Hi
My daughter has bought her first car, a 2010 Leon 1.6 Ecomotive. The car had several dash lights illuminated so was relatively well priced. Most forums suggested the steering column control unit was faulty so I replaced it with one from a scrap vehicle, same year model and the part number on the module was the same. All the lights went out apart from the ESP and TPMS warning lights. The switches on the tunnel would not switch them off. Eventually I was able to calibrate the steering angle sensor using VCDS and all lights went out. Success. Thing is the car is reporting a Cruise Control Switch (E45) as defective but the car is not fitted with Cruise Control. I got the car specs from erWin Seat and sure enough the car is not fitted with cruise control. Neither was the doner column control car.
Wondering why. Doesn't seem to affect anything although my daughter reported the steering going very stiff a few times when turning a corner at low speed. A problem I have not been able to replicate.
VIN: VSSZZZ1PZAR068638 License Plate:
Chassis Type: 1P-SE35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 61 77
VIN: VSSZZZ1PZAR068638 Mileage: 273690km-170063miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 GP HW: 03L 906 023 GG
Component: R4 1.6l TDI H23 9979
Revision: --H23--- Serial number:
Coding: 00114014030501080000
ASAM Dataset: EV_ECM16TDI02103L906023GP 003013
ROD: EV_ECM16TDI02103L997557R.rod
VCID: 7AADF778EC5A904B1DF-802E
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 133B201209280002C81104E790210091350800
Shop #: WSC 04941 000 00000
VCID: 7AADF778ECDA904B1DF-802E
Part No SW: 5P0 820 047 P HW: 5P0 820 047 P
Component: Climatic PQ35 014 0707
Revision: 00014014 Serial number: 00000000000000
VCID: 3A2D3778A05A504B5DF-806E
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Part No SW: 5K0 937 085 D HW: 5K0 937 085 D
Component: BCM PQ35 B+ 011 0029
Revision: BB011001
Coding: 46180A3E9005B0904688008091000004050100A8425D81605C80C7000001
VCID: 343119408E3EA63B873-8060
Subsystem 1 - Part No: 1P0 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 25031 22 0611
Coding: 00DB90
Subsystem 2 - Part No: 1P0 951 171
Component: Innenraumuebe 010 4971
Part No SW: 5N0 959 655 J HW: 5N0 959 655 J
Component: J234__A0E VW10 HI 1916
Revision: 20013000 Serial number: 003E2P20Q3C1
Coding: 0012357
Shop #: WSC 06402 785 00200
VCID: 44D14980D29E16BB373-8010
Subsystem 1 - Serial number: 6332MTS646180470
Subsystem 2 - Serial number: 6342MTS643450470
Subsystem 3 - Serial number: 6351HTS6H55M69KJ
Subsystem 4 - Serial number: 6361HTS6OH4O69KJ
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 856 0111
Coding: 0000532
VCID: 78A9ED70DED6825B6BB-802C
Subsystem 1 - Part No: 1P0 959 538 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H02 0101
Coding: 00000226
00895 - Cruise Control Switch (E45)
014 - Defective
Part No SW: 1P0 920 953 B HW: 1P0 920 953 B
Component: KOMBI H07 0307
Coding: 410A00
VCID: 2F3B162C679885E3FA1-807A
Part No SW: 1K0 907 530 AF HW: 1K0 907 951
Component: J533 Gateway H17 0233
Revision: H17 Serial number: 1521J1031902A6
Coding: E9801F06000612040203
VCID: 6B83C23C9F8039C3969-803E
Component: IMMO H07 0307
VCID: 6A8DC7389CFA20CBEDF-803E
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667937155
Coding: 020000
VCID: 2615F30848E2C4AB097-8072
Part No SW: 1T0 959 701 AD HW: 3C0 959 793
Component: TUER-SG FT 002 0306
Revision: 13101005 Serial number: 0000216149
Coding: 020230
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 79AFE874E95C9B53145-802C
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 65 3001
Revision: 00H17000
VCID: 313F10547D2C9313EC5-8064
Part No SW: 1T0 959 702 AB HW: 3C0 959 792
Component: TUER-SG BT 002 0306
Revision: 15101005 Serial number: 0000435963
Coding: 020230
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 78A9ED70D256825B6BB-802C
Part No SW: 1P0 035 153 B HW: 1P0 035 153 B
Component: Radio G3 UL H59 0060
Revision: 0H001001 Serial number: SEZ1Z2K6546968
Coding: 0102040004
VCID: 2411E9003EDE36BB173-8070
Part No SW: 1K0 907 534 HW: 1K0 907 951
Component: Batt.regelung H17 0233
Revision: -------- Serial number: 1521J1031902A6
Coding: 030B085A
VCID: 6889BD30827612DBFBB-803C
Subsystem 1 - Part No SW: 1K0 915 181 C HW: 1K0 915 181 A
Component: J367-BDM H07 0125
Serial number: 00000000002790170325
00458 - Control Module for Battery Monitoring (J367)
014 - Defective
Fault Status: 01101110
Reset counter: 169
Mileage: 273698 km
Date: 2014.12.23
Time: 18:04:50
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 E HW: 1Z0 035 729 E
Component: FSE_2P8x H40 0190
Revision: 00000000 Serial number: 00000005235817
Coding: 0010555
End----------(Elapsed Time: 01:17, VBatt start/end: 12.1V/12.1V)-----------
