Audi A4 2000 1.8 B5, Redir Fail!
JP2210
C?ID=402439
I took AutoScan and it seems that VCDS can't find the right label file for engine control unit.
Where can I download it or is it something else I should do to fix this problem?
Wednesday,29,July,2020,18:17:54:61968
VIN: WAUZZZ8DZYA096151   License Plate:
Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2002)
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
 VIN: WAUZZZ8DZYA096151  Mileage: 202670km-125933miles
   Part No: 8D0 906 018 Q
   Component: 1.8L R4/5V MOTR G01 0001
   Coding: 04001
   Shop #: WSC 16000
   VCID: 353724905C5E57A3B0D-5160
17924 - Intake Manifold Valve (N156)
            P1516 - 35-10 - Open Circuit - Intermittent
17925 - Power Supply Relay for ECU
            P1517 - 35-10 - Electrical Malfunction - Intermittent
Address 03: ABS Brakes        Labels: 8E0-614-111-ABS.lbl
   Part No: 8E0 614 111 AB
   Component: ABS 5.3 FRONT       D00
   Shop #: BB 24548
   VCID: 5EE59B3C8928B4FB017-51F2
Address 08: Auto HVAC        Labels: 8D0-820-043-1D.lbl
   Part No: 8D0 820 043 N
   Component: A4     KLIMAAUTOMAT D56
   Coding: 00040
   Shop #: WSC 06325
   VCID: 2B0302E88A1A1153D69-2596
Address 15: Airbags        Labels: 8D0-959-655-AI8.lbl
   Part No: 8D0 959 655 J
   Component: Airbag Front+Seite 1001
   Coding: 00104
   Shop #: WSC 06325
   VCID: 3D273CB0646E8FE378D-5184
Address 17: Instruments        Labels: 8D0-920-xxx-17.lbl
   Part No: 8D0 920 900 K
   Component: B5-KOMBIINSTR. VDO D09
   Coding: 00142
   VCID: 2B0302E88A1A1153D69-5160
   Component: AUZ7Z0X1244493
   ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ     AUZ7Z0X1244493
Address 35: Centr. Locks        Labels:. 8D0-862-257.clb
   Part No: 8D0 862 257 B
   Component: ZV-Pumpe, Funk      D12
   Coding: 12865
   Shop #: WSC 06325
   VCID: 2C0101F48F14166BDF3-4F0C
End----(Elapsed Time: 03:57, VBatt start/end: 13.7V/13.7V. VIgn 0.0V)------
Looks like another one that only exists in German at the moment. The file you want is 058-907-018-APT.lbl. It's in the Labels\DRV sub-folder of the German Version that you can download here. If you drop that file into the Labels sub-folder of the English version you're currently using, it should load.
