2012 Jetta 2.5L crank with intermittent no-start
involk
Canada
C?ID=411119
Hi so i bought a 2012 jetta with a no start issue with the assumption that this was something i could potentially fix myself, I'm not a mechanic by any means but for $600 it was worth purchasing.
When the car does start everything operates as it should however when it doesn't start the epc light and check engine light are illuminated and intermittently flickering.
I bought the hex-v2 to get an honest look into the problem and it seems to be leaning towards the immobilizer as their is a sporadic communication error from it and the cluster has an intermittent no communication error as well.
Through browsing the ross-tech wiki I am leaning towards the key being the potential issue but then again i am no expert and so I am hoping that someone here could be able to point me in the right direction! :)
I have 2 scans, one is of the vehicle running and the other is with the no-start condition present.
No-Start Condition
Tuesday,21,July,2020,09:15:09:30340
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4513.4
VIN: 3VWBX7AJ8CM354416   License Plate:
Mileage: 307450km-191040mi   Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 03 08 09 15 17 19 25 56
VIN: 3VWBX7AJ8CM354416   Mileage: 307450km-191040miles
17-Instruments -- Status: Malfunction 1010
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055     HW: 07K 906 055
   Component: 2,5l R5/4V      G01 9532
   Revision: T4H06---    Serial number:
   Coding: 0000071
   VCID: 6B83C3A9EF829813969-803E
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early - Intermittent
                    Temperature: 16.0°C
                    Temperature: 17.0°C
                    Absolute Pres.: 900.0 mbar
Readiness: 1110 0101
   Revision: 00H31001
   Coding: B14B440C492708FE8D0F22E5921F1061210000
   VCID: 7BA3F3E993E20893069-802E
                    Reset counter: 236
                    Count: 28672
                    Count: 8208
                    Count: 38656
                    Count: 511
03391 - Coding Not Possible
                    Reset counter: 236
                    Count: 28672
                    Count: 8254
                    Count: 43520
                    Count: 254
                    Reset counter: 236
                    Count: 28672
                    Count: 8211
                    Count: 43520
                    Count: 254
                    Fault Status: 00100001
                    Reset counter: 236
                    Mileage: 307457 km
                    Date: 2014.12.04
                    Time: 00:01:11
                    Count: 2
                    Count: 29184
                    Count: 129
                    Count: 50432
                    Count: 256
   Part No SW: 5C0 820 047 AQ    HW: 5C0 820 047 AQ
   Component: J301  Klimaanlage   0203
   Revision: 2001010S    Serial number: 00000000670895
   VCID: 6FBBD7B9DB9A6433BA1-803A
                    Reset counter: 21
                    Mileage: 307456 km
                    Date: 2014.09.21
                    Time: 19:20:32
   Part No SW: 5C0 937 086 E    HW: 5C0 937 086 A
   Component: BCM25 JLB M3  H67 0251
   Revision: B0067001    Serial number: 04351323110278
   Coding: 73994B1808230F0000302000240884C400C2502E60000000300000000000
   VCID: 2E050ABD10102D3BF17-807A
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3464
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3464
   Coding: 820000
   Subsystem 3 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3464
   Coding: 800000
   Subsystem 4 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3464
   Coding: 800000
00532 - Supply Voltage B+
                    Reset counter: 20
                    Reset counter: 20
00538 - Reference Voltage
                    Fault Status: 00101011
                    Reset counter: 20
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   014 0808
   Serial number: 003GTM02UJME
   Coding: 00003936
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 343118D5FEBC07EB873-8060
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y11000094KY0-
   Coding: 303255
   Serial number: 3572MSME162C6665ZZZ.
   Serial number: 3582MSME0E763364ZZZ.
