Vw Passat CC and abs sensor problem
V3lmu
Oulu, Finland
C?ID=229426
Hey!
There would be one abs problem with Vw Passat CC, 2.0 TDI, MY14.
The owner's car had to be replaced with a wheel bearing, abs ring and abs speed sensor. All the above parts are new. However, the system still has a fault code for the abs speed sensor after replacing the above parts.
There is no speed information from the left rear wheel and therefore the fault light in the instrument cluster illuminates.
- 3 different ABS speed sensors have been tested. Original and accessory parts tested.
- Fuses are checked and intact.
- Voltages are measured from electrical wires. Voltage acting and does not refer to broken wires.
- Connectors checked and cleaned.
1. Round
Wednesday,22,July,2020,13:28:06:00464
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
Dealer/Shop Name: J.P - V3lmu
VIN: WVWZZZ3CZEE505926   License Plate: VW PASSAT CC
Mileage: 145450km-90378mi   Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 10 14 15 16 17 18 19 25 2E 37 3C 42 44 46 47 4F
          52 53 55 56 61 62 65 69 6C 72 77 A5
VIN: WVWZZZ3CZEE505926   Mileage: 145450km-90378miles
Address 01: Engine (J623-CFGC)       Labels: None
   Part No SW: 03L 906 018 TL    HW: 03L 907 309 AE
   Component: R4 2.0l TDI   H28 9978
   Revision: 41H28---    Serial number: 00000000000000
   Coding: 0019003A042401080000
   Shop #: WSC 73008 205 00000
   ASAM Dataset: EV_ECM20TDI01103L906018TL 003002
   ROD: EV_ECM20TDI01103L906018RE.rod
   VCID: 074B9B0B8FAD2933121-8052
   Part No SW: 3AA 614 109 AP    HW: 3AA 614 109 AP
   Component: J104   C2 450M V4B0 0030
   Revision: --H07---    Serial number: 00000007163738
   Coding: 0002489
   Shop #: WSC 05311 000 00000
   VCID: 7BA3F7FBCFE57DD3069-802E
03841 - RPM Sensor Rear Left: Incorrect Signal
                    Fault Frequency: 15
                    Reset counter: 175
                    Mileage: 145179 km
                    Date: 2014.12.11
                    Time: 19:17:22
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.25 V
                    Bin. Bits: 00011111
                    Count: 156
                    Hex Value: 0x0000
   Part No SW: 3AA 907 044 BD    HW: 3AA 907 044 BD
   Component: Climatronic   H03 0404
   Revision: 00001K01
   Coding: 071400C849
   Shop #: WSC 00015 115 00000
   VCID: 73B3DFDBEB3535935E9-8026
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 R    HW: 3AA 937 087 R
   Component: BCM PQ47 H++  422 0474
   Revision: BD422001
   Coding: 000C000000000000008C0088B4001164237D040865202D20E480872400C9
   Shop #: WSC 12345 123 61029
   VCID: 49CF5D33D9B91F43C45-801C
   Subsystem 1 - Part No SW: 3C8 955 119 F    HW: 3C8 955 119 F  Labels: 1KX-955-119.CLB
   Component: WWS464 140513  010 0604
   Serial number: 140513
   Coding: 00B795
   Component: RLFS  024 0042
   Serial number: Y13M06D20H04M03S22S1
   Coding: 0228DD
Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
   Part No SW: 3AA 919 475 H    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0026
   Revision: --------    Serial number: 56231314100755
   Coding: 358207
   Shop #: WSC 80093 222 69422
   ASAM Dataset: EV_EPHVA2C000000000 002009
   ROD: EV_EPHVA2C000000000.rod
   VCID: 40D94017EA03DE0B13B-8014
13637396 - Databus
          [Bremsensteuergerät - mBremse_10.B10_Wegimp_HL - Fehlerspeicher auslesen]
                    Reset counter: 175
                    Mileage: 145179 km
                    Date: 2020.07.20
                    Time: 19:17:22
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 27051300860001
   Coding: 010180
   Shop #: WSC 05314 000 00000
   VCID: 270BFB8B6FED0933321-8072
   Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
   Component: J234__70H VW10 HI   2118
   Revision: 26019000    Serial number: 003L7PBZV3RY
   Coding: 0012360
   VCID: 7CA1F4E7CAEB7AEB0F3-8028
   Subsystem 1 - Serial number: 6332MTS616881443
   Subsystem 2 - Serial number: 6342MTS651821423
   Subsystem 3 - Serial number: 6351HTS6SND52CKJ
   Subsystem 4 - Serial number: 6361HTS6RKG52CKR
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 BL    HW: 5K0 953 569 T
   Revision: FF010042    Serial number: 20130605200689
   Coding: 218A270001
   VCID: 70B9D0D79A230E8BA3B-8024
   Component: E221__MFL-TK6  H07 0022
   Coding: E20000
   Part No SW: 3C8 920 880 Q    HW: 3C8 920 880 Q
   Component: KOMBI         H04 0611
   Coding: 140F00
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
   VCID: 3A2D32FF8CDF84DB5DF-806E
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 C
   Component: Standheizer     044 4840
   Revision: 00044000    Serial number: 09024302000000
   Coding: 0031032
   VCID: 353721C3A9416BA3B0D-8060
   Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1642
   Revision:   H56       Serial number: 130613F1000875
   Coding: 469006
   VCID: 7CA1F4E7C6EB7AEB0F3-8028
   Part No SW: 3AA 959 799 C    HW: 3AA 959 799 C
   Component:    IMMO         090 0407
   Revision: 00090000    Serial number: VWZCZ000000000
   VCID: 48C95837CEB3E64BDBB-801C
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Revision: A1001003    Serial number: 7664905313
   Coding: 010100
   VCID: 2B0307BB73052D53D69-807E
   Part No SW: 1T0 035 686 C    HW: 1T0 035 686 C
   Component: RNS-MID       H09 5238
   Revision: AB001001    Serial number: VWZ6Z7N6159082
   Coding: 04050002010000A0200F
   VCID: 34311CC7AE3B72AB873-8060
   Component: EU West V11  8117
Address 3C: Lane Change        Labels: None
   Part No SW: 3AA 907 566 C    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0010
   Revision: 00H02000    Serial number: 6PZ 010 316-09
   Coding: 0000174
   VCID: 392F2DF385598FC3545-806C
   Subsystem 1 - Part No: 3AA 907 568 C
   Component: J0770_SWA_Slave_H02 0010
   Subsystem 2 - Serial number: 6PZ 010 316-29
   Subsystem 3 - Serial number: 5F11.06.1300H02000AMS14130ÿ
   Subsystem 4 - Serial number: S14130ÿ
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0555
   Revision: 12110009    Serial number: 0007099389
   Coding: 0210FF
   Shop #: WSC 05311 115 00000
   VCID: 6D87C9A38D11E36388D-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0501
   Serial number: 00000003520518
   Coding: 010098
   Part No SW: 5N1 909 144 P    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.299 1202
   Revision: 1BH04737    Serial number: 00131230085201
   Coding: 0000258
   VCID: 3FDB43EB9B7DA1F36A1-806A
01316 - ABS Control Module
                    Fault Status: 11101101
                    Fault Frequency: 9
                    Reset counter: 176
                    Mileage: 145179 km
                    Date: 2014.12.11
                    Time: 19:17:24
                        Term 15 On
                    (no units): 4.0
                    Voltage: 12.20 V
Address 46: Central Conv.        Labels:. 3C0-959-799-46.clb
   Component: 09 KESSY PQ47   090 0367
   Coding: 00900A0001C60E763604941572004F0B605C0013240798
   Subsystem 4 - Part No: 3AA 962 243 B
   Component: GEB.F.Heckoef       0810
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No SW: 3C8 035 456 G    HW: 3C8 035 456 G
   Component: DSP 10 Kanal        0100
   Revision: 00H03001    Serial number: 75814000128704
   VCID: 2C0104A77A0B2A6BDF3-8078
   Component: EZE_2         H56 1642
   Coding: 01030108
   VCID: 6FBBD3AB879D1173BA1-803A
   Subsystem 1 - Part No SW: 6R0 959 591     HW: 6R0 959 591
   Component: J245/J878  H04 0054
   Serial number: 320200040413
   Coding: 000006
   Subsystem 2 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
   Component: Analoguhr  005 0004
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0555
   Revision: 14110009    Serial number: 0007115793
   Coding: 0210FE
   VCID: 6E85CEAF8017187BB17-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0501
   Serial number: 00000003507949
   Coding: 010098
   Part No SW: 3AA 907 801 H    HW: 3AA 907 801 H
   Component: J540 EPB4  VW-86594 0010
   Revision:   H19       Serial number: 00000001123128
   Coding: 0022167
   VCID: 363526CFB44760BBB97-8062
                    Fault Status: 01101101
                    Fault Frequency: 51
                    Reset counter: 176
                    Mileage: 144624 km
                    Date: 2014.12.07
                    Time: 20:11:58
                    Voltage: 14.00 V
                    Count: 104
                    Hex Value: 0x1263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Coding: 07B200104F000200
   VCID: 372B2BCBBFCD99B3A21-8062
   Subsystem 1 - Part No SW: 1T0 941 329 A    HW: 1T0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0007
   Coding: 390000
   Subsystem 2 - Part No SW: 1T0 941 329 A    HW: 1T0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0007
   Coding: 390000
13705985 - Databus
          [Fehlerwert im Signal BR3_Rad_kmh_HL]
                    Fault Frequency: 9
                    Reset counter: 176
                    Mileage: 145179 km
                    Date: 2020.07.20
                    Time: 19:17:30
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AN
   Component: Batt.regelung H56 1642
   Coding: 330F1859
   VCID: 71BFD5D391A90783AC5-8024
   Component: J367-BDM  H07 0180
   Serial number: 30158019111491558753
   Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
   Component: RDKBERU30     H09 0010
   Serial number: 10000000224597
   ASAM Dataset: EV_RDKBERU30 003012
