Hi everyone.
Just purchased my first Audi (basket case) and having a blast with it. Didn't run when I purchased it, but the previous owner threw a lot of money and parts at it before he gave up and sold it to me. Turned out it needed a replacement cluster and now it runs great except for the ABS system. The previous owner sent the ABS module in for repair and was told it was not repairable so they sent him a new one, but did not send back the old one. He installed it and the car still didn't run (bad cluster) so he gave up. Now I have the car with a new ABS module in it that was never coded and no way to retrieve the old module or code. I'm really digging this VCDS software and hopefully someone can get me a code for this ABS module so I can fix it. Attached is a full scan and thanks in advance.
Sunday,26,July,2020,16:19:13:16426
VIN: WAUHE78P69A060559 License Plate:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 47 52 56 62 65 72 77
VIN: WAUHE78P69A060559 Mileage: 256470km-159363miles
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 8P0 907 115 AH HW: 8P0 907 115 M
Component: 2.0l R4/4V TFSI 0010
Revision: E3H13--- Serial number: AUX7Z0H9FNG0AG
Coding: 0103010818070160
Shop #: WSC 06314 000 00000
VCID: 78A9ED0CAED7496B6BB-802C
006481 - Radiator Fan 2 (V177)
P1951 - 000 - Movement Restricted / Jammed - Intermittent
Mileage: 255631 km
Date: 2020.07.14
Time: 07:39:48
RPM: 2128 /min
Load: 27.0 %
Speed: 72.0 km/h
Temperature: 93.0°C
Temperature: 20.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.224 V
006480 - Radiator Fan (V7)
P1950 - 000 - Movement Restricted / Jammed - Intermittent
Mileage: 255643 km
Date: 2020.07.14
Time: 07:46:21
RPM: 2811 /min
Load: 16.5 %
Speed: 114.0 km/h
Temperature: 93.0°C
Temperature: 19.0°C
Voltage: 14.097 V
Part No SW: 1K0 907 379 CE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Shop #: WSC 05781 002 1048576
VCID: 77ABEE30AFC94613621-8022
Fault Status: 01100101
Reset counter: 77
Mileage: 254464 km
Date: 2020.06.16
Time: 17:56:00
Count: 3
Count: 2
Count: 12288
Count: 279
Count: 43776
Reset counter: 77
Mileage: 254464 km
Date: 2020.06.16
Time: 17:56:00
Count: 3
Count: 2
Count: 12288
Count: 270
Count: 43776
Reset counter: 34
Mileage: 254464 km
Date: 2020.06.16
Time: 17:56:01
Count: 7
Count: 2
Count: 12288
Count: 195
Count: 43776
Reset counter: 34
Mileage: 254464 km
Date: 2020.06.16
Time: 17:56:00
Count: 3
Count: 2
Count: 12288
Count: 291
Count: 43776
Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
Component: KlimavollautomatH09 0100
Revision: 000726 Serial number: 8P0820043BG
VCID: 72BDDF24C8AB233B55F-8026
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
Fault Status: 00101010
Reset counter: 125
Mileage: 256199 km
Date: 2020.07.23
Time: 07:26:35
Voltage: 14.10 V
(no units): 0.0
Temperature: 13.0°C
Fault Status: 00100011
Reset counter: 128
Mileage: 256282 km
Date: 2020.07.24
Time: 06:14:02
Voltage: 14.30 V
Temperature: 15.5°C
(no units): 230.0
(no units): 182.0
Temperature: 14.0°C
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 P HW: 8P0 907 279 P
Component: Bordnetz-SG H54 2903
Revision: 00H54000 Serial number: 00000008987622
Coding: 11AC2F81C0141380EF00001C0080000000284E0564114003003800000000
Shop #: WSC 06314 000 08192
VCID: 4ACD67C480BB0BFBCDF-801E
Subsystem 1 - Part No: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00064784
Shop #: WSC 06314
Fault Status: 00101100
Reset counter: 104
Mileage: 255510 km
Date: 2020.07.12
Time: 13:44:00
Voltage: 11.70 V
Reset counter: 104
