Results 1 to 5 of 5
Thread: PROGRAMMING BLOC ABS GOLF VI (MK60EC1)
    Jul 2020
    MARTINIQUE
    Good morning,
    I am Romain from Martinique.
    Hello suite has a block abs failing on a golf 6 we replaced it with an equivalent used model.
    Nevertheless, the coding taken from the old block is accepted but I could not make the basic adjustments of the sensors
    How can I please do what I need?
    Ref old block: 1K0 907 379 BE
    Ref new block abs: 1K0 907 379 BD
    Thank you in advance for your help
    Wednesday,15,July,2020,22:39:34:51501
    VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
    VIN: WVWZZZ1KZBP151000   License Plate: CA-341-LW
    Mileage: 76670km-47640mi   Repair Order:
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56
    VIN: WVWZZZ1KZBP151000   Mileage: 76670km-47640miles
    Address 01: Engine (CAX)       Labels: 03C-906-016-CAX.clb
       Part No SW: 03C 906 016 AJ    HW: 03C 907 309 A
       Component: MED17.5.5       G   9058
       Revision: LCH12---    Serial number:
       Coding: 0000077
       Shop #: WSC 00028 028 00001
       VCID: 679EB77D56A4F9BEAA-8032
    9 Faults Found:
                   P0300 - 000 -
                        Mileage: 76673 km
                        Date: 2014.12.06
                        Time: 03:54:52
                        RPM: 678 /min
                        Load: 22.0 %
                        Temperature: 52.0°C
                        Temperature: 29.0°C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 13.970 V
    000769 - Cylinder 1
                   P0301 - 000 - Misfire Detected
                        Mileage: 76673 km
                        Date: 2014.12.06
                        Time: 03:55:04
                        RPM: 660 /min
                        Load: 21.6 %
                        Temperature: 52.0°C
                        Temperature: 29.0°C
                        Voltage: 13.716 V
                   U1017 - 000 -  - Intermittent
                        Mileage: 76663 km
                        Date: 2014.06.12
                        Time: 00:15:37
                        Temperature: 78.0°C
                        Temperature: 39.0°C
                        Voltage: 12.192 V
    049441 - No Communication with ABS Brake Control Module
                   U0121 - 000 -  - Intermittent
                        Fault Frequency: 10
                        Mileage: 76673 km
                        Date: 2014.08.17
                        Time: 15:11:12
                        Temperature: 51.0°C
                        Temperature: 26.0°C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 11.938 V
    006418 - Pressure Sensor for Brake Boost (G294)
                   P1912 - 000 - Short to Plus
                        Mileage: 76663 km
                        Date: 2014.06.12
                        Time: 00:15:40
                        Temperature: 78.0°C
                        Temperature: 39.0°C
                        Voltage: 12.192 V
                        Mileage: 76663 km
                        Date: 2014.06.12
                        Time: 00:20:15
                        Temperature: 76.0°C
                        Temperature: 39.0°C
                        Voltage: 12.192 V
    005161 - Circuit for Brake Vacuum Pump
                   P1429 - 000 - Open Circuit
                        Mileage: 76663 km
                        Date: 2014.06.12
                        Time: 00:27:59
                        RPM: 343 /min
                        Load: 51.7 %
                        Temperature: 72.0°C
                        Temperature: 39.0°C
                        Voltage: 10.795 V
    008852 - Fuel Pressure Regulator Valve (N276)
                   P2294 - 000 - Open Circuit - Intermittent
                        Mileage: 76673 km
                        Date: 2014.08.21
                        Time: 15:27:09
                        RPM: 1557 /min
                        Load: 15.3 %
                        Temperature: 24.0°C
                        Temperature: 25.0°C
                        Voltage: 11.176 V
    001378 - System Voltage
                   P0562 - 000 - Too Low - Intermittent
                        Mileage: 76673 km
                        Date: 2014.11.28
                        Time: 07:31:02
                        Temperature: 33.0°C
                        Temperature: 33.0°C
                        Voltage: 9.144 V
    Readiness: 0010 0001
       Part No SW: 0AM 300 050 D    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 9030
       Revision: 00043014    Serial number: CU501810108163
       Shop #: WSC 04940 001 00001
       VCID: 2A180E49853604D675-807E
    006279 - Wheel-Speed Signal from ABS Control Module
                   P1887 - 000 - Implausible Signal - Intermittent
                        Reset counter: 7
                        Mileage: 76663 km
                        Date: 2014.06.12
                        Time: 00:15:37
    006225 - Powertrain Data Bus
                   P1851 - 000 - Missing Message from ABS Controller - Intermittent
                        Fault Frequency: 10
                        Reset counter: 10
                        Mileage: 76663 km
                        Date: 2014.06.12
                        Time: 00:15:40
    006227 - Powertrain Data Bus
                   P1853 - 000 - Implausible Message from ABS Controller - Intermittent
                        Reset counter: 7
                        Mileage: 76663 km
                        Date: 2014.06.12
                        Time: 00:16:22
       Part No SW: 1K0 907 379 BD    HW: 1K0 907 379 BD
