I hit a pot hole on the front passenger side of my 2016 Audi S3 big enough to swallow the freaking wheel, gotta love MA. I immediately lost power steering and then got all the other codes below. After checking out the underside of the car I could see where the edge of the asphalt scraped against the "X" brace portion of the front sub-frame & it contacted the connector to the power steering just enough to slightly pop it out; I plugged it right back in with a click but I still have all these codes after trying to clear them with VCDS. I checked all related fuses but they were all fine.
The alignment was bad but thanks to Firestone's unlimited alignment deal it was free even though I had gotten it aligned only a month prior so at least I have good numbers to reference. I'm not sure how fragile the headlights on these cars are regarding the Audi intelligent lighting but I've got the code below...most confusing to me is the lack of hill hold assist? Any feedback here would be great because I'm full bolt on & tune so going to the dealership really isn't ideal. I haven't had any trouble with the car since owning & building it last year so this has been quite disheartening but I have to say the lack of power steering has been giving my arms a good pump & it makes it the car kind of feel like my old BRZ haha.
Thanks!
Thanks!
Sunday,26,July,2020,22:20:01:04550
VIN: WAUB1GFF1G1060574 License Plate:
Mileage: 67240km-41780mi Repair Order:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 3C 42 44 52 55 5F 6C
A9 BB BC
VIN: WAUB1GFF1G1060574 Mileage: 67240km-41780miles
Address 01: Engine (J623-CYFB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 H HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0A1D00122426000E3004
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
ROD: EV_ECM20TFS0208V0906259H.rod
VCID: 45D75450C520FA4320D-8010
Readiness: 1010 0101
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4903
Revision: 06253104 Serial number: TFK01510131090
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 53F37A083B7454F3BE9-8006
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 63015000001107
Coding: 31FF6B9254260A6C017C030741C7698CD62A5080C08296B6024100548208
ROD: EV_Brake1UDSContiMK100IPB_034.rod
VCID: 79AFE8A0F9584EA3145-802C
0297 - Steering angle sensor
B1168 16 [137] - Voltage Too Low
Reset counter: 206
Date: 2020.07.26
Time: 22:14:54
16412 - Display for Tire Pressure Monitoring
Reset counter: 206
Mileage: 67240 km
Date: 2020.07.26
Time: 22:15:06
16413 - Display for Tire Pressure Monitoring
Reset counter: 206
Mileage: 67240 km
Date: 2020.07.26
Time: 22:15:06
Revision: 00021000 Serial number: 0384320841
Coding: 030C0C
VCID: 3A2D37ACBCDE85BB5DF-806E
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H14 0060
Revision: 20028000 Serial number: 00000000784420
Coding: 03000014010000000000000000001400
VCID: 33331A889BB474F39E9-8066
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 8E4847D7000000000001
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 085 AJ HW: 5Q0 937 085 AF
Component: BCM MQBAB HNA H24 0175
Serial number: 01061530600153
Coding: 04151C46C04106FD41C04004511807A00800000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 015F8040918816635C5-8054
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 150808 042 0585
Serial number: 151030203236
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 63414915
Coding: 02006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Component: E1 - LDS MQB H05 0032
Serial number: 17 08 2015 00001023
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0312
Serial number: 00000000000033891860
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST000MVXS600000
Coding: 101F00
18698 - Left LED Module for DRL and Parking Lights
B12EC F2 [009] - Voltage Supply Open or Short to Plus
Reset counter: 205
Mileage: 67240 km
Date: 2020.07.26
Time: 22:11:17
19210 - Right LED Module for DRL and Parking Lights
B12ED F2 [009] - Voltage Supply Open or Short to Plus
Reset counter: 205
Mileage: 67240 km
Date: 2020.07.26
Time: 22:11:17
545300 - Databus
Reset counter: 205
Mileage: 67240 km
Date: 2020.07.26
Time: 22:11:17
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391530801661
Coding: 0030150011
VCID: 43D34A48CB14C4730E9-8016
13637426 - Databus
Reset counter: 205
Mileage: 67240 km
Date: 2020.07.26
Time: 22:11:18
Component: AirbagVW20 010 0830
Serial number: 003GCR03WCZB
Coding: 9DCCFCC0000000005000001AC24800000065
ROD: EV_AirbaVW20SMEVW37X_VW48.rod
VCID: 47CB5E58FF2CE853D21-8012
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34230167A09111541333
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34230168A09111541494
Coding: 333135
Occupant Detection:
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 694000000000001ECM4T
Coding: 303334
Subsystem 4 - Part No SW: ----------- HW: 480 002 610 15
Serial number: 35700000000F827C471S
Subsystem 5 - Part No SW: ----------- HW: 480 002 610 15
