Dear friends hi. I have this used car dealer Audi Q5 with the rear camera not working when you put gear in reverse. Parking sensors are beeping but no video is switching in display. Camera is power from module with around 6.00 volts. i switched the camera module (6c) from another vehicle with no luck.All wiring looks ok. 6 wires in the connector, power ,ground, 2 can, and power and ground out put to the camera. The only thing i saw and i do not like is that under address 6c, measure block 001, when it says ( i believe data block is #3) says about the reverse gear is on or off , it always say off , even when i shift in to reverse. however when i go to address module #10 ( park / steering assist module, reverse is shows there every time i shift in to it. Can some body knows where is the reverse signal is coming from to the back up camera module ?
Any help is very appreciated
Thanks Tom
Here is the auto scan
Thanks Tom
Friday,31,July,2020,18:35:09:40431
VCDS Version: 20.4.1.0
VIN: WA1LKAFP0AA004797 License Plate: BY57174
Mileage: 117731 Repair Order:
Chassis Type: FP-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
62 6C 6D 72
VIN: WA1LKAFP0AA004797 Mileage: 189470km-117731miles
Address 01: Engine (J623-CALB) Labels:| 06E-907-559-CAL.clb
Part No SW: 8R0 907 559 G HW: 8F0 907 559 A
Component: 3.2 SIMOS8.2 H01 0004
Revision: --------
Coding: 0121000A190F0121
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_ECM32FSI0218R0907559G 001004
ROD: EV_ECM32FSI0218R0907559G.rod
VCID: 448CFD71CF0630A66F-8010
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
Part No SW: 8R0 927 158 F HW: 0B6 927 156
Component: 0B6 32 FSIUSA H05 0003
Revision: --H05---
Coding: 001012
ASAM Dataset: EV_TCMAL651 A01006
ROD: EV_TCMAL651.rod
VCID: 4084F161DB1E2C864B-8014
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 M HW: 8R0 907 379 D
Component: ESP8 quattro H06 0020
Coding: 041D18
Shop #: WSC 00477 128 28888
VCID: 4A90D349E522E6D695-801E
Part No SW: 8K0 907 064 DS HW: 8K0 907 064 DS
Component: BCM2 1.1 H02 0321
Coding: 090500
VCID: 040C3D718786F0A62F-8050
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000023512002
Component: J764 ELV MLB H36 0042
Serial number: 0209000036883013
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AK HW: 8T1 820 043 AK
Component: KLIMA 3 ZONEN H08 0160
Revision: C1000000 Serial number: 01130520090254
Coding: 46112000
VCID: 7AF04389F542B65645-802E
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000270635
Coding: 26001091063CAF010000080300001D0D0F1C460800010161000000
VCID: 3C7C8591BFF6486617-8068
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 090519 H10 0041
Serial number: 90243014090428063800
Coding: 01DD13
Component: RLS H04 0003
Serial number: 10482990
Coding: 024D25
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000001605090031
Subsystem 4 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B
Component: HOMELINK H01 0010
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 J HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0050
Revision: 11001001 Serial number: 39840914801951
Coding: 300105
VCID: 4084F161D31E2C864B-8014
01625 - Front Parking Aid Warning Chime (H22)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 21
Mileage: 189469 km
Date: 2020.07.31
Time: 16:25:32
Temperature: 33.0°C
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 A HW: 8R0 959 655 A
Component: AirbagVW-AU10 H13 0330
Serial number: 003BRD0607P6
Coding: 303633313432303030304A55304C38523053
ASAM Dataset: EV_AirbaAU10SMEAU416 001001
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 4280FB69D5123E965D-8016
Subsystem 1 - Part No SW: 8R0 959 339 HW: 8R0 959 339
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R0900003DH5
Serial number: 6334MSME474410272
Serial number: 6344MSME48356A05F
Serial number: 6352QSME252E4A20G
Serial number: 6362QSME1B2008347
Serial number: 63732SME4D2C38244
Serial number: 63832SME592F37301
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304IEL0000K
Coding: 000017
VCID: 3D7A8895A4EC416E20-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 980 K HW: 8R0 920 980 K
Component: KOMBIINSTR. H09 0253
Revision: 00100000 Serial number: BZ560WX59
Coding: 8B1622000300D705020000
VCID: 4182F465D814258E44-8014
Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0101
Revision: EB700052 Serial number: 5200E09512857E
Coding: 00C303
VCID: 52A0CB290D72AE16ED-8006
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0107
Serial number: 00000000004140555890
Part No SW: 8R0 959 760 B HW: 8R0 959 760 B
Component: MEM-FS H06 0073
Revision: AA000000 Serial number: 00001001276965
Coding: 00581300000044440000
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000008893623
Coding: 011D03205E00440004
VCID: 458AE075CC3C09AE78-8010
Revision: 00002001 Serial number: 0118551355
Coding: 0126023A207A749404B0050000000000
Shop #: WSC 06342 000 00000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Serial number: 00000000000000135031
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE19SKB12 H01 0220
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE19SKB12 H01 0220
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 H HW: 8T0 035 223 H
Component: DSP Prem H04 0120
Revision: 00004001 Serial number: 34880005036403
VCID: 336EAEAD92A8871EC6-8066
Voltage: 12.30 V
Temperature: 38.0°C
Temperature: 40.0°C
Bin. Bits: 00000100
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000008863558
VCID: 448CFD71C70630A66F-8010
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0090
Revision: 00000003 Serial number: 00000000372025
VCID: 346CADB197A68026DF-8060
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Coding: 0000006
Shop #: WSC 06334 000 00000
VCID: 346CADB157A68026DF-8060
Part No SW: 4F0 035 082 A HW: 4F0 035 082
Component: Radio U SIRIU H45 0021
Revision: AB001007 Serial number: 335EU097515075
Coding: 020000010000000001
VCID: 1D3A6815042C216E00-8048
Part No SW: 8T1 035 664 A HW: 8T1 035 664 A
Component: H-BN-NA H41 0042
Revision: -------- Serial number: 490EU097505605
Coding: 010200060005A1EF41000B0E000000030000
VCID: 366897B981DA9236E1-8062
Subsystem 1 - Part No: 8R0 060 884 F
Component: NAR 2009/2010 5304
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356EQ091104548
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Serial number: 00000000291631
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
Reset counter: 21
Mileage: 189469 km
Date: 2020.07.31
Time: 16:25:35
Voltage: 12.40 V
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000101197616
Coding: 010C03204000240004
VCID: 4280FB69DD123E965D-8016
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H03--- Serial number: 525PA8-J94A0Q7
Coding: 1020010
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 A HW: 8R0 827 851
Component: J605 Master H27 0290
Revision: -------- Serial number: 8R0827851
VCID: 3A708389B5C2765605-806E
Subsystem 1 - Part No SW: 8R0 827 852 A HW: 8R0 827 852
Component: J756 Slave H27 0290
Serial number: 8R0827852
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000101197619
End-------------------------(Elapsed Time: 04:05)-----------------------
