I have not long purchased a new VCDS cable to reset/recalibrate a OB5 Transmission. I'm following the Wiki guide http://wiki.ross-tech.com/wiki/inde..._Direct-Shift_Gearbox_(DSG/0B5)#Basic_Setting
but keep getting the following errors,
ERASE COUNTER FOR STAR AND STOP PROCESSES" receive "error: request out of range"
"CLUTCH VALVE CALIBRATION" and receive "aborted: safety reasons"
"DISTANCE SENSOR CALIBRATION" works and completes ok.
I followed all the Prerequisites,
Transmission fluid level correct
Transmission fluid temperature between 40°C - 100°C. (one user reports this needs to be below 60°C) "Tried above/below 60'C"
TCM fault free however it is strongly recommended to check/clear all Powertrain controllers faults also.
Key on, Engine off
Selector lever in P
Engine running for the "CLUTCH VALVE CALIBRATION"
Done multiple searches on the Ross-Tech Forum and Google. Found lots of posts with the same issue but have not found why these procedures fail or a fix other than different Scan-Tools work when tried.
Is there away to get this to work or do i need something other than VCDS do this?
Thank you,
Ant.
Key on, Engine off
Selector lever in P
Thank you,
Ant.
Monday,20,July,2020,12:09:09:15813
VIN: WAUZZZ8TXAA06**** License Plate:
Mileage: 132540km-82356mi Repair Order: 2020-07-20_1
Chassis Type: 8T-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 6C
72
VIN: WAUZZZ8TXAA06**** Mileage: 132540km-82356miles
Address 01: Engine (J623-CCWA) Labels:| 059-907-401-V1.clb
Part No SW: 8R0 907 401 J HW: 8K1 907 401 A
Component: 3.0TDI EDC17 H03 0008
Revision: 15H03---
Coding: 0114002C240F0128
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM30TDI0118R0907401J 001008
ROD: EV_ECM30TDI0118R0907401J.rod
VCID: 392F286EE9DA4E93545-806C
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8K1 927 156 A HW: 0B5 927 156 E
Component: 0B5 30 TDIRdW H03 0002
Revision: --H03--- Serial number: 0000000056
Coding: 000001
ASAM Dataset: EV_TCMDL501 A02044
ROD: EV_TCMDL501.rod
VCID: 33331A46CBB6B4C39E9-8066
Part No SW: 8K0 907 379 BC HW: 8K0 907 379 BC
Component: ESP8 quattro H04 0020
Coding: 1C0500
VCID: 7BA3F266A3E6BC83069-802E
Part No SW: 8K0 907 064 DT HW: 8K0 907 064 DT
Component: BCM2 1.1 H02 0327
Coding: 051400
VCID: 0557949ED522FA7360D-8050
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0210000025016003
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 AF HW: 8T2 820 043 AF
Component: KLIMA 3 ZONEN H08 0171
Revision: D0000000 Serial number: 01090320100791
Coding: 36146000
VCID: 76B5E35298C4E1EB797-8022
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H25 0380
Revision: 09025001 Serial number: 00000000487120
Coding: 260050914034AF010009000000005D5D0F1D430802010141000000
VCID: 3A2D3762EC5C458B5DF-806E
Subsystem 1 - Part No SW: 8T2 955 119 D HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 090310 H12 0070
Serial number: SWF10030090078
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10816877
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000000503100162
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 R HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0070
Revision: 11001001 Serial number: 50941007208468
Coding: 300107
VCID: 48C95DAAA2B0271BDBB-801C
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 J HW: 8K0 959 655 J
Component: AirbagVW-AU10 H41 0610
Serial number: 003GKD0DGUAZ
Coding: 30373438363030303030554A305238543053
VCID: 44D1499A9E18037B373-8010
Serial number: 6334MSME51436C0EI
Serial number: 6344MSME512275073
Serial number: 6352QSME13532204/
Serial number: 6362QSME285715028
Serial number: 63732SME5854571A1
Serial number: 63832SME59544B0E9
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304JCF0005Z
Coding: 000036
VCID: 3D273C7EFD7272B378D-8068
Component: E221 - MFL H02 0010
Part No SW: 8T0 920 931 D HW: 8T0 920 931 D
Component: KOMBIINSTR. H37 0255
Revision: 00000000 Serial number: CSF522A3A
Coding: AF07310002000008010000
VCID: 38292D6AD250579BABB-806C
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0116
Revision: EB900055 Serial number: 5500E10228021B
Coding: 00C303
VCID: 03538A86DB16C4434E9-8056
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 1000BB08260210
Part No SW: 8T0 959 793 J HW: 8T0 959 793 D
Component: TSG FA H07 1301
Coding: 011C12624001450005
VCID: 50F975CA5AE0EFDB83B-8004
Revision: 00002001 Serial number: 0128007476
Coding: 01040E20203904010020043280000000
Shop #: WSC 12345 123 61029
Part No SW: 8T0 959 792 J HW: 8T0 959 792 D
Component: TSG BF H07 1301
Coding: 011C12224C01450005
VCID: 4FFB76B647DEF0239A1-801A
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000586586
VCID: 3431195ACE38B3FB873-8060
Part No: 8K5 907 357
Shop #: WSC 06324 000 00000
VCID: 77ABEE5693CE98E3621-8022
Part No SW: 4F0 035 056 B HW: 4F0 035 056
Component: Radio U STD H45 0020
Revision: AB001007 Serial number: 342CU0A7775412
Coding: 040003020100000001
VCID: 1F1BE6F657BE00A34A1-804A
Part No SW: 8T2 035 754 D HW: 8T2 035 754 D
Component: H-BN-RW H47 0047
Revision: -------- Serial number: 485CW0A7516071
Coding: 010A0104000681EF01000B0E000000030000
Subsystem 1 - Part No: 8R0 060 884 D
Component: ROW 2009/2010 5103
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356CN0A1214832
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Serial number: 00000000489682
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
Part No SW: 8T0 959 795 J HW: 8T0 959 795 B
Component: TSG HL H05 1301
Coding: 010C12224001450005
VCID: 52FD7FC254EC9DCBB5F-8006
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H03--- Serial number: 525PA8-J0291IT
Coding: 1022006
VCID: 38292D6ADE50579BABB-806C
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H05 1301
End----------(Elapsed Time: 01:20, VBatt start/end: 12.2V/12.2V)-----------
