Caddy 1.9 TDI 4motion BLS 2010
SK2020
Norway
C?ID=296335
Hello, hope someone could help me out here:thanks: i got air in fuel lines, from the filter housing 2 the HPFP and in the return line back 2 the filter housing. no air is coming from the fuel tank 2 the filter housing.
Symptoms: Loss of power, intermittent fuel loss 2 engine.
Car was filled with gasoline and was driven until it would not run anymore.
Parts changed: All 4 injector, HPFP, Fuelpump in the tank.
NO fault codes.
any suggestions?
HMC
C?ID=28246
Hi SK2020,
The obvious question is have you changed the o rings in the fuel lines?
Regards HMC
SK2020
Norway
C?ID=296335
Hello, thank you for the response. yes i have, changed it for the second time just 2 be sure.
also changed the filterhousing without any effect.
This VW has PD injectors.
ai_Ingo
Germany (Auto-Intern)
C?ID=56975
Hi, please check whether the supply line was accidentally swapped with the return line on the tank.
ai_Ingo
C?ID=56975
Sorry, I just see that you wrote that there is no air from the tank. In that case, I would check whether the socket in the aluminum housing on the tandem pump is tight.
As the pump sucks, air could enter there.
SK2020
Norway
C?ID=296335
hey, thnx for the response!
checked the socket at the tandem pump. no air leaks there. but what i noticed is that the tandempump is making boubles in the fuel inlet and sending it back 2 the filter WHEN i turn of the engine.
when engine is running, the air is coming from the filter housing and goin 2 the tandempump, and also from the return line from the pump 2 the filter. and when i opened the fueltank filler cap i noticed that it sucked in air. almost like it was vaccum inside the fuel tank.
i also noticed some farting noise coming from the tank.
did a smoke test around the filter housing. it does not look like it is sucking in air from there. same on the socket at the tandempump.
hmmm..:confused:
Any suggestions?
ai_Ingo
C?ID=56975
Just to be absolutely sure, there is clearly a negative pressure in the tank?
