Hi all, I recently purchased my hex v2 to look into buying an Audi. It is believed to have the steering column issue (and comes with a new column) however I did the scan and got numerous errors. I am wondering if anyone would be able to provide a ‘best’ place to start with diagnostics. Was thinking about the battery then see what changes?
I will include my log below:
Mileage: 278400km-172989mi Repair Order:
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 65 67 72 76 77
Mileage: 278400km-172989miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
07-Control Head -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
67-Voice Control -- Status: Cannot be reached 1100
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0180
Revision: 30070501 Serial number: 10600600223309
Coding: 0000015
Shop #: WSC 08175 444 54613
VCID: 6393AAD36758AA632E9-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0070
Component: FBSAUDIC6 KSG H27 0080
12 Faults Found:
00190 - Driver's Door Handle Touch Sensor (G415)
007 - Short to Ground
Fault Status: 01110111
Reset counter: 29
Mileage: 268734 km
Date: 2019.07.18
Time: 01:34:10
00192 - Rear Left Door Handle Touch Sensor (G417)
Reset counter: 29
Mileage: 268734 km
Date: 2019.07.18
Time: 01:34:10
Fault Status: 01111011
Reset counter: 29
Mileage: 268734 km
Date: 2019.07.18
Time: 01:34:10
01176 - Key
Fault Status: 01110100
Reset counter: 29
Mileage: 268734 km
Date: 2019.07.20
Time: 01:46:56
16347 - Control Module - EEPROM Error
014 - Defective
Fault Status: 01111110
Reset counter: 111
00191 - Passenger's Door Handle Touch Sensor (G416)
Fault Status: 00111011
Fault Frequency: 43
Reset counter: 196
Mileage: 272332 km
Date: 2005.03.20
Time: 13:55:36
00532 - Supply Voltage B+
Reset counter: 198
Fault Status: 00100001
Reset counter: 223
Mileage: 277859 km
Date: 2005.06.08
Time: 10:07:28
Reset counter: 223
00447 - Function Limitation due to Over-Voltage
Reset counter: 223
Mileage: 277859 km
Date: 2005.06.08
Time: 10:06:12
00288 - Steering Column Lock Actuator (N360)
014 - Defective
Reset counter: 183
Mileage: 278409 km
Date: 2005.06.27
Time: 14:46:02
02764 - Access/Start Authorization Switch (E408)
Reset counter: 223
Mileage: 278409 km
Date: 2005.06.28
Time: 15:53:05
Address 07: Control Head
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 S
Component: KLIMABETAETIGUNGH12 0160
Revision: 00000027 Serial number: 00000000185048
Coding: 0524326
Shop #: WSC 02325 785 00200
VCID: 5BE392335F2892A3669-800E
Reset counter: 223
Mileage: 274171 km
Date: 2005.04.10
Time: 07:36:18
Reset counter: 223
Mileage: 274171 km
Date: 2005.04.10
Time: 07:36:18
Part No SW: 4F0 910 279 D HW: 4F0 907 279
Component: ILM Fahrer H15 0190
Coding: 0014123
Shop #: WSC 02335 785 00200
VCID: 2A0D07F740F23B2B2DF-807E
Subsystem 1 - Component: Fehler Lin-Slave 01
Subsystem 2 - Component: Fehler Lin-Slave 02
Reset counter: 183
Mileage: 262136 km
Date: 2019.07.18
Time: 01:32:00
010 - Open or Short to Plus
Fault Status: 01111010
Reset counter: 183
Mileage: 262136 km
Date: 2019.07.18
Time: 01:32:00
Reset counter: 183
Mileage: 262136 km
Date: 2005.04.22
Time: 01:50:00
02382 - Sensor for Light Detection (G399)
Fault Status: 00101110
Reset counter: 198
Mileage: 262136 km
Date: 2005.06.08
Time: 10:14:00
Address 0E: Media Player 1
Address 0F: Digital Radio
Address 15: Airbags
Address 16: Steering wheel
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 A HW: 4F0 920 980 N
Component: KOMBIINSTR. M73 H16 0630
Revision: 00100000 Serial number: 4PY54RP95
Coding: 2129263
Shop #: WSC 08105 444 100037
VCID: 211FE0DB3DC4F8737C5-8074
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 130080592481F2
Coding: ECFE73CD1B7904
VCID: 270BFEC353E00643321-8072
00384 - Optical Databus
Fault Status: 00101011
Reset counter: 189
Mileage: 277608 km
Date: 2005.05.11
Time: 02:28:36
Fault Status: 01100001
Reset counter: 158
Mileage: 277859 km
Date: 2005.06.08
Time: 10:07:28
Reset counter: 213
Mileage: 278095 km
Date: 2005.06.17
Time: 03:38:36
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 619FA0DB7D44B8733C5-8034
Reset counter: 223
Date: 2005.01.01
Time: 00:00:00
Address 37: Navigation
Address 46: Central Conv.
Address 47: Sound System
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000007214
Coding: 0002114
Shop #: WSC 02323 785 00200
VCID: 5EE59B274C3A878B017-800A
Reset counter: 223
Mileage: 262136 km
Date: 2005.06.08
Time: 10:07:00
Voltage: 18.400 V
Temperature: 77.0°C
Fault Status: 00110010
Reset counter: 223
Mileage: 262136 km
Date: 2005.07.15
Time: 10:48:00
Voltage: 6.100 V
Temperature: 12.0°C
Reset counter: 223
Mileage: 262136 km
Voltage: 18.400 V
Temperature: 77.0°C
Address 52: Door Elect, Pass.
Address 53: Parking Brake
Address 55: Headlight Range
Address 56: Radio
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0470
Revision: 00000000 Serial number: 00000000005101
VCID: 2313EAD327D8EA636E9-8076
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 320110A0NK
Coding: 344630393135313035432056413033323031313041304E4B
Shop #: WSC 08193 444 125933
02274 - Quiescent Current Stage 3
Mileage: 278409 km
Date: 2005.02.01
Time: 12:02:11
Mileage: 278409 km
Date: 2005.02.01
Time: 12:02:45
02252 - Generator
Fault Status: 00111100
Reset counter: 198
Mileage: 277859 km
Date: 2005.06.08
Time: 10:14:04
02254 - Interface to Generator
Fault Status: 00110100
Fault Frequency: 10
Reset counter: 215
Mileage: 277152 km
Date: 2005.05.07
Time: 09:02:34
Reset counter: 223
Mileage: 277859 km
Date: 2005.06.08
Time: 10:07:28
Address 62: Door, Rear Left
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 HW: 4F0 907 273
Component: Reifendruck 3 H04 0080
Revision: 00040080 Serial number: 00000900010845
Coding: 0062221
Shop #: WSC 02334 785 00200
VCID: 6099A5DF764EB17B33B-8034
Address 67: Voice Control
Address 72: Door, Rear Right
Part No SW: 4F0 910 283 B HW: 4F0 919 283 B
Component: Parkhilfe 4-Kan H09 0030
Revision: 00H09000 Serial number: 11720526406412
Coding: 0001206
01543 - Parking Aid Warning Chime (H15)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 29
Mileage: 268734 km
Date: 2019.07.18
Time: 01:29:17
Reset counter: 29
Mileage: 268733 km
Date: 2005.02.01
Time: 12:15:37
Address 77: Telephone
End-----(Elapsed Time: 01:28, VBatt start/end: 11.7V/0.0V. VIgn 0.0V)------
