2016 Skoda Superb 1.8 TSI CJSA
Kunkero
C?ID=409212
Monday,20,July,2020,15:09:55:15856
VIN: TMBAL9NP6G7021460   License Plate:
Mileage: 129621km-80542mi   Repair Order:
Chassis Type: NP-SK48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 2B 36 3C 42 44 47
          52 55 5F 69 6D A5 BB BC
VIN: TMBAL9NP6G7021460   Mileage: 129621km-80542miles
Address 01: Engine (J623-CJSA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 3G0 906 264 A    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 0C25001A2474010B7000
   Shop #: WSC 33361 790 00120
   ASAM Dataset: EV_ECM18TFS0203G0906264A 001002
   ROD: GV_ECM18TFS020VW48X.rod
   VCID: 2615F3584864D23B097-8072
   Part No SW: 0CW 300 048 R    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0610
   Revision: 00005005    Serial number: CU501508315313
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 4BC362ECF346CF53F69-801E
   Revision: 00000000    Serial number: 62445000000224
   Coding: 1D076A9C34222B6D077B060641C349B8562CD4E0608292F51841F0F8C2A2
   ROD: EV_Brake1UDSContiMK100IPB_034.rod
   VCID: 7AADF728EC5C86DB1DF-802E
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Component: VWKESSYMQB    036 0709
   Revision: 00036000    Serial number: 0375995125
   Coding: 030C0C0703
   ASAM Dataset: EV_KessyHellaMQBAB 004032
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3A2D3728ACDC46DB5DF-806E
   Subsystem 1 - Part No SW: 3AA 962 243 E    HW: 3AA 962 243 E
   Component: GEB.F.Heckoef  H16 0813
   Serial number: 65034778
   Part No SW: 3V0 907 044 AH    HW: 3V0 907 044 AH
   Component: AC Automat    H32 3601
   Revision: 20K04000    Serial number: 00000B00020048
   Coding: 11010004004101011005100000101002
   ASAM Dataset: EV_ACClimaPrehVW37X 002009
   ROD: EV_ACClimaPrehVW37X_002_VW37.rod
   Subsystem 1 - Part No SW: 3V0 907 049 B    HW: 3V0 907 049 B
   Component: E265KlimaHeck  H02 0101
   Serial number: 00000000000000000000
263425 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
                    Fault Frequency: 45
                    Reset counter: 201
                    Mileage: 128243 km
                    Date: 2020.07.06
                    Time: 11:31:56
                    Outside air temperature: 17.0 °C
                    Voltage terminal 30: 13.1 V
                    System run time-Engine running time: 253 s
                    System run time-Terminal 15 on: 253 s
                    Air quality status: ERROR
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061524801715
   Coding: 0C031E46C2C72AFB57C440040018172C0C00000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 094F98E4B9BA9D43045-805C
   Subsystem 1 - Part No SW: 3V1 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x LL 150801  032 0121
   Serial number: 00000001507300301345
   Coding: 165DDD
   Component: RLHS  037 0059
   Serial number: S3Y15M09D15H05M35S12
   Coding: 00084D
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39331525202419
   Coding: 0071057951
   VCID: 44D149D0DE18002B373-8010
   Component: ACC BOSCH MQB H04 0192
   Coding: 320067CA55FFC428949C804D
   ASAM Dataset: EV_ACCBOSCHVW48X 001008
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 343119108EB8B0AB873-8060
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Fault Frequency: 15
                    Reset counter: 201
                    Mileage: 128291 km
                    Date: 2020.07.08
                    Time: 11:17:42
                    Control Module temperature: 17 °C
                    Voltage terminal 15: 11.6 V
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0120
   Serial number: 04091541350008
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 372B2E1C9FCE5BB3A21-8062
   Part No SW: 5Q0 959 655 AE    HW: 5Q0 959 655 AE
   Component: AirbagVW21    005 0130
   Serial number: 003NSR12EYGJ
   Coding: 98FCC0C0000000005C5400CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
   VCID: 03538ACC9B96C7134E9-8056
   Belt Pretensioner left:
   Component: BeltPretRevFL  106 1032
   Serial number: 3V0857701C0246P01354
   Coding: 80000D
   Belt Pretensioner right:
   Component: BeltPretRevFR  106 1032
   Serial number: 3V0857702C0246P01242
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 002 408 15
   Serial number: 3570000000010688F51G
   Subsystem 4 - Part No SW: -----------    HW: 480 002 408 15
   Serial number: 35800000000C2788F51V
