Saturday,01,August,2020,21:46:13:17948
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
VIN: WA1LMAFE4FD032679 License Plate:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
55 56 5F 62 69 6C 6D 6F 72
VIN: WA1LMAFE4FD032679 Mileage: 115070km-71501miles
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 A HW: 4L0 907 401 E
Component: 3.0TDI FSA H23 0012
Revision: 54H23--- Serial number:
Coding: 2A2A4012253600050000
Shop #: WSC 06221 003 1048576
ASAM Dataset: EV_ECM30TDI0114L2910401A 001013
ROD: EV_ECM30TDI0114L2910401A.rod
VCID: 221DEF71144B90DB647-8076
38161 - Reductant Metering Module
P20FE 00 [096] - Malfunction
9952 - Catalyst System; Bank 1
P0420 00 [096] - Efficiency Below Threshold
Mileage: 114210 km
Date: 2020.07.12
Time: 08:57:50
Engine speed: 2038.00 /min
Normed load value: 85.1 %
Vehicle speed: 33 km/h
Coolant temperature: 62 °C
Intake air temperature: 31 °C
Ambient air pressure: 820 mbar
Voltage terminal 30: 13.880 V
Unlearning counter according OBD: 21
Engine torque: 321.6 Nm
Current operating mode_2-Bits 0-7: 64
Current operating mode_2-Bits 0-7: 0
Current operating mode_2-Bits 0-7: 2
Exh.gas temp.sen 3: 361.6 °C
Exh.gas temp.sen 4: 111.4 °C
Exh.gas temp.sen 1: 532.4 °C
Injection release status-Bits 0-7: 56
17262 - Terminal 30
U140A 00 [032] - Open Circuit
[Terminal 30Open circuit]
Time: 00:00:00
Coolant temperature: -40 °C
Intake air temperature: -40 °C
Ambient air pressure: 0 mbar
Voltage terminal 30: 0.000 V
Shut-off timer: last engine shut-off time: 0 s
Control module temp.: max. value: -273.1 °C
Mean injection quantity: 0.00 mg/stroke
Ambient temperature: -273.1 °C
Control Module temperature: -273.1 °C
4629 - ECM Power Relay Load Circuit
P068A 00 [032] - Opens Too Early
Time: 00:00:00
Starter control: Interlock- or P/N-signal-Bits 0-7: 0
Engine status: COENG_STANDBY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 AQ HW: 0C8 927 750 AQ
Component: AL1000 AISIN 002 3399
Coding: 001378
ASAM Dataset: EV_TCMAL991031 002115
ROD: EV_TCMAL991031_002.rod
VCID: 7BA3F215D3610113071-802E
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0099441
Shop #: WSC 31414 790 00001
VCID: 34311929B23F0E6B86B-8060
Reset counter: 32
Mileage: 115064 km
Date: 2020.07.25
Time: 13:24:50
Count: 192
Count: 11073
Count: 128
Count: 34304
Reset counter: 0
Mileage: 115068 km
Count: 192
Count: 2885
Count: 297
Count: 32000
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0210
Revision: 00H08000 Serial number: 10603902216261
Coding: 0000135
VCID: 2517F46D09E567E3015-8070
Component: FBSAUDIC6 EZS H05 0020
Component: FBSAUDIC6 KSG H03 0020
00956 - Key 2
Fault Status: 01110010
Reset counter: 0
00532 - Supply Voltage B+
Reset counter: 31
Mileage: 115068 km
Date: 2020.07.25
Time: 14:30:02
Reset counter: 31
Mileage: 115068 km
Date: 2020.07.25
Time: 14:20:37
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AP
Revision: 00---031 Serial number: 00000030391771
Coding: 0304A036
VCID: 2517F46D05E567E3015-8070
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Coding: 0139123
VCID: 6E85CB419C9364BBB0F-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Reset counter: 32
Mileage: 115068 km
Date: 2020.07.25
Time: 14:21:00
Reset counter: 32
Mileage: 115068 km
Date: 2020.07.25
Time: 14:30:00
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55931516104707
Coding: 25011E
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 34311929BEBF0E6B86B-8060
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH46 0230
Revision: 10H46000 Serial number: 0038QDA04DSJ
Coding: 0014131
VCID: 2B0302556F015193D71-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME174D3674K
Subsystem 3 - Serial number: 6342QSME2850485CK
Subsystem 4 - Serial number: 6352QSME7E531D5C.
