- Joined
- Nov 18, 2015
- Messages
- 3
- Reaction score
- 0
- Location
- United Kingdom
- VCDS Serial number
- C?ID=187117 (NRRT) + C?ID=145999
Hello everyone,
I wonder if someone could please shed some light on the error code that I have on my Audi A6 Avant.
The error is on Address 17: Instruments ( please see full scan below).
I tried to reset the ESI using VCDS but the error still persists.
Has anyone seen this before? any ideas/suggestion on how to clear this error?
Thank you,
Luis
Full scan:
Thank you,
Luis
Full scan:
Saturday,01,August,2020,19:00:46:50720
VCDS Version: 20.4.2.0 (x64) HEX-NET CB: 0.4513.4
Dealer/Shop Name: LR engineering
VIN: WAUZZZ4G8FN060240 License Plate:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 03 05 08 09 15 16 17 19 28 3B 42 44 46 52 53 5F 62 6D 72
AC
VIN: WAUZZZ4G8FN060240 Mileage: 91656km-56952miles
Address 01: Engine (J623-CNHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 FR HW: 04L 907 309
Component: R4 2,0L EDC H23 0654
Revision: 85H23---
Coding: 12194012242401080000
ASAM Dataset: EV_ECM20TDI01104L906021FR 002002
ROD: EV_ECM20TDI01104L906021FR_002.rod
VCID: 7AB8F3BEFD1979565D-802E
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q
Component: ESP9 Premium H01 0420
Coding: 06A09E41600579829B00
ASAM Dataset: EV_ESP9BOSCHAU57X 003019
ROD: EV_ESP9BOSCHAU57X_003.rod
VCID: 3FCE42AAA6BB9C7E2A-806A
Part No SW: 4H0 907 064 FN HW: 4H0 907 064 EN
Component: BCM2 2.0 H36 0560
Coding: 03B9704E000000000000
VCID: 7AB8F3BEF51979565D-802E
Serial number: 3214000180174014
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 CC HW: 4G0 820 043 CC
Component: KLIMA 4 ZONEN H14 0112
Serial number: 28011500040107
Coding: 34220978210000
VCID: 6288ABDE7589919665-8036
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00000986346302
Coding: 2600801501349F600481408000001D0C489D861827090201000008206100140200400024030000
VCID: 71AAD492A86F3A0EEC-8024
Component: WWS57X 141205 H37 0080
Serial number: 141215101854
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 23660209
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 26 01 2015 00000790
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: F4B80B87000000000001
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P1002YCVM
Coding: 30333130313630323639554A305234473053
VCID: 3B3636BAB2A3805E06-806E
Serial number: 3575HRB404V322V89GP
Serial number: 3585HRB406133HNIB820
Serial number: 3515JRB405H34GNE3H49
Serial number: 3525JRB405V33PKSBG69
Serial number: 3554VRB406734LSABPOE
Serial number: 3564VRB404T34JH4EP61
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862OA9000VK
Coding: 000015
VCID: 3B3636BABAA3805E06-806E
Subsystem 1 - Part No SW: 4G0 951 528 D HW: 4G0 951 528 D
Component: E221 - MFL H09 0010
Serial number: 04 12 2014 30012905
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 951 A HW: 4G8 920 951 A
Component: MDieGb H43 0506
Revision: 28450303 Serial number: 658230115592029
Coding: 33A512000B412600010400
ASAM Dataset: EV_RBC7KMID 004050
ROD: EV_RBC7KMID.rod
VCID: 2E100FEE71D165F6B1-807A
1048578 - No Basic Setting
B2010 00 [009] - -
[Steuergerät keine oder falsche Grundeinstellung / Adaption]
Reset counter: 236
Mileage: 91656 km
Date: 2020.08.01
Time: 17:28:22
Part No SW: 4G5 907 468 D HW: 4G5 907 468 C
Component: J533--Gateway H13 0075
Revision: -------- Serial number: 00000001706456
Coding: C0CD074418
ASAM Dataset: EV_GatewPkoUDS 001024
VCID: 3620278E89815D36F9-8062
Serial number: 6165385403
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663 D
Component: J532_DCDCStab H23 0022
Serial number: 141023000000000000C7
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 26011500040310
Coding: 22
VCID: 3D3238A2ACB78E6E38-8068
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720FALMS
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 33261E9A9AF3481EDE-8066
Component: TSG FA H03 0507
Coding: 011F16015C01620002080002
VCID: 47DE5A4AF66BD4BE92-8012
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0011309754
Coding: 101000010001
ASAM Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_009.rod
Revision: 00002001 Serial number: 0358650378
Coding: 013F0622A0B930C08320090400010F470000000000000000000000000000
Component: DWA-Sensor H01 0010
Component: TSG BF H03 0507
Coding: 011F16015E01620002080002
VCID: 46C0574EF161CDB669-8012
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001337447
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D1208E27CD71EEE88-8078
Address 5F: Information Electr. (J794) Labels: Redir Fail!
Part No SW: 4G1 035 192 A HW: 4G1 035 192 A
Component: RMC Nav Plus H61 0139
Coding: 0101010001415B47082B060301010000000000
VCID: 210AE4D2380FCA8E3C-8074
Subsystem 1 - Part No: 8X0 919 884 H
Component: P28-50-14.06 0001
Subsystem 2 - Part No SW: 4G0 919 603 B HW: 4G0 919 603 B
Component: DU6 Basic H43 0084
Serial number: 9464L10E2695304
Subsystem 3 - Part No SW: 4G2 919 710 E HW: 4G2 919 710 E
Serial number: 90349OAG000FT
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Component: TSG HL H03 0507
Coding: 010F14004001620002080002
VCID: 49DA5C72E07F22CE84-801C
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0150
Revision: 14005001 Serial number: 009501582
Coding: 093205C010
ROD: EV_HDSGAu571.rod
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0507
02123 - Door Warning Light / Entry Light
Reset counter: 235
Mileage: 91656 km
Date: 2020.08.01
Time: 17:05:16
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 143460344
ROD: EV_RDCMA00100.rod
End----------(Elapsed Time: 01:41, VBatt start/end: 12.3V/12.2V)-----------
