Hello Members.
I replaced my BCM on a Vw T5,1 Caravelle to a 7E0 937 090 D BCM PQ25 Max4 H82 0762
I cleared the stored data from the BCM and when attempting to code my keys VCDS says Chanel not available.
Are my only option is the dealer coding?
Latest scan
Saturday,01,August,2020,11:52:12:36108
VCDS Version: 20.4.1.0 (x64) HEX-NET CB: 0.4508.4
VIN: WV2ZZZ7HZCH133237 License Plate: AJ62
Mileage: 135260km-84046mi Repair Order: New BCM adaptation issue
Adaptation Channel 001:
Stored value
ERROR:
Channel 01
Not
Available
Latest scan
Saturday,01,August,2020,11:47:49:36108
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 0D 10 15 17 18 19 25 56 69 78 0B
VIN: WV2ZZZ7HZCH133237 Mileage: 135260km-84046miles
0D-Slide Door, Left -- Status: OK 0000
78-Slide Door, Right -- Status: OK 0000
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 022 JD HW: 03L 907 309 H
Component: R4 v002 EDC X36 8749
Revision: 22X36--- Serial number: 00000000000000
Coding: 0125401A232400080000
Shop #: WSC 79883 336 16496
ASAM Dataset: EV_ECM20BTD01103L906022JD 002011
ROD: EV_ECM20BTD01103L906022JB.rod
VCID: 70ACD288AB2E1F06FB-8024
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 045 M HW: 0BH 927 711 C
Component: DSG DQ500-7F H05 1795
Revision: 00H05V01
VCID: 3FCE41B4A6F0B07E32-806A
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 J HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0109
Revision: 00H43001
Coding: 108764AD09A7089826A49074AA6510
Shop #: WSC 02756 790 49152
VCID: 393A2FACB0D49E4E0C-806C
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E5 907 040 AC HW: 7E5 907 040 AC
Component: ClimatronicT5 H19 0407
Revision: 00001003
Coding: 0004000102
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: 699ABFEC88F4EECEBC-803C
Slave 1:
Subsystem 1 - Part No SW: 7E5 907 049 B HW: 7E5 907 049 B
Component: Heckbedienung H10 0202
Serial number: BHB-0012304120015096
U1111 00 [009] - -
[Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
Reset counter: 3
Time: 00:00:00
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 D HW: 7E0 937 090 D
Component: BCM PQ25 Max4 H82 0762
Revision: B9082001 Serial number: 8601 312180165
Coding: A0B279382E612413932888106C2B8EDD0080410F60844000300003000000
Shop #: WSC 35110 377 08192
VCID: 2C1406F84F863BE687-8078
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 180412 05 54 0403
Coding: 02302E
Subsystem 2 - Part No SW: 7E0 959 801 B HW: 7E0 959 801 B Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3311
Subsystem 3 - Part No SW: 7E0 959 802 B HW: 7E0 959 802 B Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3311
Subsystem 4 - Part No: 7E1 951 171
Subsystem 5 - Part No: 1K0 951 605 C
Subsystem 6 - Part No: 7E1 951 171
Subsystem 7 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H06 0022
Serial number: 70000000000000149465
Coding: E30000
00532 - Supply Voltage B+
Fault Status: 00101011
Reset counter: 43
01516 - Terminal 30; Left
Reset counter: 3
00927 - Terminal 30 (Right)
Reset counter: 3
04194 - Vehicle Status with Under-Voltage
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 3
Address 0D: Slide Door, Left Labels: Redir Fail!
Part No: 7E0 959 243 D
Component: Schiebetuer-SG 407 0328
Shop #: WSC 02756 790 00000
VCID: 302C1288A3AE5F06BB-8064
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 E HW: 7E0 919 475 A
Component: PARKHILFE 8K H11 0013
Revision: -------- Serial number: 47461208500166
Coding: 108102
ASAM Dataset: EV_VW75XParkAssis8K A01005
ROD: EV_VW75XParkAssis8K_A01_VN75.rod
VCID: 34241E989FB66326DF-8060
Part No SW: 7E0 959 655 C HW: 7E0 959 655 C
Component: VW10Airbag00P H07 0013
Revision: -------- Serial number: 003HM002866L
Coding: 000000000000000000000000000000003050
Shop #: WSC 02754 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3620249089CA7136E1-8062
Serial number: 3495ZRB405B0P7HOEHCF
Serial number: 3505ZRB40510P7AOGGM1
Part No SW: 7E0 920 980 E HW: 7E0 920 980 E
Component: KOMBI H04 0306
Coding: 460F01
VCID: 2D120BFC7C9C32EE90-8078
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
Reset counter: 3
Time: 00:00:00
Address 18: Aux. Heat Labels: None
Part No: 7E0 815 071 B
Component: J737__Standheizung 0605
Revision: 00085000 Serial number: 09019275F00000
Coding: 0000031
Shop #: WSC 02757 790 00000
VCID: 2404EED8E756F3A64F-8070
Temperature: 28.0°C
Voltage: 11.56 V
Temperature: 77.5°C
00625 - Vehicle Speed Signal
Temperature: 28.0°C
Voltage: 11.49 V
Temperature: 77.5°C
00667 - Ambient Temperature Signal
Temperature: 28.0°C
Voltage: 11.49 V
Temperature: 77.5°C
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090 D
Component: GW-K-CAN TP20 H82 0762
Revision: B9082001
Coding: 042300
VCID: 689CBAE89BFED7C6A3-803C
01304 - Radio
Reset counter: 3
Reset counter: 3
Component: IMMO H04 0306
VCID: 6A98C0E08DF2E5D6B5-803E
Address 56: Radio
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revision: 3B001001 Serial number: 00000509112665
Coding: 0100000101000000
VCID: 322818806DA26D16CD-8066
Reset counter: 3
Address 78: Slide Door, Right Labels: Redir Fail!
End----(Elapsed Time: 02:04, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