Serial number: 358000000005827C471J
Subsystem 6 - Part No SW: ----------- HW: 480 402 810 15
Serial number: 3510002C71D3F9741388
Subsystem 7 - Part No SW: ----------- HW: 480 400 311 15
Serial number: 3520002B71D25F06021W
Subsystem 8 - Part No SW: ----------- HW: 480 401 708 15
Serial number: 3550002BB1D1B620D165
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 401 708 15
Serial number: 3560002BB1D1B623613%
1050117 - Databus
[NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
Reset counter: 206
Mileage: 67240 km
Date: 2020.07.26
Time: 22:16:32
Part No SW: 8V0 953 521 FH HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 07111504221302
Coding: A018
ASAM Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_019_AU37.rod
VCID: 0557945085A03A4360D-8050
Part No SW: 8V0 920 972 B HW: 8V0 920 972 B
Component: KOMBI H03 6423
Coding: 0BED181B2B88D7050201E8001800000000000000
VCID: 3D273CB0ADF0B28378D-8068
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 01111510801026
Coding: 0101000830085A005B00022C180B00000001010000000000000000000000
ROD: EV_GatewConti_013.rod
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 29 10 2015 F0079789
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Serial number: HA1-00001.10.15
Coding: 0001
VCID: 4ACD676CEC3E153BCDF-801E
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000243241008
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 343119949EBA73CB873-8060
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
Component: SWA Master H06 0080
Serial number: 0383562510
Coding: 030211
ROD: EV_LaneChangAssis_VW51.rod
VCID: 38292DA482D297ABABB-806C
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 568 A HW: 8T0 907 568 B
Component: SWA Slave H05 0080
Serial number: 0381806323
Coding: 030211
Component: TSG FS 020 0041
Serial number: 290715BGS18179
Coding: 005D1B204000048000000002
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8102
VCID: 392F28A0B9D88EA3545-806C
1539 - Internal Fault
B200F F0 [008] - Unknown Error Elaboration
[Treiberfehler des Drehmomentsensors auf Kanal 0 und Kanal 1 Es werden keine Daten empfangen.]
Reset counter: 40
Mileage: 67239 km
Date: 2020.07.10
Time: 23:00:46
Motor status: 02
System status: Driving mode
Supply voltage: 13.75 V
Temperature: 83.0 °C
KFC: 06
KFA: 00 03
Environmental conditions: 71
mApplI_TorsionBarTorque_xds16: -7.675 Nm
yioDmsSin_xas16: 67.58 %
yeeTorqueSensorType_xdu8: 8
sstMDSensorState_xdu8: 10
ystfTorqueRadFiltrd_xau16: 71.19 %
AscCtrlI_GetLA_REG: 71
yioDmsErrorType_xau16: 3
sstSensorVoltageState_xdu8: 0
360576 - Control Module
B2000 F2 [153] - Defective
[Steuergerät defekt - Momentensensor Störung]
MIL ON - Confirmed - Not Tested Since Memory Clear
Reset counter: 40
Mileage: 67239 km
Date: 2020.07.10
Time: 23:00:46
Motor status: 02
KFC: 06
KFA: 00 03
16135 - Steering Angle Sensor
B1168 F2 [009] - Not Initialized
Reset counter: 206
Mileage: 67240 km
Date: 2020.07.26
Time: 22:15:23
Motor status: 00
Supply voltage: 0.00 V
Temperature: 35.0 °C
KFC: 3F
KFA: 00 07
Environmental conditions: 5F
uioUdNotFilt_xdu16: 0.06 V
uAdSensI_SwitchedKl30_xdu16: 0.07 V
Component: TSG BFS 020 0041
Serial number: 310715BGV08324
Coding: 005D13204000048000000002
VCID: 42DD4F4CD40ECD7B05F-8016
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Coding: 012A000123200400
ROD: EV_HeadlRegulAFSMQBMLB.rod
VCID: 3FDB46B8A7FCA0936A1-806A
13679104 - Local Data Bus
U10BA 00 [137] - No Communication
Reset counter: 205
Mileage: 67240 km
Date: 2020.07.26
Time: 22:11:18
Part No SW: 8V0 035 038 J HW: 8V0 035 038 B
Component: MU-H-LNS-US H44 0403
Serial number: A302J0F7511451
Coding: 017301020000000021220002041A00102F000225010001047E
ROD: EV_MUHig6C3HBAS_VW48.rod
VCID: 3B2332A8B3E4BCB3469-806E
Subsystem 1 - Part No SW: V03 959 800 T HW: -----------
Component: NAR 2016 --- 0048
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9FY2049WA
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
Component: ControlUnit_H H81 0816
Serial number: C1000005091500040099
Component: Gracenote --- 3006
B11CF 53 [009] - Deactivated
Reset counter: 205
Mileage: 67240 km
Date: 2020.07.26
Time: 22:11:21
Voltage terminal 30: 14.1 V
Satellite radio tuner status-Audio Signal: Available
Satellite radio tuner status-Reception quality: optimum_signal
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300010201000300
ASAM Dataset: EV_2CamSysRearPASE 006016
ROD: EV_2CamSysRearPASE.rod
VCID: 303915846AA24FEBE3B-8064
9529428 - Steering angle sensor
Reset counter: 205
Mileage: 67240 km
Date: 2020.07.26
Time: 22:11:18
passive
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 151022202511
VCID: 7DA7FCB0ED70728338D-8028
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 090815BH81356C
Coding: 004D13204000048000000002
Component: TSG HBFS 020 0041
Serial number: 090815BH81356A
End----------(Elapsed Time: 01:42, VBatt start/end: 14.0V/14.0V)-----------
Address 03: DTCs cleared
