Body shop replaced drivers door customer says ACC braking guard message was not there before accident. When drivers door opened, it is recognized, as interior lights do work with door also with door opened get vehicle not in park chance of roll away. checked measuring block 42-001-----drivers door closed first 2 fields are all zero's & open first field changes the second of 8 digits changes to number 1.
Thank You
"Friday,17,July,2020,08:16:07:64419
VCDS Version: 20.4.1.0 (x64) HEX-NET CB: 0.4508.4
VIN: WAUHGAFC6CN161608 License Plate:
Mileage: 167977km-104376mi Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3B 3C 42 44 46 47
52 53 55 56 5F 62 6C 72 85 8B 8E 8F 90
VIN: WAUHGAFC6CN161608 Mileage: 167977km-104376miles
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CGXB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 A HW: 4G0 907 551 A
Component: 3.0l V6 TFSI H07 0006
Revision: --H07---
Coding: 0A2A0034056600060000
ASAM Dataset: EV_ECM30TFS0214G0907551A 002007
ROD: EV_ECM30TFS0214G0907551A_002.rod
VCID: A71E9825DE1637BEEA-80F2
6506 - MIL Request Signal Active (Check TCM for errors too!)
P1624 00 [109] - -
Mileage: 166583 km
Date: 2020.06.12
Time: 10:09:04
Engine speed: 1119.00 /min
Normed load value: 24.3 %
Vehicle speed: 2 km/h
Coolant temperature: 99 °C
Intake air temperature: 41 °C
Voltage terminal 30: 13.101 V
Engine speed: actual: 640 /min
MAF_ENVD: 147.07058 mg/stroke
Coolant temperature (unfiltered): 56.25 °C
Engine: operating status: IS
Engine load: 14.062500 %
Vehicle speed: actual: 0 km/h
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G0 927 158 P HW: 0BK 927 156 AJ
Component: 0BK 30TFSIUSA H16 1006
Revision: --H16---
Coding: 000002
ASAM Dataset: EV_TCMAL551211 002018
VCID: BB365455329E835E9E-80EE
12446 - Valve for Transmission Fluid Cooler
P2753 00 [175] - Open Circuit
Fault Frequency: 9
Mileage: 166678 km
Date: 2020.06.15
Time: 12:38:14
Voltage terminal 30: 12.762 V
Voltage supply of regulator valves: 12.700 V
Current N215 Pressure control valve 1: 850.0 mA
Current N218 pressure reg.valve 4: 50.0 mA
Current N216 pressure reg.valve 2: 850.0 mA
Current N233 pressure reg.valve 5: 50.0 mA
Current N217 pressure reg.valve 3: 850.0 mA
Current N371 pressure reg. valve 6 lock-up clutch: 50.0 mA
Current N443 pressure reg.valve 7 main pressure: 850.0 mA
Current solenoid: 0.0 mA
Engine speed: 956 /min
Transmission fluid temperature: 22 °C
Control Module temperature: 22 °C
selected gear: 1
M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
M015_Time Normal Mode: 8 s
M019_Time Since Reset: 7650 ms
12448 - Valve for Transmission Fluid Cooler
P2753 00 [040] - Open Circuit
Fault Frequency: 18
Mileage: 166582 km
Date: 2020.06.12
Time: 10:04:44
Voltage terminal 30: 14.128 V
Voltage supply of regulator valves: 14.052 V
Current N215 Pressure control valve 1: 50.0 mA
Current N218 pressure reg.valve 4: 850.0 mA
Current N233 pressure reg.valve 5: 850.0 mA
Current N217 pressure reg.valve 3: 50.0 mA
Current N371 pressure reg. valve 6 lock-up clutch: 355.3 mA
Engine speed: 1237 /min
Transmission fluid temperature: 78 °C
Control Module temperature: 75 °C
selected gear: 4
M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: closed
M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Coasting
M015_Time Normal Mode: 899 s
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 J HW: 4G0 907 379 J
Component: ESP PREMIUM H09 0361
Coding: 44A70F0122E5F0805B00
VCID: B83C4B5903A8A84673-80EC
Part No SW: 4H0 907 064 BR HW: 4H0 907 064 BR
Component: BCM2 2.0 H31 0333
Coding: 0D882006000000000000
VCID: FAB8915175247A56C5-80AE
Serial number: 2312000056667008
00955 - Key 1
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 226
Mileage: 166235 km
Date: 2020.05.13
Time: 11:29:57
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 L HW: 4G0 820 043 L
Component: KLIMA 4 ZONEN H12 0064
Serial number: 05041200040995
Coding: 6601207A4C
