Hi
I keep getting conflicting info and not sure if I have messed up....
So what do you guys think?
Car: 2012 Passat natural gas, CDGA engine and DSG gearbox, 7 gears, double clutch
420 000 km
Owner calls about 60000 km AFTER the oil change was due! (She drives 75000 km a year)
"Check engine light on - since some weeks"
"Have have filled up with oil couple of times in one weeks time"
"Coolant has to be topped up as well couple of times"
Coolant leak was the coolant pump.
And:
Fault code on camshaft postion sensor:
000022 - P0016
We changed oil and told her that this most likely wont last long and the chain and coolant pump would need to be changed ASAP.
The day after, she called and told the car had died on her and didnt start after that - and she had to top up engine oil already after 50 km drive.
Fault codes this time:
000022 - P0016
008851 - P2293 - Fuel pressure control valve (N276) - intermittent
000136 - P0088 - Fuel rail / system pressure - too high
I thought I had found i perfect engine to swap with.
130000 km.
But I dont today know, if it came from a manual or DSG AND the engine is from 2010.
I have since that learned that these cars have a habit of beeing near impossible to marry used parts between cars =(
The problem after the swap is following:
The mechatronic doesnt know sometimes what gear to but in - or wether to but an other gear in...
It kind of kicks in the gears. Right from the 1:st to the 2:nd gear.
Ive tried to beform basic settings - without luck.
When I told the owner of this - she told me that the Mechatronics was changed, when the car had hardly 170 000 km on the clock. From the invoice I can read, that it was updated and 2 liters gearbod oil (G052512A2) was used. But at tha time the fault code was different, it was "The clutch opens unintentionally" - no fault codes have been saved on the invoice.
Today:
Fault codes for both clutch 1 and 2, are set almost instantly:
006011 - P177B - 007 - Clutch 1 - Tolerance limit reached - Intermittent fault
I never saved the clutch 2 fault code.
And I have been using the Swedish version.
The car is at our friends who made the swap - who use to work for VAG in the past. His friend, who still works there, is on a holiday for a month and not reachable. So dont know who to ask anymore.
What am I to do next?? Or try?
420 000 km
And:
000022 - P0016
onsdag,22,April,2020,19:43:57:18201
VCDS -- Windows-baserad VAG/VAS-emulator Tändningen Windows 7 x64
VCDS version: AER 19.6.2.1 HEX-V2 CB: 0.4508.4
Dataversion: 20191020 DS308.0
www.vcds.se
Verkstads/leverantörsnamn: Firma Johannes Bruun
Verkstadskod: 000 02013 000000
VIN: WVWZZZ3CZCE089877 Reg.nr: MCC586
Mätarställning: 405320km Rep.order:
Chassityp: 3C-VW46 (7N0)
Skanna: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 4C 4F 52 53 55 56
61 62 69 72
VIN: WVWZZZ3CZCE089877 Mätarställning: 405320km
01-Motor -- Status: Felfunktion 0010
02-Automatväxel -- Status: OK 0000
03-Bromselektronik -- Status: OK 0000