Mileage: 255510 km
Date: 2020.07.12
Time: 13:44:00
Voltage: 11.70 V
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0437314
Coding: 0000100
VCID: 33331A20F7316A339E9-8066
Reset counter: 83
Mileage: 256141 km
Date: 2020.07.22
Time: 19:37:26
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 K HW: 8P0 959 655 K
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142393041303030374A55304C38503053
ROD: EV_Airba10AURB4.rod
VCID: 4ACD67C48C3B0BFBCDF-801E
Subsystem 1 - Part No SW: 8P0 910 339 C HW: 8P0 959 339 C
Component: BF-Gewichtss. H02 0030
Serial number: 5810000R0000002Y0L
Serial number: 3572DRB400007D64CAFA
Serial number: 3582DRB400007D64FAFE
Serial number: 35128RB4000045C2681D
Serial number: 35228RB40000463421C8
Serial number: 35547RB40000463DFDD4
Serial number: 35647RB40000463DFA8/
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004042
VCID: 41DF40E8BD8DC8A31C5-8014
Component: E0221 H02 0030
Part No SW: 8P0 920 982 G HW: 8P0 920 982 G
Component: KOMBIINSTR. VDO H15 0820
Revision: D0H15004 Serial number: 2246H004000653
Coding: 0020288
Shop #: WSC 06795 116 50998
VCID: 3D273C18C175AC4378D-8068
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K08A08060F
Coding: E9807F071007022102
VCID: 35372438F9457403B0D-8060
Reset counter: 91
Mileage: 253926 km
Date: 2020.06.07
Time: 12:07:28
Revision: D0H15004 Serial number: AUX7Z0H9FNG0AG
Shop #: WSC 01507 444 94845
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0001181
VCID: 43D34AE0A791DAB30E9-8016
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 233 2301
Revision: 00H15000
VCID: 2A0D074420FB2BFB2DF-807E
Fault Status: 11100101
Mileage: 253926 km
Date: 2020.06.07
Time: 12:10:25
Battery Volts: 12.2 V
DD
Temperature: 38.0°C
Count: 3
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Part No: 8P0 959 433 K
Component: KSG H11 0080
Coding: 1B80228001382D090F0FCC8F0477
VCID: 44D149FCA29FDD8B373-8010
01134 - Alarm Horn (H12)
Part No SW: 8P4 035 382 D HW: 8P4 035 382 D
Component: AB2 SUBWOOFERBOXH06 0180
Revision: 00005 Serial number: 30674802898342
00422 - Rear Right DSP Midrange Speaker (R106)
Fault Status: 00101011
Reset counter: 116
Mileage: 255904 km
Date: 2020.07.17
Time: 07:15:02
Temperature: 15.0°C
00421 - Rear Left DSP Midrange Speaker (R105)
Reset counter: 99
Mileage: 254728 km
Date: 2020.06.29
Time: 16:36:01
Temperature: 33.0°C
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0001181
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 Q HW: 8P0 035 186 Q
Component: R Concert2+ H03 0270
Revision: 00H03000 Serial number: AUZ1Z3H8964751
Coding: 0750212
VCID: 40D945ECB687C1AB13B-8014
Reset counter: 68
Mileage: 253926 km
Date: 2020.06.07
Time: 12:13:38
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0001176
Shop #: WSC 06314 000 1012544
Address 65: Tire Pressure Labels: 8J0-907-273.lbl
Part No SW: 8J0 907 273 A HW: 8J0 907 273 A
Component: J502-RDK H03 0370
Revision: --H03-H0 Serial number: 13137781839801
Coding: 0860021
Shop #: WSC 06435 000 00000
VCID: 2F3B16501B194ED3FA1-807A
Reset counter: 115
Mileage: 255840 km
Date: 2020.07.16
Time: 07:41:50
Bin. Bits: 00001000 00100101
Voltage: 14.30 V
Text: 14,5°C;n.erkannt;3442237821;--h;---°C
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0001176
VCID: 42DD4FE4B88BD3BB05F-8016
Part No SW: 8P0 862 335 T HW: 8P0 862 335 T
Component: FSE_256x BT H34 0550
Revision: 00000000 Serial number: 00000005011726
Coding: 0001277
VCID: 47CB5EF093A9F693D21-8012
End----------(Elapsed Time: 01:34, VBatt start/end: 12.0V/12.0V)-----------