   ROD: EV_RDKBERU30_003.rod
   VCID: 353721C3A5C16BA3B0D-8060
   Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Component: ConWysTrailer H07 0100
   Revision: 3A001001    Serial number: 00000132425721
   Coding: 0100000100000000
   Shop #: WSC 00007 223 174336
   VCID: 303910D75A234E8BE3B-8064
   Part No SW: 3C8 907 441     HW: 3C8 907 441
   Revision: 00H11000    Serial number: 525PA8-J348221
   Coding: 0020008
   VCID: 678BBB8BA36DC933F21-8032
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 D    HW: 3C8 035 730 D
   Component: Telefon       022 0946
   Revision: --------    Serial number: 35502105016965
   Coding: 020100000000000000000101
   ASAM Dataset: EV_UHVPremi 002708
   ROD: EV_UHVPremi.rod
   VCID: 2411EC871E5BE22B173-8070
9457171 - Right audio channel for speech/telephone
          B104E 13 [024] - Short to GND
                    Fault Frequency: 8
                    Reset counter: 215
                    Mileage: 145179 km
                    Date: 2020.07.20
                    Time: 19:35:42
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3AA-980-654.clb
   Part No SW: 3AA 980 654 D    HW: 3AA 980 654 A
   Component: MFK_Gen1      H09 0300
   Serial number: 0193669662
   Coding: 01010201010202110201040001010000
   Shop #: WSC 05311 115 12345
   ASAM Dataset: EV_47X 001639
   ROD: EV_47X.rod
   VCID: 392F2DF389D98FC3545-806C
End----------(Elapsed Time: 02:15, VBatt start/end: 13.4V/13.3V)-----------
2. Round
Wednesday,22,July,2020,13:33:40:00464
Mileage: 145450km-90378mi   Repair Order: 2. kierros
   Coding: 0002489
                    Reset counter: 176
                    Mileage: 145453 km
                    Date: 2014.12.13
                    Time: 13:28:13
                    Hex Value: 0x0000
                    Voltage: 13.25 V
                    Bin. Bits: 00011111
                    Count: 156
                    Hex Value: 0x0000
   Revision: 00001K01
   Coding: 071400C849
   Revision: BD422001
   Coding: 00B795
   Coding: 0228DD
   Coding: 358207
13637396 - Databus
                    Reset counter: 176
                    Mileage: 145453 km
                    Date: 2020.07.22
                    Time: 13:28:13
   Coding: 010180
   Coding: 0012360
   Coding: 218A270001
   Coding: E20000
   Coding: 140F00
   Coding: 0031032
   Coding: 469006
   Coding: 010100
   Coding: 0000174
   Coding: 0210FF
   Slave Driver:
   Coding: 010098
   Coding: 0000258
                    Reset counter: 176
                    Mileage: 145453 km
                    Date: 2014.12.13
                    Time: 13:28:14
                        Term 15 On
                    RPM: 828 /min
                    (no units): 7.0
                    Voltage: 13.40 V
   Coding: 01030108
   Coding: 000006
   Coding: 0210FE
   Slave Passenger:
   Coding: 010098
   Coding: 0022167
                    Reset counter: 176
                    Mileage: 145453 km
                    Date: 2014.12.13
                    Time: 13:28:13
                    Voltage: 13.30 V
                    Count: 104
                    Hex Value: 0x1263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Coding: 390000
   Coding: 390000
13705985 - Databus
                    Reset counter: 176
                    Mileage: 145453 km
                    Date: 2020.07.22
                    Time: 13:28:13
   Coding: 330F1859
   Coding: 0020008
   ROD: EV_47X.rod
End----------(Elapsed Time: 02:10, VBatt start/end: 13.3V/13.3V)-----------
What should be tested next?
Regards: V3lmu :)
siLc
Tallinn, Estonia
C?ID=330192
Vehicle is FWD and has self-parking and it only takes one type of rear ABS sensors (left) - WHT 003 859A (supersedes to WHT 003 859B). Did you try these?
fat_chris
C?ID=309817
Has the replacement wheel bearing been checked to have the correct encoder ring installed?
Jef
HQ
If the parts being installed are factory original, what are the VW part numbers? If they are Chinese Replacement Auto Parts, then you gonna have a bad day.
PS... send me some Salmiakki. :thumbs:
V3lmu
Oulu, Finland
C?ID=229426
The ABS speed sensor is installed with this part number.
Is it possible to install this part upside down? :confused:
Spare parts are purchased from a local parts store, but spare parts are not OEM spare parts.
Roger that :thumbs:
Jef
HQ
Not saying that is the source of the problem, but I won't be surprised if you confirm it is the problem.
V3lmu
Oulu, Finland
C?ID=229426
Problem solved
The stationary abs speed sensor was broken, even though it was new and with the correct product number. The owner bought a fourth abs speed sensor and installed and everything works now.
Thanks for all the help! :)