04-Styrposition -- Status: OK 0000
08-Klimatanläggning -- Status: Felfunktion 0010
09-Elektron. elcentral -- Status: Felfunktion 0010
10-park/styr-hjälp -- Status: Felfunktion 0010
15-Krockkuddar -- Status: OK 0000
16-Rattelektronik -- Status: OK 0000
17-Instrument -- Status: OK 0000
25-Startspärr -- Status: OK 0000
42-Dörrel. förare -- Status: Felfunktion 0010
44-Styrservo -- Status: OK 0000
46-Komfortcentral -- Status: OK 0000
4C-Däcktrycksk. II -- Status: OK 0000
4F-Elektr. centralenh. II -- Status: OK 0000
52-Dörrelektr. pass. -- Status: OK 0000
53-Parkeringsbroms -- Status: OK 0000
55-Helljusområde -- Status: OK 0000
56-Radio -- Status: Felfunktion 0010
61-Batteriregul. -- Status: OK 0000
62-Dörr, Vä Bak -- Status: OK 0000
69-Släpvagn -- Status: Felfunktion 0010
72-Dörr hö bak -- Status: OK 0000
Adress 01: Motor (CDG) Labels: AER\03C-906-021-CDG.clb
Artikelnr SW: 03C 906 021 Q HW: 03C 907 309 D
Komponent: 4414 CNG 14K31 G 6368
Revision: E8H06--- Serienummer: VWZCZ000000000
Kodning: 0000077
Verkstad #: WSC 11064 003 1048576
VCID: 290FFFFE05FD53DFBE8-807C
2 Funna fel:
000715 - Turbo/kompressor "B"
P02CB - 000 - för lågt tryck
frysta data:
Felstatus: 01100000
Felprioritet: 0
Felfrekvens: 1
Reset-räknare: 255
Mätarställning: 404424 km
Tidsindikering: 0
Datum: 2014.09.07
Tid: 17:32:56
frysta data:
RPM: 1984 /min
Belastning: 91.3 %
Temperatur: 87.0°C
Temperatur: 21.0°C
Absoluttryck: 990.0 mbar
Spänning: 13.462 V
000022 - Rad 1
P0016 - 000 - kamaxelläges (G40)/vevaxellägessensor (G28) Fel anpas - Fellampa(MIL) tänd
frysta data:
Felstatus: 11100000
Felprioritet: 0
Felfrekvens: 1
Reset-räknare: 255
Mätarställning: 404641 km
Tidsindikering: 0
Datum: 2014.09.09
Tid: 09:20:42
frysta data:
RPM: 2016 /min
Belastning: 11.8 %
Temperatur: 75.0°C
Temperatur: 10.0°C
Absoluttryck: 1010.0 mbar
Spänning: 14.859 V
Adress 02: Automatväxel Labels: AER\0AM-927-769.clb
Artikelnr SW: 0AM 300 058 P HW: 0AM 927 769 D
Komponent: GSG DSG AG7 431 4547
Revision: 00043014 Serienummer: CU501604215411
Kodning: 0000020
Verkstad #: WSC 04940 001 00001
VCID: 3E253CA2EC73C467FBA-806A
Ingen felkod funnen.
Adress 03: Bromselektronik Labels: AER\3AA-614-109.clb
Artikelnr SW: 3AA 614 109 AC HW: 3AA 614 109 AC
Komponent: J104 C2 450M VD7A 0022
Revision: --H07--- Serienummer: 00000004836711
Kodning: 0132465
Verkstad #: WSC 05311 000 00000
VCID: 6E85CCE2FC9374E72BA-803A
Adress 08: Klimatanläggning (J255) Labels:| AER\5K0-907-044.clb
Artikelnr SW: 5K0 907 044 ES HW: 5K0 907 044 ES
Komponent: Climatronic H18 1112
Revision: 00001004
Kodning: 0004004802
Verkstad #: WSC 00015 115 00000
VCID: 0059825ADA877297C96-8054
1 fel funnet:
9481988 - sensor för luftkvalitet
B10AF 04 [008] - Internt system-fel
Intermittent fel - Bekräftad - Testad efter att minnet rensats
frysta data:
Felstatus: 00000001
Felprioritet: 3
Felfrekvens: 115
Reset-räknare: 140
Mätarställning: 393456 km
Datum: 2020.02.07
Tid: 19:32:19
Adress 09: Elektron. elcentral (J519) Labels:. AER\3AA-937-087.clb