       Component: ESP MK60EC1   H31 0108
       Revision: 00H31001
       Shop #: WSC 10001 850 999999
       VCID: 75A2ED35DC081B2E28-8020
                        Reset counter: 215
                        Mileage: 76673 km
                        Date: 2014.12.06
                        Time: 03:56:31
                        Count: 16391
                        Count: 24576
                        Count: 195
                        Count: 46592
    00150 - Plausibility Brake Booster System
                        Reset counter: 215
                        Mileage: 76673 km
                        Date: 2014.12.06
                        Time: 03:51:58
                        Count: 16387
                        Count: 2
                        Count: 28672
                        Count: 398
                        Count: 44288
                        Count: 1280
                        Fault Status: 01100101
                        Reset counter: 215
                        Mileage: 76673 km
                        Date: 2014.12.06
                        Time: 03:51:58
                        Count: 16387
                        Count: 2
                        Count: 28672
                        Count: 279
                        Count: 44544
                        Count: 1280
                        Reset counter: 215
                        Mileage: 76673 km
                        Date: 2014.12.06
                        Time: 03:51:58
                        Count: 16387
                        Count: 2
                        Count: 28672
                        Count: 295
                        Count: 44544
                        Count: 1280
                        Reset counter: 215
                        Mileage: 76673 km
                        Date: 2014.12.06
                        Time: 03:51:58
                        Count: 16387
                        Count: 2
                        Count: 28672
                        Count: 270
                        Count: 44544
                        Count: 1280
       Part No SW: 7N0 907 426 K    HW: 7N0 907 426 K
       Component: AC Manuell    H17 0202
       Revision: 00012001
       Coding: 0000000002
       Shop #: WSC 00028 028 00023
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 3C343811B7A28A6617-8068
    13701392 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Bremsensteuergerät - kein Signal/Kommunikation]
                        Fault Frequency: 7
                        Reset counter: 0
                        Mileage: 76663 km
                        Date: 2020.01.20
                        Time: 00:15:40
    13635840 - Supply voltage
              [Versorgungsspannung - unterer Grenzwert unterschritten]
                        Reset counter: 0
                        Mileage: 76673 km
                        Date: 2020.07.07
                        Time: 07:37:53
       Part No SW: 1K0 937 086 H    HW: 1K0 937 086 H
       Component: BCM PQ35  M   103 0615
       Revision: 00103 AE
       Coding: 40180A3A80251A0040000080100081E443010088524D8960648000200040
       VCID: 35222D359C885B2EE8-8060
       Component: Wischer 04031  26  0512
       Coding: 009795
    15 Faults Found:
                        Reset counter: 0
                        Mileage: 76663 km
                        Date: 2014.06.12
                        Time: 00:15:41
                        Voltage: 12.40 V
                            Term 50 Off
                        Reset counter: 0
                        Mileage: 76673 km
                        Date: 2014.10.24
                        Time: 05:47:11
                            Term 15 Off
                        Voltage: 17.75 V
                            Term 50 Off
    00532 - Supply Voltage B+
                        Reset counter: 0
                        Mileage: 76673 km
                        Date: 2014.10.25
                        Time: 00:00:27
                            Term 15 Off
                        Voltage: 8.20 V
                            Term 50 Off
    01598 - Drive Battery Voltage
                        Fault Status: 00101011
                        Reset counter: 0
                        Mileage: 76673 km
                        Date: 2014.10.29
                        Time: 00:02:02
                        Voltage: 14.00 V
                            Term 50 Off
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Fault Frequency: 7
                        Reset counter: 215
                        Mileage: 76673 km
                        Date: 2014.11.29
                        Time: 00:07:54
                        Voltage: 11.95 V
                            Term 50 Off
    00153 - Windshield Wiper Motor;  Driver Side (V216)
                        Reset counter: 0
                        Mileage: 76673 km
                        Date: 2014.11.28
                        Time: 07:36:09
                        Voltage: 8.50 V
                            Term 50 Off
                        Fault Frequency: 7
                        Reset counter: 215
                        Mileage: 76673 km
                        Date: 2014.11.29
                        Time: 00:08:24
                        Voltage: 11.95 V
                            Term 50 Off
                        Fault Frequency: 7
                        Reset counter: 215
                        Mileage: 76673 km
                        Date: 2014.11.29
                        Time: 00:08:38
                        Voltage: 12.00 V
                            Term 50 Off
