Hi, my 2007 2.5L jetta-running rough! Please help
Codes show it's running lean. When I cold start my car the first 10 seconds run really rough, rpms drop up and down and half the time the car dies. Once it gets going though it starts running really good. We have replaced valve cover (pcv), replaced purge solenoid, replaced the MAF sensor, did a smoke test and found no leaks in the intake system and also pulled and cleaned the throttle body.
VCDS log and fault codes below. Any suggestions?
VCDS 031 032 measuring block log
Address 01: Engine (07K 906 032 T)
17:19:00 Group 031
0.984 Lambda Sensor Current Value
1.000 Lambda Sensor Specified Value
17:19:00 Group 032
5.1 % Lambda (Idle) Self-Adaptation
20.3 % Lambda (Partial) Self-Adaptation
VCDS Fault codes
17:19:00 Group 031
17:19:00 Group 032
VCDS Fault codes
Thursday,30,July,2020,17:17:34:54968
VCDS Version: Release 20.4.1 (x64) Running on Windows 10 x64
Address 01: Engine Labels: 06A-906-032-BGP.lbl
Control Module Part Number: 07K 906 032 T HW: 07K 906 032 Q
Component and/or Version: 2.5l R5/4V G 9653
Software Coding: 0000001
Work Shop Code: WSC 00066 000 00000
VCID: 3A2D34467052F25B5DF-806E
6 Faults Found:
000369 - Fuel Trim; Bank 1
P0171 - 001 - System Too Lean - MIL ON
Fault Status: 11100001
Mileage: 316959 km
Time: 00:43:21
RPM: 2694 /min
Load: 38.0 %
Speed: 100.0 km/h
Temperature: 99.0°C
Temperature: 45.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.224 V
001290 - Cold Start Idle Air Control System
P050A - 002 - Malfunction - MIL ON
Fault Status: 11100010
Fault Frequency: 18
Mileage: 317096 km
Time: 11:44:52
RPM: 1263 /min
Load: 74.9 %
Temperature: 30.0°C
Temperature: 28.0°C
Voltage: 13.970 V
P0300 - 008 - - Intermittent - MIL ON
Fault Status: 10101000
Mileage: 317733 km
Time: 23:21:19
RPM: 1426 /min
Load: 76.4 %
Temperature: 20.0°C
Temperature: 32.0°C
Voltage: 14.097 V
000770 - Cylinder 2
P0302 - 008 - Misfire Detected - Intermittent - MIL ON
Mileage: 317733 km
Time: 23:21:58
RPM: 1207 /min
Load: 24.7 %
Speed: 9.0 km/h
Temperature: 29.0°C
Temperature: 33.0°C
Voltage: 14.351 V
000769 - Cylinder 1
P0301 - 008 - Misfire Detected - Intermittent - MIL ON
Mileage: 317881 km
Time: 19:51:49
RPM: 2334 /min
Load: 69.0 %
Speed: 19.0 km/h
Temperature: 22.0°C
Temperature: 18.0°C
Voltage: 14.478 V
000771 - Cylinder 3
P0303 - 008 - Misfire Detected - Intermittent - MIL ON
Mileage: 317881 km
Time: 19:51:49
RPM: 2334 /min
Load: 69.0 %
Speed: 19.0 km/h
Temperature: 22.0°C
Temperature: 18.0°C
Voltage: 14.478 V
Readiness: 0000 1001