Artikelnr SW: 3AA 937 087 M HW: 3AA 937 087 E
Komponent: BCM PQ47 H+ 413 1450
Revision: BC413001
Kodning: 000800000000000000180280540029F423D54B88626D8D60E48046240041
VCID: 44D14E4A8E9FAEB7ADE-8010
Subsystem 1 - Artikelnr SW: 3AB 955 419 HW: 3AB 955 419 Labels: AER\1KX-955-119.CLB
Komponent: Wischer 15091 10 0603
Kodning: 00B795
Subsystem 2 - Artikelnr: 1K0 955 559 AH Labels: AER\1K0-955-559-AG.CLB
Komponent: RLS 101011 05 54 0403
Kodning: 02302A
Adress 10: park/styr-hjälp (J446) Labels:| AER\3AE-919-475.clb
Artikelnr SW: 3AE 919 475 C HW: 7N0 919 475
Komponent: PARKHILFE 8K H06 0018
Revision: -------- Serienummer: 28231731206977
Kodning: 118102
Verkstad #: WSC 60077 001 1048576
ASAM Dataset: EV_EPHVA18VW47X0000 001006
ROD: EV_EPHVA18VW47X0000.rod
VCID: 3FDB41A6E7F9CD6FF0C-806A
1 fel funnet:
1079601 - höger givare bak för parkeringshjälpen
B1079 31 [008] - Signal saknas
frysta data:
Felstatus: 00000001
Felprioritet: 3
Felfrekvens: 22
Reset-räknare: 34
Mätarställning: 345310 km
Datum: 2019.05.31
Tid: 14:12:13
Adress 15: Krockkuddar Labels: AER\5N0-959-655.lbl
Artikelnr SW: 5N0 959 655 R HW: 5N0 959 655 R
Komponent: J234__101 VW10 HI 1918
Revision: 22014000 Serienummer: 003K0PLW5BF3
Kodning: 0012337
VCID: 4CC1666AAACF66F765E-8018
Subsystem 1 - Serienummer: 6332MTS610562671
Subsystem 2 - Serienummer: 6342MTS665232671
Subsystem 3 - Serienummer: 6351HTS6K7KPEAKJ
Subsystem 4 - Serienummer: 6361HTS6PS64FAKJ
Subsystem 5 - Serienummer: 00000000000000000
Subsystem 6 - Serienummer: 00000000000000000
Adress 16: Rattelektronik (J527) Labels:| AER\5K0-953-569.clb
Artikelnr SW: 5K0 953 569 AS HW: 5K0 953 569 AS
Komponent: LENKS.MODUL 016 0180
Revision: --X01--- Serienummer: 20151012201040
Kodning: 1982250000
Verkstad #: WSC 45670 002 1048576
VCID: 094F9F7EE9BD33DF9E8-805C
Styrdon för multifunktionsratt:
Subsystem 1 - Artikelnr SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: AER\3C8-959-537.CLB
Komponent: E221__MFL-TK6 H06 0022
Serienummer: 40000000000000489268
Kodning: E20000
Adress 17: Instrument (J285) Labels:| AER\3C8-920-xxx-17.clb-SRI1
Artikelnr SW: 3AA 920 870 E HW: 3AA 920 870 E
Komponent: KOMBI H03 0607
Kodning: 161F01
Verkstad #: WSC 05314 115 00000
VCID: 34311E8ADEBF1E371DE-8060
Adress 19: CAN Gateway (J533) Labels:. AER\7N0-907-530-V2.clb
Artikelnr SW: 7N0 907 530 L HW: 1K0 907 951
Komponent: J533 Gateway H41 1620
Revision: H41 Serienummer: 071011F2001932
Kodning: 462006
Verkstad #: WSC 00000 480 652003
VCID: 392F2FBEF95DE35FCE8-806C
Adress 25: Startspärr Labels: AER\3C0-959-433-25.clb
Artikelnr SW: 3AA 959 433 F HW: 3AA 959 433 F
Komponent: IMMO 048 0429
Revision: 00048000 Serienummer: VWZCZ000000000
VCID: 3C2136AAFA6FD677D5E-8068
Subsystem 1 - Artikelnr: 3C0 905 861 J
Komponent: ELV 029 0380
3C0905861J ELV 029 0380
Adress 42: Dörrel. förare (J386) Labels:| AER\3C0-959-70X-GEN4.clb
Artikelnr SW: 3AA 959 701 A HW: 3C0 959 793 C
Komponent: TUER-SG FT 002 0533
Revision: 12110009 Serienummer: 0003639631
Kodning: 0000B7