VCID: A81C9B19D30838C6E3-80FC
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BP HW: 4H0 907 063
Component: BCM1 2.0 H12 0111
Revision: 11012002 Serial number: 00000001270148
Coding: 02002091163C9FE2C1008884A0003908CF9CD208A2080125800008402000
VCID: F7BE88654636673EBA-80A2
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 120223 H35 0080
Serial number: 120317145543
Coding: 0045F7
Component: RLS H04 0003
Serial number: 20114073
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 02 04 2012 00001045
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555R1BGM02
Subsystem 5 - Part No SW: 8K0 959 772 E HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0026457303
Coding: 853000
Subsystem 6 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA103085000001109333
Coding: 020300
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: C4484716000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 Q HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0060
Revision: 11001001 Serial number: 55901208300972
Coding: 280906
ASAM Dataset: EV_EPHVA18AU57X0000 004005
VCID: C0CC23B95B78E086CB-8094
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H17 0400
Coding: 3601010202
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
ROD: EV_AdaptCruisContrAU57X_002.rod
154624 - Door Contact Switch
C1076 29 [009] - Signal Implausible
Reset counter: 226
Mileage: 166235 km
Date: 2020.05.13
Time: 09:53:03
Control Module temperature: 24 °C
Voltage terminal 15: 12.060 V
Velocity_vehicle_reference: -0.01 m/s
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H32 0032
Revision: -------- Serial number: 003D8001ZLKF
Coding: 303234373131303030324A55304C34473053
VCID: B3267C751ACE4B1E46-80E6
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y150001FAXM0B
Serial number: 3575HRB405D3KVOS7GGR
Serial number: 3585HRB405H17UE26OR+
Serial number: 3515JRB405B184COKOIU
Serial number: 3525JRB401G4UHL8D99W
Serial number: 3554VRB400K4UHPKM16K
Serial number: 3564VRB400K4UHPKR9UF
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372LCS000H1
Coding: 00001C
VCID: B73E486506B6A73E7A-80E2
Subsystem 1 - Part No SW: 4G0 951 528 D HW: 4G0 951 528 D
Component: E221 - MFL H09 0009
Serial number: 14 02 2012 33195007
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 982 T HW: 4G8 920 982 T
Component: TBenUsaAcc H79 0416
Revision: 28460177 Serial number: 658210312596042
Coding: 0BC609040F01D705020000
ASAM Dataset: EV_RBD4K 004045
ROD: EV_RBD4K_AU57.rod
VCID: C5C232AD445AC5AEF8-8090
Part No SW: 4G0 907 468 AB HW: 4G0 907 468 AA
Component: J533--Gateway H10 0028
Revision: -------- Serial number: 00000000471176
Coding: 00C1033000
ASAM Dataset: EV_GatewPkoUDS 001013
VCID: F0ACB3792B5830067B-80A4
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790902595
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0064
Serial number: 04041200041127
Coding: 00
VCID: AF2E7005F6E66FFE22-80FA
0075 - Button or Switch in Operating Unit
B10C7 07 [008] - Mechanical Failure
Reset counter: 40
Mileage: 167251 km
Date: 2020.06.20
Time: 11:22:19
Outside air temperature: 26.5 °C
Left rear vent temperature: 8.0 °C
Part No SW: 4G8 959 760 A HW: 4G8 959 760 A
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000025901241
Coding: C0581B008F002001000001010101102030303232203232
VCID: B83C4B590BA8A84673-80EC
03332 - Motor for Height Adjustment
Fault Status: 01100101
Reset counter: 226
Mileage: 166235 km
Date: 2020.05.13
Time: 09:53:03
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0009
Revision: -------- Serial number: EJ1BPA4204EVLR0
ASAM Dataset: EV_SARA 009017
ROD: EV_SARA_009.rod
VCID: AD126A0DFCEA1DEE10-80F8
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH02 0040
Revision: 00H02000 Serial number: 6PZ 010 287-03
VCID: B02C737923D870063B-80E4
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H02 0040
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F11.04.1200H020003CF24357ÿ
