2013 A8 - Fuel Tank System Malfuntion
DIC Display: FUEL TANK SYSTEM MALFUNCTION - CONTACT (DEALER?)
2013 A8L / 82.7k miles / 3.0T / Non-Sport / Semi-hot day (~90F), but no more than normal, sitting in sun again / First time for this fault / Fuel gauge went to "EMPTY" (blank) while fault was visible / Opened and closed fuel door and cap, good seal and pressure) fault message remained / Drove the car for a minute or less and fault warning went away and fuel gauge went back to normal reading / ~35 minutes of varied driving (Old-Guy Putt-Putt to "Flagrant Display Of Power") since and no further issues.
Found VERY little about this fault online, especially for Audis! I need to know if this is something I need to be more concerned over. I have an appointment at my local Indy Shop on Friday (front/lower/rearward CA replacement) and will ask them, as well. - Halp?
(Short Version)
Module 17 / 1 Fault Found:
9437188 - Fuel Tank Level Sensor 3; Insulation Resistance too Low
B117B 1A [008] - Resistance Too Low
(Short Version)
Tuesday,21,July,2020,20:09:24:62207
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 28 34 36 3B 3C 42
46 47 52 53 56 5F 62 6C 6D 6F 72 81 85 88 89 8B 8E 8F 90
Mileage: 133136km-82726miles
Address 01: Engine (J623-CTUB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4H0 907 551 G HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0005
Revision: --H07---
Coding: 0A2A0034056E01060000
Shop #: WSC 02313 785 00200
ASAM Dataset: EV_ECM30TFS0214H0907551G 001006
ROD: EV_ECM30TFS0214H0907551G.rod
VCID: 2E050DD970986A8BF17-807A
17249 - Implausible Data Received from Instrument Panel Control Module (Cleared on reset)
U0423 00 [168] - -
Mileage: 133094 km
Date: 2020.07.19
Time: 13:38:52
Engine speed: 859.00 /min
Normed load value: 8.2 %
Coolant temperature: 67 °C
Intake air temperature: 68 °C
Voltage terminal 30: 11.679 V
Engine speed: actual: 736 /min
MAF_ENVD: 108.94117 mg/stroke
Coolant temperature (unfiltered): 76.50 °C
Engine: operating status: IS
Engine load: 9.375000 %
Vehicle speed: actual: 0 km/h
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4H1 927 158 AR HW: 0BK 927 156 AG
Component: 0BK 30TFSIUSA H16 1005
Revision: --H16---
Coding: 000002
ASAM Dataset: EV_TCMALX51011 002018
ROD: EV_TCMALX51011_002_AU64.rod
VCID: 005983619A8C2CFB53B-8054
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 E HW: 4H0 907 379 E
Component: ESP PREMIUM H10 0352
Coding: 80E5F30001A7CF00E200
ASAM Dataset: EV_ESPPremi 005013
ROD: EV_ESPPremi_005_AU64.rod
VCID: 34311FB19EB4405B873-8060
Part No SW: 4H0 907 064 DD HW: 4H0 907 064 BD
Component: BCM2 2.0 H31 0510
Coding: 0DA72006000000000000
Shop #: WSC 56818 000 1048576
VCID: 6E85CDD9B0982A8BB17-803A
Serial number: 2311000286576003
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00000021814031
Coding: C018320085047201010001010101112131313333283333
VCID: 353722B5954E5953B0D-8060
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 H HW: 4H0 820 043 H
Component: Klima 4 Zonen H20 0110
Coding: 668122BE6C
VCID: 2517F2F5256E29D300D-8070
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BP HW: 4H0 907 063
Component: BCM1 2.0 H12 0111
Revision: 11012002 Serial number: 00000001228559
Coding: 09072091073C9FE38B000804A0003800009CD308860001218001085C3B00
VCID: 77ABE8BDCFC26B43621-8022
Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 120119 H35 0080
Serial number: 120206055445
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10213353
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 B HW: 4H0 941 531 B
Component: E1 - LDS H07 0044
Serial number: 02 02 2012 00001043