   Subsystem 5 - Part No SW: -----------    HW: 480 402 908 15
   Serial number: 3510002991CF1D33F3DM
   Subsystem 6 - Part No SW: -----------    HW: 480 403 108 15
   Serial number: 3520002BD1CB0C02B302
   Subsystem 7 - Part No SW: -----------    HW: 480 402 808 15
   Serial number: 3550002C51CB0C00E286
   Part No SW: 3Q0 953 521 BA    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20150904501302
   Coding: 6010
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 70B9D500BA20CC8BA3B-8024
   Part No SW: 3V0 920 710     HW: 3V0 920 710
   Component: KOMBI         305 6421
   Coding: 07A5011A7F840008018B6A0B5000000000000000
   VCID: 6C81C1709608286B9F3-8038
   Part No SW: 5Q0 963 272 F    HW: 5Q0 963 272 F
   Component: STH-MQB       007 0072
   Coding: 9309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002018
   VCID: 392F2824A9DA4DC3545-806C
   Subsystem 1 - Part No SW: 5Q0 963 513 A    HW: 5Q0 963 513 A
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000001206330
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2227
   Revision: --------    Serial number: 02091510800408
   Coding: 030100346F085900EB00025E9C0F00010001070000000000000000000000
   Shop #: WSC 73430 790 00063
   ROD: EV_GatewConti_013.rod
   VCID: 75B7E414C542E9A370D-8020
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000D1400070915
   Serial number: 9295647703
   Serial number: 15000099764009
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD004B12AC583AC5-8024
   Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
   Component: Sitzmemory    H06 0009
   Serial number: Y0006OH517237
   Coding: 001000000000010001A080808080000000008181000000D4
   ASAM Dataset: EV_SeatMemorDriveSide 001015
   ROD: EV_SeatMemorDriveSide_001.rod
   VCID: 3B23322CA3E67FD3469-806E
   Component: HRE_Master    H11 0071
   Serial number: 0377248764
   Coding: 02012103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C213130A6E878EB4F3-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H11 0071
   Serial number: 0375989194
   Coding: 020121
   Serial number: 170815BHH02325
   Coding: 001D0920DE00048000001100
   VCID: 43D34ACCDB1607130E9-8016
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2033
   Revision: 00000000    Serial number: 0000356394
   Coding: 01000011005001
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_008.rod
Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
   Part No SW: 3Q0 035 466 A    HW: 3Q0 035 466 A
   Component: MIB2_amp_P_SK H02 0110
   Revision: 00000001    Serial number: SKZ8Z1FAS00MVBT
   Coding: 0384010000AA002FAA0000000000
   ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001
   ROD: EV_AMPMst16C5Gen2ALPI.rod
   VCID: 2D070C746D92E163C8D-8078
   Serial number: 270815BHQ2028A
   Coding: 001D0320DE00048000001100
   VCID: 42DD4FC8C40C0E1B05F-8016
   Coding: 06D202007F010000
   VCID: 40D945C0CA001C0B13B-8014
   Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0013
   Coding: B30000
   Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0013
   Coding: B30000
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 864 A    HW: 5Q0 035 864 A
   Component: MU-S-N-ER     H24 0245
   Serial number: SKZAZ2R8846809
   Coding: 038401010000000011110002000808002F0203E40120010086
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 313F100471AA8583EC5-8064
   Subsystem 1 - Part No SW: 3V0 919 605 A    HW: 3V0 919 605 A
   Component: ABT_Std-2_Nav  H44 1028
   Serial number: SKZ8Z9RE6004QP
   Subsystem 2 - Part No SW: 5L0 051 236 BR    HW: -----------
   Component: ECE AS 20/21  --- 1430
   Part No SW: 5Q0 907 383 H    HW: 5Q0 907 383 C
   Component: Anhaenger     H21 0203
   Revision: 8B001003    Serial number: 0376805480
   Coding: 0100000202000000
   ROD: EV_TrailFunctGener2Hella_VW37.rod
   Part No SW: 5Q0 959 107 G    HW: 5Q0 959 107 G
   Component: HDSG-Modul    H12 0250
   Revision: --------    Serial number: 30237715900000
   Coding: 1088
   ASAM Dataset: EV_DeckLidCONTIAU736 001011
   Part No SW: 3Q0 980 654 D    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0024
   Serial number: 09091511K21675
   Coding: 0204080100000401002213478040A00098000E100040
   VCID: 38292D2092D054CBABB-806C
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 240715BGN08255
   Coding: 001C01208000048000001100
   Serial number: 240715BGN0825B
End----------(Elapsed Time: 02:01, VBatt start/end: 12.3V/12.2V)-----------