Verkstad #: WSC 05311 115 00000
VCID: 3537238ED5C5073F2A0-8060
Slave Driver:
Subsystem 1 - Artikelnr SW: 3C0 959 703 HW: 3C0 959 795 Labels: AER\1K0-959-70X-GEN4.CLB
Komponent: J388__TSG-HL 004 0407
Serienummer: 00000002483748
Kodning: 000090
1 fel funnet:
66304 - knapp för fönsterhiss på förarsidan
B11F0 29 [008] - Signafel
frysta data:
Felstatus: 00000001
Felprioritet: 2
Felfrekvens: 1
Reset-räknare: 136
Mätarställning: 403812 km
Datum: 2020.04.12
Tid: 12:18:16
Adress 44: Styrservo Labels: AER\5N1-909-144.clb
Artikelnr SW: 5N1 909 144 M HW: 5N1 909 148 G
Komponent: J500__APA-BS KL.308 1002
Revision: 1AH03734 Serienummer: 00112730158301
Kodning: 0000258
Adress 46: Komfortcentral Labels:. AER\3C0-959-433-46.clb
Komponent: KSG PQ47 ELV 048 0714
Kodning: 0191020052830E763404941570084FCE707801
Subsystem 1 - Artikelnr: 1K0 951 605 C
Komponent: LIN BACKUP HORN H05 1501
Subsystem 2 - Artikelnr: 3C0 951 171 C
Komponent: Neigungssensor 004 0611
Subsystem 3 - Artikelnr: 3C0 951 171 C
Komponent: Innenraumueberw.004 0611
Adress 4F: Elektr. centralenh. II (J520) Labels:. AER\1K0-907-532.clb
Artikelnr SW: 7N0 907 532 HW: 1K0 907 951
Komponent: EZE_2 H41 1620
Kodning: 00000008
VCID: 6FBBD1E6F7997DEF20C-803A
Subsystem 1 - Artikelnr SW: 3AA 919 204 A HW: 3AA 919 204 A
Komponent: Analoguhr 004 0003
Adress 52: Dörrelektr. pass. (J387) Labels:| AER\3C0-959-70X-GEN4.clb
Artikelnr SW: 3AA 959 702 A HW: 3C0 959 792 C
Komponent: TUER-SG BT 002 0533
Revision: 14110009 Serienummer: 0003615133
Kodning: 0000B6
VCID: 36352482C8C30C2723A-8062
Slave Passenger:
Subsystem 1 - Artikelnr SW: 3C0 959 704 HW: 3C0 959 794 Labels: AER\1K0-959-70X-GEN4.CLB
Komponent: J389__TSG-HR 004 0407
Serienummer: 00000002495589
Kodning: 000090
Adress 53: Parkeringsbroms Labels: AER\3AA-907-801.clb
Artikelnr SW: 3AA 907 801 G HW: 3AA 907 801 G
Komponent: J540 EPB4 VW-64783 0009
Revision: H19 Serienummer: 00000000303288
Kodning: 0022157
VCID: 3537238ED945073F2A0-8060
Adress 55: Helljusområde (J745) Labels:. AER\5M0-907-357-V3.clb
Artikelnr SW: 5M0 907 357 E HW: 7L6 907 357 C
Komponent: AFS-ECU H04 0105
Revision: -------- Serienummer: --------------
Kodning: 021200000B000200
Verkstad #: WSC 60072 001 1048576
ASAM Dataset: EV_HeadlRegulVWAFSPt 002014
Subsystem 1 - Artikelnr SW: 3D0 941 329 HW: 3D0 941 329 Labels: AER\3D0-941-329.CLB
Komponent: LeiMo links H04 0011
Kodning: 230000
Subsystem 2 - Artikelnr SW: 3D0 941 329 D HW: 3D0 941 329 D Labels: AER\3D0-941-329.CLB
Komponent: LeiMo rechts H01 0002
Kodning: 230000
Adress 56: Radio (J0503) Labels:. AER\5M0-035-1xx-56.clb
Artikelnr SW: 3C8 035 195 F HW: 3C8 035 195 F
Komponent: Radio RCD510 050 0207
Revision: 00000001 Serienummer: VWZ1Z3L7671044
Kodning: 05000400040011
Verkstad #: WSC 05314 000 00000
VCID: 2B0305F6030141CF4C4-807E
1 fel funnet:
00468 - CD-ROM-läsare (R92)
014 - felaktig
frysta data:
Felstatus: 01101110
Felprioritet: 5
Felfrekvens: 1
Reset-räknare: 12
Tidsindikering: 0
Datum: 2013.10.20
Tid: 20:22:54
