The box below shows a [slightly edited for space reasons] display from the first stage of the SRI option on the VCDS front menu from my 2015 A8 in the UK. I use this to see what the service state is and then press 'Cancel', so I don't change anything.
1) Is the text listed under 'Channel' read straight from the ECU [that is, the ECU is coded in English] or is that information translated into English from German?
2) Is the text under 'Description' read from the ECU or is that a Ross Tech interpretation of the 'Channel' text?
3) Is the list of IDE*** variables shown in this display consistent across all markets or does it vary by market? [US doesn't use Extended Service, so do US A8 owners see the same ESI information in VCDS when they perform the 'SRI'?]
4) Is the distance information printed in km in all markets?
5) I guess "ESI" stands for Extended Service Interval, but what does "SIA" and "FIX" stand for?
Thanks - Julian
Thursday,06,August,2020,20:23:52:22069
VCDS Release 20.4.2: SRI Reset-SRI1.CLB -- Data version: 20200730 DS317.0
WAUZZZ4H4GN002801
Control Module Part Number: 4H0 920 910 R Labels: .*4H0-920-xxx-17.clb-SRI1
Component:TDieGB------- H53 0803, Coding:33A608001B412600010000
Operation: Please select an operation -- 1/3
Channel Description Current val.
IDE00342-ESI: Resetting ESI ESI: Service Reminder Status no warning
IDE00510-ESI: distance driven from inspection ESI: Distance since inspection 9700 km
IDE00511-ESI: time from inspection ESI: Time since inspection 371 Days
IDE00515-ESI: oil quality ESI: Oil Quality good oil quality
IDE00517-ESI: soot entry ESI: Soot Quantity 4600 km
IDE00518-ESI: thermal load ESI: Thermal Load 10900 km
IDE01153-SIA: maximum value of distance to service SIA: Maximum Distance to Service 14500 km
IDE01154-SIA: maximum value of time to service SIA: Maximum Time to Service 365 Days
IDE03349-FIX: Max. distance until next mileage-related inspection FIX: Maximum Distance to Inspection 29200 km
IDE03350-FIX: Maximum time until next time-dependent inspection FIX: Maximum Time to Inspection 730 Days
IDE03351-FIX: Distance covered since last mileage-dependent inspection FIX: Distance since Inspection 7900 km
IDE03352-FIX: Time since last time-dependent inspection FIX: Time since Inspection 310 Days
Thanks - Julian
