2016 Tiguan 5N2
Battery management keeps battery charge only about 80%.
Recuperation increase voltage when braking and voltage will drops when accelerating or driving normally.
I am using diesel auxiliary heater, and it needs a lot of power at the winter.
It should be better that the battery will be fully charged.
I tried to disable that feature.
Originally there was ticked in Byte 1 bits 0-1: 03 and bit bit 3: Extended recuperation.
https://photos.app.goo.gl/bDpDHyqBbzjABHwF8
I disabled Extended recuperation and change the bit 01 to 01 from 03.
Nothing happens, voltage increases almost 15V when braking, and drops to 13V when driving normally.
See pictures from google link.
Today I tested again:
- Battery was charged about 75% at the start of driving.
- Voltage was 14.6 which looks normal for AGM battery.
After 30 minutes battery shows 90% charged.
But then voltage drops again to 13V and the battery charge will decreases.
Recuperation was inactive at the start, but now it was activated again.
I disabled the Start Stop from the Gateway adaptation channel 13 at many years ago.
From 002000, to 292029.
I think that it changes some kind of temperature value to battery management.
Is there other places where the recuperation must be disabled?
I tried also BCM coding, there was recuperation installed; untick the function.
Nothing changed.
This full scan is from the past year
Nothing changed.
Friday,25,October,2019,20:39:58:64262
VCDS Version: 19.6.2.0 (x64)
VIN: WVGZZZ5NZGW566432 License Plate: TIGUAN3
Mileage: 85290km-52996mi Repair Order:
Chassis Type: 5N-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 22 25 42 44 46 47 4C 52 53
55 5F 61 62 69 72
VIN: WVGZZZ5NZGW566432 Mileage: 85290km-52996miles
Address 01: Engine (J623-CUVC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 016 CN HW: 04L 907 309 K
Component: R4 2,0L EDC H20 1843
Revision: 8AH20---
Coding: 0125003A043601082000
ASAM Dataset: EV_ECM20TDI01104L906016CN 001004
ROD: EV_ECM20TDI01104L906016BJ_001_VW36.rod
VCID: 77F61D2CCE3642F796-8022
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BH 300 012 Q HW: 0BH 927 711 G
Component: DSG DQ500-7A H11 5207
Revision: 00H11V01
ROD: EV_TCMDQ500021_VW36.rod
VCID: 3162E33460D25CC718-8064
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 BN HW: 5N0 614 109 BN
Component: J104 C6 450M VD56 0021
Revision: --H07--- Serial number: 00000009052266
Coding: 0055105
VCID: 78F41E100B284D8F9F-802C
Part No SW: 1K8 907 044 BH HW: 1K8 907 044 BH
Component: Climatronic H07 0405
Revision: 00001K04
Coding: 001800C003
VCID: 76E81028C93C3BFF8D-8022
Part No SW: 5K0 937 086 T HW: 5K0 937 086 T
Component: BCM PQ35 M 122 0183
Revision: BC122001
Coding: 60180A3BC8270AC4448800C0340009EC4BFDAB086329AD20E484A7000041
VCID: 458AA7E4CC5AE067D4-8010
Subsystem 1 - Part No SW: 5N1 955 119 B HW: 5N1 955 119 B Labels: 1KX-955-119.CLB
Component: WWS316 041115 24 0664
Coding: 009795
Component: RLS 221115 05 54 0403
Coding: 07144D
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 1K8 919 475 B HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0479
Revision: -------- Serial number: 39491531400080
Coding: 0031060151
ASAM Dataset: EV_EPHVA2CVW364GP00 001010
ROD: EV_EPHVA2CVW364GP00_VW36.rod
VCID: 3972DB14B8A29487A0-806C
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__20J VW10 HI 3018
Revision: 32022000 Serial number: 003L7PP2YFY.
