Hi. i bought this car 2 weeks ago. in couple days after purchase , some issue show up.
First , when i turn on the engine in morning ,i feel strange smells (like gas).
second , some times driver side blind spot didnt work corectly (without message) but most of the time it work corectly , and 3rd , acc and braking assist didnt work and message says acc and audi braking guard: unavailable! but some times it work randomly.
after i recieved my Hex-V2 , i scan it and vcds showed me that:
VCDS Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: Release 20.4.2(x64) Data version: 20200730 DS317.0 www.Ross-Tech.com
Dealer/Shop Name: Workshop Code: 000 00000 000000
Self-Diagnosis Log Tuesday,04,August,2020,22:11:35:17634
VIN: WAUHGAFC3CN151926 License Plate: Mileage: 170231km-105776mi Repair Order:
Chassis Type: FC-AU57 (4G0) Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3B 3C 42 44 46 47 52 53 55 56 5F 62 6C 72 85 8B 8E 8F 90
VIN: WAUHGAFC3CN151926 Mileage: 170231km-105776miles
01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: Malfunction 0010 13-Auto Dist. Reg -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 28-HVAC, Rear -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: Malfunction 0010 3B-Sensor Elect. -- Status: Malfunction 0010 3C-Lane Change -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 5F-Information Electr. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: Malfunction 0010 6C-Back-up Cam. -- Status: Malfunction 0010 72-Door, Rear Right -- Status: Malfunction 0010 85-On Board Cam. -- Status: OK 0000 8B-Adaptive Cruise 2 -- Status: Malfunction 0010 8E-Image Processing -- Status: Malfunction 0010 8F-Pretens. Frt Left -- Status: Malfunction 0010 90-Pretens. Frt Right -- Status: Malfunction 0010 ------------------------------------------------------------------------------
after that , i cleared the codes and in new scan , just 3 fault show up:
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb Part No SW: 4G0 907 561 A HW: 4G0 907 561 Component: ACC3 H17 0400 Serial number: 00000000000000 Coding: 3601010202 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AdaptCruisContrAU57X 002010 ROD: EV_AdaptCruisContrAU57X_002.rod VCID: 2809FC8A1277556B3A3-807C
1 Fault Found: 93440 - Function Restriction due to Faults in Other Modules U1113 00 [009] - [FAULT_CIS_VIDEO_FAIL] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 60 Mileage: 170231 km Date: 2020.08.03 Time: 22:16:37
Control Module temperature: 25 °C Voltage terminal 15: 14.295 V Velocity_vehicle_reference: -0.01 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 4G0 035 746 C HW: 4G0 035 746 Component: H-BNT-NA H48 0423 Revision: -------- Serial number: 031CH0C7533112 Coding: 050200000003E9EF75128B3E00000003100001000000000000 Shop #: WSC 02391 785 00200 VCID: 270BFFB61FE95A13339-8072
Subsystem 1 - Part No: 8R0 060 884 AD Component: NAR 2011 0505
Subsystem 2 - Part No SW: 4G0 919 605 D HW: 4G0 919 605 D Component: DU8 C7 SV H63 0060 Serial number: AUZ8ZDEAL002Q6
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C Component: E380 BDT C7 H11 0204 Serial number: 90349LCG000RQ
Subsystem 4 - Part No: 8R0 060 961 B Component: CD-Database 3371
1 Fault Found: 03276 - Please Check Software Version Management 000 - Freeze Frame: Fault Status: 01100000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 60 Mileage: 170231 km Time Indication: 0 Date: 2020.08.03 Time: 22:16:39
Freeze Frame: Text: DUA009,Front,A,3c,15,1
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb Part No SW: 4G0 907 107 D HW: 4H0 907 107 Component: BV-SG H30 0038 Serial number: 005000051403127 Coding: 048198180111 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_BC7 001001 ROD: EV_BC7.rod VCID: 270BFFB61F695A13339-8072
1 Fault Found: 0080 - Video Cable for Image Processing C1107 02 [009] - Signal Failure [No_connection_to_camera] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 60 Mileage: 170231 km Date: 2020.08.03 Time: 22:16:37
Outside air temperature: 19.5 °C Voltage terminal 15: 14.3 V Control Module temperature: 27.0 °C
what can i do?
sorry about my bad english. im new in US.
what can i do?