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555R14A802
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000012121100010476
Coding: 100000
Subsystem 6 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000001021200010983
Coding: 100000
Subsystem 7 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA102747000000899664
Coding: 020300
Subsystem 8 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: 90588116000000000001
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 E HW: 4H0 035 108
Component: DVDCAlpine H42 0190
Revision: AA001001
VCID: 221DE9E934C0DEEB65F-8076
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 L HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0043
Revision: 11001001 Serial number: 55901203301197
Coding: 280B02
ROD: EV_EPHVA18AU57X0000_002_AU64.rod
VCID: 3B23348DB3EA8F23469-806E
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4H0 907 561 B HW: 4H0 907 561
Component: ACC3 H17 0400
Coding: 7E01020201
ASAM Dataset: EV_AdaptCruisContrAU64X 002021
ROD: EV_AdaptCruisContrAU64X_002.rod
VCID: 2A0D01C94C7006AB2DF-807E
Part No SW: 4H0 959 655 D HW: 4H0 959 655 D
Component: Airbag10.43 H41 0041
Revision: -------- Serial number: 003JS0018C5X
Coding: 303143303230303030314A55304C34483053
VCID: 372B28BD8FC2AB43A21-8062
Subsystem 1 - Part No SW: 4H0 959 339 A HW: 4H0 959 339 A
Component: BF-Gewichtss. H03 0040
Serial number: 5850000R11C0802P9Y
Serial number: 3575HRB405J14JQM5ONC
Serial number: 3585HRB405J14JQM4GG/
Serial number: 3515JRB404V0P3T49PMC
Serial number: 3525JRB404V0P3T4B8P1
Serial number: 3554VRB406511D463PF/
Serial number: 3564VRB405T11D467OLU
9498139 - Igniter for Passenger Side Active Head Restraint (Known Fault)
B10EE 1B [137] - Resistance Too High
Fault Frequency: 61
Mileage: 125622 km
Date: 2020.03.29
Time: 09:39:36
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815LB70002R
Coding: 0004BC
VCID: 38292B81825CA43BABB-806C
Subsystem 1 - Part No SW: 4H0 951 528 L HW: 4H0 951 528 L
Component: E221 - MFL H09 0009
Serial number: 09 11 2011 33160347
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4H0 920 980 J HW: 4H0 920 980 J
Component: TBenUSAACC--- H71 0416
Revision: 32081056 Serial number: 658010212592024
Coding: 0B4608015700D705020000
ASAM Dataset: EV_RBD4K 004045
ROD: EV_RBD4K_AU64.rod
VCID: 323D19A964A04E6B95F-8066
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 G HW: 4H0 919 204 G
Component: Analoguhr D4 H05 0224
Serial number: 1120125000970
9437188 - Fuel Tank Level Sensor 3; Insulation Resistance too Low (Cleared on its own, stayed gone after reset)
Fault Frequency: 18
Reset counter: 108
Mileage: 133085 km
Date: 2020.07.18
Time: 18:19:56
Part No SW: 4H0 907 468 G HW: 4H0 907 468 C
Component: J533--Gateway H08 0214
Revision: -------- Serial number: 00000000386482
Coding: 00CD075200
ROD: EV_GatewUDS_AU57.rod
VCID: 353722B595CE5953B0D-8060
Subsystem 1 - Part No SW: 4H0 915 181 HW: 4H0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650540539
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 C HW: 8K0 959 663 C
Component: J532_DCDCStab H05 0006
Serial number: 12032002031021200410
Address 28: HVAC, Rear (E265) Labels:| 4H0-919-158.clb
Part No SW: 4H0 919 158 D HW: 4H0 919 158 D
Component: Klima Fond H16 0111
Coding: 0000000000
ROD: EV_AirCondiHeck.rod
VCID: 313F16A561A67573EC5-8064
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4H0 907 553 E HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0099
Coding: 008002
ROD: EV_AirSuspe_VW51.rod
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000021801633
Coding: C0183B0085057201010001010101112131313333203333
