I have some issue with AC
If you set the temperature to 75 degrees and the outside temperature is 76, the air conditioner blows very cold air. If you set 80, it starts to blow hot air.
In my other cars, if I set 75, then the air will blow with a temperature of 75. Is this normal for Audi or is there a problem with the temperature sensors or something else?
SM
Wednesday,29,July,2020,17:46:49:61219
VIN: WAUMV94E79N000894 License Plate:
Mileage: 243080km-151042mi Repair Order:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 13 15 16 17 19 1E 28 34 36 37
38 3C 42 46 47 4F 52 53 55 56 5C 61 62 65 67 6C 72 76 77
VIN: WAUMV94E79N000894 Mileage: 243080km-151042miles
3C-Lane Change -- Status: Sporadic communication error 1000
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine ( ) Labels:. 079-907-560-BVJ.clb
Part No SW: 4E1 910 560 J HW: 4E1 907 560
Component: 4.2l V8/4V 0010
Revision: 71H22--- Serial number: AUX3Z0H4749959
Coding: 01060009190F0220
Shop #: WSC 02313 785 00200
VCID: 290FFC08E5F7D073245-807C
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 C HW: 09L 927 156 A
Component: AG6 09L 4,2lFSI USA 0030
Revision: --H01--- Serial number: 4454280
VCID: 2313EE2087DB0A236E9-8076
Part No SW: 4E0 910 517 J HW: 4E0 614 517 BQ
Component: ESP 5.7 allrad H49 0540
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 2A0D0304E0F1DB6B2DF-807E
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 C
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0H4749959
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58E989CC8E1D99FB4BB-800C
Component: ELV XXXX
00192 - Rear Left Door Handle Touch Sensor (G417)
Fault Status: 00100111
Reset counter: 34
Mileage: 242112 km
Date: 2020.07.01
Time: 09:31:08
Fault Frequency: 0
Reset counter: 29
Mileage: 242288 km
Date: 2020.07.03
Time: 22:30:22
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071648
VCID: 2411ED3C82D50D1B173-8070
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 732 T HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 348E$087529286
Coding: 0000003
VCID: 33331E60373B9AA39E9-8066
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000065848
Subsystem 3 - Serial number: 0113.05.080000000100010031ÿ
Subsystem 4 - Serial number: 010031ÿ
Part No SW: 4E0 910 043 B HW: 4E0 820 043 E
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000075895
Coding: 1126865
VCID: 1C61D5DCBAA535DBAF3-8048
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO29042008065A000000000069ÿ†89
Subsystem 5 - Serial number: 000069ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO29042008065A00000000
Subsystem 7 - Serial number: 65A000000000070ÿ
00066 - Rear Right Footwell Heater (Z43)
Reset counter: 233
Mileage: 241949 km
Date: 2020.06.26
Time: 17:07:21
Voltage: 12.70 V
00065 - Rear Left Footwell Heater (Z42)
Fault Status: 00101100
Fault Frequency: 10
Reset counter: 62
Mileage: 241976 km
Date: 2020.06.29
Time: 09:41:48
Voltage: 12.00 V
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 S HW: 4E0 907 279 S
Component: ILM Fahrer H16 0240
Coding: 0143123
VCID: 3829294C2E5D79FBABB-806C
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000035
Shop #: WSC 02313
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150573
Shop #: WSC 02313
02510 - Steering Column Adjustment
014 - Defective
Fault Status: 01101110
Fault Frequency: 169
Reset counter: 3
Mileage: 210597 km
Date: 2018.07.31
Time: 09:05:22
Address 0E: Media Player 1 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H15 0850
Revision: 00000000
Coding: 020000
Shop #: WSC 02399 823 56573
VCID: 2B030600E30BC263D69-807E
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 M HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7H0325519
Coding: 0000100
VCID: 313F1468CD27A8B3EC5-8064
Reset counter: 238
Mileage: 242071 km
Date: 2020.06.30
Time: 09:59:27
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4E0 910 561 F HW: 4E0 907 561 F
Component: ABSTANDSREGELUNGH03 0020
Coding: 0011218
VCID: 2517F03889EFF41300D-8070
Address 15: Airbags Labels: None
Part No SW: 4E0 910 655 F HW: 4E0 959 655 L
Component: Airbag 9.41 H01 4230
Revision: 91H01423 Serial number: 003CV0002TE5
Coding: 0532707
Subsystem 1 - Part No: 4E0 910 339 C
Component: BF-Gewichtsens. H02 0040
Subsystem 2 - Serial number: 02FS1
Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†63328RB403BA773CVÿ†63
Subsystem 5 - Serial number: A773CVÿ†63428RB403BE2FE4%ÿ†63
