 185885 km
Date: 2023.02.12
Time: 00:03:40
Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
Component: BCM PQ35 H+ 103 0576
Revision: 00103 AF
Coding: 6D180A1E90272A0480080081700005C441010086434D8D60648020200000
Shop #: WSC 08213 444 12159
VCID: 356ADAEA9C8E742EE8-8060
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 02120 21 0512
Coding: 009795
8 Faults Found:
Fault Frequency: 12
Reset counter: 116
Mileage: 185885 km
Date: 2017.07.05
Time: 00:11:29
Voltage: 7.30 V
Term 50 On
00532 - Supply Voltage B+
Reset counter: 116
Mileage: 185885 km
Date: 2017.07.05
Time: 00:11:29
Voltage: 7.30 V
Term 50 On
02391 - Terminal 30 Reference
Reset counter: 76
Mileage: 185885 km
Date: 2017.07.05
Time: 00:00:02
Voltage: 11.10 V
Term 50 On
00061 - Footwell Lights
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 24
Reset counter: 76
Mileage: 185885 km
Date: 2017.07.05
Time: 00:00:12
Term 15 Off
Voltage: 10.75 V
Term 50 Off
Fault Frequency: 13
Reset counter: 76
Mileage: 129737 km
Date: 2014.11.23
Time: 00:00:14
Voltage: 9.85 V
Term 50 On
Fault Frequency: 13
Reset counter: 76
Mileage: 129737 km
Date: 2014.11.23
Time: 00:00:14
Voltage: 9.85 V
Term 50 On
00153 - Windshield Wiper Motor; Driver Side (V216)
Reset counter: 116
Mileage: 129737 km
Date: 2014.11.24
Time: 02:06:32
Voltage: 8.30 V
Term 50 On
01179 - Incorrect Key Programming
Reset counter: 76
Mileage: 129737 km
Date: 2014.11.24
Time: 00:06:41
Term 15 Off
Voltage: 8.65 V
Term 50 Off
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4D0A54Y%
Coding: 00003031
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3972D6DAB896904E0C-806C
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--0004X9DT00
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME6242534EZZZY
Serial number: 3512QSME2025413EZZZM
Serial number: 3522QSME06494378ZZZX
Component: F.Sens.Fahr --- ----
Serial number: 35527SME1407421FZZZA
Component: F.Sens.Beif --- ----
Serial number: 35627SME7A08421FZZZO
9443093 - Driver's Side Airbag Crash Sensor
B1017 15 [137] - Open or Short to Plus
Mileage: 185885 km
Date: 2023.02.12
Time: 01:28:39
Reset counter: 116
Mileage: 185885 km
Date: 2023.02.12
Time: 01:29:37
9483264 - Seat Occupied Recognition
B10B4 00 [008] - Function Restriction due to Undervoltage
Reset counter: 116
Mileage: 185885 km
Date: 2023.02.12
Time: 01:28:53
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 056 0111
Coding: 0000532
VCID: 78F413DE0B1C494633-802C
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000130
Part No SW: 5K6 920 971 C HW: 5K6 920 971 C
Component: KOMBI H20 0420
Coding: 270F01
VCID: 356ADAEA948E742EE8-8060
9453330 - Outside temperature sensor
B103F 1B [008] - Resistance Too High
Reset counter: 116
Mileage: 129737 km
Date: 2020.07.02
Time: 00:11:36
13638912 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 116
Mileage: 129737 km
Date: 2020.07.02
Time: 00:11:36
Reset counter: 116
Mileage: 129737 km
Date: 2020.07.02
Time: 00:01:31
13673472 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 168
Mileage: 129737 km
Date: 2020.07.02
Time: 00:11:36
13634048 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Frequency: 19
Reset counter: 76
Mileage: 129737 km
Date: 2020.07.02
Time: 00:11:36
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0111
Revision: H07 01 Serial number: 031209F1000860
Coding: E9801F07101612000000
VCID: 69D2469A40B6E0CEBC-803C
Reset counter: 116
Mileage: 185885 km
Date: 2017.07.05
Time: 00:01:01
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223T746S04
VCID: 7EF805C62938777679-802A
Reset counter: 0
Mileage: 129737 km
Date: 2014.11.24
Time: 00:01:10
Component: IMMO H20 0420
Coding: 000007
VCID: 6AD039968DB0EBD6B5-803E
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667712863
VCID: 26480DA651280FB651-8072
Reset counter: 116
Mileage: 185885 km
Date: 2017.07.05
Time: 01:28:37
Reset counter: 116
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2111
Coding: 0001076
VCID: 3162EEFAA8E6580EB4-8064
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
Fault Status: 11100101
Mileage: 185885 km
Date: 2017.07.05
Time: 00:10:11
Battery Volts: 11.4 V
DD
Temperature: 34.0°C
Count: 2
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Part No SW: 5K0 035 456 HW: 5K0 035 456
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218198829176
VCID: 67D640A29EA2D6BEAA-8032
12608512 - Infotainment CAN Bus (SAE Bus E)
U0064 00 [008] - Malfunction
Reset counter: 116
U1400 00 [008] - -
Reset counter: 116
Mileage: 185885 km
Date: 2023.02.12
Time: 01:28:43
Part No SW: 5K0 959 702 D HW: 5K0 959 702 D
Component: Tuer-SG 009 2137
Coding: 0001076
VCID: 346CE7EE57F46D26DF-8060
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 B HW: 5K0 035 190 B
Component: Radio RCD510 005 0236
Revision: 00000001 Serial number: VWZ1Z3M7367279
Coding: 0100041004000B
Shop #: WSC 09003 957 00200
VCID: 244C17AE2714FDA64F-8070
6 Faults Found:
Reset counter: 116
Mileage: 185885 km
Date: 2017.07.05
Time: 01:17:51
Reset counter: 116
Mileage: 185885 km
Date: 2017.07.05
Time: 01:19:09
Reset counter: 76
Mileage: 185885 km
Date: 2017.07.05
Time: 00:00:02
Reset counter: 76
Mileage: 185885 km
Date: 2017.07.05
Time: 00:00:02
Reset counter: 76
Mileage: 185885 km
Date: 2017.07.05
Time: 00:00:02
Reset counter: 76
Mileage: 185885 km
Date: 2017.07.05
Time: 00:00:02
Address 65: Tire Pressure (J502) Labels:. 1K0-937-08x-65.clb
Component: RDK 103 0521
Coding: 018704
02214 - Tire Pressure Warning
Mileage: 185885 km
Text: 3365508807
Pressure: 0.00 bar
Pressure: 2.40 bar
Temperature: 52.4°C
Text: 00
Mileage: 185885 km
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000327606236
Coding: 412100
VCID: 2A50F99645302BD675-807E
Reset counter: 116
Mileage: 129737 km
Date: 2014.11.26
Time: 06:38:60
End-------------------------(Elapsed Time: 02:31)--------------------------
