2009 VW Jetta 2.5 reprogram abs module (MK60EC1)
Hidalgo auto service
C?ID=26309
I am currently trying to reprogram the abs module on this Jetta but I think I need a code to begin the reprogramming. When going to the “scans” folder no “auto scans” end up popping up. Can someone please send the correct abs coding value. Thank you!
You'll have to post an Auto-Scan for anyone to be able to help you with this. If you have no previous ones, then do one now.
C?ID=26309
2009 VW Jetta 2.5l, abs reprogramming
The old abs on this jetta did not have any communication with the scanner. We replaced it with a used abs and we are trying to reprogram it to the car i was wondering if I can get the abs coding value. thank you!
Wednesday,05,August,2020,10:52:16:16539
VCDS Version: 20.4.2.0 (x64)
VIN: 3VWJZ71K19M054109   License Plate: 6VDD208
Mileage: 240830km-149644mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWJZ71K19M054109   Mileage: 240830km-149644miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 M    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   3859
   Revision: G6H02---    Serial number: VWX7Z0H824L12Z
   Coding: 0000075
   VCID: 3875510F4B131046EB-806C
Readiness: 0110 0101
   Part No SW: 09G 927 750 JE    HW: 09G 927 750 JE
   Component: AQ 250 6F           1377
   Revision: 00H76000    Serial number:
   Coding: 0000840
   VCID: 7DFB801B24B1F56E78-8028
   Revision: 00H45001
   VCID: 0005F9EF9343988613-8054
                    Fault Status: 01100101
                    Reset counter: 2
                    Mileage: 240837 km
                    Count: 16391
                    Count: 8192
                    Count: 279
                    Count: 47104
                    Count: 65280
                    Count: 1024
                    Reset counter: 2
                    Mileage: 240837 km
                    Count: 16391
                    Count: 8192
                    Count: 295
                    Count: 47104
                    Count: 65280
                    Count: 1024
                    Reset counter: 2
                    Mileage: 240837 km
                    Count: 16391
                    Count: 8192
                    Count: 270
                    Count: 47104
                    Count: 65280
                    Count: 1024
00003 - Control Module
                    Reset counter: 2
                    Mileage: 240837 km
                    Count: 16391
                    Count: 8192
                    Count: 338
                    Count: 47104
                    Count: 65280
                    Count: 1024
                    Reset counter: 2
                    Mileage: 240837 km
                    Count: 16391
                    Count: 8192
                    Count: 195
                    Count: 47104
                    Count: 65280
                    Count: 1024
   Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
   Component: Climatic PQ35   142 1111
   Revision: 00142031    Serial number: 00000000000000
   VCID: 7CFD8D1F3FABFC664F-8028
   Revision: 00H54000    Serial number: 00000001057792
   Coding: 14058E234004150007140000001400000008730B5C000120000000000000
   VCID: 32616327AD6FFA16D5-8066
   Component: Wischer 200908 021  0501
   Coding: 00038805
   Shop #: WSC 00066
                    Reset counter: 2
                    Mileage: 211524 km
                    Voltage: 12.00 V
                    Reset counter: 2
                    Mileage: 211524 km
                    Voltage: 12.00 V
                    Reset counter: 2
                    Mileage: 211524 km
                    Voltage: 12.20 V
02092 - Enabling Heated Seat
            009 - Open or Short to Ground
                    Fault Status: 01111001
                    Reset counter: 2
                    Mileage: 240837 km
                    Voltage: 13.85 V
   Revision: 05034000    Serial number: 003B6M06WT4R
   Coding: 0013889
   VCID: 6CDDBD5F4FCB6CE6DF-8038
   Subsystem 2 - Serial number: 6332MSME3750592CE
   Subsystem 3 - Serial number: 6342MSME2255615FD
   Subsystem 4 - Serial number: 6351HSME177F5959P
   Subsystem 5 - Serial number: 6361HSME18030440V
   Subsystem 6 - Serial number: 63727SME17464035X
   Subsystem 7 - Serial number: 63827SME17474242Z
   Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
   Coding: 0010021
   VCID: 030FF6E34255839E0E-8056
   Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0003000    Serial number: VWX7Z0H824L12Z
   Coding: 0023203
   Shop #: WSC 19506 444 84912
   VCID: 3C7D4D1F7F2B3C660F-8068
                    Fault Frequency: 98
                    Reset counter: 41
                    Mileage: 240836 km
                    Time: 11:19:34
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 270708F2000740
   Coding: ED807F070002021002
   VCID: 356B583B5C01ED2EF0-8060
                    Fault Status: 00110100
                    Fault Frequency: 35
                    Reset counter: 41
                    Mileage: 240836 km
                    Time: 11:19:35
   Component: IMMO            3HL 1222
   Shop #: WSC 19506 444 53516
   Revision: 72009005    Serial number: 00000527088829
   Coding: 0001205
   VCID: 6FE7AA537EDD97FEFA-803A
                    Fault Status: 00100101
                    Reset counter: 42
   Part No: 1K0 909 144 C
   Revision: 00H15000
   VCID: 2A517B4785BFB2D66D-807E
                    Fault Status: 00101101
                    Fault Frequency: 255
                    Reset counter: 47
                    Mileage: 240800 km
                    Time: 05:12:38
                    Voltage: 13.88 V
                        DU
                    Temperature: 27.0°C
                    RPM: 1664 /min
                    Speed: 62.0 km/h
                    Speed: 62.0 km/h
                    Fault Frequency: 28
                    Reset counter: 51
                    Mileage: 240837 km
                    Time: 02:59:15
                    Voltage: 11.75 V
                        DU
                    Temperature: 26.0°C
                    Speed: 50.0 km/h
                    Speed: 50.0 km/h
   Coding: 13900F880186281B0904058FB0880F0488DCA0
   VCID: 040DF5FF475B84A637-8050
                    Fault Frequency: 81
                    Reset counter: 33
                    Mileage: 240208 km
                    Time: 14:00:30
   Revision: 72009005    Serial number: 00000551088828
   Coding: 0001204
   VCID: 70E5A92F63E38806E3-8024
                    Reset counter: 41
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 D    HW: 1K0 035 161 D
   Component: Radio DE2       018 0021
   Revision: 00018000    Serial number: VWZ4Z7H6381575
   Coding: 0040401
   VCID: 2045996FF383788633-8074
   Revision: 12006001    Serial number: 00000003473512
   Coding: 0001168
   VCID: 76E99F370187A63639-8022
00934 - Electric Window Motor; Rear Left (V26)
                    Reset counter: 40
   Coding: 0100101
00625 - Vehicle Speed Signal
                    Fault Status: 00111000
                    Reset counter: 41
                    Mileage: 240837 km
                    Time: 02:59:13
   Revision: 12006001    Serial number: 00000003439477
   Coding: 0001168
   VCID: 77F79233068DDF3E22-8022
00935 - Electric Window Motor; Rear Right (V27)
                    Reset counter: 40
End-------------------------(Elapsed Time: 02:01)--------------------------
Merged threads, and now that you are Verified, moving to Car Repair Support.
Dana
Western PA, USA
Providing 3VWJZ71K19M054109 is the correct VIN (rather than the wrong VIN due to Immo module swapping in the past) it looks like the car was born with 03-ABS module #1K0 907 379 AD. That supers to AN so either part number would be compatible. You may or may not have issues with the installed AP controller.
The factory condition coding should be:
113B400D492700FE880C02E4922200413000
The following pages should be helpful:
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Brake_Electronics_(MK60EC1)
https://forums.ross-tech.com/showthread.php?20619-MK60EC1-ABS-FAQ
C?ID=26309
2009 VW Jetta 2.5l, abs reprogramming 066 code
when doing MK60EC1 ABS it will noit let me do the 066 code it says NA instead of okay i was wondering what i can do next for this to out ok
PetrolDave
Westbury, UK
C?ID=1423
It will be much easier for people to offer suggestions if you post a full unedited VCDS Auto-Scan - see my sig for a link to a How-To
Another thread merge. ;)
Hidalgo: Please stop opening new threads about the same (or related) issues in this car.
