2010 Golf 1.4 DSG7 adaptaions
Shawa12002
Victoria, Australia
C?ID=370869
Hello all. I replaced the engine in the car. the issue I have is when it drive it shifts harshly, esp on take off then goes upto 6th gear before it even get upto 50KPH. This causes it to shudder until speed picks up.
I have tried to do adaptaions on the Transmission but most of the items are greyed out in the main menu of the trans. Do I need to put a security code first? If so where do I get it? The one I saw on the wiki was not accpted.
Oh bugger I didn't do a full scan but I will upload one later today.
Tuesday,04,August,2020,09:49:36:41695
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WVWZZZ1KZAW187659   License Plate: GOLF 1.4
Mileage: 86220km-53574mi   Repair Order:
Gateway Installation List:  1K0 907 530 AA
siLc
Tallinn, Estonia
C?ID=330192
This is only the installation list, please post a full autoscan. Into 6th gear at approximately 55-60km/h is normal and doing basic settings probably won't improve it. Does it shift harshly from 1->2 only?
Shawa12002
Victoria, Australia
C?ID=370869
It shifts harshly from in all the low gears if it doesn't skip them or when downshifting. I will do an autoscan in the morning plus I watched the WIKI video just now and learnt how to navigate the WIKI. The one thing I'm sure I did not do before attempting the adaptations on the trans is drive or bring the the trans to the correct temperature :banghead: . We have curfews here in Melbourne at the moment so I wasn't confidenet in driving aimlessly around the neighborhood in an unregistered vehicle. i will drive it to work then do the autoscan there and try clutch adaptations there. I will post update status tomorrow
TBAx
C?ID=287144
There might be an updated firmware available fixing said issue. However it‘s just an assumption based on the description.
Shawa12002
Victoria, Australia
C?ID=370869
Hi TBAx
I'm back now with feedback. I finally took the car to work one morning and halfway there i stopped and performed the adaptations on the trans and drove to work smoothly. When I got there i felt small jerks as I was parking and after work when I went to drive home I had the issue again.
So big jerks on take off in first gear and sometimes stalling at the lights then erratic upshift. worse from 1st to 2nd then shuddering in 6th. I took the car for registration and same thing. it seems to lose it settings everytime. I did a scan of the car after the issue came back.
Wednesday,05,August,2020,09:13:10:41695
Mileage: 86240km-53587mi   Repair Order:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZAW187659   Mileage: 86240km-53587miles
Address 01: Engine (CAV)       Labels: 03C-906-027-CAV.clb
   Part No SW: 03C 906 027 BA    HW: 03C 906 027 F
   Component: MED17.5.5       G   9660
   Revision: LAH08---    Serial number:
   Coding: 0000077
   Shop #: WSC 43847 000 1048576
   VCID: 618AAB9CB8EB758E7C-8034
   Part No SW: 0AM 300 048 N    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 2668
   Revision: 00043014    Serial number: CU501308037652
   Shop #: WSC 38430 000 1048576
   VCID: 3B3639F47AC77F5E06-806E
006011 - Clutch 1
               P177B - 003 - Tolerance Limit Reached - Intermittent
                    Fault Status: 00100011
                    Reset counter: 10
                    Mileage: 86239 km
                    Date: 2014.12.27
                    Time: 18:41:58
   Revision: 00H45001
   Coding: 163B600D212A0001681106E9842200803500
   VCID: 004C8E1893A1DC8613-8054
   Part No SW: 5K0 907 044 BC    HW: 5K0 907 044 BC
   Component: Climatronic   H14 0608
   Revision: 00003001
   Coding: 0000000000
   ASAM Dataset: EV_Climatronic A01001
   VCID: 6D92C7ACBC3321EEC8-8038
   Part No SW: 1K0 937 086 C    HW: 1K0 937 086 C
   Component: BCM PQ35  M   103 0573
   Revision: 00103 AF
   Coding: 40180A3A902518C044080080340081E441510088536D8960648000200000
   VCID: 302C1ED863818C06A3-8064
   Component: Wischer 05100  21  0501
   Coding: 009795
   Component: RLS 131009 05  54  0402
   Coding: 0330AD
   Part No SW: 5K0 959 655     HW: 5K0 959 655
   Component: AirbagVW10    035 0604
   Serial number: 003C2RA4778.
   Coding: 00003134
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 77BEE5C4CE6F9B3E22-8022
   Serial number: 532A464CZZZZZZZZZZZZ
   Serial number: 2619444CZZZZZZZZZZZZ
   Serial number: 1C263B65ZZZZZZZZZZZZ
   Serial number: 1E403C1AZZZZZZZZZZZZ
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Component: J0527           056 0111
   Coding: 0001532
   VCID: 76A0E8C00165E23639-8022
   Subsystem 1 - Part No: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TK6   H05 0022
   Coding: 00000226
   Part No SW: 5K0 920 870 D    HW: 5K0 920 870 D
   Component: KOMBI         H05 0206
   Coding: 770B00
   VCID: 2E1000A071B59AF6B1-807A
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H07 0081
   Revision:   H07 01    Serial number: 191009F2002411
   Coding: ED807F06000602000003
   Shop #: WSC 30081 959 59690
   VCID: 6680B88051C512B689-8032
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H05 0206
   Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
   Component: Tuer-SG         009 2124
   Coding: 0000692
   VCID: 332611D45297B71EDE-8066
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 69     2901
   Revision: 00H17000
   VCID: 2F2E1DA4BEBF93FEBA-807A
   Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
   Coding: 0000692
   VCID: 342412C85799B026C7-8060
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  013 0036
   Revision: 01000000    Serial number: VWZ1Z2I6753649
   Coding: 0700040004
   Shop #: WSC 30081 959 88100
   VCID: 6582BF8C6CC319AE80-8030
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0000144
   VCID: 35222FCC5CE3A92EF0-8060
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 051 730 B    HW: 1K8 051 730 B
   Component: Telefon       H02 5400
   Revision: 00002000    Serial number: 20389520142117
   Coding: 412120
   VCID: 2600F8805145D2B649-8072
End----------(Elapsed Time: 01:03, VBatt start/end: 12.4V/12.3V)-----------
Address 02: DTCs cleared