Adress 61: Batteriregul. (J840) Labels:. AER\1K0-907-534.clb
Artikelnr SW: 7N0 907 534 HW: 1K0 907 951
Komponent: Batt.regelung H41 1620
Kodning: 03220864
VCID: 71BFD79EE1AD6B1F368-8024
Subsystem 1 - Artikelnr SW: 1K0 915 181 H HW: 1K0 915 181 A
Komponent: J367-BDM H07 0180
Serienummer: 00000000008900751563
Adress 69: Släpvagn (J345) Labels:. AER\7N0-907-383.clb
Artikelnr SW: 7N0 907 383 HW: 7N0 907 383
Komponent: Anhaenger H09 0101
Revision: 3I001002 Serienummer: 00000159189636
Kodning: 4106040000000000
VCID: 73B3DD969BB1590FC44-8026
2 Funna fel:
02562 - Lampor för bromsljus: släp
010 - Avbrott eller kortsluten till plus - Intermittent fel - Fellampa(MIL) tänd
frysta data:
Felstatus: 10101010
Felprioritet: 3
Felfrekvens: 3
Reset-räknare: 144
Tidsindikering: 0
02566 - Vänster blinklyktor: släp-
010 - Avbrott eller kortsluten till plus - Fellampa(MIL) tänd
frysta data:
Felstatus: 11101010
Felprioritet: 3
Felfrekvens: 22
Reset-räknare: 104
Tidsindikering: 0
Slut--------(Förfluten tid: 01:44, Vbatt start/stopp: 12.2V/12.2V)---------
000022 - P0016
måndag,27,April,2020,18:56:38:18201
www.vcds.se
VIN: WVWZZZ3CZCE089877 Reg.nr: MCC568
Adress 01: Motor Labels: AER\03C-906-021-CDG.clb
Styrenhet artikelnr: 03C 906 021 Q HW: 03C 907 309 D
Komponent och/eller version: 4414 CNG 14K31 G 6368
SW-kodning: 0000077
Verkstadskod: WSC 11064 003 1048576
3 Funna fel:
000022 - Rad 1
frysta data:
Felstatus: 11100000
Felprioritet: 0
Felfrekvens: 1
Reset-räknare: 255
Mätarställning: 405325 km
Tidsindikering: 0
Datum: 2032.14.25
Tid: 11:37:43
frysta data:
RPM: 687 /min
Belastning: 19.6 %
Temperatur: 45.0°C
Temperatur: 13.0°C
Spänning: 14.859 V
008851 - Regleringsventil för bränsletryck (N276)
P2293 - 000 - mekaniskt fel - Intermittent fel - Fellampa(MIL) tänd
frysta data:
Felstatus: 10100000
Felprioritet: 0
Felfrekvens: 24
Reset-räknare: 255
Mätarställning: 405395 km
Tidsindikering: 0
Datum: 2032.14.27
Tid: 19:49:35
frysta data:
RPM: 652 /min
Belastning: 26.3 %
Temperatur: 62.0°C
Temperatur: 24.0°C
Absoluttryck: 1000.0 mbar
Spänning: 14.478 V
000136 - Bränsle rail-/systemtryck
P0088 - 000 - för högt - Fellampa(MIL) tänd
frysta data:
Felstatus: 11100000
Felprioritet: 0
Felfrekvens: 24
Reset-räknare: 255
Tidsindikering: 0
Datum: 2032.14.27
Tid: 19:49:39
frysta data:
RPM: 775 /min
Belastning: 28.2 %
Temperatur: 60.0°C
Temperatur: 24.0°C
Spänning: 14.478 V
130000 km.
Today:
Readiness: 1000 0000
måndag,20,Juli,2020,18:40:48:18201
VCDS version: AER 20.4.1.1 HEX-V2 CB: 0.4508.4
Dataversion: 20200630 DS317.0
www.vcds.se
Styrenhet artikelnr: 0AM 300 058 P HW: 0AM 927 769 D
Komponent och/eller version: GSG DSG AG7 431 4547
SW-kodning: 0000020
Verkstadskod: WSC 04940 001 00001
VCID: 3E253CA2EC73C46B616-806A
1 fel funnet:
006011 - koppling 1
P177B - 007 - Toleransgräns uppnådd - Intermittent fel
frysta data:
Felstatus: 00100111
Felprioritet: 0
Felfrekvens: 1
Reset-räknare: 10
Mätarställning: 405434 km
Tidsindikering: 0
Datum: 2034.14.27
Tid: 07:01:34