Subsystem 6 - Serial number: E2FE4%ÿ†63528RB403BE2F89%ÿ†63
Subsystem 7 - Serial number: E2F89%ÿ†63628RB403BA7759Xÿ†63
Subsystem 8 - Serial number: A7759Xÿ†63729RB403CD0896Yÿ†63
Subsystem 9 - Serial number: D0896Yÿ†63829RB403CD2585Wÿ
Subsystem 10 - Serial number: D2585Wÿ
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 C
Component: J0527 0410
Revision: 00H05000 Serial number: 90055081190127
Coding: 0032051
VCID: 2615F734F4E9FF0B097-8072
Component: E0221 H01 0030
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 981 D HW: 4E0 920 981 D
Component: KOMBIINSTR. VDO H84 0620
Revision: D03 Serial number: AUDID3H4100032
Coding: 0048283
Shop #: WSC 43391 067 57207
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4E0 907 468 H
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 0200J08412811A
Coding: F5F5DF7F777A0E00
Shop #: WSC 00672 210 01865
VCID: 2D070818D11FCC53C8D-8078
02849 - Control Module for Lane Change Assistance (J769)
Reset counter: 48
Mileage: 241976 km
Date: 2020.06.29
Time: 09:41:41
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H46 0390
Revision: 00046002 Serial number: AUZ5ZBH8414218
VCID: 1A6DD3C4B0914BEBBDF-804E
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 D
Component: KLIMA-STG. FOND 017 0230
Revision: 00000020 Serial number: 00000000071362
Coding: 0000000
VCID: 619FA428DD4758333C5-8034
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 K HW: 4E0 907 553 H
Component: LUFTFDR.-CDC H07 4590
Coding: 0015510
VCID: 2B030600EF0BC263D69-807E
Component: Sitzmemory FS H02 0010
Coding: 4071658
Part No SW: 4E0 910 888 M HW: 4E0 919 887 M
Component: MNS US H51 1100
Revision: 00000000 Serial number: 395E+087514589
Shop #: WSC 09223 444 66516
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H05 0090
Serial number: 00000809900076
Coding: 0003479
VCID: 1D67D8D8A1BF3CD358D-8048
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0050
Revision: 00H01000 Serial number: 6PZ 009 014-10
Coding: 0000008
Shop #: WSC 09223 444 12216
VCID: 2E050F14DC19B74BF17-807A
Component: J0770_SWA_Slave_H01 0020
Subsystem 3 - Serial number: 5F15.05.0800H010003C910238ÿ
Subsystem 4 - Serial number: 910238ÿ
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 F
Component: Türsteuer.FS BRM005 0180
Coding: 0032364
VCID: 2019E12C96CD113B73B-8074
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 E HW: 4E0 907 289 E
Component: Komfortgeraet H10 0030
Revision: 00300010 Serial number: W040805130176
Coding: 0048686
Component: Heckdeckel P27H08 0090
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
Component: DSP-High D3 H03 0120
Revision: PROD_01 Serial number: 00000000100897
Coding: 0000026
VCID: 2C01051CEA05C55BDF3-8078
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 D
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000024458
Coding: 0010111
VCID: 1E65DFD4ACB927CB417-804A
Subsystem 1 - Part No: 8K0 907 410 B
Component: HOMELINK H01 0010
Subsystem 2 - Serial number: 1770884T00DK01
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 F
Component: Türsteuer.BF BRM005 0180
Coding: 0032364
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000922
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Coding: 0000018
VCID: 698FBC0825771073E45-803C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Part No SW: 4E0 910 541 T HW: 4E0 035 542
Revision: 00000000 Serial number: 352EZ087658068
Address 5C: Lane Maintain. Labels: None
Part No SW: 4E0 910 217 C HW: 4E0 907 217 C
Component: J759 LDW H07 0070
Revision: 00H07018 Serial number: 8002085060001C
Coding: 0001104
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000008841
Subsystem 1 - Part No: 4E0 915 105
Component: von VA0 1234567890
Coding: 344530393135313035202056413031323334353637383930
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0032364
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000900057621
Coding: 0232125
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000805070117
Shop #: WSC 12336 024 394758
VCID: 34311D7C32359D9B873-8060
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J8410R7
Coding: 1120503
VCID: 5CE195DCFA2575DB6F3-8008
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08720813001010
Coding: 0221208
Part No SW: 4F0 910 336 F HW: 4E0 862 335
Component: Handyvorb2 H20 1110
Revision: 00000000 Serial number: 00000005038854
Coding: 0010900
End----------(Elapsed Time: 02:36, VBatt start/end: 13.0V/13.1V)-----------
SM
