2010 transporter ESC light on
merlot
Australia
C?ID=350826
i bought the van with a bad engine
i bought a 2017 t6 and swapped:engine,ecu,cluster,drive shafts,hubs,brakes,MFSteering wheel
the gearbox is now 4wd
since the swap the ESC light on the dash is constantly on
any help would be greatly appreciated
also i trie to code the later model BCM and think i stuffed it up,i really wanted the now new MFS steering wheel to show the lights,but it just wouldnt work,so i went back to the orig BCM but i messed up the long coding
Sunday,02,August,2020,13:34:35:46442
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4513.4
Dealer/Shop Name: culleys garage
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 56 69 0B
VIN: WV1ZZZ7HZHH139494   Mileage: 84070km-52238miles
69-Trailer -- Status: Cannot be reached 1100
Address 01: Engine (J623-CFCA)       Labels: None
   Part No SW: 03L 906 019 LB    HW: 03L 907 309 L
   Component: R4 2.0l BTD   H38 9979
   Revision: 22H38---    Serial number: 00000000000000
   Coding: 01254012233601080000
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ECM20BTD01103L906019LB 004003
   ROD: EV_ECM20BTD01103L906019LB.rod
   VCID: 76B5E53D384C6B1B78F-8022
5453 - SAE - Starter Request Circuit
          P0512 00 [096] - -
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [047] - -
                    Mileage: 70896 km
                    Date: 2020.01.13
                    Time: 21:05:49
                    Coolant temperature: 18 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 11.800 V
                    ACC target acceleration: 0.000 m/s²
                    ACC control module received status-Bits 0-7: 6
                    Active brake system error status-Bits 0-7: 0
                    Status of ACC/CCS acceleration interface-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_READY
12006 - Indicator Lamp for Start-Stop Operation
          P167A 00 [047] - Electrical Malfunction
                    Mileage: 70896 km
                    Date: 2020.01.13
                    Time: 21:05:49
5523 - Engine Start Blocked by Immobilizer
          P1570 00 [032] - -
                    Mileage: 83700 km
                    Date: 2020.07.18
                    Time: 22:37:24
                    Engine speed: 1001.50 /min
                    Coolant temperature: 7 °C
                    Intake air temperature: 10 °C
                    Voltage terminal 30: 13.960 V
                    Immobilizer snapshot A-Sia Error Snap A: 94 14 0A
                    Immobilizer snapshot B-Sia Error Snap B: 03 00 00
4629 - ECM Power Relay Load Circuit
          P068A 00 [032] - Opens Too Early
   Part No SW: 0BT 300 012 A    HW: 0BH 927 711 G
   Component: DSG DQ500-7A  H11 2502
   Revision: 00H11V01
   VCID: 2D070A518D9A68C3C95-8078
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 E    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0103
   Revision: 00H43001
   Coding: 708764AD89A80E9C26AA9176A96516
   Shop #: WSC 02736 790 49152
   VCID: 34311F356E30390B86B-8060
                    Reset counter: 83
                    Mileage: 84073 km
                    Date: 2020.08.01
                    Time: 01:46:04
                    Count: 529
                    Count: 4163
                    Count: 252
                    Fault Status: 01100101
                    Reset counter: 83
                    Mileage: 84073 km
                    Date: 2020.08.01
                    Time: 01:46:04
                    Count: 529
                    Count: 212
                    Count: 252
                    Reset counter: 83
                    Mileage: 84073 km
                    Date: 2020.08.01
                    Time: 01:46:04
                    Count: 529
                    Count: 279
                    Count: 252
                    Reset counter: 83
                    Mileage: 84073 km
                    Date: 2020.08.01
                    Time: 01:46:04
                    Count: 529
                    Count: 270
                    Count: 252
Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
   Part No SW: 7E5 907 047 T    HW: 7E5 907 047 T
   Component: Climatic-T5   H10 0101
   Revision: 00004001
   Coding: 0000000002
   Shop #: WSC 02757 790 50316
   ASAM Dataset: EV_ClimaticT5 A01002
   ROD: EV_ClimaT5Basis.rod
   VCID: 40D943E52A0895AB123-8014
   Part No SW: 7H0 937 087 B    HW: 7H0 937 087 B
   Component: BCM T5GP H+4  H46 0207
   Revision: BO046001    Serial number: 0156 052101031
   Coding: A8A0293A0E21200100280000242B8CD50080430F60040000300000000000
   Shop #: WSC 02736 790 12345
   VCID: 33331C296B3E3E339F1-8066
   Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3310
   Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3310
   Subsystem 3 - Part No SW: 2H0 959 442     HW: 2H0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 29170000212560027063
   Coding: A4FFFF
03303 - Response Closing Status of Rear Left Door
                    Fault Frequency: 13
                    Reset counter: 122
                    Mileage: 82747 km
                    Date: 2020.06.06
                    Time: 20:57:18
01117 - Generator Terminal DF Load Signal
                    Fault Frequency: 9
                    Reset counter: 122
                    Mileage: 72402 km
                    Date: 2020.02.28
                    Time: 02:52:20
   Part No SW: 7E0 959 655 A    HW: 7E0 959 655 A
   Component: VW10Airbag010 H05 0011
   Revision: --------    Serial number: 003E500192G7
   Coding: 000000000000000000000000000000003130
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 34311F356EB0390B86B-8060
   Part No SW: 7E0 920 870 S    HW: 7E0 920 870 S
   Component: KOMBI         H03 1104
   Coding: 1408200100
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 392F2E0149D2C46355D-806C
   Part No SW: 6N0 909 901     HW: 7H0 937 087 B
   Component: GW-K-CAN TP20 0207
   Coding: 042300
   VCID: 70B9D3255AA8452BA23-8024
                    Date: 2018.10.29
                    Time: 02:08:12
01517 - Control Module for Trailer/Towing Sensor (J345)
                    Reset counter: 171
                    Mileage: 52553 km
                    Date: 2019.06.24
                    Time: 22:22:57
   Component: IMMO          H03 1104
   VCID: 6A8DC14D7CF4BFFBEC7-803E
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Mileage: 83700 km
                    Date: 2020.07.18
                    Time: 22:37:13
   Part No SW: 7E0 035 156     HW: 7E0 035 156
   Component: Radio         H21 0058
   Revision: R0000000    Serial number: VWZAZ1K9818271
   Coding: 0000020101
   VCID: 6099A3658A48F5AB323-8034
                    Fault Status: 01110100
                    Reset counter: 89
Address 69: Trailer
End----------(Elapsed Time: 01:36, VBatt start/end: 12.1V/12.1V)-----------
Moved to Retrofits.
You say, "gearbox is now 4wd". Yet there is no AWD control module showing up in this scan?
merlot
Australia
C?ID=350826
yes
the donor van was a trakka with 4 motion
the adapter for this was on the new gearbox and i saw no reason to remove it although i havent fitted the rear transaxle
im happy with 2wd
do you think this is why the light stays on?
thanks
russ
I would guess this is why the ABS complains that it is incorrectly coded.
I don't recall having seen a coding chart for this ABS either. :(
