2006 Golf 1.6 BLF
Shahj
West Cornwall, UK
C?ID=412663
Hello. I’m trying to find the security code that will enable me to adjust idle speed, if that is an adjustable parameter on this engine. Adaptation tab appears to be locked to 128 (Ie 700rpm). Buttons appear to allow adjustments by only +\- 1 but save is greyed out so even that doesn’t work. Have read that the potentially range might be 124-131 but not sure if this is possible for my engine/car. Advice/clarification would be gratefully received. Thanks.
PetrolDave
Westbury, UK
C?ID=1423
What is possible depends on exactly how your car is configured (hardware and software) so you'll need to post a full unedited VCDS Auto-Scan - see my sig for a link to a How To
Shahj
West Cornwall, UK
C?ID=412663
VCDS scan included
A bit of a long story which I will try to summarise. 98k, manual. Well driven and looked after from new - 95% motorway miles @60mph on cruise (since 35k). Religious oil changes and only Shell Super ever used. Never lost a drop of oil until see below. Currently the idle speed hunts a little which is annoying (c. 700 +/- 50ish) - previously it was rock solid and harmonious at 700. If I hold on the throttle at c.800 it is harmonious again. Just passed UK MOT emissions test and fuel economy remains fantastic/unchanged.
For the past year had DTCs about EGR so mechanic replaced it. Some DTCs suggested throttle body so he replaced that too. Separately, rear oil seal leaked a bit so he changed that. I checked the PCV - aged but perfectly flexible - though I noticed a 1cm break so I changed that too. Mechanic cannot find the cause of the idle issue and says there is no inlet air/vacuum leak and the swirl flaps are OK. But the car had the rough idle and was hesitant/lumpy up to 2k revs then great/normal (closest description is it's like 'turbo lag', although obviously not a turbo'd car!). Emissions and fuel economy still perfect.
At idle, I could see that the TB butterfly was minutely flickering hence rough idle (not sure of cause or effect). Yesterday, I pulled off the TB connector while it was running and it switched to 900 revs and perfectly stable. Since reconnected and re-adapting the TB, the only issue is idle and the hesitance/lumpiness is completely cured - the car otherwise feels perfect/back to normal.
I know that the mechanic didn't have an alignment tool when he refitted the crankshaft pulley/flywheel, after replacing the rear seal - he insists that if nothing else was moved then it can only go back on in the correct position. I am left wondering if there might be a minute misalignment. Or maybe it's something completely different. A different mechanic who did the air leak/vacuum test thinks it's a valve seat issue. I am left with a car that now has no other issue other than a somewhat rough idle. I just bought VCDS and already seem to have 'fixed' most of the fault (although it was an 'accident' and I don't actually know how I did it!).
Any help with this would be fantastic...
Thursday,30,July,2020,00:29:21:60346
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4513.4
VIN: WVWZZZ1KZ6W132876   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ6W132876   Mileage: 159290km-98978miles
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 906 056 CG    HW: Hardware No
   Component: MED9.5.10       G00 7964
   Revision: --H08---    Serial number: VWZ7Z0F3322775
   Coding: 0000072
   Shop #: WSC 01279 785 00200
   VCID: 6A8C3B72F07152FBEDF-803E
008825 - Leak in Air Intake System
               P2279 - 008 -
                    Mileage: 159299 km
                    Time: 00:22:48
                    RPM: 680 /min
                    Load: 51.7 %
                    Temperature: 54.0°C
Readiness: 1110 0101
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Revision: 00H13001
   Coding: 0019073
   VCID: 71BE2C1EDDA7A123AC5-8024
   Part No: 1K0 820 047 DP
   Component: Climatic PQ35   090 0505
   VCID: 75B6180EA9CF8D0370D-8020
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000005306133
   Coding: E48D0F2700041500001400001400000000087B075C