Subsystem 5 - Serial number: 6362QSME174D3E5AZ
Subsystem 6 - Serial number: 63734SME6C53107E6
Subsystem 7 - Serial number: 63834SME6953044E4
Part No SW: 4F0 910 549 B HW: 4F0 953 549 F
Component: J0527 0830
Revision: 00H09000 Serial number: 90026151570190
Coding: 0012242
VCID: 2809FD597EF77A8B3A3-807C
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 Q HW: 4L0 920 985 Q
Component: KOMBIINSTR. H35 0332
Revision: 00000000 Serial number: X2S422J6G
Coding: 8BD664040100CF05020205
VCID: 42DD4FF1F48BB0DB047-8016
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB800038 Serial number: 3800M156111103
Coding: 00C303
VCID: 3FDB46058779DD336B9-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 32152629384121175379
02256 - Quiescent Current
Fault Status: 00100001
Fault Frequency: 146
Reset counter: 32
Mileage: 109959 km
Date: 2020.02.27
Time: 17:43:00
Fault Frequency: 160
Reset counter: 32
Mileage: 109959 km
Date: 2020.02.27
Time: 20:43:00
Bin. Bits: 00000
Voltage: 12.40 V
Count: 18
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AE
Revision: 00---012 Serial number: 00000000480036
Coding: 0000006
VCID: 6889BD59BE77BA8BFA3-803C
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0065
Revision: AA000000 Serial number: 00000149612500
Coding: 00581B00000011110000
VCID: 323D1F31442B005B947-8066
Reset counter: 32
Mileage: 115068 km
Date: 2020.07.25
Time: 14:30:02
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH03 0050
Revision: 00H03000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E050B415C1324BBF0F-807A
Component: J0770_SWA_Slave_H03 0050
Subsystem 3 - Serial number: 5F09.06.1500H03000AMS14750ÿ
Subsystem 4 - Serial number: S14750ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000154647447
Coding: 011F57205E40440004
VCID: 48C95DD9D2B79A8BDA3-801C
01705 - Selection Switch for Mirror-Adjust (E48)
Fault Frequency: 101
Reset counter: 31
Reset counter: 32
Mileage: 115068 km
Date: 2020.07.25
Time: 14:29:08
Reset counter: 32
Mileage: 115068 km
Date: 2020.07.25
Time: 14:30:02
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 82010344530000
Coding: 3569949
VCID: 38292D19AE57EA0BAA3-806C
00576 - Terminal 15
Reset counter: 32
Mileage: 115068 km
Date: 2020.07.25
Time: 14:13:49
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004001 Serial number: 00000000086199
Coding: 030000
VCID: 290FF85D69FD438325D-807C
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005191106784
Coding: 0758477
VCID: 2313EA7507D199D36F1-8076
02214 - Tire Pressure Warning
Reset counter: 31
Mileage: 114938 km
Date: 2020.07.23
Time: 13:11:44
Hex Value: 0x0070
Hex Value: 0x0000
Hex Value: 0x0007
Voltage: 14.30 V
Temperature: 30.0°C
(no units): 74.0
Fault Status: 00101101
Reset counter: 32
Mileage: 115064 km
Date: 2020.07.25
Time: 13:24:51
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0005
Voltage: 10.10 V
Temperature: 27.0°C
(no units): 0.0
Reset counter: 32
Mileage: 115068 km
Date: 2020.07.25
Time: 14:16:19
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0003
Voltage: 10.00 V
Temperature: 28.0°C
(no units): 255.0
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H17 0100
Revision: Serial number: 00000000244341
Coding: 0012001
VCID: 5EE59B816C33F43B00F-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000154658228
VCID: 47CB5EE5DFA995F3D39-8012
Reset counter: 32
Mileage: 115068 km
Date: 2020.07.25
Time: 14:29:08
Reset counter: 32
Mileage: 115068 km
Date: 2020.07.25
Time: 14:30:01
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Serial number: 150608-0002-006
Coding: 1147A71010020400
ROD: EV_HeadlRegulBasic.rod
VCID: 42DD4FF1F40BB0DB047-8016
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156F+0F8281364
Coding: 020007010000000000
VCID: 2411E9690EDF9EEB16B-8070
Reset counter: 247
Mileage: 115068 km
Date: 2020.07.25
Time: 14:30:03
Voltage: 8.40 V
Reset counter: 32
Mileage: 115068 km
Date: 2020.07.25
Time: 14:21:05
Voltage: 9.30 V
Part No SW: 4L2 035 746 G HW: 4L2 035 746 G
Component: H-BNT-NA H42 0901
Revision: -------- Serial number: 513F+0F7528382
Coding: 180200060004E3EF510023456F632003140000000100000000
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015 1102
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130FN0F3383032
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002256269
Component: CD-Database 5950
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000154663169
Coding: 010E57204040230004
VCID: 46D553E1D8A38CFB28F-8012
Reset counter: 32
Mileage: 115068 km
Date: 2020.07.25
Time: 14:14:34
Reset counter: 32
Mileage: 115068 km
Date: 2020.07.25
Time: 14:30:02
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H12 0100
Revision: 2A001001 Serial number: 00000372308963
Coding: 0200000000000000
VCID: 313F103D412D3B43EDD-8064
00576 - Terminal 15
Reset counter: 32
Mileage: 115068 km
Date: 2020.07.25
Time: 14:13:47
Reset counter: 32
Mileage: 115068 km
Date: 2020.07.25
Time: 14:30:00
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H09--- Serial number: 525PA8-JA541G1
Coding: 1021201
Reset counter: 32
Mileage: 115068 km
Date: 2020.07.25
Time: 14:29:02
Reverse OFF
Count: 3
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 F
Component: ValeoHeckdeckel H61 0500
Revision: --H61001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C81C149AA8F96AB9EB-8038
Subsystem 2 - Serial number: ó
Subsystem 3 - Serial number: RD17.06.15--H61001002F0188ÿ
Subsystem 4 - Serial number: 2F0188ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 0153620258----
Coding: 0003595
VCID: 2615F36174E36CFB08F-8072
Component: J_245_EE16_SKB10H15 0220
Component: J_394_EE16_SKB10H15 0220
Component: J_392_EE16_SKB10H15 0220
Reset counter: 32
Mileage: 115068 km
Date: 2020.07.25
Time: 14:30:00
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000154663170
Reset counter: 32
Mileage: 115068 km
Date: 2020.07.25
Time: 14:14:34
Reset counter: 32
Mileage: 115068 km
Date: 2020.07.25
Time: 14:30:00
End----------(Elapsed Time: 02:18, VBatt start/end: 14.1V/14.2V)-----------