   Serial number: 3516KSME73246A14ZZZQ
   Serial number: 3526KSME084F5B14ZZZ
   Serial number: 3556LSME3C4C6A10ZZZ%
   Serial number: 3566LSME41596A10ZZZV
          U0155 00 [008] - -
                    Reset counter: 21
                    Mileage: 307456 km
                    Date: 2020.04.30
                    Time: 19:20:31
12674816 - Immobilizer Control Module
          U0167 00 [008] - No Communications
          [Lost Comminication with Immobilizer]
                    Reset counter: 21
                    Mileage: 307456 km
                    Date: 2020.04.30
                    Time: 19:20:31
   Part No SW: 5C6 920 851 B    HW: 5C6 920 851 B
   Component: KOMBI         H04 0604
   Coding: 370200
   Shop #: WSC 00066 000 00122
   VCID: 290FF9A1297E4A03245-807C
10485833 - Internal Control Module Memory Check Sum Error
          B2000 49 [137] - Internal electronic failure
          [Steuergerät defekt (SiWaLa)]
                    Mileage: 33711 km
                    Date: 2014.09.03
                    Time: 02:06:47
   Part No SW: 6N0 909 901     HW: 5C0 937 086 A
   Component: GW-K-CAN TP20 H67 0251
   Revision: B0067001
   Coding: 102200
   VCID: 70B9D4C5CAA47BCBA3B-8024
                    Reset counter: 20
01304 - Radio
                    Reset counter: 236
                    Mileage: 307456 km
                    Date: 2014.09.20
                    Time: 03:29:51
                    Reset counter: 20
   Component: IMMO          H04 0604
   VCID: 6A8DC6ADECF8811BEDF-803E
Address 56: Radio
End----------(Elapsed Time: 01:08, VBatt start/end: 14.3V/14.3V)-----------
Running
Tuesday,21,July,2020,20:13:29:30340
VIN: 3VWBX7AJ8CM354416   License Plate: RUNNING
Mileage: 307470km-191053mi   Repair Order:
VIN: 3VWBX7AJ8CM354416   Mileage: 307470km-191053miles
   Coding: 0000071
                    Temperature: 16.0°C
                    Temperature: 17.0°C
000262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
               P0106 - 000 - Implausible Signal
                    Mileage: 307461 km
                    Date: 2014.12.11
                    Time: 18:49:44
                    RPM: 651 /min
                    Load: 19.2 %
                    Speed: 35.0 km/h
                    Temperature: 83.0°C
                    Temperature: 46.0°C
006469 - Control Module 1 for Cooling Fan
               P1945 - 000 - Output Short Circuit - Intermittent
                    Mileage: 307472 km
                    Date: 2014.12.11
                    Time: 19:43:12
                    RPM: 765 /min
                    Load: 16.9 %
                    Temperature: 93.0°C
                    Temperature: 51.0°C
006480 - Radiator Fan (V7)
               P1950 - 000 - Movement Restricted / Jammed - Intermittent
                    Mileage: 307474 km
                    Date: 2014.12.11
                    Time: 19:50:29
                    RPM: 996 /min
                    Load: 21.2 %
                    Speed: 42.0 km/h
                    Temperature: 90.0°C
                    Temperature: 54.0°C
Readiness: 0110 0101
   Revision: 00H31001
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 237
                    Mileage: 307475 km
                    Date: 2014.12.12
                    Time: 04:08:10
                    Count: 2
                    Count: 12288
                    Count: 8193
                    Count: 44800
                    Count: 256
   Coding: 820000
   Coding: 820000
   Coding: 800000
   Coding: 800000
   Coding: 00003936
   Coding: 303255
   Coding: 370200
                    Mileage: 33711 km
                    Date: 2014.09.02
                    Time: 02:06:47
   Revision: B0067001
   Coding: 102200
01304 - Radio
                    Reset counter: 237
                    Mileage: 307475 km
                    Date: 2014.12.11
                    Time: 23:43:28
Address 56: Radio
End----------(Elapsed Time: 01:07, VBatt start/end: 14.0V/14.0V)-----------
I rather doubt it's the key itself that's the problem here.
My gut says: Intermittent electrical issues. I would start with fixing whatever is causing the ECM Power Relay fault.
Did you know it could be harness issue, Terminal relay, BCM or undefined ignition switch with mini harness sporadic or bad ECU?
This bothers me too!
and this.....
Reset counter: 20
Reset counter: 20
Reset counter: 20
involk
Canada
C?ID=411119
Thanks for your quick replies Uwe and Jack! I went and purchased a genuine power relay as the one that was in there was aftermarket, I am a fan of replacing with genuine parts when I can. The relay itself is not the issue so i'm going to dive into the wiring harness. Where would you recommend looking to start as I don't want to cut the harness much if possible?