   Shop #: WSC 00000 785 00200
   VCID: 2A0CFB7230F192FB2DF-807E
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  013  0402
   Coding: 00065493
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Part No SW: 1K0 909 605 R    HW: 1K0 909 605 R
   Component: 38 AIRBAG VW8   018 2200
   Revision: 02018000    Serial number: 0038MD06RSN1
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3B22CE36CF6B1B73469-806E
   Subsystem 1 - Serial number: 6332MSME0D645C0EP
   Subsystem 2 - Serial number: 6342MSME0D381B18H
   Subsystem 3 - Serial number: 6352QSME09183567G
   Subsystem 4 - Serial number: 6362QSME091029155
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 634 0070
   Coding: 0000042
   VCID: 76B41F02B4C9861B797-8022
   Part No: 1K0 920 962 F
   Component: KOMBIINSTRUMENT VDD 4312
   Coding: 0003403
   Shop #: WSC 80093 222 69422
   VCID: 2E04F7620C19FEDBF17-807A
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001061210001
   Coding: 3D3F0340070003
                    Reset counter: 30
                    Mileage: 158009 km
                    Time: 13:46:05
01304 - Radio
                    Reset counter: 30
                    Mileage: 158009 km
                    Time: 13:46:10
   Component: IMMO            VDD 4312
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2374
   Coding: 0000692
   VCID: 3634DF02F449C61BB97-8062
   Part No: 1K2 909 144 K
   VCID: 3430E50AE235D40B873-8060
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Coding: 01C802087F2D8405485FC69010CC
   VCID: 79AE143E85D7E963145-802C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 1K0 951 177 A
   Component: Innenraumueberw.005 0202
   Part No: 1K0 959 702 K
   Coding: 0000692
   VCID: 372AD206F3433F13A21-8062
Address 56: Radio
   Part No: 1K0 959 703 F
   Component: Tuer-SG         021 2429
   Coding: 0000144
   VCID: 3332E616E73BD3339E9-8066
   Part No: 1K0 959 704 F
   Coding: 0000144
End----------(Elapsed Time: 00:58, VBatt start/end: 12.6V/12.6V)-----------
The source of your troubles seems pretty clear from that fault code, no?
Shahj
West Cornwall, UK
C?ID=412663
2 mechanics haven’t found an intake air leak with the pressure and smoke tests.
Shahj
West Cornwall, UK
C?ID=412663
Going back to the original question please - is it possible to adjust idle speed on this car and if so does anyone have the necessary security code? Many thanks.
PetrolDave
Westbury, UK
C?ID=1423
There really is no point changing the idle speed until you sort out the intake leak - it's clearly there even if the mechanics you've taken it to haven't found it yet, they (or maybe someone else) needs to look again.
Shahj
West Cornwall, UK
C?ID=412663
Thanks guys. I appreciate the advice. I should have said, my aim to to get it fixed. I live in a remote area so while I am trying to find an expert, I would like to adjust the idle up a touch. It’s my choice and my risk and I would grateful for a pointer on how to configure it using vcds. Thanks.
PetrolDave
Westbury, UK
C?ID=1423
Your location is shown as "London, UK" - is that correct? If so then I find your description of your location as a "remote area" hard to understand (I DO live in a remote area of North Devon BTW).
Having said that I'm sure IF it is possible to adjust the idle speed on your Golf (it isn't possible on all engine types in all cars) I'm sure someone will be along with the SA code (if required).
Shahj
West Cornwall, UK
C?ID=412663
Just happen to be in London this weekend but live in TR18 and outside of COVID times I work in PL12. Haven’t yet found a local VAG specialist. Have so far tried 2 local chaps. Would be very glad of any recommendations/ suggestions in Cornwall.
Dana
Western PA, USA
I do not believe it is possible to adjust the idle speed. I'm not aware of any Security Access, Login/Coding-II codes other than the standard ones for CCA activation and deactivation.
The video on this page may be helpful in regards to the air leak though:
http://wiki.ross-tech.com/wiki/index.php/Fuel_Trim_Info
Shahj
West Cornwall, UK
C?ID=412663
Thank you Dana! will explore this tomorrow...