Coding: 0012362
VCID: 7CFC02003F1061AFFB-8028
Subsystem 1 - Serial number: 6332MTS672622715
Subsystem 2 - Serial number: 6342MTS654602755
Subsystem 3 - Serial number: 6351HTS6S4N5SDKR
Subsystem 4 - Serial number: 6361HTS6I08NSDKJ
Part No SW: 5K0 953 501 CQ HW: 5K0 953 569 AL
Component: LENKS.MODUL 016 0180
Revision: FF010042 Serial number: 20151112201213
Coding: 199A140000
VCID: 7BFE011CF21E6697F2-802E
Subsystem 1 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H30 0036
Serial number: 0277875
Coding: 830000
Part No SW: 5N0 920 883 G HW: 5N0 920 883 G
Component: KOMBI H04 1008
Coding: 111F030000
VCID: 3874DE1083A88D8F5F-806C
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 7N0 963 272 E
Component: Standheizer 044 4941
Revision: 00044000 Serial number: 09028239000000
Coding: 0031032
Shop #: WSC 01324 011 00200
VCID: 3776DD2C46B682F756-8062
Part No SW: 7N0 907 530 BE HW: 7N0 907 530 AL
Component: J533 Gateway H58 1674
Revision: H58 Serial number: 131115F1001606
Coding: 356032
Shop #: WSC 32136 002 1048576
VCID: 74EC2A20D74029EFB3-8020
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0AY 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7540
Serial number: HA1-00003.11.15
Coding: 0001
VCID: 52A08CB8051447DF41-8006
Component: IMMO H04 1008
VCID: 6AD034588D84EF1F19-803E
Part No SW: 5N0 959 701 G HW: 3C0 959 793 C
Component: TUER-SG FT 002 0503
Revision: 12110009 Serial number: 0010212268
Coding: 0214BE
Slave Driver:
Subsystem 1 - Part No SW: 5N0 959 703 F HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 010 1505
Serial number: 00000009630409
Coding: 000490
Part No SW: 5N1 909 144 R HW: 5N1 909 148 J
Component: J500__APA-BS KL.287 1401
Revision: 1BH04841 Serial number: 00153130271601
Coding: 0000258
VCID: 4182B3F41872CC47E8-8014
Part No SW: 5K0 035 456 HW: 5K0 035 456
Component: KonzernAmp 8K 0340
Revision: -------- Serial number: BP218109080358
VCID: 67D64D6C9E96D27706-8032
Part No SW: 5N0 959 702 G HW: 3C0 959 792 C
Component: TUER-SG BT 002 0503
Revision: 14110009 Serial number: 0010219193
Coding: 0215BE
VCID: 3A70C418BDA49F9FA9-806E
Slave Passenger:
Subsystem 1 - Part No SW: 5N0 959 704 F HW: 3C0 959 795 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 010 1505
Serial number: 00000009628237
Coding: 000490
Part No SW: 3AA 907 801 J HW: 3AA 907 801 J
Component: J540 EPB4 VW-63206 0012
Revision: H19 Serial number: 00000000957529
Coding: 0026167
VCID: 3874DE104BA88D8F5F-806C
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H05 0111
Coding: 049A00000B000200
ROD: EV_HeadlRegulVWAFSPt_VW32.rod
VCID: 3776DD2C8EB682F756-8062
Subsystem 1 - Part No: 5N0 941 329 Labels: 3D0-941-329.CLB
Subsystem 2 - Part No: 5N0 941 329 Labels: 3D0-941-329.CLB
Part No SW: 5C0 035 680 B HW: 5C0 035 680 B
Component: MU-S-N-ER H22 0253
Serial number: VWZAZ2R8038564
Coding: 021306010000000011110003000808001F0106C400200100CF
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: 204416703B38E54F87-8074
Subsystem 1 - Part No SW: 5NA 919 866 AG HW: -----------
Component: ECE AS 2020 --- 1310
Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
Component: Batt.regelung H58 1674
Coding: 330F1873
VCID: 71E22334A8521CC758-8024
Component: J367-BDM H07 0180
Serial number: 32320E56361491066596
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revision: 3B001001 Serial number: 00000386647051
Coding: 410D000101000000
VCID: 3260EC386DD467DF61-8066
End-------------------------(Elapsed Time: 03:46)--------------------------