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 HW: 4H0 907 637
Component: SARA 6D H02 0020
Revision: -------- Serial number: EJ1BPA3101BL2X0
ASAM Dataset: EV_SARA 009017
ROD: EV_SARA_009.rod
VCID: 6C81C7D18604D89B9F3-8038
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4H0 907 566 A HW: 4G0 907 566
Component: J769 SWA MasterH02 0040
Revision: 00H02000 Serial number: 6PZ 010 287-07
VCID: 2E050DD97C186A8BF17-807A
Subsystem 1 - Part No: 4H0 907 568 A
Component: J770 SWA Slave H02 0040
Subsystem 2 - Serial number: 6PZ 010 287-27
Subsystem 3 - Serial number: 5F19.01.1200H020003CX27063ÿ
Subsystem 4 - Serial number: X27063ÿ
Part No SW: 4H0 959 793 G HW: 4H0 959 793 G
Component: TSG FA H06 0261
Revision: -------- Serial number: 0000124563772
Coding: 011F1F005E0062C202003017
VCID: 3D273A95AD7E811378D-8068
Revision: 00002001 Serial number: 0169601495
Coding: 0106023A00FA759FB0B0C784020301000000000000000000000000000000
Subsystem 1 - Part No SW: 4H0 959 719 HW: 4H0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000067155
Subsystem 3 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J245 007C H06 0005
Serial number: 205200040279
Coding: 020200
Subsystem 4 - Part No SW: 4H0 947 135 BR HW: 4H0 947 135 BR
Component: Dachelektroni H11 0080
Serial number: A2012000000000524981
Coding: 070000
Subsystem 5 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J394 0014 H06 0005
Serial number: 205200040205
Coding: 020200
Subsystem 6 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J392 006A H06 0005
Serial number: 205200040272
Coding: 020200
Subsystem 7 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J867 00E0 H06 0005
Serial number: 205300040661
Coding: 020200
Subsystem 8 - Part No SW: 3AA 962 243 HW: 3AA 962 243
Component: GEB.F.Heckoef H12 0719
Serial number: 84209154
03637 - Roof Electronics Control Module; Function Limitation due to Overtemp (Cleared on reset)
Reset counter: 73
Mileage: 132245 km
Date: 2020.07.01
Time: 16:56:43
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007000 Serial number: 00000000038892
Coding: 030000
Shop #: WSC 24103 444 04787
VCID: 1D67DA150DBEE11358D-8048
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H06 0261
Revision: -------- Serial number: 0000124593575
Coding: 011F1F005E0062C202003007
VCID: 3C213791B664881B4F3-8068
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000248494
ROD: EV_ParkiBrake_VW51.rod
Part No SW: 4H0 035 082 D HW: 4H0 035 082
Component: Radio U SIRIU H53 0112
Revision: AB001007 Serial number: 235BI0C7501221
Coding: 020007010000000001
Part No SW: 4H0 035 746 C HW: 4H0 035 746
Component: H-BNT-NA H48 0549
Revision: -------- Serial number: 035BZ0C7508836
Coding: 020200000001F9EF7D128B1E00000003140001000000000000
Shop #: WSC 25807 444 183079
VCID: 2809FBC152FC34BB3BB-807C
Component: NAR 2011 0505
Subsystem 2 - Part No SW: 4H0 919 604 F HW: 4H0 919 604 F
Component: DU8 D4 SV NB H47 0021
Serial number: AUZ8ZDB93007EPS
Subsystem 3 - Part No SW: 4H1 919 600 H HW: 4H1 919 600
Component: E380 BDT D4 H09 0065
Serial number: 00000000068743
Component: CD-Database 3371
Address 62: Door, Rear Left Labels:
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H06 0262
Coding: 010F1F00400062C202003007
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4H0 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H04--- Serial number: 525 PA8J1ZD049
Coding: 1080003
VCID: 2615F5F954E822CB097-8072
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 R HW: 4H0 959 107 M
Component: HDSG-Modul H11 0039
Revision: 10011001 Serial number: 030200189
Coding: 0210044100
ROD: EV_DeckLidContrUnit.rod
VCID: 3D273A95ADFE811378D-8068