Subsystem 4 - Serial number: F24357ÿ
Component: TSG FA H03 0511
Coding: 011F17015E00628002000012
VCID: C7DE38A57656D7BE0A-8092
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0020455437
Coding: 101000010000
Shop #: WSC 30594 001 1048576
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: B2287971E5D442164D-80E6
Revision: 00002001 Serial number: 0174480362
Coding: 0106023A00FA448580B00880020500000000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000079908
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO15819132
Coding: 101F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Serial number: 0000000AP00001118461
03637 - Roof Electronics Control Module; Function Limitation due to Overtemp
Fault Frequency: 13
Reset counter: 42
Mileage: 166585 km
Date: 2020.06.12
Time: 11:27:04
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007000 Serial number: 00000000041632
Coding: 030000
Shop #: WSC 45367 001 1048576
VCID: 9D72BACD844AED6E80-80C8
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
Coding: 011F17205E00628002000002
VCID: C1CA26BD5872E98EC4-8094
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000301713
ROD: EV_ParkiBrake_VW51.rod
VCID: AA186111CD040AD6F5-80FE
Address 55: Headlight Range (J431) Labels:| 4H4-907-357-V1.clb
Part No SW: 4H4 907 357 A HW: 4H4 907 357 A
Component: ....AFS13.... H01 0012
Serial number: 120404-0004-004
Coding: 1221A633701AA400
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste_AU21.rod
VCID: B02C7379EBD870063B-80E4
H02 0008
Coding: 1E0000
H02 0008
Coding: 1E0000
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H53 0133
Revision: AB001007 Serial number: 236D.0C7528255
Coding: 020007010000000001
VCID: A4048F29A720DCA6CF-80F0
Part No SW: 4G0 035 746 H HW: 4G0 035 746
Component: H-BNT-NA H48 0902
Revision: -------- Serial number: 031E-0E7539391
Coding: 050200000003E9EF75128B3E00000003100001000000000000
VCID: AC146709CFF014E607-80F8
Component: NAR 2011 0505
Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDC94018700
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349LD3000AL
Component: CD-Database 3371
01524 - Antenna for Telephone
Fault Status: 00101011
Reset counter: 34
Mileage: 167365 km
Date: 2020.06.22
Time: 18:48:04
Voltage: 13.80 V
03787 - Rotation Mechanism for Display Module Front
Fault Status: 00100011
Fault Frequency: 12
Reset counter: 42
Mileage: 167941 km
Date: 2020.07.15
Time: 12:37:28
Voltage: 12.60 V
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010F17204000628002000002
VCID: C4C42FA94760FCA6EF-8090
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H06--- Serial number: 525 PA8J23G3MN
Coding: 1080004
VCID: A6009521111C2EB6D1-80F2
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H04 0212
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H25 0038
Revision: -------- Serial number: 262130025421000
Coding: 6A060000
ROD: EV_OnBoardCamerDPC.rod
VCID: A6009521D91C2EB6D1-80F2
0001 - Front Heater for Lane-Holding Assist
C1101 15 [008] - Open or Short to Plus
Reset counter: 42
Mileage: 167941 km
Date: 2020.07.15
Time: 13:50:08
Outside air temperature: -31.5 °C
Voltage terminal 15: 12.7 V
Control Module temperature: 72.0 °C
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Coding: 3601010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
ROD: EV_AdaptCruisContr2AU57X_002.rod
Reset counter: 226
Mileage: 166235 km
Date: 2020.05.13
Time: 09:53:03
Voltage terminal 15: 12.080 V
Velocity_vehicle_reference: -0.00 m/s
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 D HW: 4H0 907 107
Component: BV-SG H30 0038
Serial number: 005000052703127
Coding: 048198180111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
Coding: 0066E608031F037E070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
VCID: B12A767DE0D2790E34-80E4
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R_VW51.rod
End----(Elapsed Time: 02:40, VBatt start/end: 12.1V/12.0V. VIgn 12.0V)-----"
Thank You