                        Fault Frequency: 7
                        Reset counter: 215
                        Mileage: 76673 km
                        Date: 2014.11.29
                        Time: 00:08:38
                        Voltage: 12.00 V
                            Term 50 Off
                        Reset counter: 215
                        Mileage: 76673 km
                        Date: 2014.12.06
                        Time: 04:08:26
                        Voltage: 12.30 V
                            Term 50 Off
                        Reset counter: 215
                        Mileage: 76673 km
                        Date: 2014.12.06
                        Time: 04:08:26
                        Voltage: 12.30 V
                            Term 50 Off
                        Reset counter: 215
                        Mileage: 76673 km
                        Date: 2014.11.29
                        Time: 00:00:17
                        Voltage: 12.45 V
                            Term 50 Off
                        Reset counter: 215
                        Mileage: 76673 km
                        Date: 2014.11.29
                        Time: 00:00:24
                        Voltage: 13.95 V
                            Term 50 Off
                        Reset counter: 215
                        Mileage: 76673 km
                        Date: 2014.11.29
                        Time: 00:00:24
                        Voltage: 14.05 V
                            Term 50 Off
                        Reset counter: 215
                        Mileage: 76673 km
                        Date: 2014.11.29
                        Time: 00:00:25
                        Voltage: 14.20 V
                            Term 50 Off
       Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
       Serial number: 003G5RA2BEJL
       Coding: 00003947
       Shop #: WSC 00028 028 00064
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 312A192560E0770EB4-8064
       Serial number: 3572MSME0643015EZZZQ
       Serial number: 3582MSME3364745CZZZ
       Serial number: 3512QSME58280614ZZZP
       Serial number: 3522QSME78130A7CZZZ/
              [Powersupply  lower threshold fall short of]
                        Reset counter: 0
                        Mileage: 76673 km
                        Date: 2020.07.07
                        Time: 07:31:20
    12656896 - No Communication with ABS Brake Control Module
              U0121 00 [008] - -
              [Lost Communication With Vehicle Dynamics Control Module]
                        Fault Frequency: 10
                        Reset counter: 0
                        Mileage: 76663 km
                        Date: 2020.01.20
                        Time: 00:15:39
       Part No SW: 5K0 953 507 AE    HW: 5K0 953 549
       Revision: --------    Serial number:  90440KCF001H1
       Coding: 5880140000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 73A6D32DDA7C051E06-8026
       Part No SW: 5K0 920 861     HW: 5K0 920 861
       Component: KOMBI         H03 0405
       Coding: 170B00
       VCID: 6A98CE498DB6C4D6B5-803E
    12656896 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für Bremse: keine Kommunikation]
                        Reset counter: 0
                        Mileage: 76663 km
                        Date: 2020.01.20
                        Time: 00:15:39
              [Supply voltage too low]
                        Reset counter: 0
                        Mileage: 76673 km
                        Date: 2020.07.07
                        Time: 07:37:28
       Part No SW: 7N0 907 530 C    HW: 1K0 907 951
       Component: J533  Gateway H37 0614
       Revision:   H37       Serial number: 220311F6000164
       Coding: 350000
       VCID: 302C1C2163EA7E06BB-8064
                        Fault Status: 00110100
                        Reset counter: 0
                        Mileage: 76663 km
                        Date: 2014.06.12
                        Time: 00:15:41
                        Reset counter: 212
                        Mileage: 76663 km
                        Date: 2014.06.12
                        Time: 00:11:55
                        Mileage: 76673 km
                        Date: 2014.08.17
                        Time: 15:11:37
                        Reset counter: 0
       Component: IMMO          H03 0405
       Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
       Component: Tuer-SG         009 2149
       Coding: 0000052
    Are you sure that -BD is an acceptable substitute for -BE?
    BD superseded to BH but NOT BE & BE doesn't to my knowledge in my notes supersede to anything else forward!
  4. Likes Uwe liked this post
    HQ
    Partslink24 shows those 2 different ABS part numbers as just that, 2 different parts that don't intersect. I don't see this going so well. Please see the following:
    https://forums.ross-tech.com/showthr...ed-parts-Maybe
    Jef
  6. Likes Uwe, Jack@European_Parts, PetrolDave liked this post
    Jul 2020
    MARTINIQUE
    Good evening,
    First of all thank you for your answers.
    The new abs block accepts the coding of the original. Is this not a reason for compatibility?
    I have already done this manipulation before but it is an external speaker which made the programming for us which does not yet have the vcds.
    What was he doing ? I don't know but as soon as the coding of the original model was accepted by the new abs block he managed to program it.
    I do not have access to box 11 for coding is this normal?
    What reference could suit my defective abs block no.1K0 907 379 BE please
